FM20B05VBDN
FM20B05VBDN
    METZCONNECT
    SMD,P=1.27mm
    排母 间距:1.27mm 2x5P 立贴
FM20B05VBDN 数据手册
Page 1/4 Data sheet P/N FM20BXXVBDN xx=number of poles FM20BxxVBDN 2020/10/20 Version: N Illustrations Dimensional drawing Drill pattern See enlarged drawings at the end of document Product specification • female connector, SMT solderable • centerline 1.27 mm, direction of connection vertical 0° • closed ends • color black • Tape & Reel packaging possible • dual rows Data sheet Page 2/4 FM20BxxVBDN P/N FM20BXXVBDN xx=number of poles 2020/10/20 Version: N Technical Data General Data Min. number of poles Max. number of poles 2 Protection category IP00 Rated current 1A 40 Material Insulating material PA6 Contact material CuSn Contact surface Ni + Ag Contact pin material CuSn Contact pin surface Ni + Au Flash Glow-Wire Flammability GWFI - Glow-Wire Flammability GWIT - Climatic Data Upper limit temperature 105 °C Lower limit temperature -40 °C general Tolerance ISO 2768 -mH Solderability Acc. to IPC/JEDEC J-STD-020D-MSL 1 Data sheet FM20BxxVBDN Page 3/4 P/N FM20BXXVBDN xx=number of poles 2020/10/20 Version: N Illustrations Dimensional drawing L=(pole size - 1) x centerline + 1.73 mm [0.068] Data sheet FM20BxxVBDN Page 4/4 P/N FM20BXXVBDN xx=number of poles 2020/10/20 Version: N Illustrations Drill pattern Powered by TCPDF (www.tcpdf.org)
FM20B05VBDN 价格&库存
很抱歉,暂时无法提供与“FM20B05VBDN”相匹配的价格&库存,您可以联系我们找货
