HR10A-7J-4S(73)
HR10A-7J-4S(73)
    HRS(广濑)
    SIL
    HR10A-7J-4S(73)
HR10A-7J-4S(73) 数据手册
The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. Push-Pull Connectors HR10 Series ■Overview The HR10 series connectors are push-pull coupling type micro-connectors.They have been developed in response to customers' needs for miniaturization, high density, and easy handling.The HR10 series connectors offer light weight and assure high reliavility and durability as well as easy "push-pull" operation. You may apply the HR10 series connectors to all kinds of small-sized electronic equipment requiring high reliability.However, these simple but refined connectors are most suitable for portable electronic equipment which requires good appearance. ■Features 1. "A LITTLE GIANT" The most compact HR10 series is as slender as a cigarette but it fits every application with well-balanced, simplified layout in limited space. 2. Easy "PUSH-PULL" OPERATION One touch "push-pull" coupling mechanism assures easy and quick connecting and disconnecting. You can couple it accurately just by pushing any part of the connector housing. 3. Polarization Five-key system permits only one way of coupling so that you can find right position to connect even when blind mating. 4. Protection of connection pin A connector pin is located to avoid any damage which may be caused when blind mating. 5. High density The space-saving "push-pull" mechanism facilitates multi-installation of connectors. 6. Easy wiring and mounting No use of screws makes wireing and mounting easier. 7. Simple and refined appearance Simple and well designed connectors with matte finish enhance the appearance of the equipment. 179 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors ■Materials Part Material Finish Shell Zinc alloy and Brass Satin-finished nickel plate Insulator Polyamide / PBT (Blue or Black) Male terminal Brass / Bronze Silver or Gold plating Female terminal Beryllium / Phosphor bronze Silver or Gold plating ■Ordering information HR10 A − 7 P − 4 P A (**) 1 2 3 4 5 6 7 8 1Series name:HR10 Series 4Shell type P:Plug 2Type A:Low-cost model J:Jack G:Shielded R:Receptacle E:Built-in capacitor 5Number of contacts B:Coaxail terminal 6Type of terminal D:Connector sleeve rotation inhibited 3Shell size: Plug mating part outside diameter in mm 7Terminal form C:Crimp connection system P:Male terminal S:Female terminal Other specifications:2 numerical digits will be 8 added when there is a specifications change other than shown in positions 1to 7 180 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors HR10 type ■Plug HR10-7P-6P(73) (An example in shape) Unit : mm HRS No. HR10-10P-12P(73) Part No. No.of pins A ØB ØC ØD Weight 110-0021-6-73 HR10-7P-4P(73) 4 28.5 11 7 5.2 8g 110-0022-9-73 HR10-7P-4S(73) 4 28.5 11 7 5.2 8g 110-0023-1-73 HR10-7P-6P(73) 6 28.5 11 7 5.2 8g 110-0024-4-73 HR10-7P-6S(73) 6 28.5 11 7 5.2 8g 110-0025-7-73 HR10-10P-12P(73) 12 32.5 14 9.5 7.2 15g 110-0026-0-73 HR10-10P-12S(73) 12 32.5 14 9.5 7.2 15g ■Receptacle HR10-7R-6S(73) HR10-10R-12S(73) (An example in shape) Unit : mm HRS No. Part No. No.of pins A ØB ØC D E Weight 110-0031-0-73 HR10-7R-4S(73) 4 14 11 8.85 M8×0.5 10 3.5g 110-0032-2-73 HR10-7R-4P(73) 4 14 11 8.85 M8×0.5 10 3.5g 110-0033-5-73 HR10-7R-6S(73) 6 14 11 8.85 M8×0.5 10 3.5g 110-0034-8-73 HR10-7R-6P(73) 6 14 11 8.85 M8×0.5 10 3.5g 110-0035-0-73 HR10-10R-12S(73) 12 16 14 11.9 M11×0.75 13 6g 110-0036-3-73 HR10-10R-12P(73) 12 16 14 11.9 M11×0.75 13 6g Remarks : For mounting holes, see page 198. 