The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information.
Push-Pull Connectors
HR10 Series
■Overview
The HR10 series connectors are push-pull coupling
type micro-connectors.They have been developed
in response to customers' needs for miniaturization,
high density, and easy handling.The HR10 series
connectors offer light weight and assure high
reliavility and durability as well as easy "push-pull"
operation.
You may apply the HR10 series connectors to all
kinds of small-sized electronic equipment requiring
high reliability.However, these simple but refined
connectors are most suitable for portable electronic
equipment which requires good appearance.
■Features
1. "A LITTLE GIANT"
The most compact HR10 series is as slender as a cigarette but it fits every application with well-balanced, simplified
layout in limited space.
2. Easy "PUSH-PULL" OPERATION
One touch "push-pull" coupling mechanism assures easy and quick connecting and disconnecting. You can couple it
accurately just by pushing any part of the connector housing.
3. Polarization
Five-key system permits only one way of coupling so that you can find right position to connect even when blind mating.
4. Protection of connection pin
A connector pin is located to avoid any damage which may be caused when blind mating.
5. High density
The space-saving "push-pull" mechanism facilitates multi-installation of connectors.
6. Easy wiring and mounting
No use of screws makes wireing and mounting easier.
7. Simple and refined appearance
Simple and well designed connectors with matte finish enhance the appearance of the equipment.
179
HR10 Series●Push-Pull Connectors
■Materials
Part
Material
Finish
Shell
Zinc alloy and Brass
Satin-finished nickel plate
Insulator
Polyamide / PBT
(Blue or Black)
Male terminal
Brass / Bronze
Silver or Gold plating
Female terminal
Beryllium / Phosphor bronze
■Ordering information
HR10 A − 7 P − 4 P A (**)
1
2
3
4
5
6
7
8
1Series name:HR10 Series
4Shell type P:Plug
2Type A:Low-cost model
J:Jack
G:Shielded
R:Receptacle
E:Built-in capacitor
5Number of contacts
B:Coaxail terminal
6Type of terminal
D:Connector sleeve rotation inhibited
3Shell size: Plug mating part outside diameter in mm
7Terminal form C:Crimp connection system
P:Male terminal
S:Female terminal
Other specifications:2 numerical digits will be
8
added when there is a specifications change other
than shown in positions 1to 7
180
HR10 type
■Plug
HR10-7P-6P(73)
(An example in shape)
Unit : mm
HRS No.
HR10-10P-12P(73)
Part No.
No.of pins
A
ØB
ØC
ØD
Weight
110-0021-6-73
HR10-7P-4P(73)
4
28.5
11
7
5.2
8g
110-0022-9-73
HR10-7P-4S(73)
4
28.5
11
7
5.2
8g
110-0023-1-73
HR10-7P-6P(73)
6
28.5
11
7
5.2
8g
110-0024-4-73
HR10-7P-6S(73)
6
28.5
11
7
5.2
8g
110-0025-7-73
HR10-10P-12P(73)
12
32.5
14
9.5
7.2
15g
110-0026-0-73
HR10-10P-12S(73)
12
32.5
14
9.5
7.2
15g
■Receptacle
HR10-7R-6S(73)
HR10-10R-12S(73)
Unit : mm
HRS No.
Part No.
No.of pins
A
ØB
ØC
D
E
Weight
110-0031-0-73
HR10-7R-4S(73)
4
14
11
8.85
M8×0.5
10
3.5g
110-0032-2-73
HR10-7R-4P(73)
4
14
11
8.85
M8×0.5
10
3.5g
110-0033-5-73
HR10-7R-6S(73)
6
14
11
8.85
M8×0.5
10
3.5g
110-0034-8-73
HR10-7R-6P(73)
6
14
11
8.85
M8×0.5
10
3.5g
110-0035-0-73
HR10-10R-12S(73)
12
16
14
11.9
M11×0.75
13
6g
110-0036-3-73
HR10-10R-12P(73)
12
16
14
11.9
M11×0.75
13
6g
Remarks : For mounting holes, see page 198.
181
■Plug (PCB dip type)
HR10-7R-6SA(73)
Dip post dia.
Ø0.55
HR10-10R-12SA(73)
Unit : mm
No.of pins
ØA
ØB
C
D
E
F
G
Weight
110-0059-9-73
HRS No.
HR10-7R-4SA(73)
Part No.
