DF50A-2P-1H(51)
DF50A-2P-1H(51)
    HRS(广濑)
    SMD
    CONN HEADER SMD R/A 2POS 1MM
DF50A-2P-1H(51) 数据手册
1mm Pitch, Board to Wire Lock Connector DF50 Series It provides clear tactile click and secure mating Aug.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Timing of locking function Simultaneous timing of locking function and contact mating provides a clearer tactile click. Fig.1 ■Features Robust structure resistant to wrenching forces 1. It provides clear tactile click and secure mating L o ck i n g f u n c t i o n a n d c o n t a c t m a t i n g o c c u r simultaneously, for a clearer tactile click. (Fig.1) 2. Robust structure resistant to wrenching forces Thick and robust housing wall provides higher strength against cracking. Insertion depth for mating housings protects against wrenching. (Fig.2) 3. Robust and reliable lance structure High lance strength by mating with crimp contact on the surface. (Fig.3) 4. Ensured adsorption area eliminates the need for adsorption cap. Adequate adsorption area is ensured despite the small size, allowing for automatic mounting without adsorption cap. (*Specifications for adsorption cap may be provided according to your requirements) Insertion depth for mating protects against wrenching. Thick and robust outer wall provides higher strength and prevents cracking. Fig.2 Robust and reliable lance structure 5. Insulation outer diameter Ø0.9mm, compatible with AWG#28 The lance mates with the crimp contact on the surface. Despite 1 mm Pitch, it is compatible with Ø0.9mm, UL1061·28 AWG Cable (Ø0.127×7) It is possible to visually inspect the assembled lance. Fig.3 In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2019.5④ 1 DF50 Series●1mm Pitch, Board to Wire Lock Connector ■Product Specifications Current Rating 1A (Note 1) Voltage Rating AC/DC 100V Operating Temperature Range Operating Humidity Range Storage Temperature Range Storage Humidity Range Ratings Aug.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Items Specifications Conditions 1.Insulation resistance 500Mø min. 100V DC 2.Withstand voltage No flashover or breakdown 300V AC/1min. 3.Contact resistance 30mø max. 20mV max., at 1mA. 4.Vibration No electrical discontinuity of 1µs or longer 5.Shock No electrical discontinuity of 1µs or longer 6.Humidity 7.Temperature cycles -35 to +85°C (Note 2) 20 to 80% (Note 3) -10 to +60°C (Note 4) 40 to 70% (Note 4) Frequency 10-55Hz, single amplitude of 0.75mm 3 directions, 10 cycles in each direction. 2 Acceleration : 490m/s for 11ms, half sine wave in 3 directions, 3 times for each direction Contact resistance : 50mø max. Insulation resistance : 100Mø min. Contact resistance : 50mø max. Insulation resistance : 500Mø min. Temperature : 40±2°C ; humidity : 90 to 95%, left for 96 hours (-55°C : 30 min. → 5 to 35°C : 2 to 3 min. → 85°C : 30 min. → 5 to 35°C : 2 to 3 min.) 5 cycles 8.Durability Contact resistance : 50mø max. 30 times (Number of insertion and withdrawal) 9.Resistance to soldering heat No deformation of components affecting performance. Reflow : according to the recommended temperature profile Hand soldering : 350°C for 3 to 4 sec. Note 1 : This is the maximum current rating