HA16R-3P(76)
HA16R-3P(76)
    HRS(广濑)
    CONN RCPT MALE 3P SILV SLDR CUP
HA16R-3P(76) 数据手册
Circular Connectors for Audio Equipment HA Series Features 1.Circular connectors with lock mechanism for audio equipment Sep.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Dec.1.2021 Additional grounding feature prevents external noise. This series includes four different receptacle s i ze s a n d t wo t y p e s o f c a bl e c l a m p i n g mechanisms used on the plugs. Receptacle selection will depend on your particular design and available mounting space. Product Specifications No. of contacts Ratings Rated voltage 3 5 2. Insulation resistance 3. Withstanding voltage 5A 4A Items 1. Contact resistance 15A 3 A (PCB dip type) Specifications t d 3 and 4 contacts: 5 mø max. 3 contacts (PCB dip type), 5 contacts: 10 mø min. e l u 1,000 Mø min. n i t n Storage temperature range -25 to +70℃ -10 to +60℃ o c s i d e b o AC130V, DC180V 4 Rated current d e u Operation temperature range Conditions Measured at DC 1 A Measured at DC 500 V No flashover or dielectric breakdown. AC 1,400 V for one minute 4. Vibration resistance No electrical discontinuity for 10 µs or greater 10 to 55 Hz/cycle, amplitude: 0.75 mm, in 3 axis directions, for 2 hours each direction 5.Shock resistance No electrical discontinuity for 10 µs or greater Acceleration: 490 m/s2, duration: 11 ms, 3 axis directions, 3 cycles each direction 6. Mating Cycles 3 and 4 contacts: a maximum of 10 mø 3 contacts (PCB dip style) 5 contacts: 20 mø max. 1,000 times d e h c S 7. Temperature cycle Insulation resistance: 1,000 Mø max. 8. Moisture resistance -55°C: 30 minutes ➝ Normal temperature: 10 to 15 minutes ➝ 85°C: 30 minutes ➝ Normal temperature: 10 to 15 minutes, left for 5 cycles Insulation resistance: 10 Mø (at high humidity) min. Temperature: 40°C, relative humidity: 90 to 95%, 100 Mø (when dry) min. left for 96 hours Materials Parts Material Finish Remarks Shell Aluminum alloy or zinc alloy Matte finished, nickel plating ―――― Insulator Polyamide resin or PBT resin ―――― UL94V-0 Contact Copper alloy Silver plating ―――― In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2014.11w 1 HA Series●Circular Connectors for Audio Equipment Ordering information Plug and receptacle HA 16 PR N - 3 S F - A (**) q w e r t y u i o qModel name: HA Series wShell size: Shell size is the outer diameter of the mating interface of the plug. eConnector shape: P: Plug R: Receptacle PR: Plug receptacle J: Jack Sep.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Dec.1.2021 rShell variation: A, B, C, etc. is used to note exterior shell changes. tNumber of contacts yContact form: P: Male contact S: Female contact n i t n d e u uContact termination method or shape: A, B, C, etc. is used to note any changes to the termination method or type. iGang type: Notes a ganged arrangement of receptacles. o c is oOther specifications: A two-digit number is added to indicate other specifications. d e h c S 2 e l u t d d e b o HA Series●Circular Connectors for Audio Equipment Plug B ØA Ø19 Ø16 Guide key (Representative example) HRS No. No. of contacts ØA B 104-0359-0 71 HA16PA-3S(71) 3 4.5 86 104-0426-6 71 HA16PK-4S(71) 4 6 78 Weight Remarks 50g ------------------- A B Ø19 Ø5.2 d e u 104-0701-9 71 HA216P-3S(71) 3 n i t n 104-0702-1 71 HA216P-4S(71) 4 77.7 52.7 104-0703-4 71 HA216P-5S(71) 5 78.5 53.5 (Representative example) HRS No. e l u HA16JA-3P(76) 2 3 B Weight Remarks 78.5 53.5 ---------40g ------------------- 73 Guide Notch 1 A ØA d e h c S d e b o t d Jack No. of contacts Ø19 HA216P-4S(71) o c is Part No. (Representative example) HRS No. 104-0358-8 76 Part No. No. of contacts ØA 3 4.5 40g No. of contacts Weight HA16JA-3P(76) Weight Remarks ---------- 72 Ø5.2 47 Ø19 Sep.