SiT5156
1 MHz to 60 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO
Description
Features
The SiT5156 is a ±0.5 ppm to ±2.5 ppm MEMS Super-
TCXO that is engineered for best dynamic performance. It
is ideal for high reliability telecom, wireless and networking,
industrial, precision GNSS and audio/video applications.
Leveraging SiTime’s unique DualMEMS™ temperature
sensing and TurboCompensation™ technologies, the
SiT5156 delivers the best dynamic performance for timing
stability in the presence of environmental stressors such as
air flow, temperature perturbation, vibration, shock, and
electromagnetic interference. This device also integrates
multiple on-chip regulators to filter power supply noise,
eliminating the need for a dedicated external LDO.
The SiT5156 offers three device configurations that can be
ordered using Ordering Codes for:
Any frequency from 1 MHz to 60 MHz in 1 Hz steps
Factory programmable options for short lead times
Best dynamic stability under airflow, thermal shock
±0.5 ppm stability across temperature
±15 ppb/°C typical frequency slope (ΔF/ΔT)
-40°C to +105°C operating temperature
No activity dips or micro jumps
Resistant to shock, vibration and board bending
On-chip regulators eliminate the need for external LDOs
Digital frequency pulling (DCTCXO) via I2C
Digital control of output frequency and pull range
Up to ±3200 ppm pull range
Frequency pull resolution down to 5 ppt
2.5 V, 2.8 V, 3.0 V and 3.3 V supply voltage
LVCMOS or clipped sinewave output
RoHS and REACH compliant
Pb-free, Halogen-free, Antimony-free
Applications
The SiT5156 can be factory programmed for any
combination of frequency, stability, voltage, and pull range.
Programmability enables designers to optimize clock
configurations while eliminating long lead times and
customization costs associated with quartz devices where
each frequency is custom built.
Precision GNSS systems
Microwave backhaul
Network routers and switches
Professional audio and video equipment
Storage and servers
Test and measurement
Refer to Manufacturing Guideline for proper reflow profile
and PCB cleaning recommendations to ensure best
performance.
Block Diagram
5.0 mm x 3.2 mm Package Pinout
SDA / NC
OE / VC / NC
1
SCL / NC
9
VDD
2
8
NC
NC
3
7
NC
GND
4
6
CLK
10
5
A0 / NC
Figure 1. SiT5156 Block Diagram
Rev 1.06
Figure 2. Pin Assignments (Top view)
(Refer to Table 13 for Pin Descriptions)
May 23, 2020
www.sitime.com
SiT5156 1 MHz to 60 MHz, ±0.5 to ±2.5 ppm, Elite Platform™ Super-TCXO
Ordering Information
The part number guide illustrated below is for reference only, in which boxes identify order codes having more than one option.
To customize and build an exact part number, use the SiTime Part Number Generator. To validate the part number, use the
SiTime Part Number Decoder.
Part
Family
TCXO
VCTCXO
DCTCXO
Silicon
Revision
Letter
Package Size
Pin 1 Function – TCXO mode only
"F": 5.0 mm x 3.2 mm
"E": Output Enable
"N": No Connect
SiT5156AC - FK - 33 E 0 - 19.123456 T
SiT5156AC - FK - 33 V T - 19.123456 T
SiT5156AC - FKG33 J R - 19.123456 T
Packaging
"T": 12 mm Tape & Reel, 3 ku reel
"Y": 12 mm Tape & Reel, 1 ku reel
“X”: 12 mm Tape & Reel, 250 u reel
(blank): bulk[2]
Temperature Range
"I": Industrial, -40 to 85°C
"C": Extended Commercial, -20 to 70°C
"E": Extended Industrial, -40 to 105°C
Output Waveform
Frequency
"-": LVCMOS[1]
"C": Clipped Sinewave
1.000000 MHz to 60.000000 MHz
Pull Range – DCTCXO mode only
Frequency Stability
"T": ±6.25 ppm
"R": ±10 ppm
"Q": ±12.5 ppm
"M": ±25 ppm
"B": ±50 ppm
"C": ±80 ppm
"E": ±100 ppm
"F": ±125 ppm
"K": for ±0.5 ppm
"A": for ±1.0 ppm
"D": for ±2.5 ppm
I2C Address Mode – DCTCXO mode only
“0”, “1”, “2”, “3”, “4”, “5”, “6”, “7”, “8”, “9”, “A”, “B”,
“C”, “D”, “E”, “F”: Order code representing hex
value of I2C address. When the I2C address is
factory programmed using this code, pin A0 is no
connect (NC).
"G":
"H":
"X":
"L":
"Y":
"S":
"Z":
"U":
±150 ppm
±200 ppm
±400 ppm
±600 ppm
±800 ppm
±1200 ppm
±1600 ppm
±3200 ppm
Pin 1 Function – DCTCXO mode only
"I": Output Enable
"J": No Connect, software OE control
“G”: I2C pin addressable mode. Address is set by
the logic on A0 pin.
Supply Voltage
"25": 2.5 V ± 10%
"28": 2.8 V ± 10%
"30": 3.0 V ± 10%
"33": 3.3 V ± 10%
Notes:
1. “-“ corresponds to the default rise/fall time for LVCMOS output as specified in Table 1 (Electrical Characteristics). Contact SiTime for other rise/fall time
options for best EMI or driving multiple loads. For differential outputs, contact SiTime.
