09195105323740
09195105323740
    HARTING(浩亭)
    弯插,P=2.54mm
    线对板针座 2x5P 弯插 间距:2.54mm
09195105323740 数据手册
SEK IEC 60 603-13 6--64 & Tape aging ack eel p Number of contacts R SMC low-profile male header, angled solder pins Identification SMC male header with angled solder pins SEK Length: 2.9 mm Colour: Beige Packaging: Carton Colour: Beige Packaging: Tape & Reel Vacuum plate for pick & place process Colour: Black Packaging: Tape & Reel Vacuum plate for pick & place process No. of contacts Part number Drawing No. of contacts 6 09 19 506 323 6 10 09 19 510 323 10 14 09 19 514 323 14 16 09 19 516 323 16 20 09 19 520 323 20 26 09 19 526 323 26 30 09 19 530 323 30 34 09 19 534 323 34 40 09 19 540 323 40 50 09 19 550 323 50 60 09 19 560 323 60 64 09 19 564 323 64 6 10 14 16 20 26 30 34 40 09 19 506 09 19 510 09 19 514 09 19 516 09 19 520 09 19 526 09 19 530 09 19 534 09 19 540 323 740 323 740 323 740 323 740 323 740 323 740 323 740 323 740 323 740 6 10 14 16 20 26 30 34 40 09 19 506 09 19 510 09 19 514 09 19 516 09 19 520 09 19 526 09 19 530 09 19 534 09 19 540 323 741 323 741 323 741 323 741 323 741 323 741 323 741 323 741 323 741 Dimensions in mm A B 15.2 20.3 25.4 27.9 33.0 40.6 45.72 50.8 58.4 71.3 84.0 89.1 12.78 17.86 22.94 25.48 30.56 38.18 43.26 48.34 55.96 68.66 81.36 86.44 2.54 2.54 2.54 2.54 2.54 2.54 2.54 2.54 2.54 2.54 2.54 2.54 E x 2= x 4= x 6= x 7= x 9= x 12 = x 14 = x 16 = x 19 = x 24 = x 29 = x 31 = 5.08 10.16 15.24 17.78 22.86 30.48 35.56 40.64 48.26 60.96 73.66 78.74 Solder pins for 1 ± 0.1 mm dia. hole Marking No. 1 contact No. 2 contact No. 1 contact No. 2 contact No. 1 contact 7 For performance level 3 please specify digit 6 For performance level 2 please specify digit = 0.76 µm (30 µinch) Au or PdNi eqivalent 5 * S4 Identification Part number Locking lever for female connector with strain relief Dimensions in mm Strain relief clamp in conjunction with low-profile male header 08 46 Drawing 09 18 000 99054) Female connector Low-profile ­male header * Not normally kept in stock 1) 2)  o polarization slot for 6, 10 or 14 way male header N No polarization slot for 6 way male header 3) 4) When the security of latching is required and space is a ­premium, these locking levers can be fitted onto the strain relief of the ­HARTING female connector.  itch tolerance: ± 0.1 P Order 2 per female connector
09195105323740 价格&库存
很抱歉,暂时无法提供与“09195105323740”相匹配的价格&库存,您可以联系我们找货
  • 280+19.82836280+2.56510
  • 280+28.22220280+3.65098