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Dec.1.2021 HA16PA-3S(71) Part No. (Representative example) HA216J-4P(76) HRS No. Part No. 104-0704-7 76 HA216J-3P(76) 3 104-0705-0 76 HA216J-4P(76) 4 104-0706-2 76 HA216J-5P(76) 5 Remarks ---------- 40g ------------------- 3 HA Series●Circular Connectors for Audio Equipment Receptacle (Solder Type) (Large Flange Type) 22.5 Ground lug 26.95 37 1 27 19 Guide Notch 2 3 (Representative example) HRS No. HA16R-3P(76) Part No. Sep.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Dec.1.2021 104-0349-7 76 No. of Weight contacts HA16R-3P(76) 3 Remarks 13g ---------- (Medium Flange Type) Ground lug 3 25 18 1 2 n i t n 2.5 21.5 27.1 23 30 o c s d e u (Representative example) HRS No. HA16RD-3P(76) 3 HA16RD-4P(76) 4 ---------- Ground lug 2 HA16RA-3P(76) ---------- 14g 3 e l u Remarks 1 d e h c S e b o 104-0393-9 76 t d (Small Flange Type) di No. of Weight contacts 104-0402-8 76 22.2 16 HA16RD-3P(76) Part No. 2.5 18 21.5 27 24 (Representative example) HRS No. Part No. No. of Weight contacts 104-0382-2 76 HA16RA-3P(76) 3 104-0408-4 76 HA16RA-4P(76) 4 104-0383-5 76 HA16RA-5P(76) 5 Remarks ---------- 11g ------------------- Receptacle (Solder Type) (Inside Mount Type) HRS No. 104-0431-6 76 4 2 19.5 25.1 21.6 28 Part No. HA16RM-3P(76) 21.5 Ø21.5 15.6 2 HA16RM-3P(76) 3 2×M2.6×0.45 1 22.4 Ground lug No. of Weight contacts 3 14g Remarks ---------- HA Series●Circular Connectors for Audio Equipment Receptacle (PCB Through Hole Type) (Inside Mount Type, Straight Dip) 2 21.5 Ø21.5 3 15.6 1 22.4 3ר0.8 Dip post dia. 1×0.8×0.6(Ground) Dip post dia. 2 21.6 2×M2.6×0.45 19.5 22.8 28 5 (Representative example) Part No. 104-0420-0 76 HA16RM-3PE(76) 3 Remarks 14g ---------- 2 d e u 21.5 22.4 15.6 3 n i t n 2 19.5 21.6 2×M2.6×0.45 2.54 Ø21.5 A 3.1 (Inside Mount Type, Right Angle Dip) 1 28 o c s 3ר0.8 Dip post dia. 1×0.8×0.6(Ground) Dip post dia. (The above shapes are examples. The left bend type is shown in this figure.) HRS No. Part No. di No. of contacts 104-0416-2 76 HA16RM-3PB(76) HA16RM-3PB(76) e b o 104-0418-8 76 HA16RM-3PD(76) 23.2 3 14g 25.8 Remarks Dip post down bent Dip post left bent Ground lug 18 25 PUSH 1 HA16PRH-3S HA16PRK-4S 2 h c S ed e l u Weight 4 t d Plug-Receptacle (Solder Type) (Small Flange Type) A 3 2.4 23 30 27 32 37.2 42.7 4 (Representative example) HRS No. No. of Weight contacts Part No. 104-0395-4 HA16PRH-3S 3 104-0403-0 HA16PRH-4S 4 104-0404-3 HA16PRH-5S 5 104-0411-9 HA16PRK-3S 3 104-0427-9 HA16PRK-4S 4 Remarks Without ground lug 26g With ground lug Plug-Receptacle (Solder Type) (Inside Mount Type) 1 21.5 PUSH 3 21.6 28 31.5 Ø21.5 2 2×M2.6×0.45 15.6 29.6 22.4 Sep.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Dec.1.2021 No. of Weight contacts HRS No. HA16RM-3PE(76) 2 21.8 22.8 5.8 Ground lug (Representative example) HA16PRM-3S(05) HRS No. 104-0432-9 05 Part No. HA16PRM-3S(05) No. of Weight contacts 3 18g Remarks ---------- 5 HA Series●Circular Connectors for Audio Equipment Plug-Receptacle (PCB Through Hole Type) (Inside Mount Type, Straight Dip) 21.5 1 HRS No. 2 21.8 22.8 5.8 Part No. 104-0421-2 71 Sep.