Multi-contact Compact Circular Connectors
RM Series
Features
Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
1. Wide variations
The RM Series provides a wide selection of
plug and receptacle types to satisfy various
kinds of application requirements.
Available position counts : 2, 3, 4, 5, 6, 7, 8,
10, 12, 15, and 20.
Available lock mechanisms : threaded
coupling type, bayonet sleeve type, and
quick detachable type.
Product Specifications
[RM15]
Rated current
10A (2 and 4 contacts)
5A (8, 10, and 12 contacts)
[RM12, 21] 5A
[RM12]
Ratings
Rated voltage
[RM15]
[RM21]
Items
AC 600V, DC 840V (2 contacts)
AC 500V, DC 700V (3 and 4 contacts)
AC 350V, DC 490V (5, 6 and 7 contacts)
AC 500V, DC 700V (4 and 8 contacts)
AC 350V, DC 490V (10 and 12 contacts)
AC 500V, DC 700V (15 contacts)
AC 350V, DC 490V (20 contacts)
Specifications
Operating
temperature
range
-25 to +85ç
Storage
temperature
range
-10 to +60ç
Conditions
1. Contact
resistance
[RM12, 21] 4mø max.
[RM15] 4mø max. (8, 10, and 12 contacts)
[RM15] 2mø max. (2 and 4 contacts)
Measured at DC 1A
2. Insulation
resistance
1,000Mø min.
Measured at DC 500V
3. Withstanding
voltage
No flashover or dielectric breakdown.
[RM12] AC 1,800V for 1 minute (2 contacts)
AC 1,500V for 1 minute (3 and 4 contacts)
AC 1,000V for 1 minute (5, 6 and 7 contacts)
[RM15] AC 1,800V for 1 minute (2 contacts)
AC 1,500V for 1 minute (4 and 8 contacts)
AC 1,000V for 1 minute (10 and 12 contacts)
[RM21] AC 1,500V for 1 minute (15 contacts)
AC 1,000V for 1 minute (20 contacts)
4. Vibration
resistance
No electrical discontinuity for 10µs. or greater
10 to 55Hz/cycle, full amplitude : 0.75mm, 3 axis directions,
2 hours each
5. Shock
resistance
Acceleration : 490m/s2, duration : 11ms
3 axis directions, 3 times each
6. Mating cycles
Contact resistance : 8mø max.
7. Temperature
cycle
Insulation resistance : 100Mø min.
8. Moisture
resistance
Insulation resistance : 100Mø min. (when dry)
2,000 times
-55°C : 30 minutes ➝ Normal temperature : 10 to 15 minutes
➝ 85°C : 30 minutes ➝ Normal temperature : 10 to 15
minutes, left for 5 cycles
Temperature : 40°C, relative humidity : 90 to 95%, left for
96 hours
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2018.7⑤
1
RM Series●Multi-contact Compact Circular Connectors
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
Plug
RM 15 T P A - 2 S (**)
q
w
e
r
t
y
u
i
qModel name : RM Series (Round Miniature Series)
wShell size : The shell size refers to the outer shell diameter of the mating interface of the plug.
eLock mechanism
T : Threaded coupling type
B : Bayonet sleeve type
Q : Quick detachable type
rConnector type
(1)
P : Plug
J : Jack
P-C : Plug cap
R-F : Square flange for receptacle
(2)
R : Receptacle
R-C : Receptacle cap
R-B : Cord bushing
tForm variation class : Indicates a variation or change within the series.
yNumber of contacts
uContact form
P : Male contact
S : Female contact
iOther specifications : A two-digit number is added to indicate other specifications.
Materials / Finish
Items
Material
Finish
Remarks
Plated shell
Brass, zinc alloy
Aluminum alloy
Nickel plating
Chromium plating
Insulator
Diallyl phthalate resin
Polycarbonate resin, PPS
UL94V-0
(Black)
Contact
Brass or copper alloy
Silver plating
Please note that materials will differ depending on the actual part number.
2
RM12B connectors (bayonet sleeve type)
Plug
Cable clamp range:
5mm min. to 8mm max.
Ø8
(Representative example.)
No. of contacts
Part No.
RM12BPE-2S(71)
Part No.
109-0423-0 71
HRS No.
2
RM12BPE-2PH(71)
109-0417-7 71
HRS No.
