SFH11-NPPC-D17-RA-BK
    SULLINS
    弯插,P=2.54mm
    排母 间距:2.54mm 2x17P 弯插
SFH11-NPPC-D17-RA-BK 数据手册
Headers .100” [2.54 mm] Contact Centers, Female Headers, Straight/Right Angle - SFH11 Series Mates with SBH11 series (See opposite page) SPECIFICATIONS • Centered Polarizing Key Optional • Operating Temperature: -40°C to +105°C • Processing Temperature: 230°C Max. for 60 seconds, (260°C Max. for 10 seconds) • UL Flammability Rating: 94V-0 • Contact Resistance: 20 milli Ohms Max. • Current Rating: 3 Amps • Dielectric Withstanding: 1000 VAC • Insulation Resistance: 5000 Megohms Min. PART NUMBER OPTIONS SFH11 - P P P C - D 10 - ST - BK - M181 SERIES SFH11 = Female Header, .100” [2.54 mm] Contact Centers by .100” [2.54 mm] Row Spacing INSULATOR MATERIAL P = PBT N = NYLON CONTACT MATERIAL P = Phosphor Bronze B = Brass MODIFICATION (Omit for Standard) M181 = Without Centered Polarizing Key COLOR BK = Black TERMINATION TYPE (Opposite Page) ST = Straight RA = Right Angle CONTACT FINISH - RoHS Compliant P = Gold Flash Overall E = .000100” Pure Tin, Matte, Overall NUMBER OF CONTACT POSITIONS 03 thru 08,10,12, 13, 15,17, 20, 25, 30, 32 Headers NUMBER OF ROWS D = Dual Row CONTACT CENTERS C = .100” [2.54 mm] DIMENSIONS For complete drawings, go to www.sullinscorp.com or e-mail techsupport@sullinscorp.com Dimensions in [ ] are in millimeters, all others are in inches. .276[7.00] .236[6.00] .100[2.54] .126[3.20] .016[0.40] .100[2.54] .039[1.00] .100[2.54] STRAIGHT (ST) Example P/N: SFH11-PPPC-D20-ST-BK -M181 Modification (No Centered Polarizing Key) Centered Polarizing Key Optional, Requires -M181 Modification to Remove .335 [8.50] .276[7.00] .236[6.00] .398[10.10] .100[2.54] .106[2.70] .016[0.40] .024[0.60] -M181 Modification (No Centered Polarizing Key) RIGHT ANGLE (RA) Example P/N: SFH11-PPPC-D20-RA-BK www.sullinscorp.com | 760-744-0125 | toll-free 888-774-3100 | fax 760-744-6081 | info@sullinscorp.com 123
物料型号:SFH11-PPPC-D10-ST-BK 和 SFH11-PPPC-D20-RA-BK
器件简介:SFH11系列是直插式或直角型的女性头文件,与SBH11系列相配。
引脚分配:文档中未明确提供引脚分配信息,但提供了不同型号的引脚数量选项。
参数特性: - 操作温度:-40°C 至 +105°C - 加工温度:最高230°C,持续60秒;最高260°C,持续10秒 - UL阻燃等级:94V-0 - 接触电阻:最大20毫欧姆 - 电流额定值:3安培 - 介质耐压:1000 VAC - 绝缘电阻:最小5000兆欧姆
功能详解:文档中未提供详细的功能解释,但提供了一些基本的电气和物理特性。
应用信息:文档中未明确提供应用信息,但根据其特性,可能适用于需要电气连接的场合。
封装信息:提供了两种封装类型,直插式(ST)和直角型(RA),并给出了尺寸信息。
SFH11-NPPC-D17-RA-BK 价格&库存
很抱歉,暂时无法提供与“SFH11-NPPC-D17-RA-BK”相匹配的价格&库存,您可以联系我们找货