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Dec.1.2021 PUSH 3 22.4 15.6 2 21.6 28 31.5 2×M2.6×0.45 HA16PRM-3SE(71) 21.5 1× 0.8×0.6(Ground) Dip post dia. 3× 0.8×0.6 Dip post dia. 5 No. of contacts Weight Remarks 3 18g ---------- HA16PRM-3SE(71) (Inside Mount Type, Right Angle Dip) 5.8 22.8 21.8 3× 0.8×0.6 Dip post dia. n i t n 1 3 3.1 28 21.6 2 2 o c is 15.6 22.4 d e b o 18g Dip post down bent 3ר3(Hole) 42 1 2 3 PUSH PUSH 1 2 1 2 3 3 PUSH 1 2 3 82 1ר2.6(Hole) 4 33.4 24.8 2.4 31.5 22 PUSH 28 d e h c S 3 Remarks t d e l u (Plug-Receptacle Solder Type) 2.54 No. of Weight contacts Part No. 104-0417-5 71 HA16PRM-3SB(71) Gang Type 23.2 2×M2.6×0.45 HRS No. HA16PRM-3SB(71) d e u 1× 0.8×0.6(Ground) Dip post dia. PUSH 1×2.6×3.2(Side face hole) 88 HA16PRN-3SF-A(71) HRS No. Part No. 104-0423-8 71 HA16PRN-3SF-A(71) 6 No. of contacts Weight Remarks 3 80g 4 chain type HA Series●Circular Connectors for Audio Equipment (Plug-Receptacle PCB Through Hole Type) 42 3ר3(Hole) 4 1 2 22 28 PUSH PUSH 1 2 3 PUSH 1 2 3 PUSH 1 2 3 3 Convex Portion Height 0.5 82 1ר2.6(Hole) 33.8 24.8 2.4 1×2.6×3.2(Side face hole) 88 HRS No. HA16PRN-3SE-A(71) No. of Weight contacts Part No. 3 68g r 4 chain type Dip post down bent type Panel Cutout Receptacle 2ר3.2 (Small Flange Type) h c S ed d e b o t d e l u 2ר2.8 9.5 o c is Ø23 23 9.5 d e u 2ר2.8 18 HA16RM 21.6 26.95 Ø1 Ø1 n i t n (Middle Flange Type) (Large Flange Type) Ø21.7 2ר2.8 16 15.6 Plug Receptacle Type (Small Flange Type) (Inside Mount Type) 9 21.6 Ø22.2 12 14 5 23 Sep.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Dec.1.2021 104-0441-0 71 HA16PRN-3SE-A(71) Remarks Ø21.7 2ר2.8 2ר2.8 18 15.6 HA16PRM 7 HA Series●Circular Connectors for Audio Equipment Panel Cutout Gang Type (Plug-Receptacle) 42 21 4× 4×8 Ø2 11.5 22 12.5 13 3 63 Sep.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Dec.1.2021 82 Receptacle Dip Post Layout d e u (The figure below shows the board surface in which connector terminal dip posts are to be inserted.) Dip post down bent type Dip post left bent type HA16RM-3PB(76) HA16RM-3PD(76) 1ר1.3 (Ground) 3ר1 d e b o 3 1ר1.3(Ground) 4.06 3.96 2 4.45 2×M2.6×0.45 e l u t d 4.45 1 4.06 o c is HA16RM-3PE(76) 2 1 3 3.96 3ר1 1 2.54 3 n i t n (As viewed from the mating surface) 1ר1.3(Ground) 2.54 2 Dip post straight type 3ר1 4.06 4.06 Plug-Receptacle Dip Post Layout (The figure below shows the board surface in which connector terminal dip posts are to be inserted.) d e h c S Dip post down bent type 2.54 HA16PRM-3SB(71) 1 3 2 3ר1 4.06 4.06 1ר1.3 (Ground) Dip post straight type (As viewed from the mating surface) HA16PRN-3SE-A(71) HA16PRM-3SE(71) 63 4ר1.3 (Ground) 4.45 4.45 21 1ר1.3 (Ground) 2 1 3.96 3 3ר1 4.06 8 4.06 3.96 2×M2.6×0.45 Mounting hole (5 places) 12ר1 4.06 4.06 HA Series●Circular Connectors for Audio Equipment Coupling Combination Female Pin Male Pin Sep.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Dec.1.2021 (Plug) (Receptacle) (Jack) (Plug-Receptacle) Termination procedure n i t n d e u Plug side (HA16 type, jack side connector follows the same assembly procedure) Screw o c is Metal clamper d e b o 3mm approx. Plug shell unit d e h c S t d e l u Operation procedure Body Cable end(ref.) 3mm 11mm 1. Please choose a cable of which the outside diameter is 4-6mm. 2. Strip insulation of the cable end in the size as shown above. 3. Solder the cable to plug shell. 4. Crimp cable clamper, which holds cable, with a tool. 5. Fit the P shell unit to the cord tube, and tighten the locking screw with a Torque of 0.3-0.4N-m(3.5-4kg-cm) to complete the work. For details, contact our sales or engineering department before using the model HA16 plugs. Receptacle side Precautions If heat shrink tubing is applied to the solder terminating section for insulation purposes, overheating could reduce the torque of the screw tightness. Such overheating may result in loosening and possible loss of the screw. It is advised to confirm that a minimum torque of at least 0.1 N•m is obtained after termination. If a torque of at least 0.1 N•m is not realized, the screw should be tightened to between 0.3 and 0.4 N•m. Screw For details on usage, please contact our Sales or Engineering Department. 