while all pins are powered or used as all power lines. When isolating power lines into multiple circuits, current ratings may go above the stated current ratings. Please consult Hirose for specifi c details before doing this. Note 2 : Includes the temperature rise of power lines. Note 3 : The connector should be completely dry. (no condensation present) Note 4 : The term “storage” refers to the long-term storage condition of unused products before PCB mounting. The operating temperature and humidity ranges are applied while in a non-energized state, while in transport or after PCB mounting. ■Materials / Finish Product Part Materials Insulator LCP Pin header (on the board side) Contact Metal fitting Locking metal fitting (DF50) Brass Brass (Note 1) Stainless steel Crimp socket Insulator PBT Crimp contact Contact Phosphor Bronze Color / Finish Black Beige Gold plating Tin Plating --------Black (DF50A) White (DF50S) Gold plating UL Regulation UL94V-0 ------------------------UL94V-0 --------- Note 1 : Phosphor bronze is applied a material for only to the single-row straight pin header. ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Connector ●Crimp contact DF 50 ❶ ❷ − * DP − 1 V (**) ❸ ❹ ❺ ❻ ❶ Series Name : DF ❷ Series No. : 50 ❸ Form Type : Blank : Double-row pin header S : Double-row crimp socket A : Single-row ❹ Number of contacts : 20, 30, 40, 50 (Double-row) : 2 to 16 (Single-row) ❺ Connector type DP : Double-row pin header DS : Double-row crimp socket P : Single-row pin header S : Single-row crimp socket ❻ Contact Pitch : 1mm ❼ Mounting style / Wiring type V : SMT Straight Type H : SMT Right Angle Type C : Crimp socket 2 ❼ ❽ DF 50 ❶ ❷ − 2830 SCF A ❸ ❾ ❽ Specifications 51 : SMT, color : black Embossed packaging 52 : SMT, color : black Embossed packaging, with adsorption cap 61 : SMT, color : beige Embossed packaging 62 : SMT, color : beige Embossed packaging, with adsorption cap ❾ Applicable wire size 26 : 26 AWG 2830 : 28, 30 AWG 3032 : 30, 32 AWG Packaging style SCF : Socket contact reel Plating specifications A : Gold plating DF50 Series●1mm Pitch, Board to Wire Lock Connector ■Double-row straight pin header 6 * : No. of Contacts 7 8dciVXiCd#' 8dciVXiCd# E2&  8dciVXiCd#& 8dciVXiCd#"& 8dciVXiCd#&bVg` 8dciVXiCd#& %#+¤%#%* E2&¤%#%* &#+¤%#%* 8dciVXiCd# 8dciVXiCd#"& 7¤%#%* %#,' &#,. [Specification number]** (51) color : black, Embossed packaging (52) color : black, Embossed packaging, with adsorption cap (61) color : beige, Embossed packaging (62) color : beige, Embossed packaging, with adsorption cap )¤%#%* %#.¤%#%* &#+¤%#%* %#-*B>C 8dciVXiCd#' &#-¤%#%* %#,¤%#%* BRecommended PCB Dimensions Unit : mm Part No. HRS No. No. of Contacts A B DF50-20DP-1V (**) 665-0019-3 ** 20 13.18 9 DF50-30DP-1V (**) 665-0001-8 ** 30 18.18 14 DF50-40DP-1V (**) 665-0005-9 ** 40 23.18 19 DF50-50DP-1V (**) 665-0011-1 ** 50 28.18 24 C D E F G 14.2 28.4 32 38.4 32.4 20.2 40.4 44 50.4 44.4 Note : Please place orders for embossed packaged products by the multiple of the number of reels. (1,000 pcs/reel) BEmboss tape dimensions (JIS C 0806 compliant) G 6"6 6 Ø1 3 Product Label F MAX Ø1.5 sprocket hole far side +2 G 0 Unreeling direction & %# % *  Unreeling direction # ¢& 6 '¤%#& )¤%#& ('#(.