M9K115-400L
M9K115-400L
    ROSENBERGER
    CONN RCPT 15POS 0.1 GOLD PCB
M9K115-400L 数据手册
Technical Data Sheet - DRAFT RF_35/09.14/6.2 Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG M9 MultiMag 15 Receptacle, PCB-Connector M9K115-400L All dimensions are in mm; tolerances according to ISO 2768 m-H General Information Magnetic connector Coding Number and type of contacts Soldering mechanical 15 rigid pins THT Interface Mating with MultiMag 15 cable assembly Material and Plating Connector parts Insulator Contact Magnets Material PBT Brass NdFeB N52 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Plating white, similar RAL 9003 AuroDur®, gold plated Nickel Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 1/3 Technical Data Sheet - DRAFT M9 MultiMag 15 Receptacle, PCB-Connector M9K115-400L Flammability Rating Connector parts Insulator Category uncolored raw material acc. to UL94 V-0* RF_35/09.14/6.2 Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG *Please note that a non UL rated color batch is added Electrical Data Operating voltage Operating current Contact resistance Impedance 12 V max. 4.5 A max. 1.5 A per contact typically ≤ 60 mΩ ~ 100 Ω differential pairs Mechanical Data Mating cycles without load Mating cycles under load Magnetic retention force min. 10.000 min. 1.000 average ~ 14 N PCB Footprint Environmental Data Temperature range Chemical resistance -25 °C to +65 °C Magnets start losing their magnetic properties above 65 °C Isopropanol 70 % Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 2/3 Technical Data Sheet - DRAFT M9 MultiMag 15 Receptacle, PCB-Connector M9K115-400L Compliance RoHS compliant RF_35/09.14/6.2 Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG Packing Standard Weight 25 pcs in blister ~ 14.9 g/pc Caution! Magnets can impact the function of pace makers and implantable cardioverterdefibrillators (e.g. actuation of reed switch). Keep a minimum distance of 0.2 m (20 cm) between the magnetic connector and the implanted devices to prevent malfunction and danger to health. While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. Draft Date Approved Date Rev. Engineering change number Name Date C. Kainzmaier 07.04.15 T. Scheuerlein 07.04.17 d00 17-0541 M. Schönsmaul 07.04.17 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 3/3
M9K115-400L 价格&库存
很抱歉,暂时无法提供与“M9K115-400L”相匹配的价格&库存,您可以联系我们找货