2. Bulk is available for sampling only
Rev 1.06
Page 2 of 38
www.sitime.com
TABLE OF CONTENTS
Description ................................................................................................................................................................................... 1
Features....................................................................................................................................................................................... 1
Applications ................................................................................................................................................................................. 1
Block Diagram ............................................................................................................................................................................. 1
5.0 mm x 3.2 mm Package Pinout ............................................................................................................................................... 1
Ordering Information .................................................................................................................................................................... 2
Electrical Characteristics.............................................................................................................................................................. 4
Device Configurations and Pin-outs ............................................................................................................................................. 9
Pin-out Top Views................................................................................................................................................................. 9
Test Circuit Diagrams for LVCMOS and Clipped Sinewave Outputs ......................................................................................... 10
Waveforms................................................................................................................................................................................. 12
Timing Diagrams ........................................................................................................................................................................ 13
Typical Performance Plots ......................................................................................................................................................... 14
Architecture Overview ................................................................................................................................................................ 16
Frequency Stability ............................................................................................................................................................. 16
Output Frequency and Format............................................................................................................................................ 16
Output Frequency Tuning ................................................................................................................................................... 16
Pin 1 Configuration (OE, VC, or NC) .................................................................................................................................. 17
Device Configurations ................................................................................................................................................................ 17
TCXO Configuration ........................................................................................................................................................... 17
VCTCXO Configuration ...................................................................................................................................................... 18
DCTCXO Configuration ...................................................................................................................................................... 19
VCTCXO-Specific Design Considerations ................................................................................................................................. 20
Linearity .............................................................................................................................................................................. 20
Control Voltage Bandwidth ................................................................................................................................................. 20
FV Characteristic Slope KV ................................................................................................................................................. 20
Pull Range, Absolute Pull Range ........................................................................................................................................ 21
DCTCXO-Specific Design Considerations ................................................................................................................................. 22
Pull Range and Average Pull Range .................................................................................................................................. 22
Output Frequency ............................................................................................................................................................... 23
I2C Control Registers .......................................................................................................................................................... 25
Register Descriptions.......................................................................................................................................................... 25
Register Address: 0x00. Digital Frequency Control Least Significant Word (LSW) ............................................................ 25
Register Address: 0x01. OE Control, Digital Frequency Control Most Significant Word (MSW)......................................... 26
Register Address: 0x02. DIGITAL PULL RANGE CONTROL [15] ....................................................................................... 27
Serial Interface Configuration Description .......................................................................................................................... 28
Serial Signal Format ........................................................................................................................................................... 28
Parallel Signal Format ........................................................................................................................................................ 29
Parallel Data Format ........................................................................................................................................................... 29
I2C Timing Specification ...................................................................................................................................................... 31
I2C Device Address Modes ................................................................................................................................................. 32
Schematic Example ............................................................................................................................................................ 33
Dimensions and Patterns ........................................................................................................................................................... 34
Layout Guidelines ...................................................................................................................................................................... 35
Manufacturing Guidelines .......................................................................................................................................................... 35
Additional Information ................................................................................................................................................................ 36
Revision History ......................................................................................................................................................................... 37
Rev 1.06
Page 3 of 38
www.sitime.com
All Min and Max limits are specified over temperature and rated operating voltage with 15 pF output load unless otherwise
stated. Typical values are at 25°C and 3.3 V Vdd.
Table 1. Output Characteristics
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
Frequency Coverage
Nominal Output Frequency Range
F_nom
1
60
MHz
Temperature Range
Operating Temperature Range
T_use
-20
+70
°C
Extended Commercial, ambient temperature
-40
+85
°C
Industrial, ambient temperature
-40
+105
°C
Extended Industrial, ambient temperature
Frequency Stability
Frequency Stability over
Temperature
F_stab
±0.5
ppm
±1.0
ppm
Referenced to (max frequency + min frequency)/2 over the
rated temperature range. Vc=Vdd/2 for VCTCXO
±2.5
ppm
Initial Tolerance
F_init
±1
ppm
Initial frequency at 25°C at 48 hours after 2 reflows
Supply Voltage Sensitivity
F_Vdd
±7.10
±16.25
ppb
±0.5 ppm F_stab, Vdd ±5%
±11.83
±32.50
ppb
±1.0ppm F_stab, Vdd ±5%
±28.40
±65.0
ppb
±2.5 ppm F_stab, Vdd ±5%
±0.81
±2.75
ppb
±0.5 ppm F_stab. LVCMOS output, 15 pF ±10%. Clipped
sinewave output, 10 kΩ || 10 pF ±10%
±1.35
±5.50
ppb
±1.0 ppm F_stab. LVCMOS output, 15 pF ±10%. Clipped
±3.24
±11.00
ppb
±2.5 ppm F_stab. LVCMOS output, 15 pF ±10%. Clipped
±15
±25
ppb/°C
±0.5 ppm F_stab, 0.5°C/min ramp rate, -40 to 105°C
±25
±50
ppb/°C
±1.0 ppm F_stab, 0.5°C/min ramp rate, -40 to 105°C
±60
±100
ppb/°C
±2.5 ppm F_stab, 0.5°C/min ramp rate, -40 to 105°C
±0.13
±0.21
ppb/s
±0.21
±0.42
ppb/s
±0.50
±0.83
ppb/s
Output Load Sensitivity
Frequency vs. Temperature Slope
Dynamic Frequency Change during
Temperature Ramp
F_load
ΔF/ΔT
F_dynamic
One-Year Aging
F_1y
±1
ppm
At 25°C, after 2-days of continued operation. Aging is
measured with respect to day 3
20-Year Aging
F_20y
±2
ppm
DC
45
55
Rise/Fall Time
Tr, Tf
0.8
1.2
1.9
ns
Output Voltage High
VOH
90%
Vdd
IOH = +3 mA
VOL
10%
Vdd
IOL = -3 mA
Z_out_c
17
Ohms
Impedance looking into output buffer, Vdd = 3.3 V
17
Ohms
Impedance looking into output buffer, Vdd = 3.0 V
18
Ohms
Impedance looking into output buffer, Vdd = 2.8 V
19
Ohms
Impedance looking into output buffer, Vdd = 2.5 V
LVCMOS Output Characteristics
Duty Cycle
Output Voltage Low
Output Impedance
10% - 90% Vdd
Clipped Sinewave Output Characteristics
Output Voltage Swing
V_out
0.8
1.2
V
Clipped sinewave output, 10 kΩ || 10 pF ±10%
Rise/Fall Time
Tr, Tf
3.5
4.6
ns
20% - 80% Vdd, F = 19.2 MHz
ms
Time to first pulse, measured from the time Vdd reaches
90% of its final value. Vdd ramp time = 100 µs from 0V to
Vdd
Start-up Characteristics
Start-up Time
Output Enable Time
Time to Rated Frequency Stability
Rev 1.06
T_start
2.5
3.5
T_oe
680
ns
F_nom = 10 MHz. See Timing Diagrams section below.