*)8ZciZgd[VYhdgei^dcVgZV R1 &#,*¤%#& 8¤%#& 8 0. 1± Ø2 :¤%#( 0.5 2± 9¤%#& Ø80±1 Contact No.1 * %#, Ø380±2 %#& % BReel Condition Dimensions ±0 .2 %#'¤%#%* Aug.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ,#%* -#(* &'¤%#& 3 DF50 Series●1mm Pitch, Board to Wire Lock Connector ■Double-row right angle pin header * : No. of Contacts 8dciVXiCd#&bVg` 6 7 E2& -#++ 8dciVXi Cd#"& . 8dciVXiCd#& 8dciVXiCd# 8dciVXiCd#' Aug.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. BRecommended PCB Dimensions '#(,* &#'*¤%#%* %#.) 8dciVXiCd#î 8dciVXiCd#' %#+¤%#%* [Specification number]** (51) color : black, Embossed packaging (61) color : beige, Embossed packaging &#+¤%#%* &#-¤%#%* %#.¤%#%* )#&¤%#%* 8dciVXiCd#"& 8dciVXiCd#& &#+¤%#%* &#,*¤%#%* E2&¤%#%* 7¤%#%* Unit : mm HRS No. No. of Contacts A B C D E F G DF50-20DP-1H(**) Part No. 665-0016-5 ** 20 14.35 9 14.2 28.4 32 38.4 32.4 DF50-30DP-1H(**) 665-0015-2 ** 30 19.35 14 DF50-40DP-1H(**) 665-0014-0 ** 40 24.35 19 20.2 40.4 50.4 44.4 DF50-50DP-1H(**) 665-0013-7 ** 50 29.35 24 Note : Please place orders for embossed packaged products by the multiple of the number of reels. (600 pcs/reel) 7"7 7 Product Label Ø1.5 sprocket F MAX hole far side +2 G 0 Unreeling direction &#,*¤%#& 8¤%#& 4 )¤%#& R1 :¤%#( 8 0. '¤%#& &+¤%#&* 1± 7 JcgZZa^c\Y^gZXi^dc Ø2 9¤%#& 0.5 2± & %# % *  # ¢& Ø380±2 G Ø80±1 %#& % 0.2 * %#, BReel Condition Dimensions Ø13 ± %#'¤%#%* BEmboss tape dimensions (JIS C 0806 compliant) DF50 Series●1mm Pitch, Board to Wire Lock Connector ■Single-row straight pin header * : No. of Contacts 6 7 E2& 8dciVXiCd#& 8dciVXiCd# 8 *#+, BRecommended PCB Dimensions 7¤%#%* E2&¤%#%* &#, %#+¤%#%* 8dciVXiCd# 8dciVXiCd#& )#,¤%#%* '#)¤%#%* %#,¤%#%* (#&*¤%#%* %#,' Aug.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ,#%* 8dciVXiCd#&bVg` [Specification number]** (51) color : black, Embossed packaging &#.¤%#%* Unit : mm Part No. HRS No. No. of Contacts A B C DF50A-2P-1V (**) 665-1001-3 ** 2 5.25 1 5 DF50A-3P-1V (**) 665-1004-1 ** 3 6.25 2 6 DF50A-4P-1V (**) 665-1006-7 ** 4 7.25 3 7 DF50A-5P-1V (**) 665-1008-2 ** 5 8.25 4 8 DF50A-6P-1V (**) 665-1010-4 ** 6 9.25 5 9 DF50A-7P-1V (**) 665-1012-0 ** 7 10.25 6 10 DF50A-8P-1V (**) 665-1014-5 ** 8 11.25 7 11 DF50A-9P-1V (**) 665-1016-0 ** 9 12.25 8 12 DF50A-10P-1V (**) 665-1017-3 ** 10 13.25 9 13 DF50A-11P-1V (**) 665-1019-9 ** 11 14.25 10 14 DF50A-12P-1V (**) 665-1021-0 ** 12 15.25 11 15 DF50A-13P-1V (**) 665-1023-6 ** 13 16.25 12 16 DF50A-14P-1V (**) 665-1025-1 ** 14 17.25 13 17 DF50A-15P-1V (**) 665-1027-7 ** 15 18.25 14 18 DF50A-16P-1V (**) 665-1029-2 ** 16 19.25 15 19 Note : Please place orders for embossed packaged products by the multiple of the number of reels. (1,000 pcs/reel) 5 DF50 Series●1mm Pitch, Board to Wire Lock Connector BReel Condition Dimensions BEmboss tape dimensions (JIS C 0806 compliant) %#& % Ø13± Unreeling direction 0.2 8 0. 1± Ø2 R1 0.5 2± Aug.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 24.4 +20 Ø1.5 sprocket hole far side 6 ¢&#* 30.4MAX Ø80±1 Product Label Ø380±2 &'¤%#& )¤%#& '¤%#& ') ''#'* %%#' &&#*¤%#& &#,*¤%#& ●DF50A-2P-1V to DF50A-8P-1V (Number of contacts : 2 to 8) JcgZZa^c\Y^gZXi^dc 6 BReel Condition Dimensions BEmboss tape dimensions (JIS C 0806 compliant) A 2±0.1 .1 +00 .5 Ø1 Product Label A-A Ø13 Ø1.5 sprocket 38.4MAX hole far side 32.4 +20 Unreeling direction ±0. 