HIF3CA-30PA-2.54DSA(71) 数据手册
Ribbon Cable connector Compliant with MIL Standard
HIF3B Series
■Features
1. Product Compliant with MIL Standard
HIF3B series has been developed as a product compliant with MIL
standard, and used for wide applications.
2. UL Approval Product
HIF3B series connectors are UL approved.
3. Mechanism to Prevent Mis-insertion
This connector is equipped with the mechanism to prevent Misinsertion as follows.
1 The system provides the convex area to insert the guide-key on the
pin header side, and to guide it in combination with the socket
convex area (MIL standard).
2 The system embeds and guides the polarizing key in the socket holes.
4. Applicable Cable AWG#28
The applicable cable is UL2651 AWG#28 flat cable (7 cores./
0.127mm, jacket dia. 0.9±0.1mm).
■Product Specifications
Current rating : 1A
Rating
Operating Temperature Range : –55 to +85ç (Note 1) Storage Temperature Range : –10 to +60ç (Note 2)
Storage Humidity Range : 40 to 70% (Note 2)
Voltage rating : 200V AC Operating Moisture Range : 40 to 80%
Item
Specification
Condition
1. Insulation Resistance
1000M ohms min.
500V DC
2. Withstanding voltage
No flashover or insulation breakdown.
650V AC/1 minute
3. Contact Resistance
15m ohms max.
0.1A
4. Vibration
No electrical discontinuity of 1µs or more
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
5. Humidity (Steady state) Insulation resistance: 1000M ohms min.
6. Temperature Cycle
96 hours at temperature of 40ç and humidity of 90% to 95%
(-55ç: 30 minutes ➝ 15 to 35ç: 5 minutes max.
No damage, cracks, or parts looseness.
125ç: 30 minutes ➝ 15 to 35ç: 5 minutes max.) 5 cycles
7. Durability (Mating/un-mating) Contact resistance: 15m ohms max.
500 cycles
Solder bath: 260ç for 10 seconds
8. Resistance to Soldering heat No deformation of components affecting performance.
Manual soldering: 360ç for 5 seconds
Note 1: Includes temperature rise caused by current flow.
Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a
specific part number shown.
Note 4: Please note that there is a risk of deforming the lock when an excessive load is applied to the inside.
■Material
Part
Material
Finish
Remarks
Insulator
PBT
Black
UL94V-0
Socket Contact
Beryllium copper
Pin header contact
Brass
Connection area
Gold plated
Selective Gold plated
B15
HIF3B Series●Ribbon Cable connector Compliant with MIL Standard
■Ordering Information
●Socket
HIF 3B - * D - 2.54 R
q
w
e
r
t
y
q Series Name
: HIF
w Series No.
: 3B, 3BA, 3BB (50, 60, 64 contacts only)
e Number of contacts : 6,10,14,16, 20, 26, 30, 34, 40, 50, 60, 64
r Contact alignment : D : Double
t Contact pitch
: 2.54mm
y Connection type
R : ID type
●Pin Header
HIF 3B - * P A - 2.54 DS
q
w
e
q Series Name
: HIF
w Series No.
r
t
y
u
: (14 contacts not included)
3BC: (10 contacts only)
3BA, 3BB: (50, 60, 64 contacts only)
3BD: (10 contacts only)
3B
r
P
: Pin header
t
A
: Selective gold plated
y Contact pitch
: 2.54mm
u Contact style
B16
DS
: Right angle type
DSA
: Straight type
■Socket (With guide to prevent mis-insertion)
Body
Protector
Clamp
Note1, Note2: The number of polarizing keys and polarizing keyways changes according to products. Refer to the list as shown below.
Note3: The 50, 60 and 64 contact connector contain two types of polarizing guides. Use the products, referring to Notes 1 and 2.
Note4: The 6 contact has no polarizing mark.
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
D
Polarizing Guide
(Note 1)
HIF3BA- 6D-2.54R 610-0032-3
6
12.19 5.08 6.35 7.72
HIF3BA-10D-2.54R 610-0021-7
10
17.27 10.16 11.43 12.8
★ HIF3BA-14D-2.54R 610-0022-0
14
22.35 15.24 16.51 17.88
★ HIF3BA-16D-2.54R 610-0023-2
16
24.89 17.78 19.05 20.42
★ HIF3BA-20D-2.54R 610-0024-5
29.97 22.86 24.13 25.5
★ HIF3BA-26D-2.54R 610-0025-8
26
37.59 30.48 31.75 33.12
★ HIF3BA-30D-2.54R 610-0026-0
30
42.67 35.56 36.83 38.2
★ HIF3BA-34D-2.54R 610-0027-3
34
47.75 40.64 41.91 43.28
★ HIF3BA-40D-2.54R 610-0028-6
40
55.37 48.26 49.53 50.9
★ HIF3BA-50D-2.54R 610-0029-9
50
68.07 60.96 62.23 63.6 One on right and left sides, resp.
★ HIF3BB-50D-2.54R 610-0041-4
50
★ HIF3BA-60D-2.54R 610-0030-8
60
80.77 73.66 74.93 76.3 One on right and left sides, resp.
★ HIF3BB-60D-2.54R 610-0042-7
60
★ HIF3BA-64D-2.54R 610-0031-0
64
85.85 78.74 80.01 81.38 One on right and left sides, resp.
★ HIF3BB-64D-2.54R 610-0043-0
64
Polarizing Keyway
(Note 2)
RoHS
None
One on left side
One at center
YES
One on right and
left sides, resp.