T_stability
5
45
ms
Time to first accurate pulse within rated stability, measured
from the time Vdd reaches 90% of its final value. Vdd
ramp time = 100 µs
Page 4 of 38
www.sitime.com
Table 2. DC Characteristics
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
Supply Voltage
Supply Voltage
Vdd
2.25
2.5
2.75
V
2.52
2.8
3.08
V
2.7
3.0
3.3
V
2.97
3.3
3.63
V
Contact SiTime for 2.25 V to 3.63 V continuous supply
voltage support
Current Consumption
Current Consumption
OE Disable Current
Idd
I_od
44
53
mA
F_nom = 19.2 MHz, No Load, TCXO and DCTCXO modes
48
57
mA
F_nom = 19.2 MHz, No Load, VCTCXO mode
43
51
mA
OE = GND, output weakly pulled down. TCXO, DCTCXO
47
55
mA
OE = GND, output weakly pulled down. VCTCXO mode
Typ.
Max.
Unit
Table 3. Input Characteristics
Parameters
Symbol
Min.
Condition
Input Characteristics – OE Pin
Input Impedance
Z_in
75
kΩ
Input High Voltage
VIH
70%
Vdd
Input Low Voltage
VIL
30%
Vdd
Internal pull up to Vdd
Frequency Tuning Range – Voltage Control or I2C mode
Pull Range
Absolute Pull Range[3]
PR
APR
±6.25
ppm
VCTCXO mode; contact SiTime for ±12.5 and ±25 ppm
±6.25
±10
±12.5
±25
±50
±80
±100
±125
±150
±200
±400
±600
±800
±1200
±1600
±3200
ppm
DCTCXO mode
±2.75
ppm
±0.5 ppm F_stab, DCTCXO, VCTCXO for PR = ±6.25 ppm
±2.25
ppm
±1.0 ppm F_stab, DCTCXO, VCTCXO for PR = ±6.25 ppm
±0.75
ppm
±2.5 ppm F_stab, DCTCXO, VCTCXO for PR = ±6.25 ppm
Upper Control Voltage
VC_U
90%
Vdd
VCTCXO mode
Lower Control Voltage
VC_L
10%
Vdd
VCTCXO mode
Control Voltage Input Impedance
VC_z
8
MΩ
VCTCXO mode
Control Voltage Input Bandwidth
VC_bw
10
kHz
Frequency Control Polarity
F_pol
Pull Range Linearity
PR_lin
Positive
0.5
VCTCXO mode; contact SiTime for other bandwidth options
VCTCXO mode
1.0
VCTCXO mode
I2C Interface Characteristics, 200 Ohm, 550 pF (Max I2C Bus Load)
Bus Speed
F_I2C
≤ 400
kHz
-40 to 105°C
≤ 1000
kHz
-40 to 85°C
Input Voltage Low
VIL_I2C
30%
Vdd
DCTCXO mode
Input Voltage High
VIH_I2C
70%
Vdd
DCTCXO mode
Output Voltage Low
VOL_I2C
0.4
V
DCTCXO mode
IL
0.5
24
µA
0.1 VDD< VOUT < 0.9 VDD. Includes typical leakage current
from 200 kΩ pull resister to VDD. DCTCXO mode
CIN
5
pF
DCTCXO mode
Input Leakage current
Input Capacitance
Note:
3. APR = PR – initial tolerance – 20-year aging – frequency stability over temperature. Refer to Table 17 for APR with respect to other pull range options.
Rev 1.06
Page 5 of 38
www.sitime.com
Table 4. Jitter & Phase Noise – LVCMOS, -40°C to 85°C
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
Jitter
RMS Phase Jitter (random)
T_phj
0.31
0.48
ps
F_nom = 10 MHz, Integration bandwidth = 12 kHz to 5 MHz
0.31
0.48
ps
F_nom = 50 MHz, Integration bandwidth = 12 kHz to 20 MHz
RMS Period Jitter
T_jitt_per
0.8
1.1
ps
F_nom = 10 MHz, population 10 k
Peak Cycle-to-Cycle Jitter
T_jitt_cc
6
9
ps
F_nom = 10 MHz, population 1 k, measured as absolute
value
1 Hz offset
-80
-74
dBc/Hz
10 Hz offset
-108
-102
dBc/Hz
100 Hz offset
-127
-123
dBc/Hz
1 kHz offset
-148
-145
dBc/Hz
10 kHz offset
-154
-151
dBc/Hz
100 kHz offset
-154
-150
dBc/Hz
1 MHz offset
-167
-163
dBc/Hz
5 MHz offset
-168
-164
dBc/Hz
-112
-105
dBc
Phase Noise
T_spur
Spurious
F_nom = 10 MHz
TCXO and DCTCXO modes, and VCTCXO mode with
±6.25 ppm pull range
F_nom = 10 MHz, 1 kHz to 5 MHz offsets
Table 5. Jitter & Phase Noise – Clipped Sinewave, -40°C to 85°C
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
Jitter
T_phj
0.31
0.45
ps
F_nom = 19.2 MHz, Integration bandwidth = 12 kHz to 5 MHz
0.31
0.48
ps
F_nom = 60 MHz, Integration bandwidth = 12 kHz to 20 MHz
Phase Noise
1 Hz offset
-74
-68
dBc/Hz
10 Hz offset
-102
-97
dBc/Hz
100 Hz offset
-121
-117
dBc/Hz
1 kHz offset
-142
-140
dBc/Hz
10 kHz offset
-148
-146
dBc/Hz
100 kHz offset
-149
-145
dBc/Hz
1 MHz offset
-162
-159
dBc/Hz
5 MHz offset
-164
-160
dBc/Hz
-109
-104
dBc
Spurious
Rev 1.06
T_spur
Page 6 of 38
F_nom = 19.2 MHz
F_nom = 19.2 MHz, 1 kHz to 5 MHz offsets
www.sitime.com
Table 6. Jitter & Phase Noise – LVCMOS, -40°C to 105°C
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
Jitter
T_phj
0.31
0.48
ps
0.31
0.50
ps
RMS Period Jitter
T_jitt_per
0.8
1.1
ps
T_jitt_cc
6
9
ps
value
1 Hz offset
-80
-74
dBc/Hz
10 Hz offset
-108
-102
dBc/Hz
100 Hz offset
-127
-123
dBc/Hz
1 kHz offset
-148
-145
dBc/Hz
10 kHz offset
-154
-151
dBc/Hz
100 kHz offset
-154
-150
dBc/Hz
1 MHz offset
-167
-162
dBc/Hz
5 MHz offset
-168
-164
dBc/Hz
-112
-101
dBc
F_nom = 10 MHz, 1 kHz to 5 MHz offsets, Vdd = 2.5 V
-112
-106
dBc
F_nom = 10 MHz, 1 kHz to 5 MHz offsets, Vdd = 2.8 V,
3.0 V, 3.3 V
Phase Noise
Spurious
T_spur
F_nom = 10 MHz
±6.25 ppm pull range.