9 HA Series●Circular Connectors for Audio Equipment Terminal arrangement and major specifications 3 2 No. of contacts 3 4 Withstanding voltage AC1,400V a minute AC1,400V a minute 15A 3A(Board dip type) Insulation resistance 5A 1,000Mø MIN. 5 mø MAX. Contact resistance Terminal arrangement 2 3 10 mø MAX. 4 No. of contacts 5 Withstanding voltage AC1,400V a minute Current rating 4A Insulation resistance 1,000 Mø MIN. d e h c S 1,000 Mø MIN. 5 mø MAX. n i t n 5 1 Contact resistance e l u t d 10 mø MAX. o c is d e b o Note 1. The above figures show the receptacle as viewed from the mating side. 2. The withstand voltages show test voltages. 3. The insulation resistances show the values at 500V DC. 4. The contact resistance show the values at 1A DC. 10 4 1 3 Current rating Sep.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Dec.1.2021 2 1 Terminal arrangement d e u HA Series●Circular Connectors for Audio Equipment Sep.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Dec.1.2021 MEMO : o c is n i t n d e h c S d e b o d e u e l u t d 11 Sep.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Dec.1.2021 HA Series●Circular Connectors for Audio Equipment USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS 2688 Westhills Court, Simi Valley, CA 93065-6235 Phone : +1-805-522-7958 Fax : +1-805-522-3217 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 3255 Scott Boulevard, Building 7, Suite 101 Santa Clara, CA 95054 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. CHICAGO OFFICE 580 Waters Edge Lane, Suite 205 Lombard IL 60148 Phone : +1-630-282-6706 Mail : inquiries@hirose.com http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 37677 Professional Center Drive, Suite #100C Livonia, MI 48154 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Herzog-Carl-Strasse 4 D-73760 Ostfildern (Scharnhauser Park) Phone : +49-711-4560-02-1 Fax : +49-711-4560-02-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUERNBERG OFFICE Muggenhofer Str. 136 90429 Nuernberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 1601, Henderson Metropolitan, NO.300, East Nanjing Road, Huangpu District, Shanghai, China 200001 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD. Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7350 http://www.hirose.com/cn/ KOREA: SINGAPORE: HIROSE KOREA CO., LTD. HIROSE ELECTRIC SINGAPORE PTE. LTD. 1261-10, Jeoungwhang-Dong, Shihung-City, 10 Anson Road #26-1, International Plaza Kyunggi-Do 429-450 079903, Singapore Phone : +82-31-496-7000,7124 Phone : +65-6324-6113 Fax : +82-31-496-7100 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.co.kr/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE Office NO.519, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Phone : +91-12-660-8018 Fax : +91-120-4804949 http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No.03, Ground Floor, Explorer Building International Tech Park Whitefield Road, Bangalore 560066 Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ d e h c S ® 12 n i t n o c is d e b o d e u t d e l u MALAYSIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. (REPRESENTATIVE OFFICE) 1-10-07, Suntech @ Penang Cybercity (1164),Lintang Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia. Phone : +604-619-2564 Fax : +604-619-2574 http://www.hirose.com/sg/ 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 11/2014. Contents are subject to change without notice for the purpose of improvements.
HA16R-3P(76) 价格&库存
很抱歉,暂时无法提供与“HA16R-3P(76)”相匹配的价格&库存,您可以联系我们找货
HA16R-3P(76)
    • 1+48.712701+6.29608
    • 5+40.207715+5.19682
    • 10+35.0332810+4.52803
    • 30+31.5781230+4.08145
    • 50+30.8887550+3.99235
    • 60+30.7143460+3.96981
    • 100+30.37380100+3.92579
    库存:1