No. of contacts
2
RM12BPE-3S(71)
109-0424-2 71
3
RM12BPE-3PH(71)
109-0418-0 71
3
RM12BPE-4S(71)
109-0425-5 71
4
RM12BPE-4PH(71)
109-0419-2 71
4
RM12BPE-5S(71)
109-0426-8 71
5
RM12BPE-5PH(71)
109-0420-1 71
5
RM12BPE-6S(81)
109-0427-0 81
6
RM12BPE-6PH(71)
109-0421-4 71
6
RM12BPE-7S(71)
109-0428-3 71
7
RM12BPE-7PH(71)
109-0422-7 71
7
Receptacle (Jam nut to be fastened)
A
17(HEX)
19.6
2
2
Ø14.1
7
Ø17
1.5
6.9
1
6
1
1
Ø 11.9
2
Ø 18
41
M14×0.75
Part No.
HRS No.
No. of contacts
HRS No.
No. of contacts
RM12BRD-2PH(71)
109-0823-8 71
2
A
RM12BRD-2S(71)
109-0609-8 71
2
RM12BRD-3PH(71)
109-0824-0 71
3
RM12BRD-3S(71)
109-0610-7 71
3
RM12BRD-4PH(71)
109-0825-3 71
4
RM12BRD-4S(71)
109-0611-0 71
4
RM12BRD-5PH(71)
109-0826-6 71
5
RM12BRD-5S(71)
109-0612-2 71
5
RM12BRD-6PH(71)
109-0827-9 71
6
RM12BRD-6S(81)
109-0613-5 81
6
RM12BRD-7PH(71)
109-0828-1 71
7
RM12BRD-7S(71)
109-0619-1 71
7
20.5
Part No.
A
21.6
Remarks : See page 12 for details on recommended panel cut-out.
3
Receptacle (Integral, square flange)
A
21
2.
9
-Ø
Ø14.1
1 2
16
21
4.5
Ø14.1
9
4
16
1.5
Part No.
HRS No.
RM12BRB-2S
109-0577-3
No. of contacts
2
A
RM12BRB-2PH
Part No.
109-0817-5
2
RM12BRB-3S
109-0578-6
3
RM12BRB-3PH
109-0818-8
3
RM12BRB-4S
109-0579-9
4
RM12BRB-4PH
109-0819-0
4
RM12BRB-5S
109-0580-8
5
RM12BRB-5PH
109-0820-0
5
RM12BRB-6S(81)
109-0581-0 81
6
RM12BRB-6PH
109-0821-2
6
RM12BRB-7S
109-0615-0
7
RM12BRB-7PH
109-0822-5
7
21.6
HRS No.
No. of contacts
A
20.5
Remarks : 1. See page 12 for details on recommended panel cut-out.
2. Please note that the RM12BRB differs in mounting dimensions from the RM12BR-F.
Jack
40
Cable clamp range:
2
Ø8
1
16
A maximum of 0.6mm
Ø 14.1
7
Part No.
4
HRS No.
No. of contacts
Part No.
HRS No.
RM12BJB-2S(07)
109-0638-6 07
RM12BJB-3S(07)
RM12BJB-4S(07)
No. of contacts
2
RM12BJB-2PH
109-0829-4
2
109-0639-9 07
3
RM12BJB-3PH
109-0830-3
3
109-0640-8 07
4
RM12BJB-4PH
109-0831-6
4
RM12BJB-5S(07)
109-0641-0 07
5
RM12BJB-5PH
109-0832-9
5
RM12BJB-6S(81)
109-0642-3 81
6
RM12BJB-6PH
109-0833-1
6
RM12BJB-7S(07)
109-0643-6 07
7
RM12BJB-7PH
109-0834-4
7
RM15Q connectors (quick detachable type)
Plug
Cable clamp range:
Ø 11.5
Ø 15.2
2
3
Ø 23
1
4
HRS No.
No. of contacts
HRS No.
No. of contacts
RM15QPS-2SA(71)
Part No.
109-0839-8 71
2
RM15QPS-2PA(71)
Part No.
109-0896-1 71
2
RM15QPS-4SA(81)
109-0840-7 81
4
RM15QPS-4PA(71)
109-0897-4 71
4
RM15QPS-8S(71)
109-0852-6 71
8
RM15QPS-8PH(71)
109-0850-0 71
8
RM15QPS-10S(71)
109-0853-9 71
10
RM15QPS-10PH(71)
109-0851-3 71
10
RM15QPS-12S(71)
109-0981-9 71
12
RM15QPS-12PH(71)
109-0980-6 71
12
A
21 (HEX)
7.6
1.5
6.5
7
Ø20
Ø17.4
4 1
3
3
M17×0.75
1 4
24.2
2
2
36.5
0.5
3
Part No.