One at center
One at center
One at center
The products marked with ★ comply with MIL standard.
B17
■Socket
Body
Protector
Clamp
Note1: The number of polarizing keys and polarizing keyways changes according to products. For details, refer to the list as shown below.
Note2: The 6 contact has no polarizing mark.
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
D
HIF3B- 6D-2.54R 610-0012-6
6
★ HIF3B-10D-2.54R 610-0001-0
10
17.27 10.16 11.43 12.80
★ HIF3B-14D-2.54R 610-0002-2
14
★ HIF3B-16D-2.54R 610-0003-5
16
★ HIF3B-20D-2.54R 610-0004-8
29.97 22.86 24.13 25.50
★ HIF3B-26D-2.54R 610-0005-0
26
★ HIF3B-30D-2.54R 610-0006-3
30
★ HIF3B-34D-2.54R 610-0007-6
34
★ HIF3B-40D-2.54R 610-0008-9
40
55.37 48.26 49.53 50.90
★ HIF3B-50D-2.54R 610-0009-1
50
★ HIF3B-60D-2.54R 610-0010-0
60
★ HIF3B-64D-2.54R 610-0011-3
64
Polarizing Guide
(Note 1)
RoHS
None
One on left side
YES
One on right and
left sides, resp.
B18
■Four Wall Angle Through hole
BPCB mounting pattern
Note 1, Note 2: The number of polarizing slot and key installed positions
Note 3: The spacer moves to the right according to the number of
contacts.
Note 4: The 10, 50, 60 and 64 contact connectors contain two types of
polarizing slots.
Use products, referring to (Note 1) (Note 2).
■n=number of contacts
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
★ HIF3BA-10PA-2.54DS(71) 610-0091-2(71)
10
32.0 17.5 10.16
HIF3BD-10PA-2.54DS(71) 610-0171-0(71)
10
32.0 17.5 10.16
★ HIF3BA-14PA-2.54DS(71) 610-0092-5(71)
14
37.1 22.6 15.24
★ HIF3BA-16PA-2.54DS(71) 610-0093-8(71)
16
39.6 25.1 17.78
★ HIF3BA-20PA-2.54DS(71) 610-0094-0(71)
★ HIF3BA-26PA-2.54DS(71) 610-0095-3(71)
26
52.3 37.8 30.48
★ HIF3BA-30PA-2.54DS(71) 610-0096-6(71)
30
57.4 42.9 35.56
★ HIF3BA-34PA-2.54DS(71) 610-0097-9(71)
34
62.5 48.0 40.64
★ HIF3BA-40PA-2.54DS(71) 610-0098-1(71)
40
70.1 55.6 48.26
★ HIF3BA-50PA-2.54DS(71) 610-0099-4(71)
50
82.8 68.3 60.96
★ HIF3BB-50PA-2.54DS(71) 610-0131-5(71)
50
82.8 68.3 60.96
★ HIF3BA-60PA-2.54DS(71) 610-0100-1(71)
60
95.5 81.0 73.66
★ HIF3BB-60PA-2.54DS(71) 610-0132-8(71)
60
95.5 81.0 73.66
★ HIF3BA-64PA-2.54DS(71) 610-0101-4(71)
64
100.6 86.1 78.74
★ HIF3BB-64PA-2.54DS(71) 610-0133-0(71)
64
100.6 86.1 78.74
D
28.14
MAX51.1
28.14
MAX51.1
33.24
MAX56.2
35.74
MAX58.7
40.84
MAX63.8
48.44
MAX71.4
53.54
MAX76.5
58.64
MAX81.6
66.24
MAX89.2
78.94
MAX101.9
78.94
MAX101.9
91.64
MAX114.6
91.64
MAX114.6
96.74
MAX119.7
96.74
MAX119.7
E
F
21.8 27.9
Polarizing Slot
(Note 1)
None
Polarizing Key Install
RoHS
(Note 2)
One on right side
21.8 27.9
None
26.9 33.0
One on right side
29.5 35.5
34.5 40.6
42.2 48.3
One at center
47.2 53.3
YES
52.3 58.4
59.9 66.0
72.6 78.7 One on right and left sides, resp.
72.6 78.7
One on right and
left sides, resp.
One at center
85.3 91.4 One on right and left sides, resp.
85.3 91.4
One at center
90.4 96.5 One on right and left sides, resp.
90.4 96.5
One at center
B19
■Four-Wall Straight Through hole
contacts.
polarizing slots.
Use products, confirming (Note 1) (Note 2).
Note 5: The 6 contact has no polarity mark.
Unit:mm
Part Number
CL No.