Table 7. Jitter & Phase Noise – Clipped Sinewave, -40°C to 105°C
Parameters
Symbol
Min.
Typ.
Max.
Unit
Condition
Jitter
T_phj
0.31
0.46
ps
0.31
0.50
ps
1 Hz offset
-74
-68
dBc/Hz
10 Hz offset
-102
-97
dBc/Hz
100 Hz offset
-121
-117
dBc/Hz
1 kHz offset
-142
-140
dBc/Hz
10 kHz offset
-148
-146
dBc/Hz
100 kHz offset
-149
-145
dBc/Hz
Phase Noise
1 MHz offset
-162
-158
dBc/Hz
5 MHz offset
-164
-159
dBc/Hz
-109
-103
dBc
Spurious
Rev 1.06
T_spur
Page 7 of 38
F_nom = 19.2 MHz
www.sitime.com
Table 8. Absolute Maximum Limits
Attempted operation outside the absolute maximum ratings may cause permanent damage to the part.
Actual performance of the IC is only guaranteed within the operational specifications, not at absolute maximum ratings.
Parameter
Test Conditions
Storage Temperature
Continuous Power Supply Voltage Range (Vdd)
Human Body Model (HBM) ESD Protection
JESD22-A114
Value
Unit
-65 to 125
°C
-0.5 to 4
V
2000
V
Soldering Temperature (follow standard Pb-free soldering guidelines)
260
°C
Junction Temperature[4]
130
°C
Input Voltage, Maximum
Any input pin
Vdd + 0.3
V
Input Voltage, Minimum
Any input pin
-0.3
V
Note:
4. Exceeding this temperature for an extended period of time may damage the device.
Table 9. Thermal Considerations[5]
Package
θJA[6] (°C/W)
θJC, Bottom (°C/W)
Ceramic 5.0 mm x 3.2 mm
54
15
Note:
5. Measured in still air. Refer to JESD51 for θJA and θJC definitions.
6. Devices soldered on a JESD51 2s2p compliant board.
Table 10. Maximum Operating Junction Temperature[7]
Max Operating Temperature (ambient)
70°C
80°C
85°C
95°C
105°C
115°C
Note:
7. Datasheet specifications are not guaranteed if junction temperature exceeds the maximum operating junction temperature.
Table 11. Environmental Compliance
Value
Unit
Mechanical Shock Resistance
Parameter
MIL-STD-883F, Method 2002
30000
g
Mechanical Vibration Resistance
MIL-STD-883F, Method 2007
70
g
Temperature Cycle
JESD22, Method A104
Solderability
MIL-STD-883F, Method 2003
Moisture Sensitivity Level
MSL1 @260°C
Rev 1.06
Test Conditions
Page 8 of 38
www.sitime.com
Table 12. Device Configurations
Configuration
Pin 1
Pin 5
TCXO
OE/NC
NC
I2C Programmable Parameters
VCTCXO
VC
NC
DCTCXO
OE/NC
A0/NC
Frequency Pull Range, Frequency Pull Value, Output Enable control.
Pin-out Top Views
OE/NC
1
NC
9
VDD
VC
1
2
8
NC
NC
NC
3
7
NC
GND
4
6
CLK
10
5
SDA
NC
NC
VDD
2
8
NC
NC
3
7
NC
GND
4
6
CLK
1
NC
SCL
7
NC
6
CLK
VDD
2
8
NC
3
GND
4
5
9
OE / NC
9
10
10
5
NC
NC
A0 / NC
Figure 3. TCXO
Figure 4. VCTCXO
Figure 5. DCTCXO
Table 13. Pin Description
Pin
1
Symbol
OE/NC [10]/VC
I/O
Internal Pull-up/Pull Down
Resistor
OE – Input
100 kΩ Pull-Up
NC – No Connect
H or L or Open: No effect on output frequency or other device functions
VC – Input
Control Voltage in VCTCXO Mode
SCL – Input
200 kΩ Pull-Up
Function
H[8]: specified frequency output
L: output is high impedance. Only output driver is disabled.
I2C serial clock input.
2
SCL / NC [10]
3
NC[10]
No Connect
4
GND
Power
Connect to ground
5
6
A0 / NC[10]
CLK
No Connect
Device I2C address when the address selection mode is via the A0 pin.
This pin is NC when the I2C device address is specified in the ordering
code.
A0 Logic Level I2C Address
1
1101010
A0 – Input
100 kΩ Pull-Up
NC – No Connect
H or L or Open: No effect on output frequency or other device functions.
Output
LVCMOS, or clipped sinewave oscillator output
7
NC
[10]
No Connect
8
NC[10]
No Connect
9
VDD
Power
Connect to power supply[9]
10
SDA / NC [10]
SDA – Input/Output
200 kΩ Pull Up
NC – No Connect
I2C Serial Data.
