2mm Pitch Miniature Connector for HDD
A3E Series
■Features
1. Variation in Number of Contacts
This connector can be chosen according to applications, using
together with other series products as follows:
Sep.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
(1) Cable crimping type (A3B series)
(2) Cable ID type (A3E series)
(3) FFC connection type (MA18 series, A3C series)
(However, the A3E series pin header corresponds to the A3E
series socket only.)
On the other hand, 44 contacts are available for AT bus
connection, and 55 contacts for SCSI connection.
2. Batch Insulation Displacement
1 mm pitch ribbon cable can be insulated and displaced.
type without polarizing guide
3. Mechanism to Prevent Mis-insertion
type with polarizing guide
The connector on the socket side contains a mechanism to
prevent mis-insertion in the connector on the header side.
■Product Specifications
Rating
Current rating: 0.5A
Operating Temperature Range:-55 to +85ç (Note 1) Storage Temperature Range:-10 to +60ç (Note 2)
Voltage rating: 125V AC
Operating Moisture Range:40 to 80%
Item
Storage Humidity Range:40 to 70% (Note 2)
Specification
1. Insulation Resistance
Condition
1000M ohms min.
250V DC
2. Withstanding voltage
No flashover or insulation breakdown.
300V AC/1 minute
3. Contact Resistance
40m ohms max.
0.1A
4. Vibration
No electrical discontinuity of 1μs or more
Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions.
5. Humidity (Steady state) Insulation resistance: 1000M ohms min.
6. Temperature Cycle
96 hours at temperature of 40ç and humidity of 90% to 95%
(-55ç: 30 minutes →15 to 35ç: 5 minutes max.→
No damage, cracks, or parts looseness.
(+85ç: 30 minutes →15 to 35ç: 5 minutes max.) 5 cycles
7. Durability (Mating/un-mating) Contact resistance: 50m ohms max.
8. Resistance to Soldering heat
100 cycles
No deformation of components affecting performance.
Solder bath: 260ç for 10 seconds
Manual soldering: 350ç for 3 seconds
Note 1: Includes temperature rise caused by current flow.
Note 2: The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for
a specific part number shown.
■Material
Part
Insulator
Contact
C26
Material
Finish
Remarks
Black
UL94V-0
Pin header
Polyamid
Socket
PBT
Pin header
Brass
Selective gold plated over nickel
Socket
Beryllium copper
underplated
A3E Series●2mm Pitch Miniature Connector for HDD
■Ordering Information
●Pin Header
q Series Name
A3E - * P A - 2 DSA
q
w
e
r
t
y
: A3E
w Number of contacts: 44, 50
e P: Pin header
r A: Selective gold plated
t Contact pitch : 2mm
y Contact type: DSA : Straight dip type
●Socket
q Series Name
: A3E
: With polarizing guide
A3EA : Without polarizing guide
A3E - * D - 2 R
q
w
e
r
t
e D: Receptacle
r Contact pitch: 2mm
t Connection type: R : ID type
C27
■Pin Header
BPCB mounting pattern
Unit: mm
CL No.
A
B
C
D
621-0911-8-71
52.0
42.0
49.2
45.0
A3E-50PA-2DSA(71)
621-0914-6-71
58.0
48.0
55.2
51.0
●For 44 pos., without contact No. 20 pin header is available. A3E-44PA-2DSA(81)
Contact No.2
Contact No.44
Without contact (No.20)
Contact No.43
44P
Contact No.1
C28
Part Number
A3E-44PA-2DSA(71)
RoHS
YES
■Socket
●Type with polarizing guide to prevent mis-insertion (A3E)
Body
Protector
Without hole(No.20)
Combination View
No.44
No.43
No.2
No.1
Unit: mm
Part Number
CL No.
A
B
C
D
A3E-44D-2R
621-0811-3
49.0
42.0
43.0
44.3
A3E-50D-2R
621-0814-1
55.0
48.0
49.0
50.3
RoHS
YES
Note : For 44 pos., without contact No. 20 hole soket is available.
