MDF7-17P-2.54DSA(01) 数据手册
2.54mm Pitch Bottom Entry Type Connector
MDF7 Series
Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Board to Board size Freely settable
Fig.1
Features
1. Board to Board Size Freely Settable
The board to board size can be set at infinite stages, according to the header pin through type structure
and the diverse header variation.
The board to board size can be set at infinite stages.
2. Integrity of Parts Mounted Surface
The parts mounted surface on two boards aren't face each other, and can be oriented in the same
direction.
3. Wide Variation
Single-row product, double-row product, tin plated and gold plated products are lined up. In addition, the
header to correspond to the board to board size are prepared. Concerning board to board size, other
products can be provided, in addition to products in this catalog. Please contact HRS company as required.
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2018.3③
1
MDF7 Series●2.54mm Pitch Bottom Entry Type Connector
Product Specifications
Operating Temperature Range : -35ç to +85ç (Note 1) Storage Temperature Range : -10ç to +60ç (Note 2)
Current rating : 3A
Rating
Voltage rating : 250V AC Operating Humidity Range : 40% to 80%
Storage Humidity Range : 40% to 70% (Note 2)
Item
1. Insulation Resistance
Specification
Condition
1000Mø min.
500V DC
2. Withstanding voltage
No flashover or insulation breakdown.
650V AC/1 minute
3. Contact Resistance
30mø max.
4. Single Insertion/Extraction
MIN 0.4N (40gf), MAX 4.4N (450gf)
Force
100mA
5. Vibration
No electrical discontinuity of 10µs or more
6. Humidity (Steady state)
Contact resistance : 30mø max.
7. Temperature Cycle
Insulation resistance : 1000Mø min.
8. Durability
(Mating/un-mating)
9. Resistance to Soldering
heat
Measured by the square steel pin with
0.635±0.002mm
Frequency : 10 to 55Hz, single amplitude of
0.75mm, 2 hours in each of the 3 directions.
96 hours at temperature of
(-55ç : 30 minutes, 5 to 35ç : 10 minutes
85ç : 30 minutes, 5 to 35ç : 10 minutes)
5cycles
Tin plating : 30 cycles
Gold plating : 50 cycles
Flow : 260ç for 10 seconds
Manual soldering : 350ç for 3 seconds
No deformation of components affecting
performance.
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature
Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during
transportation.
Material / Finish
Product
Receptacle
Pin Header
Part
Insulator
Material
Polyamide
Contact
Phosphor bronze
Insulator
PBT
Contact
Brass
Finish
Black
Remarks
Tin plated or gold plated
Main unit : Black/Locator : Gray
UL94V-0
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
MDF7
q
- * S - 2.54 DSA (**)
w
e
q Series Name : MDF7
w Number of contacts: 3 to 46
e Connector Type
S : Single row receptacle
D : Double row receptacle
P : Single row pin header
DP: Double row pin header
r Contact Pitch : 2.54mm
t Contact type
DSA : Straight through hole
DS : Right Angle through hole
2
r
t
y
y Receptacle
(95) : Tin plated (100 pcs/pack)
(96) : Gold plated (100 pcs/pack)
Pin Header
P (55) : Tin plated (100 pcs/pack)
(01) : Gold plated (100 pcs/pack)
DP (55) : Tin plated (100 pcs/pack)
Blank : Gold plated (100 pcs/pack)
UL94V-0
Single Row Receptacle
[Specific No.] (* *), * *
(95) : Tin plated
(96) : Gold plated
A±0.5
1.5±0.2
B±0.3
3±0.3
5±0.3 3±0.2
7.5±0.3
P=2.54±0.15
0.76±0.1
0.2±0.1
Part No.
HRS No.
MDF7-3S-2.54DSA(**)
MDF7-5S-2.54DSA(**)
MDF7-6S-2.54DSA(**)
MDF7-7S-2.54DSA(**)
MDF7-8S-2.54DSA(**)
MDF7-9S-2.54DSA(**)
MDF7-10S-2.54DSA(**)
MDF7-11S-2.54DSA(**)
MDF7-12S-2.54DSA(**)
MDF7-13S-2.54DSA(**)
MDF7-14S-2.54DSA(**)
547-0355-0 **
547-0112-9 **
547-0129-1 **
547-0135-4 **
547-0136-7 **
547-0137-0 **
547-0038-8 **
547-0138-2 **
547-0040-0 **
547-0139-5 **
547-0140-4 **
A
B
7.62
12.70
15.24
17.78
20.32
22.86
25.40
27.94
30.48
33.02
35.56
RoHS
5.08
10.16
12.70
15.24
17.78
20.32 Yes
22.86
25.40
27.94
30.48
33.02
Part No.