4
11
8.85
M8×0.5
10
6.3
0.5
15.5
3g
110-0050-4-73
HR10-7R-6SA(73)
6
11
8.85
M8×0.5
10
6.3
0.5
15.5
3g
110-0061-0-73
HR10-7R-6PA(73)
6
11
8.85
M8×0.5
10
6.3
0.5
15.5
3g
110-0049-5-73
HR10-10R-12SA(73)
12
14
11.9
M11×0.75
13
6.3
0.5
15.5
5g
110-0055-8-73
HR10-10R-12PA(73)
12
14
11.9
M11×0.75
13
6.3
0.5
15.5
5g
Remarks : 1.For mounting holes, see page 198.
2.For dip post arrangement, see page 193.
■Jack
HR10-7J-6S(73)
Unit : mm
No.of pins
A
ØB
ØC
D
Weight
110-0027-2-73
HRS No.
HR10-7J-4S(73)
Part No.
4
28.5
11
8.85
5.2
7g
110-0028-5-73
HR10-7J-4P(73)
4
28.5
11
8.85
5.2
7g
110-0029-8-73
HR10-7J-6S(73)
6
28.5
11
8.85
5.2
7g
110-0030-7-73
HR10-7J-6P(73)
6
28.5
11
8.85
5.2
7g
110-0037-6-73
HR10-10J-12S(73)
12
32.5
14
11.9
7.2
14g
110-0038-9-73
HR10-10J-12P(73)
12
32.5
14
11.9
7.2
14g
182
HR10A·10G Type
■Plud (Solder type)
HR10A-7P-6P(73)
Unit : mm
HRS No.
HR10A-10P-12P(73)
Part No.
No.of pins
A
ØB
ØC
ØD
Weight
110-0301-2-73
HR10A-7P-4P(73)
4
35
11.5
7
5
9g
110-0302-5-73
HR10A-7P-4S(73)
4
35
11.5
7
5
9g
110-0318-5-73
HR10A-7P-5P(73)
5
35
11.5
7
5
9g
110-0319-8-73
HR10A-7P-5S(73)
5
35
11.5
7
5
9g
110-0303-8-73
HR10A-7P-6P(73)
6
35
11.5
7
5
9g
110-0304-0-73
HR10A-7P-6S(73)
6
35
11.5
7
5
9g
110-0407-3-73
HR10A-10P-10P(73)
10
43
14.7
9.5
7
16g
110-0408-6-73
HR10A-10P-10S(73)
10
43
14.7
9.5
7
16g
110-0401-7-73
HR10A-10P-12P(73)
12
43
14.7
9.5
7
16g
110-0402-0-73
HR10A-10P-12S(73)
12
43
14.7
9.5
7
16g
110-0713-0-73
HR10A-13P-20P(73)
19
13
7
37g
110-0716-8-73
HR10A-13P-20S(73)
19
13
7
37g
■Plug (Crimp type)
HR10A-7P-6PC(73)
Unit : mm
HRS No.
HR10A-10P-12PC(73)
No.of pins
A
ØB
ØC
ØD
Weight
110-0501-1-73
HR10A-7P-4PC(73)
Part No.
4
35
11.5
7
5
9g
110-0502-4-73
HR10A-7P-4SC(73)
4
35
11.5
7
5
9g
110-0503-7-73
HR10A-7P-6PC(73)
6
35
11.5
7
5
9g
110-0504-0-73
HR10A-7P-6SC(73)
6
35
11.5
7
5
9g
110-0601-6-73
HR10A-10P-10PC(73)
10
43
14.7
9.5
7
16g
110-0602-9-73
HR10A-10P-10SC(73)
10
43
14.7
9.5
7
16g
110-0603-1-73
HR10A-10P-12PC(73)
12
43
14.7
9.5
7
16g
110-0604-4-73
HR10A-10P-12SC(73)
12
43
14.7
9.5
7
16g
110-0701-0-73
HR10A-13P-20PC(73)
19
13
7
37g
110-0702-3-73
HR10A-13P-20SC(73)
19
13
7
37g
183
■Receptacle (Solder type)
HR10G-10R-12S(71)
HR10A-7R-6S(73)
Unit : mm
HRS No.
Part No.
No.of pins A ØB ØC
D
E Weight
HRS No.
Part No.