Number of Contacts
562-0503-9-71
6
26.92 12.42 05.08
HIF3BA-10PA-2.54DSA(71) 610-0111-8-71
10
32.0 17.5 10.16
★ HIF3BD-10PA-2.54DSA(71) 610-0181-3-71
★ HIF3BA-14PA-2.54DSA(71) 610-0112-0-71
10
32.0 17.5 10.16
14
37.1 22.6 15.24
★ HIF3BA-16PA-2.54DSA(71) 610-0113-3-71
★ HIF3BA-20PA-2.54DSA(71) 610-0114-6-71
16
39.6 25.1 17.78
★ HIF3BA-26PA-2.54DSA(71) 610-0115-9-71
★ HIF3BA-30PA-2.54DSA(71) 610-0116-1-71
26
52.3 37.8 30.48
30
57.4 42.9 35.56
★ HIF3BA-34PA-2.54DSA(71) 610-0117-4-71
★ HIF3BA-40PA-2.54DSA(71) 610-0118-7-71
34
62.5 48.0 40.64
40
70.1 55.6 48.26
★ HIF3BA-50PA-2.54DSA(71) 610-0119-0-71
★ HIF3BB-50PA-2.54DSA(71) 610-0141-9-71
50
82.8 68.3 60.96
50
82.8 68.3 60.96
★ HIF3BA-60PA-2.54DSA(71) 610-0120-9-71
★ HIF3BB-60PA-2.54DSA(71) 610-0142-1-71
60
95.5 81.0 73.66
★ HIF3-6PA-2.54DSA(71)
★ HIF3BA-64PA-2.54DSA(71) 610-0121-1-71
★ HIF3BB-64PA-2.54DSA(71) 610-0143-4-71
A
B
C
60
95.5 81.0 73.66
64
100.6 86.1 78.74
64
100.6 86.1 78.74
D
23.06
MAX46.02
28.14
MAX51.1
28.14
MAX51.1
33.24
MAX56.2
35.74
MAX58.7
40.84
MAX63.8
48.44
MAX71.4
53.54
MAX76.5
58.64
MAX81.6
66.24
MAX89.2
78.94
MAX101.9
78.94
MAX101.9
91.64
MAX114.6
91.64
MAX114.6
96.74
MAX119.7
96.74
MAX119.7
E
F
Polarizing Slot
(Note 1)
RoHS
(Note 2)
16.7 22.82
One at center
None
21.8 27.9
None
One on right side
21.8 27.9
None
26.9 33.0
One on right side
29.5 35.5
34.5 40.6
42.2 48.3
One at center
47.2 53.3
YES
52.3 58.4
59.9 66.0
72.6 78.7
One on right and
left sides, resp.
One at center
85.3 91.4
One at center
90.4 96.5
One at center
B20
■Three Wall Angle Type
Note 3: The spacer moves according to the number of contacts.
Note 4: The 10 contact connector consists of two types.
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
★ HIF3BD-10PA-2.54DS(71) 610-0051-8-71
10
32.0 17.5 10.16
HIF3BC-10PA-2.54DS(71) 610-0151-2-71
10
32.0 17.5 10.16
★ HIF3BD-16PA-2.54DS(71) 610-0052-0-71
16
39.6 25.1 17.78
★ HIF3BD-20PA-2.54DS(71) 610-0053-3-71
★ HIF3BD-26PA-2.54DS(71) 610-0054-6-71
26
52.3 37.8 30.48
★ HIF3BD-30PA-2.54DS(71) 610-0055-9-71
30
57.4 42.9 35.56
★ HIF3BD-34PA-2.54DS(71) 610-0056-1-71
34
62.5 48.0 40.64
★ HIF3BD-40PA-2.54DS(71) 610-0057-4-71
40
70.1 55.6 48.26
★ HIF3BD-50PA-2.54DS(71) 610-0058-7-71
50
82.8 68.3 60.96
★ HIF3BD-60PA-2.54DS(71) 610-0059-0-71
60
95.5 81.0 73.66
★ HIF3BD-64PA-2.54DS(71) 610-0060-9-71
64
100.6 86.1 78.74
D
28.14
MAX51.1
28.14
MAX51.1
35.74
MAX58.7
40.84
MAX63.8
48.44
MAX71.4
53.54
MAX76.5
58.64
MAX81.6
66.24
MAX89.2
78.94
MAX101.9
91.64
MAX114.6
96.74
MAX119.7
E
F
21.8 27.9
Polarizing Slot
(Note 1)
(Note 2)
None
One on right side
21.8 27.9
RoHS
None
29.5 35.5
34.5 40.6
42.2 48.3
One at center
47.2 53.3
52.3 58.4
One on right and
left sides, resp.
YES
59.9 66.0
72.6 78.7
90.4 96.5
B21
■Three Wall Straight Through hole
Note1,Note2: The number of polarizing slot and key installed positions
below.
Note3: The spacer moves to the right according to the number of
contacts.
Note4: The 10 contact connector consists of two types.
Use products, referring to (Note 1) and (Note 2).
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
★ HIF3BD-10PA-2.54DSA(71) 610-0071-5-71
10
32.0 17.5 10.16
HIF3BC-10PA-2.54DSA(71) 610-0161-6-71
10
32.0 17.5 10.16
★ HIF3BD-16PA-2.54DSA(71) 610-0072-8-71
16
39.6 25.1 17.78
★ HIF3BD-20PA-2.54DSA(71) 610-0073-0-71
★ HIF3BD-26PA-2.54DSA(71) 610-0074-3-71
26
52.3 37.8 30.48
★ HIF3BD-30PA-2.54DSA(71) 610-0075-6-71
30
57.4 42.9 35.56
★ HIF3BD-34PA-2.54DSA(71) 610-0076-9-71
34
62.5 48.0 40.64
★ HIF3BD-40PA-2.54DSA(71) 610-0077-1-71
40
70.1 55.6 48.26
★ HIF3BD-50PA-2.54DSA(71) 610-0078-4-71
50
82.8 68.3 60.96
★ HIF3BD-60PA-2.54DSA(71) 610-0079-7-71
60
95.5 81.0 73.66
★ HIF3BD-64PA-2.54DSA(71) 610-0080-6-71
64
100.6 86.1 78.74
D
28.14
MAX51.1
28.14
MAX51.1
35.74
MAX58.7
40.84
MAX63.8
48.44
MAX71.4
53.54
MAX76.5
58.64
MAX81.6
66.24
MAX89.2
78.94
MAX101.9
91.64
MAX114.6
96.74
MAX119.7
E
F
21.8 27.9
Polarizing Slot
(Note 1)
None
21.8 27.9
RoHS
(Note 2)
One on right side
None
29.5 35.5
34.5 40.6
42.2 48.3
One at center
47.2 53.3
52.3 58.4
YES
One on right and
left sides, resp.