HRS No.
MDF7-15S-2.54DSA(**)
MDF7-16S-2.54DSA(**)
MDF7-17S-2.54DSA(**)
MDF7-18S-2.54DSA(**)
MDF7-19S-2.54DSA(**)
MDF7-20S-2.54DSA(**)
MDF7-21S-2.54DSA(**)
MDF7-22S-2.54DSA(**)
MDF7-23S-2.54DSA(**)
MDF7-24S-2.54DSA(**)
MDF7-25S-2.54DSA(**)
547-0012-4 **
547-0141-7 **
547-0142-0 **
547-0013-7 **
547-0143-2 **
547-0051-6 **
547-0144-5 **
547-0145-8 **
547-0146-0 **
547-0147-3 **
547-0014-0 **
No. of
Contacts
15
16
17
18
19
22
23
24
25
A
38.10
40.64
43.18
45.72
48.26
50.80
53.34
55.88
58.42
60.96
63.50
B
RoHS
35.56
38.10
40.64
43.18
45.72
48.26 Yes
50.80
53.34
55.88
58.42
60.96
Note : The quantity for delivery is determined 100 pcs/pack. Please order the products per pack.
A±0.5
B±0.3
P=2.54±0.15
5±0.3
10±0.3
2.54±0.15
Double Row Receptacle
3±0.3
Unit : mm
No. of
Contacts
3
5
6
7
8
9
10
11
12
13
14
0.76±0.1
0.2±0.1
8.54±0.4
Unit : mm
No. of
A
B RoHS
Part No.
HRS No.
Contacts
(95) : Tin plated
MDF7-12D-2.54DSA(**) 547-0032-1 **
12
15.24 12.70
(96) : Gold plated
MDF7-14D-2.54DSA(**) 547-0354-8 **
14
17.78 15.24
MDF7-16D-2.54DSA(**) 547-0363-9 **
16
20.32 17.78
MDF7-20D-2.54DSA(**) 547-0033-4 **
MDF7-22D-2.54DSA(**) 547-0246-5 **
22
27.94 25.40 Yes
MDF7-24D-2.54DSA(**) 547-0244-0 **
24
30.48 27.94
MDF7-26D-2.54DSA(**) 547-0247-8 **
26
33.02 30.48
MDF7-30D-2.54DSA(**) 547-0016-5 **
30
38.10 35.56
MDF7-34D-2.54DSA(**) 547-0227-0 **
34
43.18 40.64
Note 1 : A quantity for delivery is determined 100 pcs/pack. Please order the products per pack.
3
Single Row Straight Pin Header
(55) : Tin plated
(01) : Gold plated
2.54±0.3
0.5±0.2
2.54±0.2
C±0.3
□0.64±0.1
[without locator]
MDF7 (PCB distance : 2.54 to 5.5mm)
A±0.5
B±0.3
P=2.54±0.15
3±0.3
0.5±0.2
C±0.3
3±0.3
●Board Through-hole Diameter : Ø1.0++0.1
2.54±0.2
2.54±0.3
A±0.5
B±0.3
P=2.54±0.15
□0.64±0.1
[with locator]
MDF7B (PCB distance : 2.54 to 12mm)
Unit : mm
Unit : mm
HRS No.