No.of pins A ØB ØC
D
E Weight Remarks
110-0305-3-73 HR10A-7R-4S(73)
4
14
11 8.85 M8×0.5
10
3g
110-1601-1-73 HR10G-7R-4S(73)
4
14
11 8.85 M8×0.5
10
3g
110-0306-6-73 HR10A-7R-4P(73)
4
14
11 8.85 M8×0.5
10
3g
110-1602-4-73 HR10G-7R-4P(73)
4
14
11 8.85 M8×0.5
10
3g
110-0320-7-73 HR10A-7R-5S(73)
5
14
11 8.85 M8×0.5
10
3g
110-1605-2-73 HR10G-7R-6S(73)
6
14
11 8.85 M8×0.5
10
3g
110-0321-0-73 HR10A-7R-5P(73)
5
14
11 8.85 M8×0.5
10
3g
110-1606-5-73 HR10G-7R-6P(73)
6
14
11 8.85 M8×0.5
10
3g
110-0307-9-73 HR10A-7R-6S(73)
6
14
11 8.85 M8×0.5
10
3g
110-1607-8-71 HR10G-10R-10S(71)
10
16
14 11.9 M11×0.75 13
5g
110-0308-1-73 HR10A-7R-6P(73)
6
14
11 8.85 M8×0.5
10
3g
110-1608-0-73 HR10G-10R-10P(73)
10
16
14 11.9 M11×0.75 13
5g
110-0409-9-71 HR10A-10R-10S(71)
10
16
14 11.9 M11×0.75 13
5g
110-1609-3-71 HR10G-10R-12S(71)
12
16
14 11.9 M11×0.75 13
5g
110-0410-8-73 HR10A-10R-10P(73)
10
16
14 11.9 M11×0.75 13
5g
110-1610-2-73 HR10G-10R-12P(73)
12
16
14 11.9 M11×0.75 13
5g
110-0403-2-71 HR10A-10R-12S(71)
12
16
14 11.9 M11×0.75 13
5g
110-0404-5-73 HR10A-10R-12P(73)
12
16
14 11.9 M11×0.75 13
5g
110-0714-2-73 HR10A-13R-20S(73)
19.2 18 15.4 M14×0.75 17
8g
110-0715-5-73 HR10A-13R-20P(73)
20.2 18 15.4 M14×0.75 17
8g
Shield
type
■Receptacle (Crimp type)
HR10A-7R-6SC(73)
HR10G-10R-12SC(71)
Unit : mm
HRS No.
Part No.
No.of pins A ØB
C
D E
F Weight
HRS No.
Part No.
No.of pins A ØB
C
D E F Weight Remarks
110-0506-5-73 HR10A-7R-4SC(73)
4
11 8.85 M8×0.5
10 6.3 12
3g
110-1701-6-73 HR10G-7R-4SC(73)
4
11 8.85 M8×0.5
10 6.3 12
3g
110-0505-2-73 HR10A-7R-4PC(73)
4
11 8.85 M8×0.5
10 6.3 12.2
3g
110-1702-9-73 HR10G-7R-4PC(73)
4
11 8.85 M8×0.5
10 6.3 12.2
3g
110-0508-0-73 HR10A-7R-6SC(73)
6
11 8.85 M8×0.5
10 6.3 12
3g
110-1705-7-73 HR10G-7R-6SC(73)
6
11 8.85 M8×0.5
10 6.3 12
3g
110-0507-8-73 HR10A-7R-6PC(73)
6
11 8.85 M8×0.5
10 6.3 12.2
3g
110-1706-0-73 HR10G-7R-6PC(73)
6
11 8.85 M8×0.5
10 6.3 12.2
3g
110-0606-0-71 HR10A-10R-10SC(71)
10
14 11.9 M11×0.75 13 6.3 12
5g
110-1707-2-71 HR10G-10R-10SC(71)
10
5g
110-0605-7-71 HR10A-10R-10PC(71)
10
14 11.9 M11×0.75 13 6.3 12.2
5g
110-1708-5-71 HR10G-10R-10PC(71)
10
5g
110-0608-5-71 HR10A-10R-12SC(71)
12
5g
110-1709-8-71 HR10G-10R-12SC(71)
12
5g
110-0607-2-71 HR10A-10R-12PC(71)
12
5g
110-1710-7-73 HR10G-10R-12PC(73)
12
5g
110-0703-6-73 HR10A-13R-20SC(73)
18 15.4 M14×0.75 17 9.3 15
8g
110-1711-0-73 HR10G-13R-20SC(73)
8g
110-0704-9-73 HR10A-13R-20PC(73)
8g
110-1712-2-73 HR10G-13R-20PC(73)
8g
184
Shield
type
■Receptacle (Dip type)
Dip post dia.
0.2×0.5
HR10A-7R-6SB(73)
HR10G-10R-12SB(71)
Unit : mm
HRS No.
110-0314-4-73
110-0315-7-73
110-0322-2-73
110-0316-0-73
110-0317-2-73
110-0413-6-71
110-0414-9-71
110-0415-1-71
110-0416-4-71
110-0707-7-73
110-0708-0-73
110-1801-0-73
110-1802-3-73
110-1805-1-73
110-1806-4-73
110-1807-7-71
110-1808-0-71
110-1809-2-71
110-1810-1-71
110-1811-4-73
110-1812-7-73
Part No.