2 0.2±0.05 8 0. 1± Ø2 R1 0.5 2± 6 R0 .7 5 +0 0 .1 A Unreeling direction Ø80±1 Ø380±2 12±0.1 4±0.1 32±0.3 28.4±0.1 14.2±0.1 1.75±0.1 ●DF50A-9P-1V to DF50A-16P-1V (Number of contacts : 9 to 16) DF50 Series●1mm Pitch, Board to Wire Lock Connector ■Single-row right angle pin header 6 7 * : No. of Contacts E2& 8dciVXiCd#& 8dciVXiCd# 8dciVXiCd#&bVg` ,#+ BRecommended PCB Dimensions '#' 7¤%#%* E2&¤%#%* %#+¤%#%* 8dciVXiCd# ,#(&¤%#%* 8dciVXiCd#& '#)¤%#%* *#+,¤%#%* &#&,* Aug.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. +#%- 8 &#*&¤%#%* [Specification number]** (51) color : black, Embossed packaging &#.¤%#%* Unit : mm HRS No. No. of Contacts A B C DF50A-2P-1H (**) Part No. 665-1031-4 ** 2 6.81 1 6 DF50A-3P-1H (**) 665-1032-7 ** 3 7.81 2 7 DF50A-4P-1H (**) 665-1033-0 ** 4 8.81 3 8 DF50A-5P-1H (**) 665-1034-2 ** 5 9.81 4 9 DF50A-6P-1H (**) 665-1035-5 ** 6 10.81 5 10 DF50A-8P-1H (**) 665-1037-0 ** 8 12.81 7 12 DF50A-10P-1H (**) 665-1039-6 ** 10 14.81 9 14 DF50A-12P-1H (**) 665-1041-8 ** 12 16.81 11 16 DF50A-16P-1H (**) 665-1045-9 ** 16 20.81 15 20 Note : Please place orders for embossed packaged products by the multiple of the number of reels. (1,000 pcs/reel) 7 DF50 Series●1mm Pitch, Board to Wire Lock Connector BReel Condition Dimensions BEmboss tape dimensions (JIS C 0806 compliant) Ø380±2 &#,*¤%#& ±0.2 8"8 ¢ R1 8 0. &&#*¤%#& 1± ') 8 Ø2 ''#'* %%#' Ø13 & %# % * &# Ø1.5 sprocket 30.4 MAX hole far side +2 24.4 0 Unreeling direction 0.5 2± Aug.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Product Label &'¤%#& )¤%#& '¤%#& Ø80±1 ●DF50A-2P-1H to DF50A-6P-1H (Number of contacts : 2 to 6) JcgZZa^c\Y^gZXi^dc 8 BReel Condition Dimensions BEmboss tape dimensions (JIS C 0806 compliant) )¤%#& '¤%#& 8 Product Label & %# % *  &# ¢ G MAX +2 0 H Unreeling direction Ø13 8"8 Ø1.5 sprocket hole far side ±0.2 9¤%#& R1 %#'¤%#%* :¤%#& 8 0. 8 1± Ø2 ;¤%#( 0.5 2± Ø380±2 &#,*¤%#& &'¤%#& Ø80±1 ●DF50A-8P-1H to DF50A-16P-1H (Number of contacts : 8 to 16) JcgZZa^c\Y^gZXi^dc Unit : mm Part No. HRS No. No. of Contacts DF50A-8P-1H (**) 665-1037-0 ** 8 DF50A-10P-1H (**) 665-1039-6 ** 10 DF50A-12P-1H (**) 665-1041-8 ** 12 DF50A-16P-1H (**) 665-1045-9 ** 16 D E F G H 14.2 28.4 32 38.4 32.4 20.2 40.4 44 50.4 44.4 Note : Please place orders for embossed packaged products by the multiple of the number of reels. (1,000 pcs/reel) 8 DF50 Series●1mm Pitch, Board to Wire Lock Connector ■Double-row crimp socket 6 7 8dciVXiCd#' E2& 8dciVXiCd# 8dciVXiCd#& 8dciVXiCd#"& 8dciVXiCd#&bVg` 86KCd# + -#* =GHbVg` * : No. of Contacts HRS No. No. of Contacts A B DF50S-20DS-1C Part No. 665-0020-2 20 12.28 9 DF50S-30DS-1C 665-0021-5 30 17.28 14 DF50S-40DS-1C 665-0022-8 40 22.28 19 DF50S-50DS-1C 665-0012-4 50 27.28 24 Note : Sold in 100 pcs/pack. ■Single-row crimp socket 6 7 E2& 8dciVXiCd#&bVg` 8dciVXiCd# 8dciVXiCd#& +#-* + Aug.