NRPN254RCCN-RC
NRPN254RCCN-RC
    SULLINS
    CONN HEADER VERT 100POS 2MM
NRPN254RCCN-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO C 1811 D 2828 DESCRIPTION DATE UPDATE VIEWS, POSI. CHART, TOLERANCE, ADD 1/15/2009 PCB LAYOUT UPDATE PROCESSING TEMPERATURE FOR NYLON 6T 04/09/2015 MATERIAL BY JH LH F F B±.014 [ .35] E E .315 8.00 D A±.010 [ .25] .079±.002 2.00±0.05 D .236±.004 6.00±0.10 .079±.002 2.00±0.05 .020±.002 0.50±0.05 .173 4.40 (REF.) .327±.008 8.30±0.20 .059 1.50 .094±.008 2.40±0.20 C 02-20, 0.20mm MAX. 21-40, 0.30mm MAX. C A±.004 [ .10] .079±.002 2.00±0.05 .031±.002 0.80±0.05 .079±.002 2.00±0.05 B A B .236±.004 6.00±0.10 NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. 2. CONTACT MATERIAL: BRASS. 3. CONTACT PLATING: GOLD FLASH OVERALL. 4. CURRENT RATING: 2 AMPS. 5. INSULATOR RESISTANCE: 1000 MEGOHMS MIN. 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 7. DIELECTRIC WITHSTANDING: AC 500V. 8. OPERATING TEMPERATURE: -40° C TO +105° C. 9. PROCESSING TEMP.: WAVE/MANUAL SOLDERING ONLY. 8 7 6 RECOMMENDED PCB LAYOUT Pb RoHS COMPLIANT 5 4 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] TOLERANCES: ANGULAR: 1 DECIMALS .X= .012 [.30] .XX= .008 [.20] .XXX= .006 [.15] DRAWN DATE NAME 09/20/2006 YCH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER, MALE 2mm CC, 4 ROWS, ST PART NUMBER SIZE C CAGE CODE 54453 SCALE: 8:1 3 2 NRPNxx4RCCN-RC DWG. NO. 10734 SHEET 1 OF 1 1 REV D FILE NAME: 10734, NRPNxx4RCCN-RC A
NRPN254RCCN-RC 价格&库存
很抱歉,暂时无法提供与“NRPN254RCCN-RC”相匹配的价格&库存,您可以联系我们找货