59.9 66.0
72.6 78.7
90.4 96.5
B22
■Four Wall Wrapping Type
Note 1, Note 2. The number of polarizing slot and key installed positions
Note 3. The spacer moves to the right according to the number of
contacts.
Note 4. The 10, 50, 60 and 64 contact connectors consists of two types.
Note 5. The mark * indicates the number of contacts.
Note 6. The nut built-in specification product is also provided.
The product can be fixed by M2 screws from the rear side.
Use the screw of (board thickness) +4 mm under the neck.
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
★ HIF3BA-10P-2.54W 610-0503-8
10
32.0 17.5 10.16
HIF3BD-10P-2.54W 610-0492-3
10
32.0 17.5 10.16
★ HIF3BA-14P-2.54W 610-0493-6
14
37.1 22.6 15.24
★ HIF3BA-16P-2.54W 610-0494-9
16
39.6 25.1 17.78
★ HIF3BA-20P-2.54W 610-0495-1
★ HIF3BA-26P-2.54W 610-0496-4
26
52.3 37.8 30.48
★ HIF3BA-30P-2.54W 610-0497-7
30
57.4 42.9 35.56
★ HIF3BA-34P-2.54W 610-0498-0
34
62.5 48.0 40.64
★ HIF3BA-40P-2.54W 610-0499-2
40
70.1 55.6 48.26
★ HIF3BA-50P-2.54W 610-0504-0
50
82.8 68.3 60.96
★ HIF3BB-50P-2.54W 610-0500-0
50
82.8 68.3 60.96
★ HIF3BA-60P-2.54W 610-0505-3
60
95.5 81.0 73.66
★ HIF3BB-60P-2.54W 610-0501-2
60
95.5 81.0 73.66
★ HIF3BA-64P-2.54W 610-0506-6
64
100.6 86.1 78.74
★ HIF3BB-64P-2.54W 610-0502-5
64
100.6 86.1 78.74
D
28.14
MAX51.1
28.14
MAX51.1
33.24
MAX56.2
35.74
MAX58.7
40.84
MAX63.8
48.44
MAX71.4
53.54
MAX76.5
58.64
MAX81.6
66.24
MAX89.2
78.94
MAX101.9
78.94
MAX101.9
91.64
MAX114.6
91.64
MAX114.6
96.74
MAX119.7
96.74
MAX119.7
E
F
21.8 27.9
Polarizing Slot
(Note 1)
(Note 2)
None
One on right side
21.8 27.9
None
26.9 33.0
One on right side
RoHS
29.5 35.5
34.5 40.6
42.2 48.3
One at center
47.2 53.3
YES
52.3 58.4
59.9 66.0
72.6 78.7
One on right and
left sides, resp.
One at center
85.3 91.4
One at center
90.4 96.5
One at center
B23
■Four Wall Straight Through hole
[Flux Blister Prevention Type]
Note1: The number of polarizing slot and key installed positions changes
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
★ HIF3CA-10PA-2.54DSA(71) 610-0701-1-71
10
32.0 17.5 10.16
HIF3CD-10PA-2.54DSA(71) 610-0722-1-71
10
32.0 17.5 10.16
★ HIF3CA-16PA-2.54DSA(71) 610-0703-7-71
16
39.6 25.1 17.78
★ HIF3CA-20PA-2.54DSA(71) 610-0704-0-71
★ HIF3CA-26PA-2.54DSA(71) 610-0705-2-71
26
52.3 37.8 30.48
★ HIF3CA-30PA-2.54DSA(71) 610-0706-5-71
30
57.4 42.9 35.56
★ HIF3CA-34PA-2.54DSA(71) 610-0707-8-71
34
62.5 48.0 40.64
★ HIF3CA-40PA-2.54DSA(71) 610-0708-0-71
40
70.1 55.6 48.26
★ HIF3CA-50PA-2.54DSA(71) 610-0709-3-71
50
82.8 68.3 60.96
★ HIF3CB-50PA-2.54DSA(71) 610-0721-9-71
50
82.8 68.3 60.96
★ HIF3CB-60PA-2.54DSA(71) 610-0723-4-71
60
95.5 81.0 73.66
★ HIF3CB-64PA-2.54DSA(71) 610-0724-7-71
64
100.6 86.1 78.74
D
28.14
MAX51.1
28.14
MAX51.1
35.74
MAX58.7
40.84
MAX63.8
48.44
MAX71.4
53.54
MAX76.5
58.64
MAX81.6
66.24
MAX89.2
78.94
MAX101.9
78.94
MAX101.9
91.64
MAX114.6
96.74
MAX119.7
E
F
21.8 27.9
Polarizing Slot
None
21.8 27.9
Polarizing Key Install RoHS
One on right side
None
29.5 35.5
34.5 40.6
42.2 48.3
One at center
47.2 53.3
YES
52.3 58.4
One on right and
left sides, resp.
59.9 66.0
72.6 78.7
85.3 91.4
One at center
90.4 96.5
B24
■Two Stage Staking Right Angle Through hole
Note 1, Note 2: The number of polarizing slot and key installed positions changes according to products. Refer
Note 3: The spacer moves to the right according to the number of contacts.