Notes:
8. In OE mode for noisy environments, a pull-up resistor of 10 kΩ or less is recommended if pin 1 is not externally driven. If pin 1 needs to be left floating, use
the NC option.
9. A 0.1 μF capacitor in parallel with a 10 μF capacitor are required between VDD and GND. The 0.1 μF capacitor is recommended to place close to the
device, and place the 10 μF capacitor less than 2 inches away.
10. All NC pins can be left floating and do not need to be soldered down.
Rev 1.06
Page 9 of 38
www.sitime.com
VDD
Power
Supply
9
0.1µF
8
7
6
5
10
10µF
1
2
VDD
Test Point
CLK
3
4
Power
Supply
15pF
(including probe
and fixture
capacitance)
9
0.1µF
8
7
6
5
10
10µF
Test Point
CLK
1
2
3
10pF
10kΩ
(including probe
and fixture
resistance and
capacitance)
4
Vdd
Vdd
OE Function
OE Function
Figure 6. LVCMOS Test Circuit (OE Function)
VDD
Power
Supply
CLK
9
0.1µF
8
7
2
3
Power
Supply
15pF
(including probe
and fixture
capacitance)
4
Figure 8. LVCMOS Test Circuit (VC Function)
VDD
CLK
9
6
10µF
5
1
2
3
10pF
10kΩ
(including probe
and fixture
resistance and
capacitance)
4
0.1µF
8
7
10µF
1
3
4
VDD
5
2
Test Point
6
10
Figure 9. Clipped Sinewave Test Circuit (VC Function)
for AC and DC Measurements
Power
Supply
15pF
(including probe
and fixture
capacitance)
8
7
6
10
10µF
1
5
2
3
4
10pF
10kΩ
(including probe
and fixture
resistance and
capacitance)
NC Function
NC Function
Figure 10. LVCMOS Test Circuit (NC Function)
9
0.1µF
Test Point
CLK
Any state
or floating
Any state
or floating
Rev 1.06
7
VC Function
VC Function
Power
Supply
8
10
Control
Voltage
Control
Voltage
0.1µF
Test Point
CLK
9
5
1
VDD
Test Point
6
10
10µF
Figure 7. Clipped Sinewave Test Circuit (OE Function)
Figure 11. Clipped Sinewave Test Circuit (NC Function)
Page 10 of 38
www.sitime.com
Test Circuit Diagrams for LVCMOS and Clipped Sinewave Outputs (continued)
VDD
Power
Supply
9
0.1µF
8
7
6
10
10µF
SDA
A0/NC
5
1
[11]
Test Point
CLK
2
Any state
or floating
NC
Function
3
15pF
(including probe
and fixture
capacitance)
4
SCL
Figure 12. LVCMOS Test Circuit (I2C Control), DCTCXO mode for AC and DC Measurements
VDD
Power
Supply
8
9
0.1µF
10pF
5
2
1
SDA[11]
A0/NC
6
7
10
10µF
Test Point
CLK
Any state
or floating
NC
Function
(including probe
and fixture
resistance and
capacitance)
4
3
10kΩ
SCL
Figure 13. Clipped Sinewave Test Circuit (I2C Control), DCTCXO mode for AC and DC Measurements
VDD
Power
Supply
CLK
9
0.1µF
8
7
6
10
10µF
1
Test Point
A0/NC
5
2
3
4
10pF
10kΩ
(including probe
and fixture
resistance and
capacitance)
Any state
or floating
NC Function
Figure 14. Clipped Sinewave Test Circuit for Phase Noise Measurements, Applies to All Configurations
(NC Function shown for example only)
Note:
11. SDA is open-drain and may require pull-up resistor if not present in I2C test setup.
Rev 1.06
Page 11 of 38
www.sitime.com
Waveforms
tr
tf
90 % Vdd
50 % Vdd
10 % Vdd
High Pulse
(TH)
Low Pulse
(TL)
Period
Figure 15. LVCMOS Waveform Diagram[12]
tr
tf
80 % Vout
50 % Vout
Vout
20 % Vout
High Pulse
(TH)
Low Pulse
(TL)
Period
Figure 16. Clipped Sinewave Waveform Diagram[12]
Note:
12. Duty Cycle is computed as Duty Cycle = TH/Period.
Rev 1.06
Page 12 of 38
www.sitime.com
Timing Diagrams
90% Vdd
Vdd
Vdd
50% Vdd
T_start
Vdd Pin
Voltage
OE Voltage
CLK Output
CLK Output
HZ
T_start: Time to start from power-off
HZ
T_oe: Time to re-enable the clock output
Figure 18. OE Enable Timing (OE Mode Only)
Figure 17. Startup Timing
Rev 1.06
T_oe
Page 13 of 38
www.sitime.com
2.5 V
55
2.8 V
3.0 V
3.3 V
Rise time (ns)
Duty cycle (%)
51
49
1,05
1,00
0,95
0,90
10
2.5 V
48
30
40
50
Frequency (MHz)
60
10
2.8 V
3.0 V
3.3 V
45
44
43
42
41
40
50
2.5 V
52
46
10
2.8 V
60
3.0 V
3.0 V
3.3 V
48
47
46
45
44
10
40
Frequency (MHz)
50
60
2.5 V
3.3 V
Period Jitter (ps RMS)
1,90
200
100
10
40
Frequency (MHz)
50
1,70
1,50
1,30
1,10
0,90
0,70
0,50
60
10
Figure 23. RMS Phase Jitter, DCTCXO, TCXO (LVCMOS)
2.5 V
48
2.8 V
3.0 V
Phase Jitter (fs RMS)
45
44
43
42
41
10
40
50
2.5 V
500
46
40
Frequency (MHz)
50
60
Figure 24. RMS Period Jitter (LVCMOS)
3.3 V
47
2.8 V
3.0 V
3.3 V
400
300
200
100
60
Frequency (MHz)
Figure 25. IDD DCTCXO (LVCMOS)
Rev 1.06
2.8 V
49
3.3 V
300
40
60
Figure 22. IDD VCTCXO (LVCMOS)
400
50
Figure 21. IDD TCXO (LVCMOS)
2.5 V
40
51
Frequency (MHz)
500
30
Figure 20. Rise Time (LVCMOS)
47
40
Frequency (MHz)
Current consumption (mA)
3.3 V
1,10
Figure 19. Duty Cycle (LVCMOS)
3.0 V
1,15
47
2.8 V
1,20
53
45
2.5 V
1,25
40
Frequency (MHz)
50
60
Figure 26. RMS Phase Jitter, VCTCXO (LVCMOS)
Page 14 of 38
www.sitime.com
6,25
5
3,75
2,5
1,25
-2,5
-3,75
-5
-6,25
-6,25
2.5 V
3,80
3,00
2,80
-5
-3,75 -2,5 -1,25
2.5 V
2,5
3,75
5
2,60
6,25