181 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors ■Plug (PCB dip type) HR10-7R-6SA(73) Dip post dia. Ø0.55 HR10-10R-12SA(73) (An example in shape) Unit : mm No.of pins ØA ØB C D E F G Weight 110-0059-9-73 HRS No. HR10-7R-4SA(73) Part No. 4 11 8.85 M8×0.5 10 6.3 0.5 15.5 3g 110-0050-4-73 HR10-7R-6SA(73) 6 11 8.85 M8×0.5 10 6.3 0.5 15.5 3g 110-0061-0-73 HR10-7R-6PA(73) 6 11 8.85 M8×0.5 10 6.3 0.5 15.5 3g 110-0049-5-73 HR10-10R-12SA(73) 12 14 11.9 M11×0.75 13 6.3 0.5 15.5 5g 110-0055-8-73 HR10-10R-12PA(73) 12 14 11.9 M11×0.75 13 6.3 0.5 15.5 5g Remarks : 1.For mounting holes, see page 198. 2.For dip post arrangement, see page 193. ■Jack HR10-7J-6S(73) Unit : mm No.of pins A ØB ØC D Weight 110-0027-2-73 HRS No. HR10-7J-4S(73) Part No. 4 28.5 11 8.85 5.2 7g 110-0028-5-73 HR10-7J-4P(73) 4 28.5 11 8.85 5.2 7g 110-0029-8-73 HR10-7J-6S(73) 6 28.5 11 8.85 5.2 7g 110-0030-7-73 HR10-7J-6P(73) 6 28.5 11 8.85 5.2 7g 110-0037-6-73 HR10-10J-12S(73) 12 32.5 14 11.9 7.2 14g 110-0038-9-73 HR10-10J-12P(73) 12 32.5 14 11.9 7.2 14g 182 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors HR10A·10G Type ■Plud (Solder type) HR10A-7P-6P(73) (An example in shape) Unit : mm HRS No. HR10A-10P-12P(73) Part No. No.of pins A ØB ØC ØD Weight 110-0301-2-73 HR10A-7P-4P(73) 4 35 11.5 7 5 9g 110-0302-5-73 HR10A-7P-4S(73) 4 35 11.5 7 5 9g 110-0318-5-73 HR10A-7P-5P(73) 5 35 11.5 7 5 9g 110-0319-8-73 HR10A-7P-5S(73) 5 35 11.5 7 5 9g 110-0303-8-73 HR10A-7P-6P(73) 6 35 11.5 7 5 9g 110-0304-0-73 HR10A-7P-6S(73) 6 35 11.5 7 5 9g 110-0407-3-73 HR10A-10P-10P(73) 10 43 14.7 9.5 7 16g 110-0408-6-73 HR10A-10P-10S(73) 10 43 14.7 9.5 7 16g 110-0401-7-73 HR10A-10P-12P(73) 12 43 14.7 9.5 7 16g 110-0402-0-73 HR10A-10P-12S(73) 12 43 14.7 9.5 7 16g 110-0713-0-73 HR10A-13P-20P(73) 20 58.8 19 13 7 37g 110-0716-8-73 HR10A-13P-20S(73) 20 58.8 19 13 7 37g ■Plug (Crimp type) HR10A-7P-6PC(73) (An example in shape) Unit : mm HRS No. HR10A-10P-12PC(73) No.of pins A ØB ØC ØD Weight 110-0501-1-73 HR10A-7P-4PC(73) Part No. 4 35 11.5 7 5 9g 110-0502-4-73 HR10A-7P-4SC(73) 4 35 11.5 7 5 9g 110-0503-7-73 HR10A-7P-6PC(73) 6 35 11.5 7 5 9g 110-0504-0-73 HR10A-7P-6SC(73) 6 35 11.5 7 5 9g 110-0601-6-73 HR10A-10P-10PC(73) 10 43 14.7 9.5 7 16g 110-0602-9-73 HR10A-10P-10SC(73) 10 43 14.7 9.5 7 16g 110-0603-1-73 HR10A-10P-12PC(73) 12 43 14.7 9.5 7 16g 110-0604-4-73 HR10A-10P-12SC(73) 12 43 14.7 9.5 7 16g 110-0701-0-73 HR10A-13P-20PC(73) 20 58.8 19 13 7 37g 110-0702-3-73 HR10A-13P-20SC(73) 20 58.8 19 13 7 37g 183 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors ■Receptacle (Solder type) HR10G-10R-12S(71) HR10A-7R-6S(73) (An example in shape) Unit : mm HRS No. Part No. No.of pins A ØB ØC D E Weight HRS No. Part No. No.of pins A ØB ØC D E Weight Remarks 110-0305-3-73 HR10A-7R-4S(73) 4 14 11 8.85 M8×0.5 10 3g 110-1601-1-73 HR10G-7R-4S(73) 4 14 11 8.85 M8×0.5 10 3g 110-0306-6-73 HR10A-7R-4P(73) 4 14 11 8.85 M8×0.5 10 3g 110-1602-4-73 HR10G-7R-4P(73) 4 14 11 8.85 M8×0.5 10 3g 110-0320-7-73 HR10A-7R-5S(73) 5 14 11 8.85 M8×0.5 10 3g 110-1605-2-73 HR10G-7R-6S(73) 6 14 11 8.85 M8×0.5 10 3g 110-0321-0-73 HR10A-7R-5P(73) 5 14 11 8.85 M8×0.5 10 3g 110-1606-5-73 HR10G-7R-6P(73) 6 14 11 8.85 M8×0.5 10 3g 110-0307-9-73 HR10A-7R-6S(73) 6 14 11 8.85 M8×0.5 10 3g 110-1607-8-71 HR10G-10R-10S(71) 10 16 14 11.9 M11×0.75 13 5g 110-0308-1-73 HR10A-7R-6P(73) 6 14 11 8.85 M8×0.5 10 3g 110-1608-0-73 HR10G-10R-10P(73) 10 16 14 11.9 M11×0.75 13 5g 110-0409-9-71 HR10A-10R-10S(71) 10 16 14 11.9 M11×0.75 13 5g 110-1609-3-71 HR10G-10R-12S(71) 12 16 14 11.9 M11×0.75 13 5g 110-0410-8-73 HR10A-10R-10P(73) 10 16 14 11.9 M11×0.75 