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm * : No. of Contacts Unit : mm HRS No. No. of Contacts A B DF50A-2S-1C Part No. 665-1002-6 2 3.95 1 DF50A-3S-1C 665-1005-4 3 4.95 2 DF50A-4S-1C 665-1007-0 4 5.95 3 DF50A-5S-1C 665-1009-5 5 6.95 4 DF50A-6S-1C 665-1011-7 6 7.95 5 DF50A-7S-1C 665-1013-2 7 8.95 6 DF50A-8S-1C 665-1015-8 8 9.95 7 DF50A-9S-1C 665-1100-5 9 10.95 8 DF50A-10S-1C 665-1018-6 10 11.95 9 DF50A-11S-1C 665-1020-8 11 12.95 10 DF50A-12S-1C 665-1022-3 12 13.95 11 DF50A-13S-1C 665-1024-9 13 14.95 12 DF50A-14S-1C 665-1026-4 14 15.95 13 DF50A-15S-1C 665-1028-0 15 16.95 14 DF50A-16S-1C 665-1030-1 16 17.95 15 Note : Sold in 100 pcs/pack. 9 DF50 Series●1mm Pitch, Board to Wire Lock Connector %#+( %#%#* ) ¢&#' ( )#+ &#. *#%* ■Crimp contact &#) '#, Aug.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. ●Strip length ) ●Reel contact (30,000 pcs/reel) HRS No. UL DF50-26SCFA 665-0023-0 3302 DF50-2830SCFA 665-0002-0 1061 DF50K-2830SCFA 665-0017-8 1571 DF50-3032SCFA 665-0026-0 1571 %#&' 1.3 to 1.7mm Applicable wire (Tin plated annealed copper wire) (Note 1) Wire size Stranded wire conductor Section area Jacket outer diameter 26 AWG 28 AWG 30 AWG 28 AWG 30 AWG 30 AWG 32 AWG 7/0.160mm 7/0.127mm 7/0.102mm 7/0.127mm 7/0.102mm 7/0.102mm 7/0.080mm 0.141mm2 0.089mm2 0.057mm2 0.089mm2 0.057mm2 0.057mm2 0.035mm2 0.88mm 0.80 to 0.88mm 0.58mm 0.54 to 0.56mm Note 1 : When using other than the recommended wire, contact your nearest Hirose sales representative. Note 2 : The strip length is a reference value. Please make adjustments so finished crimps will meet the specified values. Refer to the crimping quality standards (ETAD-H0616-00) for details. Note 3 : As this product is sold 30,000 pcs/reel, please place orders by the multiple of the number of reels. BApplicable crimping tool Type Part No. HRS No. AP105-DF50-2630S 901-4641-7 AP105-DF50K-2830S AP105-DF50-3032S DHS799100-BH(-UP) DHX001800K(-UP) Press CM-105C Hand crimping tool HT305/DF50-2830HC (Note 3) Contact extraction tool DF-C-PO(B) Applicator 901-4628-9 901-4648-0 ----------------901-0001-0 902-4634-8 550-0179-2 Applicable contact Remarks DF50-26SCFA DF50-2830SCFA DF50K-2830SCFA DF50-3032SCFA DF50-2830SCFA Manufaftured by Japan Automatic Machine Co., Ltd. (Note 4) DF50K-2830SCFA --------DF50-2830SCFA DF50(K)-****SCFA Note 1 : Please do the crimping operations according to the "Crimping quality standard (ETAD-H0616-00)" and "Crimping condition table". Note 2 : If any trouble has occurred due to tools other than the designated tool, Hirose bears no respoisibility for any trouble. Note 3 : The compatible wire is limited to UL1061, 28 to 30 AWG. Note 4 : Please contact Japan Automatic Machine Co., Ltd. (hereinafter J.A.M.) through their website regarding crimping issues when using applicators manufactured by J.A.M. URL http://www.jam-net.co.jp BMated dimensions Double Row Single Row (8.78) (6.85) DF50-*DP-1V 10 DF50-*DP-1H (7.35) DF50A-*P-1V (8.96) (7.9) (9) Horizontal DF50S-*DS-1C DF50A-*S-1C DF50A-*P-1H DF50A-*S-1C (7.05) (7.35) Vertical DF50S-*DS-1C DF50 Series●1mm Pitch, Board to Wire Lock Connector BCrimping ■Items required prior to start crimping The work-related documents shown below are required before starting the harness connections. (The ● mark shows the document required.) When the documents shown below are not available, ask our sales personnel to provide them. Aug.