No. of
Contacts
MDF7-3P-2.54DSA(**)
547-0220-1 **
3
7.62 5.08
MDF7B-3P-2.54DSA(**) 547-0304-0 **
3
7.62 5.08
MDF7-5P-2.54DSA(**)
547-0113-1 **
5
12.70 10.16
MDF7B-5P-2.54DSA(**) 547-0133-9 **
5
12.70 10.16
MDF7-6P-2.54DSA(**)
547-0130-0 **
6
15.24 12.70
MDF7B-6P-2.54DSA(**) 547-0131-3 **
6
15.24 12.70
MDF7-7P-2.54DSA(**)
547-0148-6 **
7
17.78 15.24
MDF7B-7P-2.54DSA(**) 547-0177-4 **
7
17.78 15.24
MDF7-8P-2.54DSA(**)
547-0149-9 **
8
20.32 17.78
MDF7B-8P-2.54DSA(**) 547-0178-7 **
8
20.32 17.78
MDF7-9P-2.54DSA(**)
547-0150-8 **
9
22.86 20.32
MDF7B-9P-2.54DSA(**) 547-0179-0 **
9
22.86 20.32
MDF7-10P-2.54DSA(**) 547-0039-0 **
10
25.40 22.86
MDF7B-10P-2.54DSA(**) 547-0048-1 **
10
25.40 22.86
MDF7-11P-2.54DSA(**) 547-0151-0 **
11
27.94 25.40
MDF7B-11P-2.54DSA(**) 547-0047-9 **
11
27.94 25.40
MDF7-12P-2.54DSA(**) 547-0043-8 **
12
30.48 27.94
MDF7B-12P-2.54DSA(**) 547-0041-2 **
12
30.48 27.94
MDF7-13P-2.54DSA(**) 547-0152-3 **
13
33.02 30.48
MDF7B-13P-2.54DSA(55) 547-0180-9 55
13
33.02 30.48
MDF7-14P-2.54DSA(**) 547-0153-6 **
14
35.56 33.02
MDF7B-14P-2.54DSA(55) 547-0181-1 55
14
35.56 33.02
MDF7-15P-2.54DSA(**) 547-0018-0 **
15
38.10 35.56
MDF7B-15P-2.54DSA(**) 547-0024-3 **
15
38.10 35.56
MDF7-16P-2.54DSA(**) 547-0111-6 **
16
40.64 38.10
MDF7B-16P-2.54DSA(**) 547-0182-4 **
16
40.64 38.10
MDF7-17P-2.54DSA(**) 547-0154-9 **
17
43.18 40.64
MDF7B-17P-2.54DSA(55) 547-0183-7 55
17
43.18 40.64
MDF7-18P-2.54DSA(**) 547-0022-8 **
18
45.72 43.18
MDF7B-18P-2.54DSA(55) 547-0025-6 55
18
45.72 43.18
MDF7-19P-2.54DSA(**) 547-0155-1 **
19
48.26 45.72
MDF7B-19P-2.54DSA(55) 547-0184-0 55
19
48.26 45.72
MDF7-20P-2.54DSA(**) 547-0123-5 **
MDF7B-20P-2.54DSA(**) 547-0052-9 **
MDF7-21P-2.54DSA(**) 547-0156-4 **
21
53.34 50.80
MDF7B-21P-2.54DSA(55) 547-0185-2 55
21
53.34 50.80
MDF7-22P-2.54DSA(**) 547-0157-7 **
22
55.88 53.34
MDF7B-22P-2.54DSA(55) 547-0186-5 55
22
55.88 53.34
MDF7-23P-2.54DSA(**) 547-0158-0 **
23
58.42 55.88
MDF7B-23P-2.54DSA(55) 547-0066-3 55
23
58.42 55.88
MDF7-24P-2.54DSA(**) 547-0159-2 **
24
60.96 58.42
MDF7B-24P-2.54DSA(55) 547-0067-6 55
24
60.96 58.42
MDF7-25P-2.54DSA(**) 547-0023-0 **
25
63.50 60.96
MDF7B-25P-2.54DSA(55) 547-0026-9 55
25
63.50 60.96
Part No.
A
B
C RoHS
10
Yes
Part No.
HRS No.
No. of
Contacts
Note 1 : PCB distance in the above table represents the case where the 1.6mm thickness board is used.
Note 2 : The quantity for delivery is determined 100 pcs/pack. Please order the products per pack.
4
A
B
C RoHS
16.46 Yes
MDF7P (PCB distance : 2.54 to 8mm)
MDF7C (PCB distance : 5.08 to 15mm, with Locator)
Unit : mm
Part No.
HRS No.