HR10A-7R-4SB(73)
HR10A-7R-4PB(73)
HR10A-7R-5SB(73)
HR10A-7R-6SB(73)
HR10A-7R-6PB(73)
HR10A-10R-10SB(71)
HR10A-10R-10PB(71)
HR10A-10R-12SB(71)
HR10A-10R-12PB(71)
HR10A-13R-20SB(73)
HR10A-13R-20PB(73)
HR10G-7R-4SB(73)
HR10G-7R-4PB(73)
HR10G-7R-6SB(73)
HR10G-7R-6PB(73)
HR10G-10R-10SB(71)
HR10G-10R-10PB(71)
HR10G-10R-12SB(71)
HR10G-10R-12PB(71)
HR10G-13R-20SB(73)
HR10G-13R-20PB(73)
No.of pins
ØA
ØB
C
D
E
F
G
4
4
5
6
6
10
10
12
12
4
6
6
10
10
12
12
11
11
11
11
14
14
14
14
18
18
11
11
11
11
14
14
14
14
18
18
8.85
8.85
8.85
8.85
8.85
11.9
11.9
11.9
11.9
15.4
15.4
8.85
8.85
8.85
8.85
11.9
11.9
11.9
11.9
15.4
15.4
M8×0.5
M8×0.5
M8×0.5
M8×0.5
M8×0.5
M11×0.75
M11×0.75
M11×0.75
M11×0.75
M14×0.75
M14×0.75
M8×0.5
M8×0.5
M8×0.5
M8×0.5
M11×0.75
M11×0.75
M11×0.75
M11×0.75
M14×0.75
M14×0.75
10
10
10
10
10
13
13
13
13
17
17
10
10
10
10
13
13
13
13
17
17
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
9.3
9.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
6.3
9.3
9.3
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
15.6
15.6
15.6
15.6
15.6
15.6
15.6
15.6
17.8
17.8
15.6
15.6
15.6
15.6
15.6
15.6
15.6
15.6
17.8
17.8
Weight Remarks
3g
3g
3g
3g
3g
5g
5g
5g
5g
8g
8g
3g
3g
3g
3g
5g
5g
5g
5g
8g
8g
Shield type
■Dust cap
HR10-7R-C
Unit : mm
HRS No.
110-0058-6-00
Part No.
HR10-7R-C
110-0052-0-00
HR10-10R-C
110-0452-8-00
HR10A-13R-C
ØA
B
ØC
ØD
ØE
11
7
8
11.2
13
14
8.5
10.8
14
15
17.5
11.5
14
18.1
19
185
■Jack (Solder type)
HR10A-7J-6S(73)
Unit : mm
HRS No.
110-0309-4-73
HR10A-10J-12S(73)
Part No.
HR10A-7J-4S(73)
No.of pins
A
ØB
ØC
ØD
Weight
4
35.3
11
8.85
5.5
9g
110-0310-3-73
HR10A-7J-4P(73)
4
35.3
11
8.85
5.5
9g
110-0311-6-73
HR10A-7J-6S(73)
6
35.3
11
8.85
5.5
9g
110-0312-9-73
HR10A-7J-6P(73)
6
35.3
11
8.85
5.5
9g
110-0411-0-73
HR10A-10J-10S(73)
10
43
14
11.9
7
16g
110-0412-3-73
HR10A-10J-10P(73)
10
43
14
11.9
7
16g
110-0405-8-73
HR10A-10J-12S(73)
12
43
14
11.9
7
16g
110-0406-0-73
HR10A-10J-12P(73)
12
43
14
11.9
7
16g
■Jack (Crimp type)
HR10A-7J-6SC(73)
Unit : mm
HRS No.
186
Part No.
No.of pins
A
ØB
ØC
ØD
Weight
110-0510-2-73
HR10A-7J-4SC(73)
4
35.3
11
8.85
5.5
9g
110-0512-8-73
HR10A-7J-6SC(73)
6
35.3
11
8.85
5.5
9g
110-0610-7-73
HR10A-10J-10SC(73)
10
43
14
11.9
5.5
16g
110-0612-2-73
HR10A-10J-12SC(73)
12
43
14
11.9
5.5
16g
110-0705-1-73
HR10A-13J-20SC(73)
18
15.4
8.5
37g
110-0706-4-73
HR10A-13J-20PC(73)
18
15.4
8.5
37g
HR10B Type Connector
The HR10B connector combines 10 signal lines and one coaxial contact in the standard number 10 shell. Electrical
performance are same as HR10A connector except coaxial contacts. Performance specifications for the coaxial
contacts are on the next page.
■Plug
HR10B-10P-10PC(73)
Unit : mm
HRS No.
Part No.
