FGG.1B.310.CLAD52
FGG.1B.310.CLAD52
    LEMO(雷莫)
    CONN PLUG MALE 10P GOLD SLDR CUP
FGG.1B.310.CLAD52 数据手册
FGG.1B.310.CLAD52 www.lemo.com SUMMARY # Wires Low voltage 10 Image is for illustrative purpose only Series 1B Termination type Male solder IP rating 50 AWG wire size 34.00 - 28.00 Catalog Cable Ø 4.30 - 5.20 mm See video assembly instructions Status active Matching parts EGG.1B.310.CLL Download Request a quote Eplan PHG.1B.310.CLLD52 TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 15.34 g Performance Configuration 1B.310 : 10 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 2.5 Amps Specifications Contact Type: Solder Contact Dia.: 0.5 mm (0.02in) Bucket Dia.: 0.45 mm (0.018in) Max. Solid Conductor: 0.09 mm^2 (AWG 28) Max. Stranded Conductor: 0.09 mm^2 (AWG 28) R (max): 8.7 mOhm Vtest (contact-shell): 1500 V (AC), 2120 V (DC) Vtest (contact-contact): 900 V (AC), 1270 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 12 43 32 10 9 in. 0,47 1,69 1,26 0,39 0,35 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.1B.015.PA090 Caps: BFG.1B.100.PCSG LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables CMN.10.T28.052PGZE Grey CMN.10.T28.052PNZE LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.1B.310.CLAD52 价格&库存
很抱歉,暂时无法提供与“FGG.1B.310.CLAD52”相匹配的价格&库存,您可以联系我们找货