10
2.8 V
3.0 V
3.3 V
44,5
44,0
43,5
30
35
40
Frequency (MHz)
45
50
55
60
3.0 V
3.3 V
400
300
200
100
40
Frequency (MHz)
50
3.0 V
50
55
60
2.8 V
3.0 V
3.3 V
46
45
44
43
10
15
30
35
40
45
Frequency (MHz)
50
55
60
2.5 V
46,5
2.8 V
3.0 V
3.3 V
46,0
45,5
45,0
44,5
44,0
43,5
43,0
10
15
30
35
40
45
50
55
60
Figure 32. IDD DCTCXO (Clipped Sinewave)
3.3 V
2.5 V
55
2.8 V
3.0 V
3.3 V
53
300
200
100
51
49
47
45
10
40
Frequency (MHz)
50
60
Figure 33. RMS Phase Jitter, VCTCXO (Clipped Sine)
Rev 1.06
45
Frequency (MHz)
400
47
60
Duty cycle (%)
500
2.8 V
35
48
Figure 31. RMS Phase Jitter, DCTCXO, TCXO (Clip Sine)
2.5 V
30
Frequency (MHz)
Figure 30. IDD VCTCXO (Clipped Sinewave)
2.8 V
25
49
Figure 29. IDD TCXO (Clipped Sinewave)
2.5 V
2.5 V
50
45,0
15
15
Figure 28. Rise Time (Clipped Sinewave)
45,5
500
3.3 V
3,20
Figure 27. DCTCXO frequency pull characteristic
10
3.0 V
3,40
DCTCXO pull (ppm)
43,0
2.8 V
3,60
Rise Time (ns)
Frequency deviation (ppm)
Typical Performance Plots (continued)
Page 15 of 38
10
15
30
35
40
Frequency (MHz)
45
50
55
60
Figure 34. Duty Cycle (Clipped Sinewave)
www.sitime.com
Functional Overview
Based on SiTime’s innovative Elite Platform™, the SiT5156
delivers exceptional dynamic performance, i.e. resilience to
environmental stressors such as shock, vibration, and fast
temperature transients. Underpinning the Elite platform are
SiTime’s unique DualMEMS™ temperature sensing
architecture and TurboCompensation™ technologies.
The SiT5156 is designed for maximum flexibility with an
array of factory programmable options, enabling system
designers to configure this precision device for optimal
performance in a given application.
DualMEMS is a noiseless temperature compensation
scheme. It consists of two MEMS resonators fabricated on
the same die substrate. The TempFlat™ MEMS resonator
is designed with a flat frequency characteristic over
temperature whereas the temperature sensing resonator is
by design sensitive to temperature changes. The ratio of
frequencies between these two resonators provides an
accurate reading of the resonator temperature with 20 µK
resolution.
By placing the two MEMS resonators on the same die, this
temperature sensing scheme eliminates any thermal lag
and gradients between resonator and temperature sensor,
thereby overcoming an inherent weakness of legacy quartz
TCXOs.
The DualMEMS temperature sensor drives a state-of-theart CMOS temperature compensation circuit. The
TurboCompensation design, with >100 Hz compensation
bandwidth, achieves a dynamic frequency stability that is
far superior to any quartz TCXO. The digital temperature
compensation enables additional optimization of
frequency stability and frequency slope over temperature
within any chosen temperature range for a given system
design.
The Elite platform also incorporates a high resolution, low
noise frequency synthesizer along with the industry
standard I2C bus. This unique combination enables system
designers to digitally control the output frequency in steps
as low as 5 ppt and over a wide range up to ±3200 ppm.
For more information regarding the Elite platform and its
benefits please visit:
SiTime's breakthroughs section
TechPaper: DualMEMS Temperature Sensing Technology
TechPaper: DualMEMS Resonator TDC
Rev 1.06
Frequency Stability
The SiT5156 comes in three factory-trimmed stability
grades.
Table 14. Stability Grades vs. Ordering Codes
Frequency Stability Over Temperature
Ordering Code
±0.5 ppm
K
±1.0 ppm
A
±2.5 ppm
D
The SiT5156 can be factory programmed for an output
frequency without sacrificing lead time or incurring an
upfront customization cost typically associated with customfrequency quartz TCXOs.
The device supports both LVCMOS and clipped sinewave
output. Ordering codes for the output format are shown below:
Table 15. Output Formats vs. Ordering Codes
Output Format
Ordering Code
LVCMOS
Clipped Sinewave
“C”
In addition to the non-pullable TCXO, the SiT5156 can also
support output frequency tuning through either an analog
control voltage (VCTCXO), or I2C interface (DCTCXO). The
I2C interface enables 16 factory programmed pull-range
options from ±6.25 ppm to ±3200 ppm. The pull range can
also be reprogrammed via I2C to any supported pull-range
value.
Refer to Device Configuration section for details.
Page 16 of 38
www.sitime.com
Pin 1 of the SiT5156 can be factory programmed to support
three modes: Output Enable (OE), Voltage Control (VC), or
No Connect (NC).
The SiT5156 supports 3 device configurations – TCXO,
VCTCXO, and DCTCXO. The TCXO and VCTCXO options
are directly compatible with the quartz TCXO and
VCTCXO.