13 5g 110-1610-2-73 HR10G-10R-12P(73) 12 16 14 11.9 M11×0.75 13 5g 110-0403-2-71 HR10A-10R-12S(71) 12 16 14 11.9 M11×0.75 13 5g 110-0404-5-73 HR10A-10R-12P(73) 12 16 14 11.9 M11×0.75 13 5g 110-0714-2-73 HR10A-13R-20S(73) 20 19.2 18 15.4 M14×0.75 17 8g 110-0715-5-73 HR10A-13R-20P(73) 20 20.2 18 15.4 M14×0.75 17 8g Shield type ■Receptacle (Crimp type) HR10A-7R-6SC(73) HR10G-10R-12SC(71) (An example in shape) Unit : mm HRS No. Part No. No.of pins A ØB C D E F Weight HRS No. Part No. No.of pins A ØB C D E F Weight Remarks 110-0506-5-73 HR10A-7R-4SC(73) 4 11 8.85 M8×0.5 10 6.3 12 3g 110-1701-6-73 HR10G-7R-4SC(73) 4 11 8.85 M8×0.5 10 6.3 12 3g 110-0505-2-73 HR10A-7R-4PC(73) 4 11 8.85 M8×0.5 10 6.3 12.2 3g 110-1702-9-73 HR10G-7R-4PC(73) 4 11 8.85 M8×0.5 10 6.3 12.2 3g 110-0508-0-73 HR10A-7R-6SC(73) 6 11 8.85 M8×0.5 10 6.3 12 3g 110-1705-7-73 HR10G-7R-6SC(73) 6 11 8.85 M8×0.5 10 6.3 12 3g 110-0507-8-73 HR10A-7R-6PC(73) 6 11 8.85 M8×0.5 10 6.3 12.2 3g 110-1706-0-73 HR10G-7R-6PC(73) 6 11 8.85 M8×0.5 10 6.3 12.2 3g 110-0606-0-71 HR10A-10R-10SC(71) 10 14 11.9 M11×0.75 13 6.3 12 5g 110-1707-2-71 HR10G-10R-10SC(71) 10 14 11.9 M11×0.75 13 6.3 12 5g 110-0605-7-71 HR10A-10R-10PC(71) 10 14 11.9 M11×0.75 13 6.3 12.2 5g 110-1708-5-71 HR10G-10R-10PC(71) 10 14 11.9 M11×0.75 13 6.3 12.2 5g 110-0608-5-71 HR10A-10R-12SC(71) 12 14 11.9 M11×0.75 13 6.3 12 5g 110-1709-8-71 HR10G-10R-12SC(71) 12 14 11.9 M11×0.75 13 6.3 12 5g 110-0607-2-71 HR10A-10R-12PC(71) 12 14 11.9 M11×0.75 13 6.3 12.2 5g 110-1710-7-73 HR10G-10R-12PC(73) 12 14 11.9 M11×0.75 13 6.3 12.2 5g 110-0703-6-73 HR10A-13R-20SC(73) 20 18 15.4 M14×0.75 17 9.3 15 8g 110-1711-0-73 HR10G-13R-20SC(73) 20 18 15.4 M14×0.75 17 9.3 15 8g 110-0704-9-73 HR10A-13R-20PC(73) 20 18 15.4 M14×0.75 17 9.3 15 8g 110-1712-2-73 HR10G-13R-20PC(73) 20 18 15.4 M14×0.75 17 9.3 15 8g 184 Shield type The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors ■Receptacle (Dip type) Dip post dia. 0.2×0.5 HR10A-7R-6SB(73) HR10G-10R-12SB(71) (An example in shape) Unit : mm HRS No. 110-0314-4-73 110-0315-7-73 110-0322-2-73 110-0316-0-73 110-0317-2-73 110-0413-6-71 110-0414-9-71 110-0415-1-71 110-0416-4-71 110-0707-7-73 110-0708-0-73 110-1801-0-73 110-1802-3-73 110-1805-1-73 110-1806-4-73 110-1807-7-71 110-1808-0-71 110-1809-2-71 110-1810-1-71 110-1811-4-73 110-1812-7-73 Part No. HR10A-7R-4SB(73) HR10A-7R-4PB(73) HR10A-7R-5SB(73) HR10A-7R-6SB(73) HR10A-7R-6PB(73) HR10A-10R-10SB(71) HR10A-10R-10PB(71) HR10A-10R-12SB(71) HR10A-10R-12PB(71) HR10A-13R-20SB(73) HR10A-13R-20PB(73) HR10G-7R-4SB(73) HR10G-7R-4PB(73) HR10G-7R-6SB(73) HR10G-7R-6PB(73) HR10G-10R-10SB(71) HR10G-10R-10PB(71) HR10G-10R-12SB(71) HR10G-10R-12PB(71) HR10G-13R-20SB(73) HR10G-13R-20PB(73) No.of pins ØA ØB C D E F G 4 4 5 6 6 10 10 12 12 20 20 4 4 6 6 10 10 12 12 20 20 11 11 11 11 11 14 14 14 14 18 18 11 11 11 11 14 14 14 14 18 18 8.85 8.85 8.85 8.85 8.85 11.9 11.9 11.9 11.9 15.4 15.4 8.85 8.85 8.85 8.85 11.9 11.9 11.9 11.9 15.4 15.4 M8×0.5 M8×0.5 M8×0.5 M8×0.5 M8×0.5 M11×0.75 M11×0.75 M11×0.75 M11×0.75 M14×0.75 M14×0.75 M8×0.5 M8×0.5 M8×0.5 M8×0.5 M11×0.75 M11×0.75 M11×0.75 M11×0.75 M14×0.75 M14×0.75 10 10 10 10 10 13 13 13 13 17 17 10 10 10 10 13 13 13 13 17 17 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 9.3 9.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 9.3 9.3 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0 0 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0 0 15.6 15.6 15.6 15.6 15.6 15.6 15.6 15.6 15.6 17.8 17.8 15.6 15.6 15.6 15.6 15.6 15.6 15.6 15.6 17.8 17.8 Weight Remarks 3g 3g 3g 3g 3g 5g 5g 5g 5g 8g 8g 3g 3g 3g 3g 5g 5g 5g 5g 8g 8g Shield type Remarks : 1.For mounting holes, see page 198. 