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Document Title Description Automatic Hand Crimping Crimping Machine Tool Remarks When purchasing main press machine unit, it is bundled. (1) Main unit of crimping machine instruction manual Explanation of main press machine unit ● − (2) Applicator Spare Parts Identification Explanation for Applicator installation ● − (3) Crimp Conditions Standard values of : Crimp height ; Tensile strength ● − (4) Crimp Quality Standards Various standards for crimping conditions ● − (5) Operating lnstructions for Hand Tool Inspection items of : Crimp height ; Tensile strength ; and others − ● When purchasing Hand Tool, it is bundled. ● ● Ask our sales personal to provide them. (6) Harness Procedure Manual DF50 series : ETAD-H0354-00 Harness procedure DF50A series : ETAD-H0437-00 When purchasing Applicator, it is bundled. ■Tools When crimping work is applied to our contacts, the tool designated by Hirose should be used. Crimping work by using tools other than as designated must not be done because it may result in contact failure, disconnection of cable, etc. *The operating instructions manual is available for the crimping machine and the applicator. Be sure to carefully read the operating instructions manual befor implementing the work. ■Applicable electric wires Check that the electric wire to be used is in the range of application. If you intend to use an electric wire other than the recommended one, ask our sales personnel. [Precautions] ・Electric wires that are applicable for crimping connectors shall, principally, be the tin-plated stranded softcopper wire. ・Crimping of electric wires wherein single wires, polyester yarns, etc., exist and crimping of tin-coated wires should be avoided. ・Avoid crimping two electric wires together. ・The setting values of crimp height (Note 1) may vary between tin-plated and gold-plated terminals even if the same electric wires are used. ・The setting values of crimp height (Note 1) may vary depending on the difference in the core wire configuration even if the computed cross-sectional area is the same. Note 1 : The crimp height is an important item that determines crimping quality. We execute crimping tests for each electric wire to ensure the optimal value for the crimp height with high precision, thereby ensuring optimal setup values. 11 DF50 Series●1mm Pitch, Board to Wire Lock Connector BPrecautions 10secMAX 1.Recommended Temperature Profile (Compatible with lead-free soldering) MAX 250℃ Aug.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. TEMPERATURE (℃) 250 220℃ 200 180℃ 150 100 0 90 – 120sec PRE-HEATING TIME 60secMAX TIME (sec) SOLDERING TIME [Applicable Conditions] 1. Peak temperature : a maximum of 250°C for no more than 10 seconds 2. Heating unit : no less than 220°C for no more than 60 seconds 3. Preheating unit : 150 to 180°C for 90 to 120 seconds 4. Number of times : no more than 2 times * Measurement is conducted at the contact lead part As it may change depending on the conditions such as solder paste types, manufacturers, PCB size, and other soldering materials, please fully check the mounting conditions before use. (Note 1) This temperature profile is a recommended value. 