A
ØB
Applicable coaxial contact
110-0901-0-73
HR10B-10P-10PC(73)
50
5
HR10B-2.5CJ(73)
110-0906-3-73
HR10B-10PA-10PC(73)
43
7
HR10B-2.5CJ(73)
■Receptacle
HR10B-10R-10SC(71)
Unit : mm
HRS No.
Part No.
110-0902-2-71
HR10B-10R-10SC(71)
HR10B-2.5CP(73)
187
■Coaxial contacts
The coaxial contacts shown here are for use with the HR10B connector.These contacts have locking barbs and are
inserted from the rear of connector.Please use the following information to select the correct terminals.
■Material
■Performance
Part
Material
Finish
Description
Test data
Plug shell
Brass
Gold plating
Impedance
50ø
Jack shell
Brass
Gold plating
Insulation resistance
1000Mø or more at DC250V
Insulator
Tetrafluoride resin
Contact resistance
Center 6.5mø or less and outer 4mø or less at DC1A
Male pin
Phosphor bronze
Gold plating
Withstanding voltage
AC250V r.m.s for 1minute
Female pin
Beryllium copper
Gold plating
V.S.W.R
1.3 or less for 0 to 1000MHz
Pull force
4.9N 500gf or more
■Plug
(clamp)
HR10B-2.5CP(73)
Unit : mm
HRS No.
Part No.
Applicable cable
Applicable connector
110-0904-8-73
HR10B-2.5CP(73)
0.8D-QEW-CW
(By Fjikura wire)
HR10B-10R-10SC(71)
■Jack
(clamp)
HR10B-2.5CJ(73)
Unit : mm
HRS No.
110-0903-5-73
188
Part No.
Applicable cable
HR10B-2.5CJ(73)
0.8D-QEW-CW
(By Fjikura wire)
HR10B-10P-10PC(71)
■Cable connecting methods
HR10B-2.5CP
HR10B-2.5CJ
1.Cable end treatment
Fig.1
3.Crimping cable outer conductor
Fig.3
11±0.5
A
(HR10B-2.5CP)
1.4±0.2
(2.5)
Clamp metal
3.7±0.2
Slit cable outer jaket
2 pieces (180° reverse side)
1.Dimensions for cable end treatment are shown in
Fig 1.
2.Termination is described below.
(1).Strip cable outer jacket as indicated.
(2).Slit outer jacket on both sides per Fig.1.
(3).Fold back outer cover.
(4).Remove insulator from cable.
2.Soldering male pin to cable center
conductor.
Fig.2
Malu pin or Female pin
Soldering
Connector
Remove excess insulator
material (remaining after
clamping is complated)
with a knife or aimilarobject.
Table 1 dimenshion A
2.5CP
2.5CJ
1.5±0.2mm
0 +0.3
0 mm
1.Insert cable prepared per PROCESS 2 into the
connector.The cable should be inserted until it
comes to a full stop.This may be verified by
checking the dimension from the side of the
connector to the top of the contact(as indicated in
Fig 3). This dimension should be A.
2.Crimp this installed metal clamp with tool HR10TC-01 per Fig.3 and remove excess insulation with
a knife.
It is possible to pull back the contact.
Hold cable when crimping metal clamp and keep
the dimension to show in Fig 3. after crimping metal
clamp.
Should fix flush
Contact fixing jig
such as vise
1.Solder male pin to cable center conductor as
indicated in Fig.2.
(1).Pre-solder the solder pot of pin with Ø0.5mm
string solder.
(2).Male pin should fit flush against the cable
insulator as shown.
(3).Remove any excess solder from the pin with a
knife.This surface must be smooth.
(4).A properly soldered terminal will yield 500gf
when stretched.
189
HR10A-[ ]T Type (Threaded Coupling Type)
HR10A-( )T connector is a new product having a threaded coupling locking mechanism.Electric parformance is same as
HR10 and HR10A push-pull locking type connector.
■Plug (Solder type)
HR10A-10TP-12P(73)
Unit : mm
HRS No.
110-0331-3-73
Part No.
No.of pins ØA
HR10A-7TP-6P(73)
6
12
B
ØC
D
ØE
M10×0.75
7
M8×0.5
5
110-0331-3-74
HR10A-7TP-6P(74)
6
12
M10×0.75
7
M8×0.5
5
110-0432-0-73
HR10A-10TP-12P(73)
12
17
M13×0.75
9.5
M8×0.5
7
110-0446-5-73
HR10A-10TPA-12S(73)
12
17
M13×0.75
9.5
M8×0.5
7
Remarks
Gold plating
110-1101-9-73
HR10A-10WTP-12P(73)
12
15
M12×0.75
9.5
M11×0.75
6.5
110-1106-2-73
HR10A-10WTP-12S(73)
12
15
M12×0.75
9.5
M11×0.75
6.5
110-1015-9-73
HR10A-13TPD-20P(73)
M17×1
13
M11×0.75
7
*Waterproof plug need resin filling inside when connector assembly.