The
DCTCXO
configuration
provides
performance enhancement by eliminating VCTCXO’s
sensitivity to control voltage noise with an I2C digital
interface for frequency tuning.
Table 16. Pin Configuration Options
Pin 1 Configuration
Operating Mode
Output
OE
TCXO/DCTCXO
Active or High-Z
NC
TCXO/DCTCXO
Active
VC
VCTCXO
Active
When pin 1 is configured as OE pin, the device output is
guaranteed to operate in one of the following two states:
Clock output with the frequency specified in the part
number when Pin 1 is pulled to logic high
Hi-Z mode with weak pull down when pin 1 is pulled to
logic low.
When pin 1 is configured as NC, the device is guaranteed
to output the frequency specified in the part number at all
times, regardless of the logic level on pin 1.
In the VCTCXO configuration, the user can fine-tune the
output frequency from the nominal frequency specified in
the part number by varying the pin 1 voltage. The
guaranteed allowable variation of the output frequency is
specified as pull range. A VCTCXO part number must
contain a valid pull-range ordering code.
Figure 35. Block Diagram – TCXO
TCXO Configuration
The TCXO generates a fixed frequency output, as shown in
Figure 35. The frequency is specified by the user in the
frequency field of the device ordering code and then factory
programmed. Other factory programmable options include
supply voltage, output types (LVCMOS or clipped
sinewave), and pin 1 functionality (OE or NC).
Refer to the Ordering Information section at the end of the
datasheet for a list of all ordering options.
Rev 1.06
Page 17 of 38
www.sitime.com
A VCTCXO, shown in Figure 36, is a frequency control device
whose output frequency is an approximately linear function of
control voltage applied to the voltage control pin. VCTCXOs
have a number of use cases including the VCO portion of a
jitter attenuation/jitter cleaner PLL Loop.
The SiT5156 achieves a 10x better pull range linearity of
250
nsec
FM+ (1 MHz)
>0
nsec
FM (400 KHz)
>0
nsec
SM (100 KHz)
>0
nsec
FM+
> 450
nsec
FM (400 KHz)
> 900
nsec
SM (100 KHz)
> 3450
nsec
NA (s-awk + s-data)/(m-awk/s-data)
Page 31 of 38
www.sitime.com
Table 24. Pin Selectable I2C Address Control[17]
A0
Pin 5
There are two I2C address modes:
I2C Address
1
1101010
Notes:
17. Table 24 is only valid for the DCTCXO device option which supports
I2C control and A0 Device Address Control Pin.
Table 23. Factory Programmed I2C Address Control[16]
I2C Address Ordering Code
Device I2C Address
1
1100001
2
1100010
3
1100011
4
1100100
5
1100101
6
1100110
7
1100111
8
1101000
9
1101001
A
1101010
B
1101011
C
1101100
D
1101101
E
1101110
F
1101111
Notes:
16. Table 23 is only valid for the DCTCXO device option which supports
I2C Control.
Rev 1.06
Page 32 of 38
www.sitime.com
Schematic Example
Figure 49. DCTCXO schematic example
Rev 1.06
Page 33 of 38
www.sitime.com
Package Size – Dimensions (Unit: mm)
Recommended Land Pattern (Unit: mm)
Rev 1.06
Page 34 of 38
www.sitime.com
Layout Guidelines
The SiT5156 uses internal regulators to minimize the
impact of power supply noise. For further reduction
of noise, it is essential to use two bypass capacitors
(0.1 μF and 10 μF). Place the 0.1 μF capacitor as
close to the VDD pin as possible, typically within
1 mm to 2 mm. Place the 10 μF capacitor within
2 inches of the device VDD and VSS pins.
It is also recommended to connect all NC pins to the
ground plane and place multiple vias under the GND
pin for maximum heat dissipation.
The SiT5156 Super-TCXOs are precision timing devices.
Proper PCB solder and cleaning processes must be
followed to ensure best performance and long-term
reliability.
For additional layout recommendations, refer to the
Best Design Layout Practices.
Rev 1.06
No Ultrasonic or Megasonic Cleaning: Do not subject
the SiT5156 to an ultrasonic or megasonic cleaning
environment. Otherwise, permanent damage or long-term
reliability issues to the device may result.
No external cover. Unlike legacy quartz TCXOs, the
SiT5156 is engineered to operate reliably, without
performance degradation in the presence of ambient
disturbers such as airflow and sudden temperature
changes. Therefore, the use of an external cover
typically required by quartz TCXOs is not needed.
Reflow profile: For mounting these devices to the PCB,
IPC/JEDEC J-STD-020 compliant reflow profile must be
used. Device performance is not guaranteed if soldered
manually or with a non-compliant reflow profile.
PCB cleaning: After the surface mount (SMT)/reflow
process, solder flux residues may be present on the PCB
and around the pads of the device. Excess residual solder
flux may lead to problems such as pad corrosion,
elevated leakage currents, increased frequency aging, or
other performance degradation. For optimal device
performance and long-term reliability, thorough cleaning
to remove all the residual flux and drying of the PCB is
required as shortly after the reflow process as possible.
Water soluble flux is recommended. In addition, it is
highly recommended to avoid the use of any “no clean”
flux. However, if the reflow process necessitates the use
of “no clean” flux, then utmost care should be taken to
remove all residual flux between SiTime device and the
PCB. Note that ultrasonic PCB cleaning should not be
used with SiTime oscillators.
For additional manufacturing guidelines and marking/
tape-reel instructions, refer to SiTime Manufacturing
Notes.
Page 35 of 38
www.sitime.com
Table 25. Additional Information
Document
Description
Download Link
ECCN #: EAR99
Five character designation used on the commerce
Control List (CCL) to identify dual use items for export
control purposes.
HTS Classification Code:
8542.39.0000
A Harmonized Tariff Schedule (HTS) code developed by —
the World Customs Organization to classify/define
internationally traded goods.
