PM208MBALST
PM208MBALST
    ANDERSON
    POWERMOD 2X8 PIN STRAIGHT PCB 7M
PM208MBALST 数据手册
PowerMod® Two Row - Male The PowerMod® connector family offers minimum size and high power. The high performance contacts and insulator are rated for 30 amps continuous. Applications requiring lower operating temperatures can be de-rated using our current-temperature chart. FEATURES • Mechanically polarized housings Only mate one-way, ensuring proper mating • High reliability positive retention latches Are made from stainless steel to provide optimum performance The three row male PowerMod connectors are offered in 6, 8, 12 and 16 circuit sizes. The connectors are available with straight crimp, straight PCB or right angle PCB contacts. • PCB, panel or cable mounting A wide variety of contact styles with optional mounting brackets, panel clips and back-shell hoods provide broad design flexibility APP connectors are manufactured using the finest materials and world-class manufacturing processes. They embody the highest quality in the industry and meet all applicable industry standards. • Optional sequential contact mating 4 pin contact lengths can be custom specified for make-first/break-last or make-last/break-first circuits SPECIFICATIONS Electrical Mechanical Current Rating Mating Cycles No Load per IEC 512-5 1,000 30 Mating / Unmating Force per IEC 512-13 10 oz (3N) avg. UL / CSA Voltage Rating (AC/DC) 600 Contact Retention per IEC 512-8 Creepage / Clearance Distance 3.2 mm (.125") Min 18 lb (80N) Crimp 9 lb (40N) PCB Connector Contact Resistance per IEC 512-2 3 milliohms Materials Dielectric Withstanding Voltage (AC) Contact Wire Range (AWG) (mm²) * 2,200 #24 to #12 0.25 to 4.0 Insulator Pins Tail Solder (PCB contacts) PPS UL94 V-0, material group IIIa Copper alloy, 10 µ inch Au over Ni Sn/Ag/Cu (lead free) Operating Temperature (°C) (°F) -55° to 180° -67° to 356° Retention Clips Stainless steel Hoods PBT UL94 V-0 IEC 512-3, UL 1977 (Amperes) * Stranding, IEC class 5 or lower ORDERING INFORMATION Tooling PowerMod Part Number Plan - Two Row Male Series PM Rows # Poles 2 06 Gender M Contact Latch Mounting BA L CH 2 06, 08, 12, 16 Poles M - Male OO - None (Crimp contacts ordered separately) BA - Straight PCB Solder Standard Length-RoHS RA - R/A PCB Solder Standard Length-RoHS Customized Connector - X X X Consult factory for options OO - None SB - R/A PCB Snap Bracket HB - R/A PCB Bracket with Hole ST - Self-tapping screws for straight PCB mount SP - Push in fastener for straight PCB mount CH - With clam-shell hood PC - Panel Clip MC - Mounting Clip SC - Screw for 1.6mm panel mount L - Connector with latch (standard for contact type OO) O - No latch www.andersonpower.com Part Number TM0001 TP0001 Mil-Standard M22520/1-01 N/A Description AF8 hand tool WA27F pneumatic crimp tool Turret & Locator for TM0001 & TP0001 TL0001 N/A For pin contacts TL0002 N/A For socket contacts PM1000G1 N/A PM1002G1 N/A PM1003G1 N/A Four indent hand tool with locator Contact insertion tool Contact extraction tool 200 180 160 140 120 100 80 60 40 20 0 2 Row Current vs Temperature Rise Temperature (°C) Temperature (°C) TEMPERATURE CHARTS 0 5 10 4mm² 15 Amps 12AWG 20 25 30 200 180 160 140 120 100 80 60 40 20 0 2 Row Ambient Temperature De-rating 0 5 16 circuits all energized 10 15 20 Amps 12AWG 4mm² 25 30 16 circuits all energized DIMENSIONS - mm(in.) Cable Connector ROWS CONTACTS 2 - 06 2 - 08 2 - 12 2 - 16 A -Amm in. 28.5 33.5 43.5 53.5 15.4 (0.61) 1.12 1.32 1.71 2.11 23.4 (0.92) 9.4 (0.37) 9.0 (0.35) See accessory