No. of
A
B
Contacts
3
7.62 5.08
C RoHS
Unit : mm
Part No.
HRS No.
MDF7C-3P-2.54DSA(**)
547-0489-7 **
No. of
A
B
Contacts
3
7.62 5.08
MDF7P-3P-2.54DSA(01)
547-0462-0 01
MDF7P-5P-2.54DSA(**)
547-0511-4 **
5
12.70 10.16
MDF7C-5P-2.54DSA(**)
547-0344-4 **
5
12.70 10.16
MDF7P-6P-2.54DSA(**)
547-0513-0 **
6
15.24 12.70
MDF7C-6P-2.54DSA(55)
547-0268-8 55
6
15.24 12.70
MDF7P-7P-2.54DSA(**)
7
17.78 15.24
MDF7C-7P-2.54DSA(**)
547-0378-6 **
7
17.78 15.24
MDF7P-8P-2.54DSA(55)
547-0514-2 55
8
20.32 17.78
MDF7C-8P-2.54DSA(55)
547-0375-8 55
8
20.32 17.78
MDF7P-9P-2.54DSA(**)
9
22.86 20.32
MDF7C-9P-2.54DSA(55)
547-0506-4 55
9
22.86 20.32
MDF7P-10P-2.54DSA(55) 547-0360-0 55
10
25.40 22.86
MDF7C-10P-2.54DSA(55) 547-0191-5 55
10
25.40 22.86
MDF7P-11P-2.54DSA(**)
11
27.94 25.40
MDF7C-11P-2.54DSA(55) 547-0376-0 55
11
27.97 25.40
MDF7P-12P-2.54DSA(55) 547-0345-7 55
12
30.48 27.94
MDF7C-12P-2.54DSA(**) 547-0475-2 **
12
30.48 27.94
MDF7P-13P-2.54DSA(**)
13
33.02 30.48
MDF7C-13P-2.54DSA(55) 547-0401-6 55
13
33.02 30.48
MDF7P-14P-2.54DSA(55) 547-0385-1 55
14
35.56 33.02
MDF7C-14P-2.54DSA(55) 547-0380-8 55
14
35.56 33.02
MDF7P-15P-2.54DSA(55) 547-0230-5 55
15
38.10 35.56
MDF7C-15P-2.54DSA(55) 547-0187-8 55
15
38.10 35.56
MDF7P-16P-2.54DSA(55) 547-0346-0 55
16
40.64 38.10
MDF7C-16P-2.54DSA(**)
16
40.64 38.10
MDF7P-17P-2.54DSA(**)
17
43.18 40.46
MDF7C-17P-2.54DSA(**)
17
43.18 40.64
MDF7P-18P-2.54DSA(**)
12.5 Yes
18
45.72 43.18
MDF7C-18P-2.54DSA(55) 547-0029-7 55
18
45.72 43.18
MDF7P-19P-2.54DSA(55) 547-0347-2 55
19
48.26 45.72
MDF7C-19P-2.54DSA(55) 547-0361-3 55
19
48.26 45.72
MDF7P-20P-2.54DSA(**)
MDF7C-20P-2.54DSA(**) 547-0198-4 **
MDF7P-21P-2.54DSA(**)
21
53.34 50.80
MDF7C-21P-2.54DSA(**)
21
53.34 50.80
MDF7P-22P-2.54DSA(**)
22
55.88 53.34
MDF7C-22P-2.54DSA(**)
22
55.88 53.34
MDF7P-23P-2.54DSA(**)
23
58.42 55.88
MDF7C-23P-2.54DSA(55) 547-0909-0 55
23
58.42 55.88
MDF7P-24P-2.54DSA(**)
24
60.96 58.42
MDF7C-24P-2.54DSA(**)
24
60.96 58.42
25
63.50 60.96
MDF7C-25P-2.54DSA(55) 547-0305-2 55
25
63.50 60.96
MDF7P-25P-2.54DSA(55) 547-0348-5 55
C RoHS
19.46 Yes
Note 2 : A quantity for delivery is determined 100 pcs/pack. Please order the products per pack.
Note 3 : As for the products, which HRS No. is not indicated in the above table, we will correspond to samples, and massproduction according to your demand. Please contact our account executive, as required.