2.For dip post arrangement, see page 193. ■Dust cap HR10-7R-C (An example in shape) Unit : mm HRS No. 110-0058-6-00 Part No. HR10-7R-C 110-0052-0-00 HR10-10R-C 110-0452-8-00 HR10A-13R-C ØA B ØC ØD ØE 11 7 8 11.2 13 14 8.5 10.8 14 15 17.5 11.5 14 18.1 19 185 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors ■Jack (Solder type) HR10A-7J-6S(73) (An example in shape) Unit : mm HRS No. 110-0309-4-73 HR10A-10J-12S(73) Part No. HR10A-7J-4S(73) No.of pins A ØB ØC ØD Weight 4 35.3 11 8.85 5.5 9g 110-0310-3-73 HR10A-7J-4P(73) 4 35.3 11 8.85 5.5 9g 110-0311-6-73 HR10A-7J-6S(73) 6 35.3 11 8.85 5.5 9g 110-0312-9-73 HR10A-7J-6P(73) 6 35.3 11 8.85 5.5 9g 110-0411-0-73 HR10A-10J-10S(73) 10 43 14 11.9 7 16g 110-0412-3-73 HR10A-10J-10P(73) 10 43 14 11.9 7 16g 110-0405-8-73 HR10A-10J-12S(73) 12 43 14 11.9 7 16g 110-0406-0-73 HR10A-10J-12P(73) 12 43 14 11.9 7 16g ■Jack (Crimp type) HR10A-7J-6SC(73) (An example in shape) Unit : mm HRS No. 186 Part No. No.of pins A ØB ØC ØD Weight 110-0510-2-73 HR10A-7J-4SC(73) 4 35.3 11 8.85 5.5 9g 110-0512-8-73 HR10A-7J-6SC(73) 6 35.3 11 8.85 5.5 9g 110-0610-7-73 HR10A-10J-10SC(73) 10 43 14 11.9 5.5 16g 110-0612-2-73 HR10A-10J-12SC(73) 12 43 14 11.9 5.5 16g 110-0705-1-73 HR10A-13J-20SC(73) 20 58.5 18 15.4 8.5 37g 110-0706-4-73 HR10A-13J-20PC(73) 20 58.5 18 15.4 8.5 37g The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors HR10B Type Connector The HR10B connector combines 10 signal lines and one coaxial contact in the standard number 10 shell. Electrical performance are same as HR10A connector except coaxial contacts. Performance specifications for the coaxial contacts are on the next page. ■Plug HR10B-10P-10PC(73) (An example in shape) Unit : mm HRS No. Part No. A ØB Applicable coaxial contact 110-0901-0-73 HR10B-10P-10PC(73) 50 5 HR10B-2.5CJ(73) 110-0906-3-73 HR10B-10PA-10PC(73) 43 7 HR10B-2.5CJ(73) ■Receptacle HR10B-10R-10SC(71) Unit : mm HRS No. Part No. Applicable coaxial contact 110-0902-2-71 HR10B-10R-10SC(71) HR10B-2.5CP(73) Remarks : For mounting holes, see page 198. 187 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors ■Coaxial contacts The coaxial contacts shown here are for use with the HR10B connector.These contacts have locking barbs and are inserted from the rear of connector.Please use the following information to select the correct terminals. ■Material ■Performance Part Material Finish Description Test data Plug shell Brass Gold plating Impedance 50ø Jack shell Brass Gold plating Insulation resistance 1000Mø or more at DC250V Insulator Tetrafluoride resin Contact resistance Center 6.5mø or less and outer 4mø or less at DC1A Male pin Phosphor bronze Gold plating Withstanding voltage AC250V r.m.s for 1minute Female pin Beryllium copper Gold plating V.S.W.R 1.3 or less for 0 to 1000MHz Pull force 4.9N 500gf or more ■Plug (clamp) HR10B-2.5CP(73) Unit : mm HRS No. Part No. Applicable cable Applicable connector 110-0904-8-73 HR10B-2.5CP(73) 0.8D-QEW-CW (By Fjikura wire) HR10B-10R-10SC(71) ■Jack (clamp) HR10B-2.5CJ(73) Unit : mm HRS No. 110-0903-5-73 188 Part No. Applicable cable Applicable connector HR10B-2.5CJ(73) 0.8D-QEW-CW (By Fjikura wire) HR10B-10P-10PC(71) The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors ■Cable connecting methods HR10B-2.5CP HR10B-2.5CJ 1.Cable end treatment Fig.1 3.Crimping cable outer conductor Fig.3 11±0.5 A (HR10B-2.5CP) 1.4±0.2 (2.5) Clamp metal 3.7±0.2 Slit cable outer jaket 2 pieces (180° reverse side) 1.Dimensions for cable end treatment are shown in Fig 1. 