8P1P003200GRF01
8P1P003200GRF01
    NORCOMP
    8P1P003200GRF01
8P1P003200GRF01 数据手册
DESCRIPTION: QUIK-LOQ - FEMALE - SOLDER CUP - FRONT PANEL MOUNT - PLASTIC UNITS = MM [INCHES] CHARACTERISTICS MATERIALS HOUSING : ABS+PC HOUSING COLOR : GREY NUT A : BRASS NUT A PLATING : NICKEL CONTACTS : COPPER ALLOY CONTACT PLATING : 7µ" GOLD PLATED OVER 196µ" NICKEL MIN. INSULATOR : PPS (HIGH TEMPERATURE) 8P1P YYY 2 0 0 GRF 01 1 = GOLD FLASH SERIES 14.00 [0.551] RoHS COMPLIANT NUT "B" COLOR G = GREY # OF POSITIONS (Ex. 002) **SEE CHART A** MECHANICAL DURABILITY: 2000 CYCLES OPERATING TEMP. RANGE: -20 C ~ +120 C PROCESS TEMPERATURE : 260 C FOR 5 SECONDS MAX. TORQUE VALUE : 0.7 Nm [6.19 IN/lbs] 2 = FEMALE SOLDER CUP (PANEL MOUNT) PLASTIC SHELL 0.955 24.25 IP RATING: 50 0.797 20.25 0 4.0 1] 55 [0. 0.496 12.60 0.728 18.50 M14*1.0 0.488 12.40 0.669 17.00 1 1 14 POSITION 26 AWG MAX. 2 AMP MAX. PIN = 0.50 [0.020] PANEL CUTOUT 0.157 4.00 0.315 8.00 MAX. PANEL THICKNESS CHART A 1 1 CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1200V WORKING VOLTAGE = 400V 3 POSITION 22 AWG MAX. 10 AMP MAX. PIN = 1.30 [0.051] CONTACT RESISTANCE = 5 mΩ TEST VOLTAGE = 1200V WORKING VOLTAGE = 400V 4 POSITION 22 AWG MAX. 8 AMP MAX. PIN = 0.90 [0.035] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1200V WORKING VOLTAGE = 400V RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 600V WORKING VOLTAGE = 200V **VIEW FROM TERMINATION END** = KEY LOCATION 1 2 POSITION 22 AWG MAX. 10 AMP MAX. PIN = 1.30 [0.051] TOLERANCE = +0.10, -0.0 [+0.004, -0.00] 1 1 1 1 1 1 5 POSITION 22 AWG MAX. 7 AMP MAX. PIN = 0.90 [0.035] 6 POSITION 24 AWG MAX. 6 AMP MAX. PIN = 0.70 [0.028] 7 POSITION 24 AWG MAX. 5 AMP MAX. PIN = 0.70 [0.028] 8 POSITION 24 AWG MAX. 5 AMP MAX. PIN = 0.70 [0.028] 9 POSITION 26 AWG MAX. 3 AMP MAX. PIN = 0.50 [0.020] 10 POSITION 26 AWG MAX. 3 AMP MAX. PIN = 0.50 [0.020] CONTACT RESISTANCE = 6 mΩ TEST VOLTAGE = 1050V WORKING VOLTAGE = 350V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 1050V WORKING VOLTAGE = 350V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 1050V WORKING VOLTAGE = 350V CONTACT RESISTANCE = 7.5 mΩ TEST VOLTAGE = 1050V WORKING VOLTAGE = 350V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 850V WORKING VOLTAGE = 280V CONTACT RESISTANCE = 10 mΩ TEST VOLTAGE = 850V WORKING VOLTAGE = 280V NorComp DRAWN: M. SIGMON DATE: 10-04-16 SCALE: N.T.S. SHEET 1 DWG NO. OF 1 REV: 8P1PYYY200GRF01 2
8P1P003200GRF01
物料型号:8P1P YYY 2 0 0 GRF 01
器件简介:QUIK-LOQ - FEMALE - SOLDER CUP - FRONT PANEL MOUNT - PLASTIC
引脚分配:根据位置数有不同的配置,例如: - 14位置:26 AWG MAX, 2 AMP MAX - 6位置:5 POSITION 22 AWG MAX, 7 AMP MAX - 2、3、4位置:22 AWG MAX, 10 AMP MAX 或 8 AMP MAX - 7、8、9、10位置:24 AWG MAX 或 26 AWG MAX, 3 AMP MAX 至 5 AMP MAX
参数特性:包括最大面板厚度8.00mm, 接触电阻从5 mΩ 到 10 mΩ, 测试电压从600V 到 1200V,工作电压从200V 到 400V
功能详解:文档提供了不同位置配置的详细技术参数,例如最大电流、针脚尺寸、接触电阻、测试电压和工作电压。
应用信息:适用于前面板安装的插座,符合RoHS标准。
封装信息:材料包括ABS+PC塑料外壳、黄铜螺母、镍镀层、铜合金接触点、7微英寸金层覆盖在196微英寸镍上,最小绝缘体为PPS(耐高温),机械耐久性为2000次循环,操作温度范围从-20°C到+120°C,最高加工温度为260°C持续5秒,最大扭矩值为0.7牛顿米。
8P1P003200GRF01 价格&库存
很抱歉,暂时无法提供与“8P1P003200GRF01”相匹配的价格&库存,您可以联系我们找货
