CUSTOMER DRAWING
MFG.
ENG.
APPROVED BY:
DATE:
QA
APPROVED BY:
DATE:
NOTES:
1.
ALL HOLES REQUIRED REGARDLESS OF NUMBER OF POSITIONS OF
CONNECTOR.
2.
MAXIMUM PANEL THICKNESS RECOMMENDED: 0.188 [4.78mm]
3.
HEX NUT & GASKET SHIPPED UNASSEMBLED.
4.
HEX NUT TIGHTENING TORQUE: 8-10 IN/LB
5.
THE DIMENSION DOES NOT INCLUDE THE GASKET.
6.
CURRENT RATING5-8 CONTACT: 4.0 AMP
2-4 CONTACT: 5.0 AMP
7.
TEMPERATURE RATING: -40 C TO +85 C (-40 F TO +185 F)
8.
MATERIALSPANEL CONNECTOR, HEX NUT, & SPACER: THERMOPLASTIC
GASKET: ELASTOMER
CONTACTS: COPPER ALLOY, GOLD PLATE
PCB: FR-4
HEADER INSULATOR: THERMOPLASTIC, UL94V-0
9.
THIS PRODUCT IS RoHS COMPLIANT.
0.96
24.3
0.80
20.3
0.81
20.6
0.56
14.2
(SEE NOTE 5)
7261-8PG-300 SHOWN
0.77
19.6
0.10
2.5
POSITION 1 INDICATOR
8X 0.020
0.50
0.502
12.75
HEX NUT
(SEE NOTE 3 & 4)
GASKET
(SEE NOTE 3)
0.551
14.00
8X
0.038
0.97
5/8-27
THREAD
0.222
5.63
(SEE NOTE 5)
7X 0.079
2.00
5
6
1
2
3
4
NC NC
CL
RECOMMENDED PCB LAYOUT
PCB COMPONENT SIDE
SCALE 3:1
(SEE NOTE 1)
0.582
14.8
7261-6SG-300 SHOWN
6 PIN FEMALE ASSEMBLY
CL
2, 3, 5 & 6 POSITION LOCATIONS
0.128 MAX
3.25
TO EDGE OF PCB
4
1
2
NC NC NC
3
NC
7261-_ _ G-300 SERIES
CL
4 POSITION LOCATIONS
0.610
15.5
RECOMMENDED PANEL CUT-OUT
(SEE NOTE 2)
5
6
7
8
1
2
3
4
CL
PART
NUMBER:
7261 7261-8PG-300 SHOWN
8 PIN MALE ASSEMBLY
PRELIMINARY
# OF CONTACTS
2,3,4,5,6,7,8
(7&8 NOT AVAILABLE IN FEMALE)
7 & 8 POSITION LOCATIONS
G - 300
GENDER
P - MALE
S - FEMALE
CUSTOMER DRAWING
0C
0B
0A
JGK
JGK
JGK
REV. INIT.
11/05/15
9/21/15
8/28/13
DATE
ALL INFORMATION ILLUSTRATED IS
THE PROPERTY OF "CONXALL
CORPORATION." UNAUTHORIZED
DUPLICATION OR DISTRIBUTION OF
THIS DOCUMENT IS PROHIBITED.
ALL UNITS ARE IN FEET,
INCHES, FRACTION OF INCHES
AND DECIMALS.
RoHS COMPLIANT
UNLESS OTHERWISE SPECIFIED
TOLERANCES:
3 PLACE DECIMALS ±.005
ANGLES ±1°
FRACTIONS ±1/16
= CRITICAL CHARACTERISTIC
FLAG PER SPEC. XXXX
UPDATED NOTES.
UPDATED NOTES.
DRAWING CREATED PER PROJECT #09001.
DESCRIPTION
ORIG. DRAWN BY:
JGK
DATE:
8/26/13
CHECKED BY:
601 E. WILDWOOD VILLA PARK, IL 60181
TITLE:
APPROVED BY:
SCALE
3:2
FILE:
SIZE
B
SAME AS P/N
SHEET
1 OF 1
CUSTOMER:
DIRECTORY:
PART
NUMBER:
SLW
MINI-CON-X RIGHT ANGLE
2-8 POSITION
NARROW PC BOARD
STANDARD PRODUCT
7261- _ _G-300 SERIES
REV
0C
很抱歉,暂时无法提供与“7261-8PG-300”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+198.796811+25.71968
- 10+168.9869110+21.86297
- 25+158.3990925+20.49315
- 50+153.8874250+19.90945