2.Termination is described below. (1).Strip cable outer jacket as indicated. (2).Slit outer jacket on both sides per Fig.1. (3).Fold back outer cover. (4).Remove insulator from cable. 2.Soldering male pin to cable center conductor. Fig.2 Malu pin or Female pin Soldering Connector Remove excess insulator material (remaining after clamping is complated) with a knife or aimilarobject. Table 1 dimenshion A 2.5CP 2.5CJ 1.5±0.2mm 0 +0.3 0 mm 1.Insert cable prepared per PROCESS 2 into the connector.The cable should be inserted until it comes to a full stop.This may be verified by checking the dimension from the side of the connector to the top of the contact(as indicated in Fig 3). This dimension should be A. 2.Crimp this installed metal clamp with tool HR10TC-01 per Fig.3 and remove excess insulation with a knife. It is possible to pull back the contact. Hold cable when crimping metal clamp and keep the dimension to show in Fig 3. after crimping metal clamp. Should fix flush Contact fixing jig such as vise 1.Solder male pin to cable center conductor as indicated in Fig.2. (1).Pre-solder the solder pot of pin with Ø0.5mm string solder. (2).Male pin should fit flush against the cable insulator as shown. (3).Remove any excess solder from the pin with a knife.This surface must be smooth. (4).A properly soldered terminal will yield 500gf when stretched. 189 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors HR10A-[ ]T Type (Threaded Coupling Type) HR10A-( )T connector is a new product having a threaded coupling locking mechanism.Electric parformance is same as HR10 and HR10A push-pull locking type connector. ■Plug (Solder type) HR10A-10TP-12P(73) Unit : mm HRS No. 110-0331-3-73 Part No. No.of pins ØA HR10A-7TP-6P(73) 6 12 B ØC D ØE M10×0.75 7 M8×0.5 5 110-0331-3-74 HR10A-7TP-6P(74) 6 12 M10×0.75 7 M8×0.5 5 110-0432-0-73 HR10A-10TP-12P(73) 12 17 M13×0.75 9.5 M8×0.5 7 110-0446-5-73 HR10A-10TPA-12S(73) 12 17 M13×0.75 9.5 M8×0.5 7 Remarks Gold plating 110-1101-9-73 HR10A-10WTP-12P(73) 12 15 M12×0.75 9.5 M11×0.75 6.5 * 110-1106-2-73 HR10A-10WTP-12S(73) 12 15 M12×0.75 9.5 M11×0.75 6.5 * 110-1015-9-73 HR10A-13TPD-20P(73) 20 20 M17×1 13 M11×0.75 7 *Waterproof plug need resin filling inside when connector assembly. When mated, the connector against water penetration. ■Plug (Crimp type) HR10A-10TP-12PC(73) Unit : mm HRS No. 110-0455-6-73 190 Part No. HR10A-10TP-12PC(73) No.of pins 12 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors ■Receptacle (Solder type) HR10A-10TR-12S(73) (An example in shape) Unit : mm HRS No. Part No. No.of pins A ØB C ØD E F Remarks Gold plating 110-0089-0-73 HR10-7TR-6S(73) 6 M10×0.75 6.3 M8×0.5 11 14 10 110-0453-0-73 HR10A-10TR-12S(73) 12 M13×0.75 6.3 M11×0.75 14 16 13 110-1104-7-73 HR10A-10WTR-12S(73) 12 M12×0.75 6.8 M10.5×0.75 14 16 13 Remarks:For mounting hole, see page 192(10TR,10WTR) 198(7TR) ■Receptacle (Crimp type) HR10A-10TR-12SC(73) (An example in shape) Unit : mm HRS No. Part No. No.of pins ØA B C 110-0456-9-73 HR10A-10TR-12SC(73) 12 14 12 6.3 110-1002-7-73 HR10A-13TR-20SC(73) 20 18 15 9.3 ØD E F M13×0.75 M11×0.75 M17×1 M14×0.75 13 17 Remarks:For mounting hole, see page 192 ■Receptacle (Dip type) Dip post Ø H HR10A-10TR-12PB(73) (An example in shape) Unit : mm HRS No. Part No. 110-0330-0-73 HR10A-7TR-6SA(73) No.of pins ØA 6 11 B C D E F E H M10×0.75 M8×0.5 10 6.3 0.5 15.5 Ø0.55 110-0433-3-73 HR10A-10TR-12SB(73) 12 14 M13×0.75 M11×0.75 13 6.3 0.5 15.5 0.2×0.5 110-0457-1-73 HR10A-10TR-12PB(73) 12 14 M13×0.75 M11×0.75 13 6.3 0.5 15.5 0.2×0.5 M11×0.75 13 6.3 0.5 13 6.8 0 110-0445-2-73 HR10A-10TR-12PE(73) 12 14 M13×0.75 110-1102-1-73 HR10A-10WTR-12SB(73) 12 14 M12×0.75 M10.5×0.75 14 0.2×0.5 15.5 0.2×0.5 110-1013-3-73 HR10A-13TR-20PB(73) 20 18 M17×1 M14×0.75 17 9.3 0 17.8 0.2×0.5 110-1014-6-73 HR10A-13TR-20SB(73) 20 18 M17×1 M14×0.75 17 9.3 0 17.8 0.2×0.5 Remarks : 1.For mounting holes, see page 192. However, 7TR size shell be referred to page 198 on the shell size 7. 