FGG.0B.302.CLAD52
FGG.0B.302.CLAD52
    LEMO(雷莫)
    FGG.0B.302.CLAD52
FGG.0B.302.CLAD52 数据手册
FGG.0B.302.CLAD52 www.lemo.com SUMMARY # Wires Low voltage 2 Image is for illustrative purpose only Series 0B Termination type Male solder IP rating 50 AWG wire size 28.00 - 20.00 Catalog Cable Ø 4.30 - 5.20 mm See video assembly instructions Status active Matching parts EGG.0B.302.CLL Download Request a quote Eplan PHG.0B.302.CLLD52 TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 8.21 g Performance Configuration 0B.302 : 2 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.035in) Bucket Dia.: 1.0 mm (0.039in) Max. Solid Conductor: 0.56 mm^2 (AWG 20) Max. Stranded Conductor: 0.56 mm^2 (AWG 20) R (max): 4.8 mOhm Vtest (contact-shell): 1050 V (AC), 1490 V (DC) Vtest (contact-contact): 1000 V (AC), 1400 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 9.5 36 26 8 7 in. 0,37 1,42 1,02 0,31 0,28 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.0B.005.PA070 Caps: BFG.0B.100.PCSG LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 120240 PVC Black 120250 PVC Grey 2221 PVC Black 4082 PVC Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.0B.302.CLAD52
物料型号:FGG.0B.302.CLAD52
器件简介:LEMO生产的低电压系列连接器,适用于电缆直径在4.30 - 5.20毫米之间,具有IP50防护等级。
引脚分配:2个低电压引脚。
参数特性: - 额定电流:10安培 - 接触类型:焊接 - 接触直径:0.9毫米 - 桶直径:1.0毫米 - 最大固体导体截面积:0.56平方毫米(AWG 20) - 最大绞合导体截面积:0.56平方毫米(AWG 20) - 最大电阻:4.8毫欧 - 接触-外壳电压测试:1050伏交流,1490伏直流 - 接触-接触电压测试:1000伏交流,1400伏直流
功能详解: - 耐久性:5000次 - 工作温度范围:-55°C至+250°C - 湿度:最大95%(在60°C/140°F) - 振动:15g(10Hz至2000Hz) - 抗冲击:100g(6ms) - 气候类别:50/175/21 - 屏蔽效能:最小75dB(10MHz),最小40dB(1GHz) - 盐雾腐蚀:超过1000小时
应用信息:适用于需要低电压连接和信号传输的应用。
封装信息: - 外壳样式/型号:FG:直插头,电缆固定套 - 键槽:1个键(alpha=0,插头:男性接触,插座:女性接触) - 外壳材料:黄铜(镀铬[SAE AMS 2460])外壳和固定螺母,镍镀[SAE AMS QQ N 290]黄铜拉杆套和中间件 - 重量:8.21克
推荐工具和配件: - 扳手:DCD.0B.005.PA070 - 端盖:BFG.0B.100.PCSG
FGG.0B.302.CLAD52 价格&库存
很抱歉,暂时无法提供与“FGG.0B.302.CLAD52”相匹配的价格&库存,您可以联系我们找货
FGG.0B.302.CLAD52
    • 1+246.08939
    • 5+240.78874
    • 25+230.81229
    • 50+223.13729
    库存:403
    FGG.0B.302.CLAD52
      • 1+239.698041+30.71328
      • 10+231.2892910+29.63584
      • 25+216.1194525+27.69208
      • 50+202.8164250+25.98752
      • 100+191.06366100+24.48160
      库存:406