Note 4: The 10, 50, 60 and 64 contact connectors consists of two types.
Note 5: The mark * ndicates the number of contacts.
Note 6: The locator is located optionally.
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
★ HIF3BA-10PA-2.54WB(71) 610-1502-0-71
10
32.0 17.5 10.16
HIF3BD-10PA-2.54WB(71) 610-1503-3-71
10
32.0 17.5 10.16
★ HIF3BA-16PA-2.54WB(71) 610-1505-9-71
16
39.6 25.1 17.78
★ HIF3BA-20PA-2.54WB(71) 610-1506-1-71
★ HIF3BA-26PA-2.54WB(71) 610-1507-4-71
26
52.3 37.8 30.48
★ HIF3BA-30PA-2.54WB(71) 610-1508-7-71
30
57.4 42.9 35.56
★ HIF3BA-34PA-2.54WB(71) 610-1509-0-71
34
62.5 48.0 40.64
★ HIF3BA-40PA-2.54WB(71) 610-1510-9-71
40
70.1 55.6 48.26
★ HIF3BA-50PA-2.54WB(71) 610-1511-1-71
50
82.8 68.3 60.96
★ HIF3BB-50PA-2.54WB(71) 610-1512-4-71
50
82.8 68.3 60.96
★ HIF3BA-60PA-2.54WB(71) 610-1513-7-71
60
95.5 81.0 73.66
★ HIF3BB-60PA-2.54WB(71) 610-1514-0-71
60
95.5 81.0 73.66
★ HIF3BA-64PA-2.54WB(71) 610-1515-2-71
64
100.6 86.1 78.74
★ HIF3BB-64PA-2.54WB(71) 610-1516-5-71
64
100.6 86.1 78.74
D
28.14
MAX51.1
28.14
MAX51.1
35.74
MAX58.7
40.84
MAX63.8
48.44
MAX71.4
53.54
MAX76.5
58.64
MAX81.6
66.24
MAX89.2
78.94
MAX101.9
78.94
MAX101.9
91.64
MAX114.6
91.64
MAX114.6
96.74
MAX119.7
96.74
MAX119.7
E
F
21.8 27.9
Polarizing Slot
(Note 1)
None
21.8 27.9
RoHS
(Note 2)
One on right side
None
29.5 35.5
34.5 40.6
42.2 48.3
One at center
47.2 53.3
52.3 58.4
YES
59.9 66.0
72.6 78.7
One on right and
left sides, resp.
One at center
85.3 91.4
One at center
90.4 96.5
One at center
B25
BCombination Pattern
Note : Fix the HIF3-mounting hole spacer by screws between upper stage and lower stage connectors.
■Mounting Hole Spacer
Part Number
CL No.
HIF-3 mounting hole spacer
562-0714-4
Note : 2 pieces are contained in a bag.
B26
Finish
PBT
Black
RoHS
YES
BPolarizing Key
HIF3B-GK
CL562-0601-8
HIF3-GPIN(A)
HIF3BA-GPIN
Note1: One unit of this
product is a set of five
pieces in conjunction
with a runner. The unit
for sale is defined one
pack containing 20
pieces.
Note2: This product is
applicable to HIF3A*D2.54R, HIF3C*D2.54C and
HIF3BA-*D2.54C
products.
Part Number
CL No.
Material
Remarks
pack containing 20
pieces.
applicable to the
HIF3BA-*D2.54R
product.
RoHS
HIF3-GPIN(A) 562-0126-6 Poly acetal (white) A set of 5 pieces YES
Part Number
CL No.
Material
Remarks
RoHS
HIF3BA-GPIN 612-0500-2 Poly acetal (white) A set of 5 pieces YES
B27
BHIF3-Multi Clamp
BHIF3-*CL Pull Tab
This clamp is used for intermediate connection in the
This pull tab is used for the HIF3 series equipped with cable clamp
bus-line system, etc. Remove compulsory force from the
function. Remove all compulsory force, which is loaded on the
insulation displacement area of the connector in
insulation displacement area of the connector for extraction.
intermediate connection.
Note: This HIF3-* Pull Tab can not be used for HIF3BA-*PD.
Note: The pin header corresponds to the HIF3BAE
Note: The pin header corresponds to the HIF3BAE series (lock E).
series (lock E).
BLock
Lock G
Lock F
Part Number : HIF3BAG-**PA-2.54DSA(71)
●Low profile type, and used for lock ejection.
Connector height is reduced.
Since no connector clamp is needed on the cable side,
this is used without turning back on the cable side. Take
care about this point.
B28
27.3
●F Type Lock Pin Header
21.5
●Low Profile Lock Pin Header
●Locking range more reduced than conventional lock type.
Even if connectors are aligned laterally, the mounting
space is reduced.
Note : The clamp must be replaced for HIF3A socket type
60 contacts only. Take care about this point.
■Socket for Crimping
Unit: mm
Part Number
CL No.
Number of Contacts
A
B
HIF3BA-10D-2.54C
610-1041-0
10
17.25
10.16
HIF3BA-14D-2.54C
610-1051-3
14
22.35
15.24
HIF3BA-16D-2.54C
610-1042-2
16
24.8
17.78
HIF3BA-20D-2.54C
610-1043-5
22.86
HIF3BA-26D-2.54C
610-1044-8
26
37.55
30.48
HIF3BA-30D-2.54C
610-1045-0
30
42.63
35.56
HIF3BA-34D-2.54C
610-1046-3
34
47.75
40.64
HIF3BA-40D-2.54C
610-1047-6
40
55.35
48.26
HIF3BA-50D-2.54C
610-1048-9
HIF3BB-50D-2.54C
610-1061-7
50
68.04
60.96
HIF3BA-60D-2.54C
610-1049-1
HIF3BB-60D-2.54C
610-1062-0
HIF3BA-64D-2.54C
610-1064-5
HIF3BB-64D-2.54C
610-1063-2
60
80.77
73.66
64
85.85
78.74
Polarizing Guide
RoHS
One at center
YES
One right and left side, resp.