C29
●Type without polarizing guide to prevent false-insertion (A3EA)
Body
Protector
Combination View
Unit: mm
C30
Part Number
CL No.
A
B
C
D
A3EA-44D-2R
621-0861-1
49.0
42.0
43.0
44.3
A3EA-50D-2R
621-0864-0
55.0
48.0
49.0
50.3
RoHS
YES
■Recommended Cable for A3E Socket
(tin plating annealed steel wire)
Ribbon Cable
Number of Core wire Construction
A
B
7/0.127
44
43
7/0.127
50
49
Contacts
(pc./mm)
44
50
BTable of A3E Series Connection Tools
●Connection Press
Part Number: HI-FLEX Connection Press HHP502
CL550-0082-2
●Pressing Block
Part Number: Pressing Block A-01
CL550-0133-1
●Applicator
Universal Guide Plate
Part Number: A3E-GPA
CL550-0216-7
C31
MA18 Series
The MA18 series is a 2mm pitch FFC socket connector developed for miniature HDD and main port connection. 44 contacts
are provided for AT bus connection.
C32
MA18A - 44 D A - 2 DSA
q
w
e
q Series Name : MA18A
r
t
y
y Contact type (Straight type)
w Number of contacts : 44
DSA : Dip length 3mm
e Contact alignment : D : Double row
DSB : Dip length 2.5mm
r Contact plating type
DSC : Dip length 2mm
A : Selective gold plated
■Variation in Number of Contacts
Part Number
CL No.
Remarks
MA18A-44DA-2DSA(71)
588-0247-3-71
MA18A-44DA-2DSB(71)
588-0255-1-71
MA18A-44DA-2DSC(71)
588-0253-6-71
MA18M-44DA-2DSB(71)
588-0291-5-71
High profile mount type
RoHS
YES
Variation in Connection between HDD and Main Board
■Pin Heade
(1) Conventional product (used as conventional HDD interface pin header)
●Straight through hole type (see catalog page C15)
44 contacts : A3C-44P-2DSA (see photo)
50 contacts : A3C-50P-2DSA
●Straight SMT type (see catalog page C22)
44 contacts : A3-44PA-2SV(71) (see photo)
50 contacts : A3-50PA-2SV(71)
(With boss type available)
●Right angle through hole type (see catalog page C13)
44 contacts : A3B-44PA-2DS(71) (see photo)
50 contacts : A3B-50PA-2DS(71)
(2) Box type product (Socket side prevents mis-insertion)
●Straight through hole type(see catalog page C28)
44 contacts : A3E-44PA-2DSA(71) (see photo)
50 contacts : A3E-50PA-2DSA(71)
Note: Correspond to A3E series socket only.
C33
■Socket
(1) Products suitable to various cables
●Discrete wire Crimping Type (see catalog page C19)
44 contacts: A3B-44D-2C
Crimping contacts and crimping tools are
detailed on page C20.
●Ribbon Cable (1mm pitch) Batch ID Type (see catalog page C29)
44 contacts: A3E-44D-2R (see photo)
50 contacts: A3E-50D-2R
Insulation displacement is detailed on page C31.
●FPC Connection Type
44 contacts: MA18A-44DA-2DSA(71) (photo)
For a typical example, products
are provided corresponding to
various board thickness.
For details, refer to page C32.
50 contacts: A3C-50DA-2DSC(71)
For details, refer to page C17.
(2) Right Angle through hole Type (see catalog page C16.)
44 contacts: A3-44DA-2DS(71) (see photo)
50 contacts: A3-50DA-2DS(71)
(3) Straight through hole Type
44 contacts: MA18A-44DA-2DSA(71) (see photo)
(See catalog page C32.)
50 contacts: A3C-50DA-2DSA(71) (see catalog page C17.)
C34
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“A3E-44PA-2DSA(71)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 90+18.7741290+2.43654
