8
7
4
5
6
1
2
3
REVISIONS
F
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
1595
INITIAL RELEASE
04/01/08
VJ
B
1707
05/30/08
ASK
C
1946
UPDATE P/N CODING CHART, PLATING
UPDATE NOTES, COLOR CODE & TOLERANCE BLOCK,
TAIL LENGTH OPTION 1 REMOVED
06/26/09
JH
F
131.68 5.184
E
11.67 .459
38.27 1.507
10.00 .394
PIN A1
IDENTIFIER
PIN A2
PIN A1
37.00 1.457
E
91.68 3.609
90.00 3.543
1.73±0.08 .068±.003
1.73±0.08 .068±.003
1.00 .039 TYP
7.50 .295 MAX
PIN B1
PIN B2
D
1.50 .059
3.75 .148 MAX
D
11.25 .443
MAX
+0.15
+.006
1.80
.071
- 0.08
- .003
2X 1.20 .047
149.00 5.866
0.90±0.20 .035±.008
5.10 .201
A
3.75 .148
7.80 .307
C
15.60 .614
4.40±0.20 .173±.008
1.00 .039 TYP
1.25 .049
SECTION A-A
3.25 .128
133.15 5.242
14.65 .577
40.00 1.575
TAIL LENGTH
SEE PART NUMBER
CODING
B
NOTES:
3X 2.15±0.10 .085±.004
1. INSULATOR MATERIAL: NYLON46, UL 94V-0.
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: SEE PART NUMBER CODING.
4. CURRENT RATING: 1.1 AMP.
5. VOLTAGE RATING: 50 V DC.
6. INSULATOR RESISTANCE: 1000 MEGOHMS MIN.
7. CONTACT RESISTANCE: 30 MILLI OHMS MAX.
8. DIELECTRIC WITHSTANDING: 500V DC.
9. INSERTION FORCE: 117gf (1.15 N) MAX PER CONTACT PAIR USING A 1.7 mm (.067") STEEL CARD.
10. WITHDRAWAL FORCE: 15.3gf (0.15 N) MIN PER CONTACT PAIR USING A 1.44 mm (.057") STEEL CARD.
11. OPERATING TEMPERATURE: -55° C TO +105° C.
12. PROCESSING TEMP.: 260° C FOR 10 SECS MAX.
(INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURE
MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED
oHS COMPLIANT
INDICATED TEMPERATURE AND TIME.)
Pb
R
8
C
5.60 .220
A
0.34X0.25 [.013X.010] TYP
2X 2.00±0.10 .079±.004
A
8.85 .348
7
6
5
4
UNLESS OTHERWISE SPECIFIED:
DIMENSIONS ARE IN MM[INCHES]
TOLERANCES:
ANGULAR: 5
.X= .3 [.01]
.XX= .25 [.010]
.XXX= .080 [.0030]
SURFACE FINISH: 63 Ra
REMOVE ALL BURRS AND SHARP EDGES .010 MAX
DRAWN
NAME
3/23/09
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT DESCRIPTION
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
PART NUMBER
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
PCI EXPRESS, 1mm CC, 140P, DIP SOLDER
N_E140DHHN-T9_ _
SIZE DWG. NO.
C
INTERPRET DIMENSIONS AND GEOMETRIC
TOLERANCING
PER: ANSI Y14.5M-1994
3
DATE
B
REV
11040
SCALE: 1:1
2
C
SHEET 1 OF 2
1
FILE NAME: Z:\ECO PENDING\1946\11040, N_E140DHHN-T9_ _ PRINT: 9/2/2009
A
8
7
4
5
6
1
2
3
F
F
1.90±0.06 .075±.002 , 2X
1.50 .059 , 2X
1.50 .059 , 2X
PIN B1
4.20 .165
E
5.60 .220
B
0.70 .028 TYP
1.00 .039 TYP.
10.00 .394
37.00 1.457
90.00 3.543
12.15 .478
40.00 1.575
92.15 3.628
E
0.50[.020] x 45 TYP
144.30 5.681
I/O PANEL DIRECTION PRIMARY (COMPONENT) SIDE
D
D
1.57±0.13 .062±.005
PIN A1
0.70 .028 TYP.
1.40 .055
1
I/O PANEL DIRECTION SECONDARY (SOLDER) SIDE
C
C
20.0°
ADD-IN CARD EDGE-FINGER DIMENSIONS
DETAIL B
SCALE 8 : 1
133.15 5.242
PIN A2
B
40.00 1.575
1.65 .065
1.35 .053
PIN A1
1.65 .065
1.35 .053
2.00 .079 TYP
3X
1.00 .039 TYP
2.35±0.05 .093±.002
B
6.50 .256
PIN B1
0.70±0.08 .028±.003 TYP
PIN B2
10.00 .394
37.00 1.457
2.50 .098
90.00 3.543
RECOMMENDED PCB LAYOUT
TOLERANCE: 0.13 [.005]
Pb
A
1. CHAMFER EDGE MUST BE FREE OF CUTTING BURRS.
DESCRIPTION
PART NUMBER
N_E140DHHN-T9_ _
SIZE DWG. NO.
RoHS COMPLIANT C
REV
11040
SCALE: NTS
8
7
6
5
4
3
2
C
SHEET 2 OF 2
1
A
很抱歉,暂时无法提供与“NWE140DHHN-T931”相匹配的价格&库存,您可以联系我们找货