2.For dip post arrangement, see page 193. 191 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors ■Jack (Solder type) HR10A-10TJ-12S(73) (An example in shape) Unit : mm HRS No. Part No. 110-0436-1-73 HR10A-10TJ-12S(73) No.of pins ØA B 12 14.7 41.3 110-0459-7-73 HR10A-10TJ-12P(73) 12 14.7 41.3 110-1103-4-73 HR10A-10WTJ-12S(73) 12 14 46.5 ØC D 7 M13×0.75 7 M13×0.75 6.5 M12×0.75 Remarks * *Waterproof jack need resin filling inside when connector assembly. When mated, the connector against water penetration. ■Panel mounting hole dimensions (Screw coupling) The mounting hole dimensions shown below are for connectors to be tightened by a hexagonal nut from the back of the panel. The dimensions below apply only to the HR10A-( )T and not the 7TR. For the dimensions of connectors of other types, see page 198. Type HR10A-10TR (Panel thickness 1 to 2mm) 192 Type HR10A-10WTR (Panel 1 thickness 1 to 2mm) Type HR10A-13TR (Panel thickness 1 to 1.5mm) The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors ■Contact ●Male pin  Unit : mm Type HRS No. Loose contact Chain contact Part No. Type of plating Applicable cable 110-0515-6 HR10-PC-111 Partial gold plating AWG#26 to #30 110-0513-0 HR10-PC-112 AWG#26 to #30 110-0516-9 HR10-PC-211 Partial gold plating AWG#26 to #30 110-0514-3 HR10-PC-212 AWG#26 to #30 Silver plating Silver plating Remarks : 1.Use cables with a coating outside diameter of 1mm or less. 2.L oose-picce terminal are available in packs. Each pack contains 100 terminals. Strip terminals are available in reels. Each reel contains 10,000 terminals. ●Female pin  Unit : mm Type HRS No. Type of plating Applicable cable Loose contact 112-0410-0 HR12-SC-111 Partial gold plating Part No. AWG#26 to #30 112-0411-3 HR12-SC-112 AWG#26 to #30 Chain contact 112-0407-6 HR12-SC-211 Partial gold plating AWG#26 to #30 112-0408-9 HR12-SC-212 AWG#26 to #30 Silver plating Silver plating Remarks : 1.Use cables with a coating outside diameter of 1mm or less. 2.L oose-picce terminal are available in packs. Each pack contains 100 terminals. Strip terminals are available in reels. Each reel contains 10,000 terminals. ■Receptacle dip post arrangement dimensions (4 Places) (6 Places) (12 Places) (10 Places) (20 Places) 7-size 4 cores 7-size 6 cores (5 Places) 10-size 10 cores 10-size 12 cores 13-size 20 cores 7-size 5 cores Remarks : 1.The above figures are views of receptacle-socket inserts from the mating side and plug-pin inserts from the wiring-connection side. 2.Dimensional tolerance of ±0.05 is recommended for the board arrangement. 193 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors ■Tools Type Item Manual HRS No. Part No. Manual crimping tool 150-0052-9 HR12-SC-TC Automatic crimping machine body 901-0005-4 CM-105 Automatic Applicator Cable crimping tool Extractor 901-2015-9 AP105-HR12-1 150-0036-2 HR10-TC-01 150-0041-2 HR10A-TC-02 150-0050-3 HR12-SC-TP 150-0039-0 RP6-SC-TP 150-0061-0 HR10B-TP Applicable terminal HR10-PC-112 HR12-SC-112 Applicable cable AWG#26 to #30 –– HR10-PC-211 HR10-PC-212 HR10-SC-211 HR10-SC-212 –– –– AWG#26 to #30 (HR10B-2.5CP, HR10B-2.5CJ) Ø5, Ø7 HR12-SC-112 HR12-SC-212 HR10-PC-112 