When mated, the connector against water penetration.
■Plug (Crimp type)
HR10A-10TP-12PC(73)
Unit : mm
HRS No.
110-0455-6-73
190
Part No.
HR10A-10TP-12PC(73)
No.of pins
12
HR10A-10TR-12S(73)
Unit : mm
HRS No.
Part No.
No.of pins
A
ØB
C
ØD
E
F
Remarks
Gold plating
110-0089-0-73 HR10-7TR-6S(73)
6
M10×0.75
6.3
M8×0.5
11
14
10
110-0453-0-73 HR10A-10TR-12S(73)
12
M13×0.75
6.3
M11×0.75
14
16
13
110-1104-7-73 HR10A-10WTR-12S(73)
12
M12×0.75
6.8
M10.5×0.75
14
16
13
Remarks:For mounting hole, see page 192(10TR,10WTR) 198(7TR)
HR10A-10TR-12SC(73)
Unit : mm
HRS No.
Part No.
No.of pins ØA
B
C
110-0456-9-73 HR10A-10TR-12SC(73)
12
14
12
6.3
110-1002-7-73 HR10A-13TR-20SC(73)
15
9.3
ØD
E
F
M13×0.75 M11×0.75
M17×1
M14×0.75
13
17
Dip post Ø
H
HR10A-10TR-12PB(73)
Unit : mm
HRS No.
Part No.
110-0330-0-73 HR10A-7TR-6SA(73)
No.of pins ØA
6
11
B
C
D
E
F
E
H
M10×0.75
M8×0.5
10
6.3
0.5
15.5
Ø0.55
110-0433-3-73 HR10A-10TR-12SB(73)
12
14
M13×0.75
M11×0.75
13
6.3
0.5
15.5 0.2×0.5
110-0457-1-73 HR10A-10TR-12PB(73)
12
14
M13×0.75
M11×0.75
13
6.3
0.5
15.5 0.2×0.5
M11×0.75
13
6.3
0.5
13
6.8
110-0445-2-73 HR10A-10TR-12PE(73)
12
14
M13×0.75
110-1102-1-73 HR10A-10WTR-12SB(73)
12
14
M12×0.75 M10.5×0.75
14
0.2×0.5
15.5 0.2×0.5
110-1013-3-73 HR10A-13TR-20PB(73)
M17×1
M14×0.75
17
9.3
17.8 0.2×0.5
110-1014-6-73 HR10A-13TR-20SB(73)
M17×1
M14×0.75
17
9.3
17.8 0.2×0.5
Remarks : 1.For mounting holes, see page 192. However, 7TR size shell be referred to page 198 on the shell size 7.
191
■Jack (Solder type)
HR10A-10TJ-12S(73)
Unit : mm
HRS No.
Part No.
110-0436-1-73 HR10A-10TJ-12S(73)
No.of pins ØA
B
12
14.7 41.3
110-0459-7-73 HR10A-10TJ-12P(73)
12
14.7 41.3
110-1103-4-73 HR10A-10WTJ-12S(73)
12
14
46.5
ØC
D
7
M13×0.75
7
M13×0.75
6.5
M12×0.75
Remarks
*Waterproof jack need resin filling inside when connector assembly.
■Panel mounting hole dimensions (Screw coupling)
The mounting hole dimensions shown below are for connectors to be tightened by a hexagonal nut from the back of
the panel. The dimensions below apply only to the HR10A-( )T and not the 7TR. For the dimensions of connectors of
other types, see page 198.
Type HR10A-10TR
(Panel thickness 1 to 2mm)
192
Type HR10A-10WTR
(Panel 1 thickness 1 to 2mm)
Type HR10A-13TR
(Panel thickness 1 to 1.5mm)
■Contact
●Male pin
Unit : mm
Type
HRS No.
Loose
contact
Chain
contact
Part No.
Type of plating
Applicable cable
110-0515-6
HR10-PC-111 Partial gold plating
AWG#26 to #30
110-0513-0
HR10-PC-112
AWG#26 to #30
110-0516-9
HR10-PC-211 Partial gold plating
AWG#26 to #30
110-0514-3
HR10-PC-212
AWG#26 to #30
Silver plating
Silver plating
Remarks : 1.Use cables with a coating outside diameter of 1mm or less.
2.L oose-picce terminal are available in packs. Each pack
contains 100 terminals. Strip terminals are available in reels.
Each reel contains 10,000 terminals.
