Additional Resources:
Product Page
3D Model
date
10/14/2019
page
1 of 3
SERIES: MD-PL100 │ DESCRIPTION: MINI DIN CONNECTOR
FEATURES
• panel mount
• 10 cm lead wires
• 3~8 pins
PART NUMBER KEY
MD - XX PL100
Base Number
Pin Options
30 = 3 pins
40 = 4 pins
50 = 5 pins
60 = 6 pins
80 = 8 pins
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
max
30
rated input current
contact resistance
insulation resistance
at 250 Vdc
voltage withstand
for 1 minute
Vdc
1
A
30
mΩ
1,000
MΩ
insertion force
withdrawal force
500
Vac
45
N
9
operating temperature
N
-25
life
85
500
flammability rating
UL94V-0
RoHS
yes
cuidevices.com
units
°C
cycles
Product Page
3D Model
CUI Devices │ SERIES: MD-PL100 │ DESCRIPTION: MINI DIN CONNECTOR
date 10/14/2019 │ page 2 of 3
MECHANICAL DRAWINGS
units: mm
tolerance:
X. ±0.2 mm
X.X ±0.10 mm
X.XX ±0.050 mm
X.XXX ±0.005 mm
MATERIAL
PLATING
body
PBT (UL94V-0)
earth terminal
phosphor bronze
nickel
contact terminals
phosphor bronze
tin
wire
UL 1007/AWG #26
MD-30PL100
MD-40PL100
MD-50PL100
MD-60PL100
MD-80PL100
PIN
Wire Color
Wire Color
Wire Color
Wire Color
Wire Color
1
black
black
brown
brown
brown
2
green
green
black
white
white
3
orange
yellow
green
black
black
red
yellow
green
blue
red
yellow
green
red
yellow
4
5
6
7
orange
8
red
cuidevices.com
Product Page
3D Model
date 10/14/2019 │ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
02/23/2006
1.01
new template applied
03/07/2012
1.02
updated datasheet
08/25/2017
updated housing, brand update
10/14/2019
1.03
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“MD-40PL100”相匹配的价格&库存,您可以联系我们找货
