NOTES:
1. PARTS TO BE BULK PACKED.
2. SOLDER CONTACTS ARE PRESSED INTO CONNECTOR.
SIZE 12 CONTACTS AND SIZE 26 CONTACTS (POSITIONS 3, 7, 8) FACE TOP KEY (UP).
SIZE 26 CONTACTS (POSITIONS 4-6) FACE DOWN.
3. ALL DIMENSIONS ARE FOR REFERENCE ONLY EXCEPT WHERE NOTED WITH TOLERANCE.
0.700
0.745
FLAT
0.153
0.050
0.550
0.380 ±0.015
(6) #26 SOCKET CONTACT
SOLDER CUP STYLE
MAT'L: COPPER ALLOY
GOLD PLATED
CUSTOMER PRINT
KEYWAY
3
8
7
7
1.000
FLATS
1
4
FACE VIEW
0.70
3
1
(2) #12 SOCKET CONTACT
SOLDER CUP STYLE
MAT'L: COPPER ALLOY
GOLD PLATED
6
0.075
6
5
KEYWAY
8
2
2
0.367 ±0.015
HEX NUT
MAT'L: UV PBT, BLACK
GASKET
MAT'L: RUBBER,
BLACK
PANEL CONNECTOR, FEMALE
4
5
WIRE VIEW
19.1
0.750
0.63
20.1
0.790
PART
NUMBER:
W4B82-8SG-300
0.980
RECOMMENDED PANEL CUT-OUT
TOLERANCE ±.003 [0.08]
CUSTOMER APPROVAL
THIS DOCUMENT CONTAINS CONFIDENTIAL
INFORMATION PROPRIETARY TO CONXALL
CORPORATION. ANY REPRODUCTION,
DISCLOSURE, OR USE OF THIS
DOCUMENT /INFORMATION IS EXPRESSLY
PROHIBITED UNLESS AUTHORIZED IN
WRITING BY CONXALL CORPORATION.
APPROVED BY:
DATE:
RoHS COMPLIANT
A
AB
05-10-19
REV.
INIT.
DATE
ALL INFORMATION ILLUSTRATED IS
THE PROPERTY OF "CONXALL
CORPORATION." UNAUTHORIZED
DUPLICATION OR DISTRIBUTION OF
THIS DOCUMENT IS PROHIBITED.
ALL UNITS ARE IN FEET,
INCHES, FRACTION OF INCHES
AND DECIMALS.
= CRITICAL CHARACTERISTIC
FLAG PER SPEC. XXXX
RELEASE PER DOR 14-6281TC
DESCRIPTION
ORIG. DRAWN BY:
DATE:
07-18-14
AB
CHECKED BY:
601 E. WILDWOOD VILLA PARK, IL 60181
TITLE:
APPROVED BY:
SCALE
SIZE
SHEET
NTS
B
1 OF 1
FILE:
SAME AS P/N
DIRECTORY:
SLW
PANEL CONNECTOR KIT
(2)#12 + (6)#26 SOCKET CONTACTS, SOLDER
MULTI-CON-X, WEATHER RESISTANT
CUSTOMER:
STANDARD PRODUCT
PART
NUMBER:
W4B82-8SG-300
REV
A
很抱歉,暂时无法提供与“W4B82-8SG-300”相匹配的价格&库存,您可以联系我们找货