●Female pin
Unit : mm
Type
HRS No.
Type of plating
Applicable cable
Loose
contact
112-0410-0
HR12-SC-111 Partial gold plating
Part No.
AWG#26 to #30
112-0411-3
HR12-SC-112
AWG#26 to #30
Chain
contact
112-0407-6
HR12-SC-211 Partial gold plating
AWG#26 to #30
112-0408-9
HR12-SC-212
AWG#26 to #30
Silver plating
Silver plating
■Receptacle dip post arrangement dimensions
(4 Places)
(6 Places)
(12 Places)
(10 Places)
(20 Places)
7-size 4 cores
7-size 6 cores
(5 Places)
10-size 10 cores
10-size 12 cores
13-size 20 cores
7-size 5 cores
Remarks : 1.The above figures are views of receptacle-socket inserts from the mating side and plug-pin inserts from the wiring-connection
side.
2.Dimensional tolerance of ±0.05 is recommended for the board arrangement.
193
■Tools
Type
Item
Manual
HRS No.
Part No.
Manual crimping tool
150-0052-9
HR12-SC-TC
Automatic crimping
machine body
901-0005-4
CM-105
Automatic
Applicator
Cable crimping tool
Extractor
901-2015-9
AP105-HR12-1
150-0036-2
HR10-TC-01
150-0041-2
HR10A-TC-02
150-0050-3
HR12-SC-TP
150-0039-0
RP6-SC-TP
150-0061-0
HR10B-TP
Applicable terminal
HR10-PC-112
HR12-SC-112
Applicable cable
AWG#26 to #30
HR10-PC-211
HR10-PC-212
HR10-SC-211
HR10-SC-212
AWG#26 to #30
(HR10B-2.5CP,
HR10B-2.5CJ)
Ø5, Ø7
HR12-SC-112
HR12-SC-212
HR10-PC-112
HR10-PC-212
HR10B-2.5CP
HR10B-2.5CJ
(HR12-SC-TC)
Hand Crimp Tool
(HR12-SC-TP)
(HR10A-TC-02)
Hand Cable Crimp Tool
(RP6-SC-TP)
Extraction Tool
Auto Crimp Tool CM-105
(HR10B-TP)
Coaxial Contact Removal Tool
194
■How to use a connector
1.Inserting
2.Withdrawing
Panel
HR10 TYPE
Panel
Receptacle
Plug
Plug Connection sleeve
Cable
B
A
Panel
HR10A TYPE
Panel
Receptacle
Cable
Plug
Plug connection sleeve
Cable
Cable
A
B
Hold the plug at point A, align the plug guide with the receptacle
guide, and push the plug straight.
The plug will mate with the receptacle smoothly.
Hold the plug connection sleeve B and pull the sleeve straight. The
plug will come off easily.
■Jack (Solder type)
HRS No.
Part No.
150-0009-0
HR10-7P-T01
HR10-7P
150-0010-9
HR10-10P-T02
HR10-10P
150-0011-1
HR10-7J-T03
HR10-7J
150-0012-4
HR10-10J-T04
HR10-10J
150-0059-8
HR10-13P-T05
HR10-13P
150-0060-7
HR10-13J-T06
HR10-13J
HR10-10P-T02
HR10-10J-T04
195
■Connection work procedure(plug side)
This applies also to the jack side connection work.
No special connection work procedure is given here for the receptacle side because no special procedure is
necessary.
Clamp washer
Plug body
P shell unit
Cable
Tightener
HR10 TYPE
Bifurcated part
C
About 2
Face B
Face A
Spanner jaw distance
P shell unit
Plug body
Clamp
Cord bushing
HR10A TYPE
Cable
2 or more
A
About 2 for solder type
for crimp type
Boss
D
Set screw
Table 2 spanner jaw distance
Table 3 cable end processing dimensions
Size
HR10
HR10A
Size 7
8
7.5
Size 10
11
9.5
Size 7
5.5 or less
10
Size 13
13
Size 10
7 or less
Size 13
Size
HR10 TYPE
1
Table 1
Dimension C Dimension D for HR10A
for HR10 Solder type Crimp type
Size
Tightening force
Size 7
1.5N∙m(15kg∙cm)
15-20
Size 10
2N∙m(20kg∙cm)
16
15-20
Size 13
2N∙m(20kg∙cm)
26
26
HR10A TYPE
2
Use cables with a nominal sectional area of 0.129 mm (AWG#26) at the finish outside diameters applicable for each size.
After processing the cable ends according to the dimensions in the above drawings, fit the parts to the cable as shown in the drawings.
2
3
4
5
Fit the parts to the cable in the following order: tightener, clamp
washer, and plug body.
