W18980-5PG-P-522
W18980-5PG-P-522
    SWITCHCRAFT
    CONN RCPT MALE 5POS GOLD CRIMP
W18980-5PG-P-522 数据手册
NOTES: 1. ALL PARTS TO BE BULK PACKED 2. CONTACTS SHIPPED UNASSEMBLED 3. ALL DIMENSIONS ARE REFERENCE EXCEPT HOSE WITH A TOLERANCE ASS'Y P/N FOR CABLE O.D. ASS'Y P/N CONTACT QTY KEY STYLE W18980-XPG-P-518 .175-.185 [4.4-4.7] W18980-XPG-P-521 .205-.215 [5.2-5.5] W18980-5PG-P-5XX W18980-6PG-P-5XX 5 6 A-KEY B-KEY W18980-XPG-P-522 .215-.225 [5.5-5.7] W18980-7PG-P-5XX W18980-XPG-P-5XX 7 A-KEY 1.560 39.6 GROMMET SIZE NUMBER OF CONTACTS .500 12.7 .060±.015 1.5±0.4 CONTACT HEIGHT SEE NOTE 2 SHOWN ASSEMBLED FOR CUSTOMER REFERENCE ONLY CUSTOMER PRINT (5-7) #26 PIN CONTACTS, CRIMP MAT'L: GOLD PLATED COPPER ALLOY .940 23.9 .950 24.1 CABLE TO CABLE CONNECTOR, MALE MAT'L: UV PBT, BLACK KEY KEY GROMMET MAT'L: RUBBER, BLACK 6 1 PART NUMBER: W18980-XPG-P-5XX 5 5 5 2 2 3 2 4 3 4 FACE VIEW W18980-5PG-P-5XX A-KEY 7 3 4 FACE VIEW FACE VIEW W18980-6PG-P-5XX B-KEY W18980-7PG-P-5XX A-KEY KEY KEY 1 KEY 6 6 1 1 CUSTOMER APPROVAL 7 5 2 5 2 2 5 4 3 WIRING VIEW W18980-5PG-P-5XX BACKSHELL MAT'L: UV PBT, BLACK KEY 6 1 1 .898 22.8 4 3 4 WIRING VIEW W18980-6PG-P-5XX 3 WIRING VIEW W18980-7PG-P-5XX DIMENSIONS IN BRACKETS [ ]ARE IN MILLIMETERS THIS DOCUMENT CONTAINS CONFIDENTIAL INFORMATION PROPRIETARY TO CONXALL CORPORATION. ANY REPRODUCTION, DISCLOSURE, OR USE OF THIS DOCUMENT /INFORMATION IS EXPRESSLY PROHIBITED UNLESS AUTHORIZED IN WRITING BY CONXALL CORPORATION. APPROVED BY: DATE: RoHS COMPLIANT A MA 08-21-20 JGK 8/28/19 REV. INIT. DATE ALL INFORMATION ILLUSTRATED IS THE PROPERTY OF "CONXALL CORPORATION." UNAUTHORIZED DUPLICATION OR DISTRIBUTION OF THIS DOCUMENT IS PROHIBITED. ALL UNITS ARE IN FEET, INCHES, FRACTION OF INCHES AND DECIMALS. UNLESS OTHERWISE SPECIFIED TOLERANCES: 3 PLACE DECIMALS ±.005 ANGLES ±1° FRACTIONS ±1/16 = CRITICAL CHARACTERISTIC FLAG PER SPEC. XXXX RELEASED PER PDR 18004 DRAWING CREATED FOR PDR #18004. DESCRIPTION ORIG. DRAWN BY: DATE: 8/28/19 JGK CHECKED BY: 601 E. WILDWOOD VILLA PARK, IL 60181 TITLE: APPROVED BY: SCALE SIZE NTS B FILE: W18980-XPG-P-5XX SHEET 1 OF 1 DIRECTORY: SLW CABLE TO CABLE CONN. ASS'Y (5-7) #26 PIN CONTACTS, CRIMP INSTA-CLICK™ MICRO-CON-X CUSTOMER: STANDARD PRODUCT PART NUMBER: W18980-XPG-P-5XX REV A
W18980-5PG-P-522
1. 物料型号:文档列出了几种不同的物料型号,例如W18980-5PG-P-5XX、W18980-6PG-P-5XX、W18980-7PG-P-5XX,以及W18980-XPG-P-5XX系列。
2. 器件简介:文档描述了一种电缆对电缆连接器,名为Insta-Click™ Micro-Con-X,具有5-7个#26引脚接触点,采用压接方式。
3. 引脚分配:文档提供了不同型号的引脚分配,例如W18980-5PG-P-5XX为A-KEY,W18980-6PG-P-5XX为B-KEY,W18980-7PG-P-5XX为另一种A-KEY。
4. 参数特性:文档提到了接触点的高度、电缆外径范围、接触点材料(例如金镀铜合金)等参数。
5. 功能详解:文档展示了连接器的装配图和布线视图,但未提供详细的功能描述。
6. 应用信息:文档指出所有部件应散装,接触件未组装发货,所有尺寸除公差外均为参考。
7. 封装信息:文档提到了橡胶垫圈、黑色背壳等封装材料,以及UV PBT材料。
W18980-5PG-P-522 价格&库存
很抱歉,暂时无法提供与“W18980-5PG-P-522”相匹配的价格&库存,您可以联系我们找货