5
A±0.5
B±0.5
P=2.54±0.25
4±0.3
0.5±0.2
0.5±0.2
12.2±0.5
7.43±0.5
3.3±0.3
(7.3)
4±0.2
Single-Row Right Angle Pin Header
(55) : Tin plated
(56) : Gold plated
□0.64±0.1
Unit : mm
Part No.
HRS No.
MDF7-5P-2.54DS(**)
MDF7-6P-2.54DS(**)
MDF7-7P-2.54DS(**)
MDF7-8P-2.54DS(**)
MDF7-9P-2.54DS(**)
MDF7-10P-2.54DS(**)
MDF7-11P-2.54DS(**)
MDF7-12P-2.54DS(**)
MDF7-13P-2.54DS(**)
MDF7-14P-2.54DS(**)
MDF7-15P-2.54DS(**)
547-0160-1 **
547-0161-4 **
547-0162-7 **
547-0163-0 **
547-0164-2 **
547-0165-5 **
547-0166-8 **
547-0116-0 **
547-0167-0 **
547-0168-3 **
547-0027-1 **
No. of
Contacts
5
6
7
8
9
10
11
12
13
14
15
A
12.70
15.24
17.78
20.32
22.86
25.40
27.94
30.48
33.02
35.56
38.10
B
RoHS
Part No.
HRS No.
10.16
MDF7-16P-2.54DS(**) 547-0169-6 **
12.70
MDF7-17P-2.54DS(**) 547-0170-5 **
15.24
MDF7-18P-2.54DS(**) 547-0019-3 **
17.78
MDF7-19P-2.54DS(**) 547-0171-8 **
20.32
MD7F-20P-2.54DS(**) 547-0172-0 **
22.86 Yes MDF7-21P-2.54DS(**) 547-0173-3 **
MDF7-22P-2.54DS(**) 547-0174-6 **
25.40
27.94
MDF7-23P-2.54DS(**) 547-0175-9 **
30.48
MDF7-24P-2.54DS(**) 547-0176-1 **
33.02
MDF7-25P-2.54DS(**) 547-0028-4 **
35.56
No. of
Contacts
16
17
18
19
22
23
24
25
A
40.64
43.18
45.72
48.26
50.80
53.34
55.88
58.42
60.96
63.50
B
RoHS
38.10
40.64
43.18
45.72
48.26
Yes
50.80
53.34
55.88
58.42
60.96
Note : A quantity for delivery is determined 100 pcs/pack. Please order the products per pack.
Application Pattern and PCB mounting pattern
When the single-row straight pin header is used
When the header with locator is used
The locator moves as the connector is inserted.
When the PCB distance is set to MAX
To separate clearance between the boards, the operation limit t is defined as the
state where the male pin has passed through the receptacle.
6
When the right angle pin header is used
A±0.5
B±0.3
P=2.54±0.15
3±0.3
0.5±0.2
C±0.3
2.54±0.2
5.08±0.3
2.54±0.15
Double-Row Straight Pin Header
(55) : Tin plated
Blank : Gold plated
□0.64±0.1
Unit : mm
Part No.
HRS No.
MDF7-12DP-2.54DSA(**)
MDF7-14DP-2.54DSA(**)
MDF7-16DP-2.54DSA(**)
MDF7-20DP-2.54DSA(**)
MDF7-22DP-2.54DSA(**)
MDF7-24DP-2.54DSA(**)
MDF7-26DP-2.54DSA(**)
MDF7-30DP-2.54DSA(**)
MDF7-34DP-2.54DSA(**)
547-0034-7 **
547-0365-4 **
547-0364-1 **
547-0114-4 **
547-0093-6 **
547-0250-2 **
547-0251-5 **
547-0037-5 **
547-0252-8 **
No. of
Contacts
12
14
16
24
26
30
34
A
15.24
17.78
20.32
25.40
27.94
30.48
33.02
38.10
43.18
B
C RoHS
12.70
15.24
17.78
22.86
25.40 10 Yes
27.94
30.48
35.56
40.64
Unit : mm
Part No.
