IO-XLR3-M-BV
IO-XLR3-M-BV
    IO
    IO-XLR3-M-BV
IO-XLR3-M-BV 数据手册
XLR CHASSIS CONNECTORS 3 PIN B SERIES - VERTICAL PCB MOUNT Locking vertical PCB Mount 3 pin chassis connector with plastic body and metal faceplate for audio and lighting control. Other Available Mounting Option: Horizontal PCB Mount SPECIFICATIONS IO-XLR3-M-BV IO-XLR3-F-BV MECHANICAL PRODUCT Lifetime: > 1000 Mating Cycles Gender: Male (IO-XLR3-M-BV) Female (IO-XLR3-F-BV) Contacts: 3 Wiring: Vertical PCB Mount Locking Device: Latch Lock Mounting Direction: Rear ELECTRICAL Capacitance Between Contacts: ≤ 2 pF Solderability: Complies with IEC 60068-2-20 Capacitance Between Contact and Ground: ≤ 2.4 pF MATERIAL Contact Resistance: < 6 mΩ Contacts: Brass Insulation Resistance: ≥ 5000 MΩ Contact Plating: .05μm Au Dielectric Strength: 1500V @ 60s Ground Terminal: Brass Current Rating: 6A / 50V AC Ground Terminal Finish: Nickel Grounding: Separate Ground Pin. Grounds to Panel. Shell: PA Shell Finish: Black ENVIRONMENTAL Push Button: Stainless Steel Standard Compliance: IEC 61076-2-103 UL Flammability: Meets UL 94 HB Temperature Range: -40°C ~ +70° C (-40°F ~ +158°F) Push Button Finish: Nickel Latch: Stainless Steel Latch Finish: Nickel Faceplate Finish: Nickel Product specifications may change without prior notification Io Audio Technologies® is a registered trademark of Knight Electronics, Inc. 10557 Metric Dr. Dallas , TX 75243 | 214-340-0265 | 800-323-2439 | Fax: 214-340-5870 | DRAWINGS IO-XLR3-F-BV IO-XLR3-M-BV Panel Cutout FEATURES & APPLICATIONS B Series XLR chassis connectors offer the most cost-effective solution for design-in applications where the termination method is to a printed circuit board. The small footprint makes this our XLR receptacle with the highest packing density available. These connectors feature a compact, all plastic housing with a nickel plated faceplate. Precision machined, one piece, gold plated contacts are standard to help prolong the useful life of the connectors. They also come with a separate nickel plated ground pin that grounds the connector to the panel. The compact form factor of the these connectors makes them perfect for situations where space saving is a priority or space for a connector is limited. Available in 3 or 5 pin, Male or Female variations with options for vertical or horizontal PCB mounting. PART NUMBER BREAKDOWN: STANDARDS & CLASSIFICATIONS IO-XLR3-M-BV Series Identifier IO-XLR3-M-BV Number of Poles IO-XLR3-M-BV Gender IO-XLR3-M-BV Series Identifier IO-XLR3-M-BV H = Horizontal PCB Mount V = Vertical PCB Mount Product specifications may change without prior notification Io Audio Technologies® is a registered trademark of Knight Electronics, Inc. 10557 Metric Dr. Dallas, TX 75243 | 214-340-0265 | 800-323-2439 | Fax: 214-340-5870 | www.ioaudiotechnologies.com
IO-XLR3-M-BV
物料型号:IO-XLR3-M-BV(公头)和IO-XLR3-F-BV(母头)。
器件简介:这些是带塑料外壳和金属面板的锁定式垂直PCB安装3针底盘连接器,用于音频和照明控制。
引脚分配:3个接触点。
参数特性: - 接触之间的电容:≤ 2 pF - 接触点与地之间的电容:≤ 2.4 pF - 接触电阻:< 6 mΩ - 绝缘电阻:≥ 5000 MΩ - 耐电压:1500V @ 60s - 电流额定值:6A / 50V AC - 接地:单独的接地针,接地到面板
功能详解:这些连接器具有紧凑的全塑料外壳和镀镍面板。标准配置为精密加工的一体式镀金接触点,有助于延长连接器的使用寿命。它们还配有单独的镀镍接地针,将连接器接地到面板。
应用信息:B系列XLR底盘连接器为设计应用提供了最具成本效益的解决方案,其中端接方法是到印刷电路板。小尺寸使其成为我们XLR插座中可用的最高封装密度。这些连接器的紧凑外形使它们非常适合空间节省是优先考虑或连接器空间有限的情况。
封装信息:提供3针或5针,公头或母头变体,有垂直或水平PCB安装的选项。
IO-XLR3-M-BV 价格&库存
很抱歉,暂时无法提供与“IO-XLR3-M-BV”相匹配的价格&库存,您可以联系我们找货
IO-XLR3-M-BV
  • 1+43.132651+5.60711
  • 10+36.6648910+4.76632
  • 25+34.3632025+4.46711
  • 50+32.7227950+4.25386
  • 100+31.15982100+4.05068
  • 250+29.20913250+3.79710
  • 500+27.81553500+3.61593
  • 1000+26.488721000+3.44345
  • 2500+24.832072500+3.22809
库存:130
