PAG.M0.4GL.AC39G
www.lemo.com
SUMMARY
# Wires
Low voltage
4
Image is for illustrative purpose only
Series
1P
Termination type
Male solder
IP rating
50
AWG wire size
0.00 - 22.00
Cable Ø
2.70 - 3.90 mm
Status
active
Matching parts
PLG.M0.4GL.LG
Download
Request a quote
Eplan
Catalog
TECHNICAL DETAILS
Mechanics
Shell Style/Model
PA*: Straight plug with cable collet
Keying
1 key (alpha=0; Plug: male contact; Receptacle: female contact)
Housing Material
PSU (Polysulfone), gray
Variant
G : Gray collet nut
Weight
4.86 g
Performance
Configuration
1P.M04 : 4 Low Voltage
Insulator
L: PEEK (UL 94 / V-0/1.5)
Rated Current
8 Amps
Specifications
Contact Type: Solder
Contact Dia.: 0.9 mm (0.035in)
Bucket Dia.: 0.8 mm (0.031in)
Max. Solid Conductor: 0.34 mm^2 (AWG 22)
Max. Stranded Conductor: 0.34 mm^2 (AWG 22)
R (max): 4.5 mOhm
Test voltage (kV rms) Contact-contact: 1.2
LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of
them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications
using LEMO components.
1/3
Air clearance min.: 1.2 mm
Creepage distance min.: 1.2 mm
Others
Endurance (Shell): >2000 mating cycles
Temp (min / max): -50°C / +150°C
F ret (min): 50 N
F ret (max): 150 N
Steam sterilization: > 100 times (with potting on rear connection)
DRAWINGS
RECOMMENDED BY LEMO
Tools
Cables
CMN.04.T28.031PGCE
PVC
CMN.04.T28.031PGZE
CMN.04.T28.031PNCE
GREY
Grey
PVC
Black
CMN.04.T28.031QGC
TPR
Grey
40080
PVC
Black
CMN.04.T28.031PNZE
2/3
40086
40240
PVC
PTFE
Blue
White
4041
PVC
Grey
4050
PVC
Black
4260
PTFE
White
3/3
很抱歉,暂时无法提供与“PAG.M0.4GL.AC39G”相匹配的价格&库存,您可以联系我们找货