HRS No.
No. of contacts
RM15QRD-2PA(71)
109-0880-1 71
2
RM15QRD-4PA(71)
109-0881-4 71
4
RM15QRD-8PH(71)
109-0854-1 71
8
RM15QRD-10PH(71) 109-0855-4 71
10
RM15QRD-12PH(71) 109-0982-1 71
12
A
21.0
20.6
Part No.
HRS No.
No. of contacts
RM15QRD-2SA(71)
109-0841-0 71
2
RM15QRD-4SA(81)
109-0842-2 81
4
RM15QRD-8S(71)
109-0864-5 71
8
RM15QRD-10S(71)
109-0779-8 71
10
RM15QRD-12S(71)
109-0983-4 71
12
A
21.7
21.6
5
RM [ ] T connectors (threaded coupling type)
Plug
B
Part No.
HRS No.
RM15TP-2SA(71)
109-0845-0 71
RM15TP-2PA(71)
109-0898-7 71
RM15TP-4SA(81)
109-0846-3 81
RM15TP-4PA(71)
109-0899-0 71
RM15TP-8S(71)
109-0053-2 71
RM15TP-8PH(71)
109-0856-7 71
RM15TP-10S(71)
109-0055-8 71
RM15TP-10PH(71)
109-0857-0 71
RM21TP-15S(81)
109-0321-0 81
RM21TP-15P(71)
109-0323-5 71
RM21TP-20S(81)
109-0322-2 81
RM21TP-20P(71)
109-0324-8 71
No. of contacts
ØA
B
ØC
ØD
L
15.2
M19×1
11.5
21.5
34
21
TM25×2
15
28
37
2
4
8
10
15
Remarks : TM25x2 represents 30° trapezoidal thread profile.
A
1.5
21(HEX)
6.5
7
M19×1
Ø20
24.2
7.6
3
0.5
M17×0.75
Part No.
HRS No.
RM15TRH-2PA(71)
109-0886-8 71
RM15TRH-2SA(71)
109-0847-6 71
RM15TRH-4SA(81)
109-0848-9 81
RM15TRH-4PA(71)
109-0887-0 71
RM15TRH-8PH(71)
109-0858-2 71
RM15TRH-8S(71)
109-0868-6 71
RM15TRH-10PH(71)
109-0859-5 71
RM15TRH-10S(71)
109-0869-9 71
No. of contacts
2
4
8
10
6
A
21
21.7
21
20.6
21.6
20.6
21.6
(Maximum cord diameter)
ØC
ØA
ØD
L
21
2.5
D
6.5 B
φA
6
C
Part No.
HRS No.
RM21TR-15S(81)
109-0327-6 81
RM21TR-15P(71)
109-0325-0 71
RM21TR-20S(81)
109-0328-9 81
RM21TR-20P(71)
109-0326-3 71
No. of contacts
ØA
B
C
D
27
TM25×2
M22×0.75
23.5
15
Remarks : 1. TM25x2 represents 30° trapezoidal thread profile.
2. See page 12 for details on recommended panel cut-out.
7
RM15T (type D) connectors
Plug (solder type)
50
3
10
5
Ø23
2
6
Ø15
8 1
9
7
Ø9.8
TM20×2
4
Part No.
HRS No.
RM15TPD-10P(71)
109-0601-6 71
RM15TPD-10S(71)
109-0686-9 71
RM15TPD-12P(71)
109-0660-5 71
RM15TPD-12S(71)
109-0661-8 71
No. of contacts
10
12
Jack (solder type)
49
Ø21
2
3
10
5
Ø9.8
8 1
7
6
4
TM20×2
Part No.
HRS No.
RM15TJD-10P(71)
109-0706-4 71
RM15TJD-10S(71)
109-0603-1 71
RM15TJD-12P(71)
109-0715-5 71
RM15TJD-12S(71)
109-0665-9 71
No. of contacts
10
12
Receptacle (solder type)
A
9
TM20×2
1
8
5
7
2
6
3
7.6
M17×0.75
Part No.
HRS No.
