Nov.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
HNC Series
2.5mm Pitch Connector for Discrete Wire Connection
Feb. 2021 ①
HNC Series/2.5mm Pitch Connector for Discrete Wire Connection
Features
1. Positive Lock
Postive lock design does not unlock without
releasing the lock on both sides for effective
prevention against cable disconnection when the
cable gets caught, etc.
Mis-insertion
Prevention Design
Positive Lock
2. Low Profile
Mounted height when the connector is used at a
right angle : 4. 8mm
3. Mechanism to Prevent Misinsertion
This thin type connector is equipped with a misinsertion prevention design.
4. Tin and Gold Plating
Variations Available
Two plating types, tin and gold, are available and
can be chosen based on your application needs.
Additionally, the tin plating type has a light
operating feel.
Applications
Various business equipment, financial terminals
2
Product Specifications
Rated Current (Note 1)
Rated Voltage
22 AWG
24AWG
26 AWG
28 AWG
30 AWG
Operating Temperature (Note 2)
-55 to +85℃
3A/pin
3A/pin
2A/pin
1A/pin
0.5A/pin
Storage Temperature Range
-10 to +60℃
Operating Humidity Range (Note 3)
20 to 80%
Storage Humidity Range
40 to 70%
250V AC/DC
Item
Specification
Condition
Insulation Resistance
1000M Ω Min.
500V DC
Withstanding Voltage
No flashover or insulation breakdown.
1000V AC for 1 min.
Contact Resistance
10m Ω Max.
Measured at a maximum of 20mV, 1mA (DC or
1000Hz)
Insertion/Extraction Force
Insertion force : 4.4N Max.
Extraction force : 0.4N Min.
Measure at the square steel pin of 0.635 ±
0.002mm
Vibration
No electrical discontinuity of 10μ s or more
10 cycles in each of three axis at frequency
10-55Hz,
half amplitude 0.75mm
Humidity (Steady State)
Contact resistance : 10m Ω Max.
Insulation resistance : 1000M Ω Min.
96 hours at temperature of 40 ± 2℃ and
humidity of 90% to 95%
Temperature Cycle
(-55℃ : 30 minutes → 5 to 35℃ : 2 to 3 minutes
-85℃ : 30 minutes → 5 to 35℃ : 2 to 3 minutes)
5 cycles
Mating Durability
Tin plating : Contact resistance : 30m Ω Max.
Gold plating : Contact resistance : 20m Ω Max.
Tin plating : 30 cycles
Gold plating : 50 cycles
Resistance to Soldering
Heat
No deformation of components affecting
performance.
Flow : 250℃ for 5 seconds
Note 1 :
Note 2 :
Note 3 :
Note 4 :
Manual soldering : 300℃ for 2 seconds
The rated current varies based on the cable size for use. The rated current of the header only is 3A.
Includes temperature rise caused by current flow.
The connector should be completely dry (no condensation present).
Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and
specifications for a specific part number shown.
Materials / Finish
Product
Part
Material
Finish
Remarks
Crimp Socket
Insulator
Polyamide
Black
UL94V-2
Socket Crimp Contact
Contact
Phosphor Bronze
Tin Plated or Gold Plated
Insulator
Polyamide
Black
UL94V-2
Contact
Brass
Pin Header
3
RoHS
〇
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
■ Connector
HNC2 - 2.5 P - # DSL
❶
❷
❸
❹
❺
❶
Series Name
HNC2, 1
❹
Number of
Contacts
2 to 5, 7, 8, 10, 12, 15
❷
Contact Pitch
2.5mm
❺
Contact Type
❸
Connector Type
S : Socket
P : Pin Header
None : Crimp Socket
DS : Straight
DSL : Right Angle
❸
Applicable Cable
Size
A : 22-26 AWG
B : 26-30 AWG
■ Contact
HNC - 2.5S - C - A
❶
❷
❸
❶
Type
2.5mm Pitch Socket
❷
Packaging Type
C : Reel
D : Bag
4
Crimp Socket
[Fig.1] [Fig.2]
Contact No.1
Contact No.1
Unit : mm
Part No.
HRS No.
No. of Pos.
A
B
C
Dimensions
HNC2-2.5S-2
CL0218-0011-1-00
2
12.4
6.0
2.5
HNC2-2.5S-3
CL0218-0022-8-00
3
14.9
8.5
5.0
HNC2-2.5S-4
CL0218-0039-0-00
4
17.4
11.0
7.5
HNC2-2.5S-5
CL0218-0027-1-00
5
19.9
13.5
10.0
HNC2-2.5S-7
CL0218-0030-6-00
7
24.9
18.5
15.0
HNC2-2.5S-8
CL0218-0014-0-00
8
27.4
21.0
17.5
HNC2-2.5S-10
CL0218-0017-8-00
10
32.4
26.0
22.5
HNC1-2.5S-12
CL0218-0008-7-00
12
37.0
31.0
27.5
Fig.2
HNC2-2.5S-15
CL0218-0045-3-00
15
44.9
38.5
35.0
Fig.1
Note : The series name for the 12 position connector is HNC1 and varies slightly in design.