One at center
One at center
One at center
Note: Some variations may differ from those in above figures.
B29
■Cover Case for Crimping socket
Unit: mm
Part Number
CL No.
Number of Contacts
A
B
C
D
E
HIF3-20CV(72)
562-0201-0-72
18.0
12.0
30.5
29.95
HIF3-26CV(72)
562-0202-2-72
26
30.2
20.0
14.0
32.0
37.55
HIF3-30CV(72)
562-0203-5-72
30
32.2
22.0
16.0
33.0
42.63
HIF3-34CV(72)
562-0204-8-72
34
34.2
24.0
18.0
33.5
47.75
HIF3-40CV(72)
562-0205-0-72
40
36.2
26.0
20.0
35.5
55.35
HIF3-50CV(72)
562-0206-3-72
50
39.2
29.0
23.0
38.0
68.04
HIF3-60CV(72)
562-0207-6-72
60
42.2
32.0
26.0
40.5
80.77
Note 1: The type F lock pin header cannot be used for a mating member.
Note 2: Note that the product cannot be used with AWG #20.
Applicable jacket diameters are as described below.
20 contacts: 1.7 mm diameter MAX
26 to 40 contacts: 1.6 mm diameter MAX
50 to 60 contacts: 1.4 mm diameter MAX
B30
RoHS
YES
■Contact for Crimping Socket
HIF3-2226SC
HIF3-2226SCA
Applicable cable
Manual crimping tool
RoHS
562-0079-8 gold plated contact in bag
YES
562-0244-2 Selective gold plated contact in bag
AWG#22 to #26 UL 1007 Stranded wire
HIF3-T2226HC
HIF3-2428SC
HIF3-2428SCA
Applicable cable
RoHS
562-0124-0 gold plated contact in bag
YES
562-0246-8 Selective gold plated contact in bag
AWG#24 to #28 UL 1007 Stranded wire
HIF3-TA2428HC
RoHS
HIF3-2022SC 562-0492-4 gold plated contact in bag YES
Applicable cable AWG#20 to #22 UL 1007 Stranded wire
Manual crimping tool HIF3-TA2022HC
RoHS
RoHS
RoHS
HIF3-2226SCF 562-0080-7 gold plated contact in reel
HIF3-2428SCF 562-0125-3 gold plated contact in reel
HIF3-2022SCF 562-0493-7 gold plated contact in reel YES
YES
YES
* HIF3-2226SCFA 562-0245-5 Selective gold plated contact in reel
* HIF3-2428SCFA 562-0247-0 Selective gold plated contact in reel
Applicable cable AWG#22 to #26 UL 1007 Stranded wire
Applicable cable AWG#24 to #28 UL 1007 Stranded wire
Note:* products have both side careers.
Type VA (Selective gold plated in reel)
Applicable Cable
Part Number CL No.
HIF3-2226SCFC 613-0002-1 AWG#22 to #26 UL 1007 Stranded wire
HIF3-2630SCFC 613-0001-9 AWG#26 to #30 UL 1007 Stranded wire
HIF3A-3236SCFC 613-0005-0 AWG#32 to #36 UL 1007 Stranded wire
A
11.5
11.5
12.4
B
0.8
0.8
1.7
C
1.8
1.4
1.1
D
1.8
1.35
1.1
E
2.3
2.0
1.4
F RoHS
2.6
2.1 YES
1.5
Type VA (Selective gold plated contact in bag)
Applicable Cable
Manual Crimp Tool A B C D E F RoHS
Part Number CL No.
HIF3-2226SCC 613-0004-7 AWG#22 to #26 UL 1007 Stranded wire HIF3-TB2226HC 11.5 0.8 1.8 1.8 2.3 2.6
YES
HIF3-2630SCC 613-0003-4 AWG#26 to #30 UL 1007 Stranded wire HIF3-TB2630HC 11.5 0.8 1.4 1.35 2.0 2.1
B31
BTools
●Crimping Tool
Manual Crimping Tool
Part Number
CL No.
HIF3-T2226HC
550-0063-8
Part Number
CL No.
CM-105
901-0005-4
HIF3-T2226HC
●Automatic Crimping Tool (Type: CM-105)
●Contact Extraction Tools
Part Number
CL No.
HIF1-PO
550-0049-7
How to use the extraction tool
(1) How to extract contacts
(2) How to adjust the lance (raise)
As shown in Figure 1, where the
extraction tool is inserted in the lance
fixed slot on the insulated case, slightly
pull the cable, and the contact can be
removed.
In order to re-insert the contact
removed from the insulated case,
raise the contact lance area using the
tool A, and re-insert the contact, as
shown in Figure 2.
Figure 1
B32
Type
Item
Manual
Automatic
Part Number
CL No.