HR10-PC-212 HR10B-2.5CP HR10B-2.5CJ (HR12-SC-TC) Hand Crimp Tool (HR12-SC-TP) (HR10A-TC-02) Hand Cable Crimp Tool (RP6-SC-TP) Extraction Tool Auto Crimp Tool CM-105 (HR10B-TP) Coaxial Contact Removal Tool 194 –– The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors ■How to use a connector 1.Inserting 2.Withdrawing Panel HR10 TYPE Panel Receptacle Plug Plug Connection sleeve Cable B A Panel HR10A TYPE Panel Receptacle Cable Plug Plug connection sleeve Cable Cable A B Hold the plug at point A, align the plug guide with the receptacle guide, and push the plug straight. The plug will mate with the receptacle smoothly. Hold the plug connection sleeve B and pull the sleeve straight. The plug will come off easily. ■Jack (Solder type) HRS No. Part No. Applicable connector 150-0009-0 HR10-7P-T01 HR10-7P 150-0010-9 HR10-10P-T02 HR10-10P 150-0011-1 HR10-7J-T03 HR10-7J 150-0012-4 HR10-10J-T04 HR10-10J 150-0059-8 HR10-13P-T05 HR10-13P 150-0060-7 HR10-13J-T06 HR10-13J HR10-10P-T02 HR10-10J-T04 195 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors ■Connection work procedure(plug side) This applies also to the jack side connection work. No special connection work procedure is given here for the receptacle side because no special procedure is necessary. Clamp washer Plug body P shell unit Cable Tightener HR10 TYPE Bifurcated part C About 2 Face B Face A Spanner jaw distance Spanner jaw distance P shell unit Plug body Clamp Cord bushing HR10A TYPE Cable 2 or more A About 2 for solder type 0 2 -0.5 for crimp type Boss D Set screw Table 2 spanner jaw distance Table 3 cable end processing dimensions Size HR10 HR10A Size 7 8 7.5 Size 10 11 9.5 Size 7 5.5 or less 10 Size 13 –– 13 Size 10 7 or less Size 13 –– Size HR10 TYPE 1 Table 1 Dimension C Dimension D for HR10A for HR10 Solder type Crimp type Size Tightening force Size 7 1.5N∙m(15kg∙cm) 15-20 Size 10 2N∙m(20kg∙cm) 16 15-20 Size 13 2N∙m(20kg∙cm) 26 26 HR10A TYPE 2 Use cables with a nominal sectional area of 0.129 mm (AWG#26) at the finish outside diameters applicable for each size. After processing the cable ends according to the dimensions in the above drawings, fit the parts to the cable as shown in the drawings. 2 3 4 5 Fit the parts to the cable in the following order: tightener, clamp washer, and plug body. Fit the parts to the cable in the following order: cord bushing and plug body. (solder type) Insert the P shell unit into the assembly tool stand and solder it. (crimp type) After crimping the appropriate crimp terminal to the cable core, insert the crimp terminal into the terminal hole in the P shell unit. Assemble the connector in the following steps. 1.Screw the plug body into the thread in the P shell unit with the tightening force shown in Table 1 using a torque wrench with a fixed torque. Before tightening the plug body,slacken part C so that no load is applied to the soldered wires. 2.Apply the clamp washer to the bifurcated part of the plug body, and then tighten the tightener until surface B touches the plug body surface A. 1.Fix by caulking the clamp accompanying the cable with the cable crimping tool(HR10A-TC-02) 2.Screw the plug body into the thread in the P shell until with a tightening force shown in Table 1 using a torque wrench with a fixed torque. Before tightening the plug body, slacken the part D so that no load is applied to the soldered wires. 