5
Purchase Unit
Fig.1
100pcs per bag
Straight Pin Header
[Fig.3] [Fig.4]
Contact No.1
Contact No.1
0.1
Note : Board Through-hole Diameter : φ 1.1 +
Unit : mm
Specific No.
Part No.
HRS No.
No. of Pos.
A
B
C
HNC2-2.5P-2DS(##)
CL0218-0012-4-##
2
12.5
7.8
2.5
55
02
HNC2-2.5P-3DS(##)
CL0218-0023-0-##
3
15.0
10.4
5.0
55
02
HNC2-2.5P-4DS(##)
CL0218-0040-0-##
4
17.5
12.9
7.5
55
01
HNC2-2.5P-5DS(##)
CL0218-0028-4-##
5
20.0
15.4
10.0
55
02
HNC2-2.5P-7DS(##)
CL0218-0031-9-##
7
25.0
20.4
15.0
55
02
HNC2-2.5P-8DS(##)
CL0218-0015-2-##
8
27.5
22.8
17.5
55
02
HNC2-2.5P-10DS(##)
CL0218-0018-0-##
10
32.5
27.8
22.5
55
02
HNC1-2.5P-12DS(##)
CL0218-0009-0-##
12
35.5
32.8
27.5
55
02
Fig.4
HNC2-2.5P-15DS(##)
CL0218-0046-6-##
15
45.0
40.4
35.0
55
01
Fig.3
6
Tin
Gold Dimensions Purchase Unit
Plating Plating
Fig.3
100pcs per bag
Right Angle Pin Header
[Fig.5] [Fig.6]
Contact No.1
Contact No.1
0.1
Unit : mm
Specific No.
Part No.
HRS No.
No. of
Pos.
A
B
C
Tin
Plating
HNC2-2.5P-2DSL(##)
CL0218-0013-7-##
2
12.5
7.8
2.5
55
02
HNC2-2.5P-3DSL(##)
CL0218-0024-3-##
3
15.0
10.4
5.0
55
02
HNC2-2.5P-4DSL(##)
CL0218-0041-2-##
4
17.5
12.9
7.5
55
01
HNC2-2.5P-5DSL(##)
CL0218-0029-7-##
5
20.0
15.4
10.0
55
02
HNC2-2.5P-7DSL(##)
CL0218-0032-1-##
7
25.0
20.4
15.0
55
02
HNC2-2.5P-8DSL(##)
CL0218-0016-5-##
8
27.5
22.8
17.5
55
02
HNC2-2.5P-10DSL(##)
CL0218-0019-3-##
10
32.5
27.8
22.5
55
02
HNC1-2.5P-12DSL(##)
CL0218-0010-9-##
12
35.5
32.8
27.5
55
02
Fig.6
HNC2-2.5P-15DSL(##)
CL0218-0047-9-##
15
45.0
40.4
35.0
55
01
Fig.5
7
Gold Dimensions
Plating
Purchase
Unit
Fig.5
100pcs per
bag
Unit : mm
Part No.
A
B
1.8
2.6
1.5
1.7
HNC-2.5S-C-A(15)
HNC-2.5S-C-A(02)
HNC-2.5S-D-A(15)
HNC-2.5S-D-A(02)
HNC-2.5S-C-B(15)
HNC-2.5S-C-B(02)
HNC-2.5S-D-B(15)
HNC-2.5S-D-B(02)
● Reel
Contact (Applicable Tool : Applicator)
Part No.
HRS No.
Finish
HNC-2.5S-C-A(15)
HNC-2.5S-C-A(02)
CL0218-0021-5-15
CL0218-0021-5-02
Tin Plated
Gold Plated
HNC-2.5S-C-B(15)
HNC-2.5S-C-B(02)
● Loose
CL0218-0020-2-15
CL0218-0020-2-02
Tin Plated
Gold Plated
Applicable Wire(Tin Plated Annealing Copper Wire) (Note 2)
UL
AWG Wire Construction Sectional Area Jacket Diameter
1007
22
24
26
17/0.16mm
11/0.16mm
7/0.16mm
0.342mm2
0.221mm2
0.141mm2
1.35 to 1.7mm
1061,1007
26
28
30
7/0.16mm
7/0.127mm
7/0.1mm
0.141mm2
0.089mm2
0.055mm2
1.0 to 1.35mm
Purchase Unit
10,000pcs per reel
Contact (Applicable Tool : Manual Crimping Tool)
Part No.