Applicable Cable
550-0063-8
HIF3-TA2428HC
550-0100-2
HIF3-TA2022HC
550-0124-0
HIF3-2022SC
AWG#20 to #22
HIF3-TB2226HC
550-0154-1
HIF3-2226SCC
AWG#22 to #26
HIF3-TB2630HC
550-0155-4
HIF3-2630SCC
AWG#26 to #30
901-0005-4
HIF3-2226SCF
HIF3-2428SCF
HIF3-2226SCFA
HIF3-2428SCFA
AWG#22 to #26
AWG#24 to #28
AWG#22 to #26
AWG#24 to #28
AP105-HIF3-22-28SCF
901-4031-6
(Note1)
AP105-HIF3-22-28SCFA
901-4030-3
(Note1)
Extraction tool
HIF3-2226SC
HIF3-2226SCA
HIF3-2428SC
HIF3-2428SCA
HIF3-T2226HC
Automatic crimping tool unit CM-105
Applicator
Applicable Contact
AWG#22 to #26
AWG#24 to #28
AP105-HIF3-2022S
901-4027-9
HIF3-2022SCF
AWG#20 to #22
AP105-HIF3-2226SCFC
901-4005-6
HIF3-2226SCFC
AWG#22 to #26
AP105-HIF3-2630SCFC
901-4006-9
HIF3-2630SCFC
AWG#26 to #30
AP105-HIF3-3236SCFC
901-4007-1
HIF3-3236SCFC
AWG#32 to #36
HIF1-PO
550-0049-7
Note1: AP106-HIF3-22-28SCF and AP105-HIF3-22-28CFA can be modified by changing a few parts.
B33
BSocket Side (Crimping) Assembling Procedures
(1) As shown in Figure 1, peel the applicable cable (AWG#20 to #26) jacket, and connect it using crimping jig HIF3-TA2022HC,
HIF3-TA2226HC, or HIF3-TA2426HC. In this case, insert the cable so as to hit the contact cable stripper position as shown
Figure 2.
(2) After connection as shown Figure 2, check the contact direction, and insert the contact as shown Figures 3 and 4. Slightly pull
the cable, and check whether the contact lance position is firmly fixed to the insulation case, as shown in the area (A).
Note1 : For handling procedures for special crimping tools, refer to the "Handling Instruction Manual".
Note2 : Wire strip length: Refer to crimp condition sheet.
Wire strip length
B34
Figure 1
Figure 2
Figure 3
Figure 4
HIF3B Connection Circuit Diagram
Type AB
Type AB
Type AD
Type AD
Type CD
Type CD
B35
Type AC
Type AC
Type CC
Type CC
Type AA
Type AA
B36
HIF2E R(S) A to HIF3B Connection Circuit Diagram
Type AA
Type AC
B37
Type BA
Type BC
B38
HIF2E R(S)B to HIF3 Connection Circuit Diagram
Type AA
Type AC
B39
Type BA
Type BC
B40
HIF3B In-line Type Ribbon Cable Connector
■Features
1. In-line Type
This connector can be used for internal wiring cable to cable within
equipment.
2. Compatibility
This connector is compatible with HIF3A series as well as HIF3B
series socket.
3. Applicable Cable
(7 pcs./6.127mm, jacket diameter: 0.8 to 1.0mm).
Current rating : 1A
Rating
Item
Specification
Condition
1000M ohms min.
500V DC
650V AC/1 minute
15m ohms max.
0.1A
4. Vibration
(-65ç: 30 minutes ➝ 15 to 35ç: 5 minutes max.
500 cycles
■Material
Part
Material
Finish
Remarks
Insulator
PBT
Black
UL94V-0
Plug Contact
Beryllium copper
Gold plated over nickel underplated
HIF3BA - * P D - 2.54 R - MC
q
q Series Name
w
e
r
t
y
u
: HIF3BB (50, 60, 64 contacts only) e P : Plug
HIF3BD (10 contacts only)
r D : contact alignment : D : Double
HIF3BAE (60 contacts only)
t Contact Pitch
w Number of Contacts : 10, 16, 20, 26, 30, 34, 40, 50, 60
and 64
: 2.54mm
y Connection type
: Ribbon cable
u MC
: Mold clamp
B41
■Plug
The 10 contact connector only has no position for polarizing key insulation.
Note 3: The number indicated in parentheses are sizes for 60 and 64 contact connectors.
Note 4: The HIF3BAE-60PD-2.54R-MC product partially differs in a locking form, and the mating member is
applicable for HIF3A only.
Unit:mm
Part Number
CL No.
Number of Contacts
A
B
C
HIF3BDE-10PD-2.54R-MC 611-0031-7
10
31.98 17.48 10.16
HIF3BAE-16PD-2.54R-MC 611-0032-0
16
39.60 25.10 17.78
HIF3BAE-20PD-2.54R-MC 611-0033-2
44.68 30.18 22.86
HIF3BAE-26PD-2.54R-MC 611-0034-5
26
52.30 37.80 30.48
HIF3BAE-30PD-2.54R-MC 611-0035-8
30
57.38 42.88 35.56
HIF3BAE-34PD-2.54R-MC 611-0036-0
34
62.46 47.96 40.64
HIF3BAE-40PD-2.54R-MC 611-0037-3
40
70.08 55.58 48.26
HIF3BAE-50PD-2.54R-MC 611-0038-6
50
HIF3BBE-50PD-2.54R-MC 611-0041-0
50
HIF3BAE-60PD-2.54R-MC 611-0039-9
60
HIF3BBE-60PD-2.54R-MC 611-0042-3
60
D
28.14
MAX51.1
35.74
MAX58.7
40.84
MAX63.8
48.44
MAX71.4
53.54
MAX76.5
58.64
MAX81.6
66.24
MAX89.2
E
F
G
H
29.50 37.75
34.58 42.83
42.20 50.45
One at center
33.2
47.28 55.53
52.36 60.61 29.2
59.98 68.23
72.68 80.93
91.64
MAX114.6
HIF3BAE-60PD-2.54R-MC 611-0059-6
60
91.7
MAX121.3
HIF3BAE-64PD-2.54R-MC 611-0040-8
64
96.74
HIF3BBE-64PD-2.54R-MC 611-0045-1
64
85.38 93.63
35.2
MAX119.7
One at center
31.2 37.2
90.46 98.71 29.2 35.2
100.56 86.06 78.74
One at center
*D size
B42
YES
One at center
MAX101.9
95.48 80.98 73.66
RoHS
21.88 30.13
78.94
82.78 68.28 60.96
Polarizing slot
locking size
unlocking size
BConnection Procedures
Note1: Cable length tolerance Less than 500 +10
+00 (mm)
More than 500 +3
+0 (mm)
Note2: When a cable such as a twist cable
or a slit (like a roller screen) cable is
used, the cable pitch will change
according to cable manufacturers.