3.Tighten the set screw so that the tip of the screw presses one of the two bosses on the clamp. Fix the set screw with a tightening torque of 0.3N(3kg∙cm) 4.Attach the cord bushing to the plug body. This completes the work. For any question on using the plugs, contact our sales or engineering department. Remarks : Loctite 242, Henkel Japan or equivalent is recommend to prevent the male thread section of the P shell unit and the set screw for loosing. 196 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors ■Connector Male Pin side Female Pin side (HR10 • HR10A HR10G Type Receptacle) (HR10 Type Plug) (HR10 Type Jack) (HR10A Type Plug) (HR10A Type Jack) (HR10B Type Receptacle) (HR10B Type Plug) (HR10A-[ ]T Type Receptacle) (HR10A-[ ]T Type Plug) (HR10A-[ ]T Type Jack) Notes 1 : When using a plug with male terminal, be sure to use a receptacle or jack fitted with female terminal. 2 : Standard finish of the terminal is gold plating for the HR10, and silver plating for the HR10A and HR10G. Be sure to use male and female connectors of the same plating. 197 The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information. HR10 Series●Push-Pull Connectors ■Recommended Mounting Hole Mounting hole dimension shown here is tight by hexagon nut from back side. Shell size 7 size 10 size 13 size A 1.6 +0.1 0 2.6 +0.1 0 2.6 +0.1 0 B 5.1 +0.1 0 +0.1 0 8.6 +0.1 0 C 8.1 +0.1 0 11.1 +0.1 0 14.5 +0.1 0 Panel thickness 0.7~2 0.7~2 Map mark 6.6 0.8~1.5 ■Contact arrangement Shell size 7 size 10 size Contact arrangement No. of pins 4 Withstanding voltage AC500V for a minute 5 6 AC300V for a minute 10 12 AC300V for a minute Current rating 2A 2A 2A Insulation resistance MIN 1,000Mø MIN 1,000Mø MIN 1,000Mø Contact resistance MAX 10mø MAX 10mø MAX 10mø Solder pot inside dia. Ø0.8 Ø0.8 Ø0.8 Shell size 10 size 13 size Contact arrangement No. of pins 10+coaxial contact 20 Withstanding voltage AC300V for a minute AC300V for a minute Current rating 2A 2A Insulation resistance MIN 1,000Mø MIN 1,000Mø Contact resistance MAX 10mø MAX 10mø Solder pot inside dia. - Ø0.8 Note 1. The contact arrangement shown here is the mating surface of socket insert assembled in a receptacle. 2. The withstanding voltage shown here is test voltage value. 3. The isulation resistance value is measured at DC100V. 4. The contact resistance value is measured at DC1A. ■Precautions 1. Switch off the power of the circuit before disconnecting or plugging-in the connector. 2. Use a connector with socket contacts at the power side of the circuit. 3. Make sure that the coupling is in completely cocked position. 4. The cable pull and twisting strength and other characteristics may differ, deponding on the cable structure. Please confirm vefore the use. 198
HR10A-7J-4S(73) 价格&库存
很抱歉,暂时无法提供与“HR10A-7J-4S(73)”相匹配的价格&库存,您可以联系我们找货
HR10A-7J-4S(73)
  • 1+86.28906
  • 10+85.08105
  • 50+83.34194
  • 100+81.52993
  • 250+79.72834
库存:103
HR10A-7J-4S(73)
    库存:248
    HR10A-7J-4S(73)
      • 1+104.204591+13.47887
      • 5+74.211335+9.59924
      • 10+69.0409310+8.93045
      • 30+65.5884730+8.48387
      • 50+64.8996450+8.39477
      • 60+64.7253660+8.37223
      • 100+64.38509100+8.32822
      库存:117
      HR10A-7J-4S(73)
        库存:20
        HR10A-7J-4S(73)
          • 1+94.84560
          • 10+91.99440
          库存:3
          HR10A-7J-4S(73)
          • 1+153.361971+19.83738
          • 20+124.1196420+16.05488
          • 40+118.1930840+15.28828
          • 60+114.8595660+14.85709
          • 100+110.79578100+14.33144
          • 260+103.57812260+13.39784
          • 500+98.91334500+12.79445
          库存:569
          HR10A-7J-4S(73)
            • 1+121.883541+15.87600
            • 5+117.530565+15.30900
            • 10+104.4716110+13.60800
            库存:15