HRS No.
Finish
HNC-2.5S-D-A(15)
HNC-2.5S-D-A(02)
CL0218-0037-5-15
CL0218-0037-5-02
Tin Plated
Gold Plated
HNC-2.5S-D-B(15)
HNC-2.5S-D-B(02)
CL0218-0038-8-15
CL0218-0038-8-02
Tin Plated
Gold Plated
UL
1007
22
24
26
17/0.16mm
11/0.16mm
7/0.16mm
0.342mm2
0.221mm2
0.141mm2
1.6mm
1.5mm
1.3mm
1007
26
28
30
7/0.16mm
7/0.127mm
7/0.1mm
0.141mm2
0.089mm2
0.055mm2
1.3mm
1.2mm
1.1mm
Note : Please consult with a Hirose representative when using wires other than those specified.
Mated Diagram
8
Purchase Unit
100pcs
per bag
Applicable Crimping Tool
Type
Part No.
HRS No.
Applicable Contact
Applicator
AP105-HNC
CL0901-4502-0-00
HNC-2.5S-C-A(15)、 HNC-2.5S-C-A(02)
HNC-2.5S-C-B(15)、 HNC-2.5S-C-B(02)
Press Main Unit
CM-105C
CL0901-0001-0-00
TC-HNC-B
CL0250-0005-7-00
HNC-2.5S-D-B(15)、 HNC-2.5S-D-B(02)
TC-HNC-A
CL0250-0006-0-00
HNC-2.5S-D-A(15)、 HNC-2.5S-D-A(02)
Extraction Tool
Flat-blade screwdriver (thickness < 0.75mm)
Note 1 : Please conduct crimping work according to the "Crimping Quality Standard" (ETAD-H0980-00)" and "Crimping Condition Table".
Note 2 : Issues with non-Hirose specified tools are outside the scope of warranty.
Note 3 : When non-authorized tools are used, please consult with Hirose sales representative about provision of the drawing of the crimping tool.
9
Crimping
■Items Required Prior to Starting
The work- related documents listed below are required before starting harness assembly.
The ● mark indicates a required document.
When the documents shown below are not available, ask a Hirose sales personnel to provide them.
Description
Automatic
Crimping
Machine
Hand
Crimping
Tool
1. Crimping Machine Main
Unit Instruction Manual
Explanation of main press machine unit
2. Applicator Instruction
Manual
Crimp Method
3. Applicator Spare Parts
List
Explanation for Applicator Installation
4. Crimp Conditions
Standard crimp height and tensile
strength values
5. Crimp Quality Standards
Various standards for crimping
conditions
6. Operating Instructions for
Hand Tool
Crimping method, standard crimp height
and tensile strength values
Bundled with purchase of
hand tool.
7 .Cable Assembly
Procedure
Cable Assembly Procedure
Ask a Hirose sales personnel
to provide them.
Document Title
Remarks
main press machine unit.
applicator.
■Tools
The tools specified by Hirose should be used for crimping work.
Crimping work by tools other than those specified must not be done because it may result in contact failure,
disconnection of cable, etc.
* The operating instructions manual is available for the crimping machine and the applicator.
Be sure to carefully read the operating instructions manual before implementing the work.
■Applicable Electric Wires
Check that the electric wire to be used is within the applicable range.
If you intend to use an electric wire other than those recommended, ask a HRS sales personnel.
[ Precautions]
・Electric wires that are suitable for crimping connectors are tin- plated stranded softcopper wire.
・Avoid crimping solid wires, wires with polyester threads or tin- coated wires.
・Avoid crimping two electric wires together.
・The crimp height setting value ( Note) may vary between tin- plated and gold- plated contacts even if the
same electric wires are used.
・The crimp height setting value ( Note) may vary depending on the difference in the core wire configuration even if the
computed cross- sectional area is the same.
Note : The crimp height is an important item that determines crimping quality. We execute crimping tests for
each electric wire to ensure the optimal value for the crimp height with high precision, thereby ensuring
optimal setup values.
10
Handling Precautions
1. Cleaning Conditions
Please refer to the " Wire- to- Board Connector Guide" .
2. Handling Instructions
Please refer to the following documents.
■ Crimp Quality Standard ( ETAD- H0980- 00)
■ Wire- to- Board Connector Guide
While Taking into Consideration
Specifications mentioned in this catalog are reference values.
When considering to order or use this product, please confirm the Drawing and Product Specifications sheets.
Use an appropriate cable when using the connector in combination with cables.
If considering usage of a non- specified cable, please contact your sales representative.
If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given.
If considering usage for below mentioned applications, please contact your sales representative.
In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public
infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com
※ The contents of this catalog are current as of date of 2/ 2021. Contents are subject to change without notice for the purpose of improvements.
11