section for panel clip and mounting clip cut-out dimensions. ORDERING INFORMATION Crimp Contacts Cable Connector With Snap-in Panel Clip Part Number Description Standard Length 7.7mm PM16P2024S30 Pin PM16P1620S30 Pin PM16P1416S30 Pin PM16P12S30 Pin Part Number PM206MOOLOO PM208MOOLOO PM212MOOLOO PM216MOOLOO Part Number PM206MOOLPC PM208MOOLPC PM212MOOLPC PM216MOOLPC AWG Wire sq. mm #24 / 20 #20 / 16 #16 / 14 #12 0.50 / 0.75 0.50 / 1.5 1.5 / 2.5 2.5 / 4.0 Pre-Mate 9.3mm PM16P2024A30 PM16P1620A30 PM16P1416A30 PM16P12A30 Pin Pin Pin Pin #24 / 20 #20 / 16 #16 / 14 #12 0.50 / 0.75 0.50 / 1.5 1.5 / 2.5 2.5 / 4.0 Pre-Mate 8.5mm PM16P2024B30 PM16P1620B30 PM16P1416B30 PM16P12B30 Pin Pin Pin Pin #24 / 20 #20 / 16 #16 / 14 #12 0.50 / 0.75 0.50 / 1.5 1.5 / 2.5 2.5 / 4.0 Post-Mate 6.4mm PM16P2024C30 PM16P1620C30 PM16P1416C30 PM16P12C30 Pin Pin Pin Pin #24 / 20 #20 / 16 #16 / 14 #12 0.50 / 0.75 0.50 / 1.5 1.5 / 2.5 2.5 / 4.0 Description 2x3 MALE Cable Connector 2x4 MALE Cable Connector 2x6 MALE Cable Connector 2x8 MALE Cable Connector Description 2x3 MALE Cable Connector 2x4 MALE Cable Connector 2x6 MALE Cable Connector 2x8 MALE Cable Connector Panel Mount With Screws With Clam Shell Hood & Strain Relief Part Number PM206MOOLSC PM208MOOLSC PM212MOOLSC PM216MOOLSC Part Number PM206MOOLCH PM208MOOLCH PM212MOOLCH PM216MOOLCH Description 2x3 MALE Cable Connector 2x4 MALE Cable Connector 2x6 MALE Cable Connector 2x8 MALE Cable Connector Description 2x3 MALE Cable Connector 2x4 MALE Cable Connector 2x6 MALE Cable Connector 2x8 MALE Cable Connector Panel Mount With Mounting Clip Part Number PM206MOOLMC PM208MOOLMC PM212MOOLMC PM216MOOLMC Description 2x3 MALE Cable Connector 2x4 MALE Cable Connector 2x6 MALE Cable Connector 2x8 MALE Cable Connector www.andersonpower.com DIMENSIONS - mm(in.) 2 Row - PCB Right Angle Connector 2 Row - PCB Hole Layout For Right Angle Connector ROWS CONTACTS A 9.4 (0.37) 2 - 06 2 - 08 2 - 12 2 - 16 A mm in. 28.5 33.5 43.5 53.5 L1 mm in. 1.12 10 1.32 15 1.71 25 2.11 35 0.39 0.59 0.98 1.38 L2 mm in. 22.3 27.3 37.3 47.3 3.7 (0.15) 15.2 (0.60) 0.88 1.07 1.47 1.86 Finished hole 15.4 (0.61) 2.5 (0.10) 1.6 (0.06) 5.0 (0.20) 5.0 (0.20) ORDERING INFORMATION No Latch With Latch Part Number PM206MRALOO PM208MRALOO PM212MRALOO PM216MRALOO Description 2x3 MALE Right Angle PCB Solder 2x4 MALE Right Angle PCB Solder 2x6 MALE Right Angle PCB Solder 2x8 MALE Right Angle PCB Solder Part Number PM206MRAOOO PM208MRAOOO PM212MRAOOO PM216MRAOOO Description 2x3 MALE Right Angle PCB Solder 2x4 MALE Right Angle PCB Solder 2x6 MALE Right Angle PCB Solder 2x8 MALE Right Angle PCB Solder Right Angle PCB Snap Bracket & Latch Right Angle Latch PCB Snap Bracket & No Latch Part Number PM206MRALSB PM208MRALSB PM212MRALSB PM216MRALSB Part Number PM206MRAOSB PM208MRAOSB PM212MRAOSB PM216MRAOSB Description 2x3 MALE Right Angle PCB Solder 2x4 MALE Right Angle PCB Solder 2x6 MALE Right Angle PCB Solder 2x8 MALE Right Angle PCB Solder Description 2x3 MALE Right Angle PCB Solder 2x4 MALE Right Angle PCB Solder 2x6 MALE Right Angle PCB Solder 2x8 MALE Right Angle PCB Solder Right Angle PCB Bracket With Hole & Latch Right Angle PCB Bracket With Hole & No Latch Part Number PM206MRALHB PM208MRALHB PM212MRALHB PM216MRALHB Part Number PM206MRAOHB PM208MRAOHB PM212MRAOHB PM216MRAOHB Description 2x3 MALE Right Angle PCB Solder 2x4 MALE Right Angle PCB Solder 2x6 MALE Right Angle PCB Solder 2x8 MALE Right Angle PCB Solder Description 2x3 MALE Right Angle PCB Solder 2x4 MALE Right Angle PCB Solder 2x6 MALE Right Angle PCB Solder 