If connection failure has occurred,
please contact Hirose sales.
Type AO
Type BO
Type CO
Type DO
B43
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Hirose Electric:
HIF3BA-34D-2.54R(05) HIF3BA-34D-2.54R(11) HIF3BA-40D-2.54R(05) HIF3BA-40D-2.54R(11) HIF3BA-50D2.54R(05) HIF3BA-64D-2.54R(05) HIF3BB-50D-2.54R(05) HIF3BA-10PA-2.54DS(75) HIF3BA-10PA-2.54DS(81)
HIF3BA-16PA-2.54DS(75) HIF3BA-16PA-2.54DS(81) HIF3BA-20PA-2.54DS(75) HIF3BA-26PA-2.54DS(75) HIF3BA30PA-2.54DS(75) HIF3BA-34PA-2.54DS(75) HIF3BA-40PA-2.54DS(75) HIF3BA-50PA-2.54DS(75) HIF3BA-16PA2.54DSA(71) HIF3BA-16PA-2.54DSA(75) HIF3BA-20PA-2.54DSA(75) HIF3BA-26PA-2.54DSA(72) HIF3BA-26PA2.54DSA(75) HIF3BA-30PA-2.54DSA(72) HIF3BA-30PA-2.54DSA(75) HIF3BA-30PA-2.54DSA(88) HIF3BA-34PA2.54DSA(75) HIF3BA-50PA-2.54DSA(71) HIF3BA-50PA-2.54DSA(75) HIF3BA-60PA-2.54DSA(75) HIF3BA-64PA2.54DSA(75) HIF3BC-10PA-2.54DSA(71) HIF3BD-10PA-2.54DS(75) HIF3BD-10P-2.54W HIF3BD-10P-2.54W(88)
HIF3BA-16P-2.54W HIF3BA-20P-2.54W HIF3BA-20P-2.54W(88) HIF3BA-26P-2.54W HIF3BA-30P-2.54W HIF3BA34P-2.54W HIF3BA-34P-2.54W(88) HIF3BA-40P-2.54W HIF3BA-40P-2.54W(88) HIF3BB-50P-2.54W HIF3BB-50P2.54W(88) HIF3BB-60P-2.54W HIF3BB-64P-2.54W HIF3BA-10P-2.54W HIF3BA-10P-2.54W(88) HIF3BA-50P2.54W(88) HIF3BA-60P-2.54W HIF3BA-60P-2.54W(88) HIF3BA-64P-2.54W(88) HIF3BA-20D-2.54C(03) HIF3BA10PA-2.54WB(71) HIF3BD-10PA-2.54WB(71) HIF3BA-20PA-2.54WB(71) HIF3BA-26PA-2.54WB(71) HIF3BA-30PA2.54WB(71) HIF3BA-40PA-2.54WB(71) HIF3BA-50PA-2.54WB(71) HIF3BB-50PA-2.54WB(71) HIF3BA-60PA2.54WB(71) HIF3BB-60PA-2.54WB(71) HIF3BB-64PA-2.54WB(71) HIF3CA-10PA-2.54DSA(71) HIF3CA-16PA2.54DSA(91) HIF3CA-20PA-2.54DSA(91) HIF3CA-26PA-2.54DSA(91) HIF3CA-30PA-2.54DSA(91) HIF3CA-34PA2.54DSA(91) HIF3CA-40PA-2.54DSA(91) HIF3CA-50PA-2.54DSA(91) HIF3CB-50PA-2.54DSA(71) HIF3CB-50PA2.54DSA(91) HIF3CB-60PA-2.54DSA(91) HIF3CB-64PA-2.54DSA(71) HIF3CB-64PA-2.54DSA(91) HIF3CD-10PA2.54DSA(71) HIF3CD-10PA-2.54DSA(91) HIF3-2226SC(02) HIF3-2226SCA(01) HIF3-2226SCF(04) HIF32226SCF(05) HIF3-2226SCFA(01) HIF3-2226SCFC(11) HIF3-2428SC(02) HIF3-2428SCF(02) HIF3-TA2022HC
HIF3-TA2428HC HIF3-TB2226HC HIF3-TB2630HC HIF3BA-16D-2.54R(05) HIF3BA-26D-2.54R(05) HIF3BA-30D2.54R(05) HIF3BA-16PA-2.54DSA(74) HIF3BA-20PA-2.54DSA(74) HIF3BA-26PA-2.54DS(85) HIF3BA-40PA2.54DS(82) HIF3BA-64PA-2.54DS(75)