Evaluation Boards
SiT6722EB Evaluation Board User Manual
https://www.sitime.com/support/user-guides
Demo Board
SiT6702DB Demo Board User Manual
Time Machine II
MEMS oscillator programmer
http://www.sitime.com/support/time-machine-oscillator-programmer
Time Master Web-based
Configurator
Web tool to establish proper programming
https://www.sitime.com/time-master-web-based-configurator
Manufacturing Notes
Tape & Reel dimension, reflow profile and other
manufacturing related info
https://www.sitime.com/support/resource-library?filter=531
Qualification Reports
RoHS report, reliability reports, composition reports
http://www.sitime.com/support/quality-and-reliability
Performance Reports
Additional performance data such as phase noise,
current consumption and jitter for selected frequencies
http://www.sitime.com/support/performance-measurement-report
Termination Techniques
Termination design recommendations
http://www.sitime.com/support/application-notes
Layout Techniques
Layout recommendations
Rev 1.06
Page 36 of 38
www.sitime.com
Revision History
Table 26. Revision History
Version
Release Date
0.1
0.15
05/10/2016
08/04/2016
0.16
0.2
0.4
09/12/2016
09/21/2016
12/19/2016
0.5
07/21/2017
0.51
08/20/2017
0.52
11/24/2017
0.55
02/05/2018
0.60
1.0
03/01/2018
06/26/2018
1.01
1.02
1.03
07/03/2018
07/04/2018
08/03/2018
1.04
12/04/2018
1.05
03/28/2020
1.06
05/23/2020
Rev 1.06
Change Summary
First release, advanced information
Replaced QFN package with SOIC-8 package
Added 10 µF bypass cap requirement
Updated test circuits to reflect both new bypass cap requirement and SOIC-8 package
Update Table 1 (Electrical Characteristics)
Updated test circuit diagrams
Revised Table 1 (Electrical Characteristics)
Added DCTCXO mode
Added I2C information
Added I2C
Added 5.0 mm x 3.2 mm package information
Updated Table 1 (Electrical Characteristics)
Changed to preliminary
Updated 5.0 mm x 3.2 mm package dimensions
Updated part ordering info
Misc. corrections
Updated the Thermal Characteristics table
Added more on Manufacturing Guideline section
Added View labels to Package Drawings
Updated the frequency vs. output type changes to 60 MHz
Updated links and notes
Added 105°C support, updated Ordering Information
Updated Electrical Characteristics tables.
Added Performance Plots.
Improved readability.
Fixed bad hyperlinks.
Updated I2C specifications in Table 3 (Input Characteristics).
Updated Mechanical Shock Resistance, Table 11 (Environmental Compliance)
Added test circuit for clipped sinewave phase noise.
Revised phase noise specifications. Updated package outline drawing.
Updated conditions for one day and one year aging specs.
Various formatting updates.
Formatting updates
Fixed APR typo for 125 ppm pull range and 0.5 ppm stability, Table 18
Fixed test condition typo (10 MHz to 50 MHz) for phase jitter in Table 4
Corrected typos in package drawing dimensions
Added nominal value for LVCMOS output impedance
Increased Mechanical Shock Resistance to 30000g
Added “X” ordering code for 250u Tape and Reel
Improved I2C bus frequency specification
Updated Manufacturing Guidelines to recommend water soluble flux
Corrected typos for write/read I2C polarity
Clarified PCB cleaning instructions
Added link to SiT6702DB
Added ECCN and HTS codes
Formatting updates
Added note for Theta JA
Updated DCTCXO Delay and Settling Time table
Added max and min input voltage to the Absolute Maximum Limits table
Updated output impedance typical spec
Clarified Initial Tolerance specification condition
Relabeled “First Pulse Accuracy” parameter to “Time to Rated Frequency Stability” for clarity
Revised Parallel Data Format section description and figures
Page 37 of 38
www.sitime.com
SiTime Corporation, 5451 Patrick Henry Drive, Santa Clara, CA 95054, USA | Phone: +1-408-328-4400 | Fax: +1-408-328-4439
© SiTime Corporation 2016-2020. The information contained herein is subject to change at any time without notice. SiTime assumes no responsibility or liability for any loss, damage
or defect of a Product which is caused in whole or in part by (i) use of any circuitry other than circuitry embodied in a SiTime product, (ii) misuse or abuse including static discharge, neglect
or accident, (iii) unauthorized modification or repairs which have been soldered or altered during assembly and are not capable of being tested by SiTime under its normal test conditions, or
(iv) improper installation, storage, handling, warehousing or transportation, or (v) being subjected to unusual physical, thermal, or electrical stress.
Disclaimer: SiTime makes no warranty of any kind, express or implied, with regard to this material, and specifically disclaims any and all express or implied warranties, either in fact or by
operation of law, statutory or otherwise, including the implied warranties of merchantability and fitness for use or a particular purpose, and any implied warranty arising from course of dealing or
usage of trade, as well as any common-law duties relating to accuracy or lack of negligence, with respect to this material, any SiTime product and any product documentation. Products sold by
SiTime are not suitable or intended to be used in a life support application or component, to operate nuclear facilities, or in other mission critical applications where human life may be involved
or at stake. All sales are made conditioned upon compliance with the critical uses policy set forth below.
CRITICAL USE EXCLUSION POLICY
BUYER AGREES NOT TO USE SITIME'S PRODUCTS FOR ANY APPLICATION OR IN ANY COMPONENTS USED IN LIFE SUPPORT DEVICES OR TO OPERATE NUCLEAR
FACILITIES OR FOR USE IN OTHER MISSION-CRITICAL APPLICATIONS OR COMPONENTS WHERE HUMAN LIFE OR PROPERTY MAY BE AT STAKE.
SiTime owns all rights, title and interest to the intellectual property related to SiTime's products, including any software, firmware, copyright, patent, or trademark. The sale of SiTime products does
not convey or imply any license under patent or other rights. SiTime retains the copyright and trademark rights in all documents, catalogs and plans supplied pursuant to or ancillary to the sale
of products or services by SiTime. Unless otherwise agreed to in writing by SiTime, any reproduction, modification, translation, compilation, or representation of this material shall be strictly
prohibited.
Rev 1.06
Page 38 of 38
www.sitime.com