2.Recommended hand soldering conditions 3.Recommended screen thickness and aperture ratio (Pattern surface ratio) 4.Warpage of the Board 5.Cleaning Conditions Thickness : 0.1mm, aperture ratio : 100% A maximum of 0.02mm at the center of connector, as measured from either end of the connector IPA cleaning is allowed. (Cleaning is not recommended because cleaning may change the push/pull feeling etc. Please contact us when you use other cleaning agents. ) 6.Precautions ▪ When inserting crimp-type (solderless) terminals to crimping (solderless) sockets, to maintain reliable performance, please do not insert obliquely. ▪ Please refer to the documents "DF50 Series Cable assembly Procedure ETAD-H0354"", ""DF50A Series Cable assembly Procedure ETAD-H0437", "Crimp condition" and "DF50#-****SCFA(%%) Crimp quality standards ETAD-H0616-00" for the cable assembly procedures. ▪ Please refrain from pushing/pulling operation when the PCB is not mounted. It may cause breakage, contact deformation, etc. ▪ Please refrain from pushing/pulling operation with wires in your hand. It maycause damage. ▪ During hand soldering, do not apply flux which will cause flux oozing on connector. ▪ This product may have a little difference in its molded color depending on the production lot, but the difference doesn't have any influence on the performance. 7.Handling instructions Please refer to the following documents in handling this product. ▪ Crimp quality standards(ETAD-H0616-00) ▪ Cable assembly Procedure(ETAD-H0354-00, ETAD-H0437-00) ▪ User guide for Wire-to-Board connector ® 12 Temperature of soldering iron : 350±10°C, soldering time : 3 to 4 seconds 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 05/2019. Contents are subject to change without notice for the purpose of improvements. Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Hirose Electric: DF50-30DP-1V(51) DF50-30DS-1C DF50-20DP-1H(51) DF50-20DP-1V(51) DF50-20DP-1V(52) DF50-30DP1H(51) DF50-30DP-1V(52) DF50-40DP-1H(51) DF50-40DP-1V(52) DF50-50DP-1V(51) DF50-50DP-1V(52) DF50A10P-1H(51) DF50A-10P-1V(51) DF50A-11P-1V(51) DF50A-11S-1C DF50A-12P-1H(51) DF50A-12P-1V(51) DF50A13P-1V(51) DF50A-15P-1V(51) DF50A-16P-1V(51) DF50A-16S-1C DF50A-2P-1H(51) DF50A-2P-1V(51) DF50A2S-1C DF50A-3P-1H(51) DF50A-3P-1V(51) DF50A-3S-1C DF50A-4P-1H(51) DF50A-4P-1V(51) DF50A-4S-1C DF50A-5P-1H(51) DF50A-5P-1V(51) DF50A-5S-1C DF50A-6P-1H(51) DF50A-6P-1V(51) DF50A-6S-1C DF50A-7P1V(51) DF50A-7S-1C DF50A-8P-1H(51) DF50A-8P-1V(51) DF50A-9P-1V(51) DF50A-9S-1C DF50S-20DS-1C DF50S-30DS-1C DF50S-40DS-1C DF50S-50DS-1C DF50-50DP-1H(51) DF50-40DS-1C DF50K-2830SCFA DF5040DP-1V(51) DF50-3032SCFA DF50-30DP-1V(62) DF50-26SCFA DF50-50DP-1V(61) DF50-30DP-1V(61) DF5040DP-1V(62)
DF50A-2P-1H(51) 价格&库存
很抱歉,暂时无法提供与“DF50A-2P-1H(51)”相匹配的价格&库存,您可以联系我们找货
DF50A-2P-1H(51)
    • 1000+2.16410
    库存:1000
    DF50A-2P-1H(51)
    • 1+1.73110
    • 100+1.66350
    库存:840
    DF50A-2P-1H(51)
    • 1+5.281581+0.63702
    • 10+4.5832510+0.55279
    • 25+4.1912325+0.50551
    • 50+3.9442750+0.47572
    • 100+3.77981100+0.45589
    • 250+3.45119250+0.41625
    • 500+3.28676500+0.39642
    库存:1000