2x8 MALE Right Angle PCB Solder PCB contacts and mounting accessories are designed for a board thickness of 1.60mm (.063) with a contact protrusion of 2.10 (.083). Other contact lengths are available upon request. www.andersonpower.com DIMENSIONS - mm(in.) 2 Row - PCB Straight Solder Connector 2 Row - PCB Hole Layout For Straight Solder Connector A 9.4 (0.37) 3.7 (0.15) 15.2 (0.60) 5.0 (0.20) 1.6 (0.06) ROWS CONTACTS 2 - 06 2 - 08 2 - 12 2 - 16 A mm in. 28.5 33.5 43.5 53.5 1.12 1.32 1.71 2.11 L1 mm in. L2 mm in. 10 15 25 35 22.3 27.3 37.3 47.3 0.39 0.59 0.98 1.38 5.0 (0.20) 0.88 1.07 1.47 1.86 Finished hole 15.4 (0.61) ORDERING INFORMATION No Latch With Latch Part Number PM206MBALOO PM208MBALOO PM212MBALOO PM216MBALOO Part Number PM206MBAOOO PM208MBAOOO PM212MBAOOO PM216MBAOOO Description 2x3 MALE Straight PCB Solder 2x4 MALE Straight PCB Solder 2x6 MALE Straight PCB Solder 2x8 MALE Straight PCB Solder Description 2x3 PIN Straight PCB Solder 2x4 PIN Straight PCB Solder 2x6 PIN Straight PCB Solder 2x8 PIN Straight PCB Solder Push On PCB Fastener & Latch Push On PCB Fastener & No Latch Part Number PM206MBALSP PM208MBALSP PM212MBALSP PM216MBALSP Part Number PM206MBAOSP PM208MBAOSP PM212MBAOSP PM216MBAOSP Description 2x3 MALE Straight PCB Solder 2x4 MALE Straight PCB Solder 2x6 MALE Straight PCB Solder 2x8 MALE Straight PCB Solder Description 2x3 PIN Straight PCB Solder 2x4 PIN Straight PCB Solder 2x6 PIN Straight PCB Solder 2x8 PIN Straight PCB Solder Self-tapping Screws For PCB Mount & Latch Self-tapping Screws For PCB Mount & No Latch Part Number PM206MBALST PM208MBALST PM212MBALST PM216MBALST Part Number PM206MBAOST PM208MBAOST PM212MBAOST PM216MBAOST Description 2x3 MALE Straight PCB Solder 2x4 MALE Straight PCB Solder 2x6 MALE Straight PCB Solder 2x8 MALE Straight PCB Solder Description 2x3 PIN Straight PCB Solder 2x4 PIN Straight PCB Solder 2x6 PIN Straight PCB Solder 2x8 PIN Straight PCB Solder PCB contacts and mounting accessories are designed for a board thickness of 1.60mm (.063) with a contact protrusion of 2.10 (.083). Other contact lengths are available upon request. All Data Subject To Change Without Notice 15250 DS-PM2RM REV12 HEADQUARTERS: Anderson Power Products , 13 Pratts Junction Road, Sterling, MA 01564-2305 USA T:978-422-3600 F:978-422-0128 EUROPE: Anderson Power Products® Ltd., Unit 3, Europa Court, Europa Boulevard, Westbrook, Warrington, Cheshire, WA5 7TN United Kingdom T: +44 (0) 1925 428390 F: +44 (0) 1925 520203 ASIA / PACIFIC: IDEAL Anderson Asia Pacific Ltd., Unit 922-928 Topsail Plaza, 11 On Sum Street, Shatin N.T., Hong Kong T:+(852) 2636 0836 F:+(852) 2635 9036 CHINA: IDEAL Anderson Technologies (Shenzhen) Ltd., Block A8 Tantou Western Industrial Park, Songgang Baoan District, Shenzhen, PR. China 518105 T: +(86) 755 2768 2118 F: +(86) 755 2768 2218 TAIWAN: IDEAL Anderson Asia Pacific Ltd., Taiwan Branch, 4F.-2, No.116, Dadun 20th St., Situn District, Taichung City 407, Taiwan (R.O.C.) T: +(886) 4 2310 6451 F:+(886) 4 2310 6460 ® www.andersonpower.com
PM208MBALST
物料型号:PowerMod® 连接器系列,包括不同排数和极数的型号,例如PM206MOOLOO、PM208MOOLOO等。
器件简介:PowerMod® 连接器家族提供最小尺寸和高功率。高性能接触件和绝缘体额定为30安培连续。需要更低工作温度的应用可以使用电流-温度图表进行降额。
引脚分配:三排男性PowerMod连接器提供6、8、12和16电路尺寸。连接器可配备直插压接、直插PCB或直角PCB接触件。
参数特性: - 电气特性:接触电阻、工作温度范围、接触线范围、介电耐压、电流额定值等。 - 机械特性:包括配合周期、无负载配合/脱配合力量、接触保持力、材料等。
功能详解:APP连接器使用最优质的材料和世界级的制造工艺制造。它们体现了行业中的最高质量,并符合所有适用的行业标准。
应用信息:适用于需要高可靠性和高性能接触的应用,例如电源管理系统。
封装信息:提供直插式、面板安装或电缆安装等多种安装方式,以及可选的安装支架、面板夹和后壳罩,提供广泛的设计灵活性。
PM208MBALST 价格&库存
很抱歉,暂时无法提供与“PM208MBALST”相匹配的价格&库存,您可以联系我们找货