MDF7P-12DP-2.54DSA(**)
MDF7P-14DP-2.54DSA(**)
MDF7P-16DP-2.54DSA(55)
MDF7P-20DP-2.54DSA(55)
MDF7P-22DP-2.54DSA(55)
MDF7P-24DP-2.54DSA(**)
MDF7P-26DP-2.54DSA(**)
MDF7P-30DP-2.54DSA(55)
MDF7P-34DP-2.54DSA(**)
No. of
HRS No.
Contacts
547-0407-2 **
12
14
547-0367-0 55
16
547-0260-6 55
22
547-0262-1 **
24
547-0263-4 **
26
547-0264-7 55
30
34
A
B
C RoHS
15.24 12.70
17.78 15.24
20.32 17.78
25.40 22.86
27.94 25.40 12.5 Yes
30.48 27.94
33.02 30.48
38.10 35.56
43.18 40.64
Note 1 : PCB distance in the above table represents the state where the 1.6mm thickness board is used.
When the double-row straight pin header is used
Precautions
1. Recommended Soldering Condition
2. Board Masking
3. Cleaning Condition
4. Cautions
■Flow Condition by Automatic Soldering Unit
Soldering temperature : 255±5ç, Soldering time: within 10 seconds
■Manual Soldering Condition
Soldering iron temperature : 340±10ç, Soldering time : within 3 seconds
If the automatic soldering unit is used, block the pin header through-hole on
the receptacle mounted board with the masking tape, etc., and prevent the flux
pervasion.
In addition, if much flux is adhered so as to affect the contact, please be sure to clean
the board.
Refer to Wire-to-Board Connector Use Hand book.
■It is impossible to fix the board to the board by the connector only. Please take
actions to fix the board without using the connector.
■If the board deformation could occur due to vibration, please use the gold plating.
■Don't use the connector as the top entry.
7
USA:
HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE
2300 Warrenville Road, Suite 150,
Downers Grove, IL 60515
Phone : +1-630-282-6700
http://www.hirose.com/us/
USA:
HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE
2841 Junction Ave, Suite 200
San Jose, CA. 95134
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE)
17197 N. Laurel Park Drive, Suite 253,
Livonia, MI 48152
Phone : +1-734-542-9963
Fax : +1-734-542-9964
USA:
HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE
300 Brickstone Square Suite 201,
Andover, MA 01810
Phone : +1-978-662-5255
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hirose.com/eu/
GERMANY:
HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH
Schoenbergstr. 20, 73760 ostfildern
Phone : +49-711-456002-1
Fax : +49-711-456002-299
GERMANY:
HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE
Neumeyerstrasse 22-26, 90411 Nurnberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
GERMANY:
HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE
Bayernstr. 3, Haus C 30855 Langenhagen, Germany
Phone : +49-511 97 82 61 30
Fax : +49-511 97 82 61 35
FRANCE:
HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE
130 Avenue Joseph Kessel, Bat E, 78960
Voisins le Bretonneux, France
Phone : +33-1-85764886
Fax : +33-1-85764823
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE BV (UK BRANCH)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS)
18, Enterprise Center Tower 2, 209# Gong He
Road, Jing’an District, Shanghai, CHINA 200070
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose.com/cn/
CHINA:
HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose.com/hk/
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7355
http://www.hirose.com/tw/
KOREA:
HIROSE KOREA CO.,LTD.
143, Gongdan 1-daero, Siheung-si,
Gyeonggi-do, 15084, Korea
Phone : +82-31-496-7000
Fax : +82-31-496-7100
http://www.hirose.co.kr/
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE
03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C,
Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India
Singapore 079909
Phone : +91-12-660-8018
Phone : +65-6324-6113
Fax : +91-120-4804949
Fax : +65-6324-6123
http://www.hirose.com/sg/
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE
Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma
Gandhi (MG) Road, Bangalore 560 001, Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
MALAYSIA:
THAILAND:
PENANG REPRESENTATIVE OFFICE
BANGKOK OFFICE (REPRESENTATIVE OFFICE)
73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn
Road, Yannawa, Sathorn, Bangkok 10120 Thailand
Lepas Penang, 11950, Malaysia
Phone : +66-2-686-1255
Phone : +604-648-5536
Fax : +66-2-686-3433
8
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 03/2018. Contents are subject to change without notice for the purpose of improvements.