RM15TRD-10P(71)
109-0687-1 71
RM15TRD-10S(71)
109-0602-9 71
RM15TRD-12P(71)
109-0662-0 71
RM15TRD-12S(71)
109-0663-3 71
No. of contacts
10
12
A
20.5
21.3
20.5
21.3
8
9
10
1
10
5
9
8
4
6
2
7
3
6
4
21
(HEX)
24.2
Plug (crimp type)
A
B
TM20×2
4
ØC
6
Ø15
7
9
10
3
Ø23
8
1
2
5
Part No.
HRS No.
RM15TPD-10PC(71)
109-0677-8 71
RM15TPN-10PC(71)
109-0712-7 71
No. of contacts
10
A
B
ØC
50
40
15
8
Receptacle (crimp type)
9
TM20×2
6
7
21
(HEX)
19.5
6
5
8
9
10
1
4
2
3
M17×0.75
Part No.
RM15TRD-10SC(71)
HRS No.
109-0676-5 71
No. of contacts
10
Receptacle (dip type)
A
TM20×2
Mating guide
21
(HEX)
19.5
6
9
6
7
5
8
9
10
1
4
2
3
B
M17×0.75
Dip post arrangement dimensions when
viewed from the mating end
Mating guide position
1.5
Dip post diameter
Ø0.8
HRS No.
No. of contacts
A
B
4
8
Part No.
6
109-0710-1 71
10
32.3
8.3
1.5
RM15TRD-10SB(71)
1
9
7
4
2
3
10
4
5
2
4
2
4
9
RM Series accessories
Cap
Plug cap
100
Ø6
D
C
φ3.3
Part No.
RM15TP-C(71)
RM21TP-C(71)
HRS No.
109-0079-6 71
109-0353-6 71
ØA
21.5
28
B
M19X1
TM25X2
C
12
17.5
D
16.5
22
B
ØA
Receptacle cap
100
Ø6
D
C
Ø 3.3
B
Part No.
RM15TR-C(31)
RM21TR-C(31)
HRS No.
109-0080-5 31
109-0354-9 31
ØA
21.5
28
B
M19X1
TM25X2
C
9
8
D
13.5
12.5
ØA
Square flange
B
ØA
C
D
D
C
Part No.
HRS No.
ØA
B
C
D
RM12BR-F(71)
109-0154-0 71
14.1
6
18
26
RM15TR-F(71)
109-0319-8 71
17.1
7.6
20.6
28
Cord bushing
Part No.
RM12BPG-B(71)
10
HRS No.
109-0776-0 71
Ø8
Ø6.4
Ø10.7
31
Remarks
Contact
Male contact
A-A
B
C
1.4
A
16.7
A
Type
Loose piece
contacts
Reel
contacts
Part No.
RM-PC-112
RM-PC-122
RM-PC-212
RM-PC-222
HRS No.
109-0668-7
109-0672-4
109-0670-9
109-0674-0
B
1.6
1.45
1.6
1.45
C
2.0
1.5
2.0
1.5
Applicable wire size
20 to 24 AWG
24 to 28 AWG
20 to 24 AWG
24 to 28 AWG
Part No.
RM-SC-112
RM-SC-122
RM-SC-212
RM-SC-222
HRS No.
109-0669-0
109-0673-7
109-0671-1
109-0675-2
B
1.6
1.45
1.6
1.45
C
2.0
1.5
2.0
1.5
20 to 24 AWG
24 to 28 AWG
20 to 24 AWG
24 to 28 AWG
Female contact
A-A
B
C
1.4
A
A
17
Type
Loose piece
contacts
Reel
contacts
Note : Loose piece contacts are available in 100 pcs/pack. Reel contacts are available in 8,000 pcs/reel.
Applicable tools
Type
Items
Manual
Manual crimping
tool
Automatic crimping
press
Automatic
Part No.
HRS No.
HT802/RM-11
150-0401-6
HT802/RM-12
150-0402-9
CM-105C
901-0001-0
AP-105-RM-1
901-2017-4
AP-105-RM-2
901-2018-7
RM-TP
150-0008-7
Applicator
Extraction tool
Manual crimping tool
Applicable contact
RM-PC-112
RM-SC-112
RM-PC-122
RM-SC-122
RM-PC-212
RM-SC-212
RM-PC-222
RM-SC-222
Contact extraction tool
20 to 24 AWG
24 to 28 AWG
20 to 24 AWG
24 to 28 AWG
Automatic crimping
press (Type CM-105C)
How to use the RM15Q connectors (quick detachable type)
1. Insertion
2.Extraction
For smooth mating, while holding the plug tube, match the
guide of the receptacle with the key-way on the plug and
push straight it in as shown in the above figure.