Fit the parts to the cable in the following order: cord bushing and
plug body.
(solder type)
Insert the P shell unit into the assembly tool stand and solder it.
(crimp type)
After crimping the appropriate crimp terminal to the cable core, insert the crimp terminal into the terminal hole in the P shell unit.
Assemble the connector in the following steps.
1.Screw the plug body into the thread in the P shell unit with the
tightening force shown in Table 1 using a torque wrench with a
fixed torque.
Before tightening the plug body,slacken part C so that no load is
applied to the soldered wires.
2.Apply the clamp washer to the bifurcated part of the plug body,
and then tighten the tightener until surface B touches the plug
body surface A.
1.Fix by caulking the clamp accompanying the cable with the cable
crimping tool(HR10A-TC-02)
2.Screw the plug body into the thread in the P shell until with a
fixed torque. Before tightening the plug body, slacken the part D so
that no load is applied to the soldered wires.
3.Tighten the set screw so that the tip of the screw presses one of
the two bosses on the clamp.
Fix the set screw with a tightening torque of 0.3N(3kg∙cm)
4.Attach the cord bushing to the plug body.
This completes the work.
For any question on using the plugs, contact our sales or engineering department.
Remarks : Loctite 242, Henkel Japan or equivalent is recommend to prevent the male thread section of the P shell unit and the set screw
for loosing.
196
■Connector
Male Pin side
Female Pin side
(HR10 • HR10A
HR10G Type Receptacle)
(HR10 Type Plug)
(HR10 Type Jack)
(HR10A Type Plug)
(HR10A Type Jack)
(HR10B Type Receptacle)
(HR10B Type Plug)
(HR10A-[ ]T Type Receptacle)
(HR10A-[ ]T Type Plug)
(HR10A-[ ]T Type Jack)
Notes
1 : When using a plug with male terminal, be sure to use a receptacle or jack fitted with female terminal.
2 : Standard finish of the terminal is gold plating for the HR10, and silver plating for the HR10A and HR10G.
Be sure to use male and female connectors of the same plating.
197
■Recommended Mounting Hole
Mounting hole dimension shown here is tight by hexagon nut from back side.
Shell size
7 size
10 size
13 size
A
1.6 +0.1
B
5.1
+0.1
C
8.1 +0.1
Panel thickness
0.7~2
0.7~2
Map mark
6.6
0.8~1.5
■Contact arrangement
Shell size
7 size
10 size
Contact arrangement
No. of pins
4
AC500V for a minute
5
6
AC300V for a minute
10
12
AC300V for a minute
Current rating
2A
2A
2A
MIN 1,000Mø
MIN 1,000Mø
MIN 1,000Mø
Contact resistance
MAX 10mø
MAX 10mø
MAX 10mø
Solder pot inside dia.
Ø0.8
Ø0.8
Ø0.8
Shell size
10 size
13 size
Contact arrangement
No. of pins
10+coaxial contact
AC300V for a minute
AC300V for a minute
Current rating
2A
2A
MIN 1,000Mø
MIN 1,000Mø
Contact resistance
MAX 10mø
MAX 10mø
Ø0.8
Note 1. The contact arrangement shown here is the mating surface of socket insert assembled in a receptacle.
2. The withstanding voltage shown here is test voltage value.
3. The isulation resistance value is measured at DC100V.
4. The contact resistance value is measured at DC1A.
■Precautions
1. Switch off the power of the circuit before disconnecting or plugging-in the connector.
2. Use a connector with socket contacts at the power side of the circuit.
3. Make sure that the coupling is in completely cocked position.
4. The cable pull and twisting strength and other characteristics may differ, deponding on the cable structure.
Please confirm vefore the use.
198
很抱歉,暂时无法提供与“HR10G-7R-4S(73)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+74.920531+9.73612
- 20+74.2850020+9.65353
- 40+54.0635840+7.02570
- 60+52.7126360+6.85014
- 100+49.15495100+6.38781
- 260+46.23465260+6.00831
- 500+43.98560500+5.71604
- 1000+42.755691000+5.55621
- 国内价格 香港价格
- 1+74.792531+9.71948
- 20+74.1581120+9.63704
- 40+53.9713240+7.01371
- 60+52.6220660+6.83837
- 100+49.07115100+6.37692
- 260+46.15508260+5.99797
- 500+43.90942500+5.70614
- 1000+42.682891000+5.54675
- 国内价格 香港价格
- 1+76.062541+9.88453
- 20+61.5779420+8.00221
- 40+58.6367440+7.62000
- 60+56.9819060+7.40495
- 100+54.96465100+7.14280
- 260+51.38216260+6.67725
- 500+49.06715500+6.37641
- 1000+46.727781000+6.07240
