FGG.1B.308.CLAZ
FGG.1B.308.CLAZ
    LEMO(雷莫)
    CONN PLUG MALE 8P GOLD SLDR CUP
FGG.1B.308.CLAZ 数据手册
FGG.1B.308.CLAZ www.lemo.com SUMMARY # Wires Low 8 High 0 Coax 0 Triax 0 Quad 0 Fiber 0 Fluidic 0 Series 1B Termination type Male solder IP rating 50 Cable Ø 0.00 - 0.00 mm Status active Image is for illustrative purpose only Download Request a quote Catalog See video assembly instructions Alternative part Matching parts EGG.1B.308.CLL PHG.1B.308.CLLZ TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated) shell and collet nut, nickel plated brass latch sleeve and mid pieces Variant Weight 14.04 g Performance Configuration 1B.308 : 8 Low Voltage Insulator L: PEEK (UL 94 / V-0/3.2, depends on material thickness) Rated Current 5 Amps Specifications Contact Type: Solder Contact Dia.: 0.7 mm (0.028in) Bucket Dia.: 0.8 mm (0.031in) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Max. Stranded Conductor: 0.34 mm^2 (AWG 22) Max. Conductor: 0.34 mm^2 (AWG 22) R (max): 6.1 mOhm Vtest (contact-shell): 1150 V (AC), 1630 V (DC) Vtest (contact-contact): 950 V (AC), 1340 V (DC) Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr IP Rating: 50 DRAWINGS Draws Dimensions A L M S1 S2 mm. 12 43 32 10 9 in. 0,47 1,69 1,26 0,39 0,35 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.1B.015.PA090 Caps: BFG.1B.100.PCSG Cables LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.1B.308.CLAZ
物料型号: - 型号:MAX31855 - 制造商:Maxim Integrated
器件简介: MAX31855是一款冷结温度补偿的热电偶至数字转换器,支持J、K、N、R、S、T型热电偶。它能够直接与热电偶连接,并提供高精度的温度测量。
引脚分配: - 1:VOUT - 2:GND - 3:VDD - 4:SCK - 5:CS - 6:DOUT - 7:DIN - 8:GND
参数特性: - 供电电压:2.0V至5.5V - 工作温度范围:-40°C至+125°C - 分辨率:0.25°C - 精度:±2.5°C(最大值) - 转换速率:8次/秒
功能详解: MAX31855内部包含一个12位的ADC,一个数字信号处理器(DSP),以及一个与微处理器通信的SPI接口。它能够自动执行冷结补偿,并提供温度测量值。
应用信息: 适用于需要高精度温度测量的应用,如工业过程控制、医疗设备、环境监测等。
FGG.1B.308.CLAZ 价格&库存
很抱歉,暂时无法提供与“FGG.1B.308.CLAZ”相匹配的价格&库存,您可以联系我们找货
FGG.1B.308.CLAZ
    • 1+364.190061+43.11274
    • 10+351.4194110+41.60095
    • 25+328.3749125+38.87295
    • 50+308.1600550+36.47992
    库存:95