To unmate, hold the locking sleeve and twist it approximately
30 degrees to the left, then pull it straight off as shown in the
above figure.
11
Receptacle-recommended panel cut-out
For square flange type
For jam nut type
Recommended panel cut-out for shell
1.6
sizes 21
ØA
B
C
D
sizes 12 and 15
4×ØE
D
ØA
ØA
Remarks : Use a 0.5 ~ 2 mm thickness panel for all shell sizes.
Mounting met
hod
She
ing m ll size
echa
nism
Lock
12
Sign
BRD
ØA
14.1
B
6.1
---------------------C
---------------------D
---------------------ØE
Remarks : The dimensional tolerance to be +0.1 / 0.
Nut tightening
15
QRD
TRH · TRD
17.1
7.6
Square flange
12
BRB
14.5
------------------------------------------1.6
2.9
21
TR
22.1
---------------------12.65
Contact Position Arrangement and Specifications
Shell size : 12
2
Contact
arrangement
3
1
1
2
No. of contacts
2
Withstanding AC 1,800V for
voltage
one minute
Rated current
Insulation
resistance
Contact
resistance
Inner diameter
of solder pot
3
4
1
3
2
Shell size : 15
5
2
4
8
Contact
arrangement
7
4
6
11
5
4
3
1
10
2
9
8
2
15
11 3
12 4
14
13
7
5
6
1
2
7
7
1
3
2
5A
1,000Mø min.
1,000Mø min.
4mø max.
2mø max.
Ø1.1mm
Ø1.7mm
AC 1,000V for one minute
Shell size : 21
1
10
9 17 18 11 2
19
8
3
16
12
7
20 13
15
4
6 14 5
No. of contacts
8
10
12
Withstanding AC 1,500V for
AC
1,000V
for
one
minute
voltage
one minute
Rated current
5A
Insulation
1,000Mø
min.
resistance
Contact
4mø max.
resistance
Inner diameter
Ø1.1mm
of solder pot
1
10
9
8
2
15
11 3
12 4
14
13
7
5
6
1
10
9 17 18 11 2
19
8
3
16
12
7
20 13
15
4
6 14 5
15
AC 1,500V for AC 1,000V for
one minute
one minute
5A
1,000Mø min.
4mø max.
Ø1.1mm
Remarks
1. The above figures show contact arrangements viewed from the mating end of the connectors with female contacts.
2. The "▼" marks shown in the above figures represent the position of the receptacle mating guide.
3. Withstanding voltages are shown as test voltages.
12
4
1
3
4
5
2
2
4
AC 1,800V for AC 1,500V for
one minute
one minute
10A
AC 1,500V for one minute
1
12 10
5
3
Shell size : 15
9
6
1
Precautions
Powered by TCPDF (www.tcpdf.org)
1. Be sure the power is off before mating/unmating a connector.
2. Be sure to use a connector with female contacts for the power side of the circuit.
3. Be sure to engage the lock mechanism on the connectors.
4. Regarding plugs and jacks : the forces from cable clamping, cable rotation, and other forces may vary with the cable
construction. Please make sure that your cable is suitable for use with these connectors before usage and production.
5. This product series uses silver plated contacts. Silver reacts easily to exposure to sulfur gas so the below conditions may
cause tarnishing.
・Dusty environments
・Area with a high concentration area of gases such as sulfur dioxide gas, hydrogen sulfide gas, nitrogen dioxide gas
and so on.
Example; In close proximity to factory exhaust, automotive emissions, etc.
・Close to heaters, or in other areas marked by extreme temperature differences or high humidity.
・Close to rubber products includes rubber adhesives.
The Electrical connection is not affected by tarnishing on a silver surface due to the wiping effect of the contact pins.
Storage
Packing state; Packed in original packing or equivalent container
Temperature -10 to +60°C
Humidity
85% Max
(It is recommended that the product be stored in an area of normal level of temperature and humidity, and free of any
temperature fluctuation)
Please use this products within 6 months of delivery.
(After 6 month, please check the solderbility before use)
“Storage” means long-term storage of the unused products in sealed packaging, prior to assembly to PCB.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 07/2018. Contents are subject to change without notice for the purpose of improvements.
13
