FGG.0B.303.CLAZ
FGG.0B.303.CLAZ
    LEMO(雷莫)
    FGG.0B.303.CLAZ
FGG.0B.303.CLAZ 数据手册
FGG.0B.303.CLAZ www.lemo.com SUMMARY # Wires Low 3 High 0 Coax 0 Triax 0 Quad 0 Fiber 0 Fluidic 0 Series 0B Termination type Male solder IP rating 50 Cable Ø 0.00 - 0.00 mm Status active Image is for illustrative purpose only Download Request a quote Catalog See video assembly instructions Alternative part Matching parts EGG.0B.303.CLL PHG.0B.303.CLLZ TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Variant Weight 7.74 g Performance Configuration 0B.303 : 3 Low Voltage Insulator L: PEEK (UL 94 / V-0/3.2, depends on material thickness) Rated Current 8 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 1.0 mm (0.039in) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Max. Solid Conductor: 0.56 mm^2 (AWG 20) Max. Stranded Conductor: 0.56 mm^2 (AWG 20) R (max): 4.8 mOhm Vtest (contact-shell): 900 V (AC), 1270 V (DC) Vtest (contact-contact): 1200 V (AC), 1700 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr IP Rating: 50 DRAWINGS Draws Dimensions A L M S1 S2 mm. 9.5 36 26 8 7 in. 0,37 1,42 1,02 0,31 0,28 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.0B.005.PA070 Caps: BFG.0B.100.PCSG Cables LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.0B.303.CLAZ 价格&库存
很抱歉,暂时无法提供与“FGG.0B.303.CLAZ”相匹配的价格&库存,您可以联系我们找货
FGG.0B.303.CLAZ
    • 1+266.317491+34.12412
    • 10+256.9708710+32.92651
    • 25+240.1231825+30.76776
    • 50+225.3429450+28.87392
    库存:86
    FGG.0B.303.CLAZ
    • 1+317.993501+41.13732
