BH010-08-C-0850-0840-0573-G
    GCT
    CONN HEADER SMD 8POS 3.96MM
BH010-08-C-0850-0840-0573-G 数据手册
Number of Contacts H 1.80 6.35 D+1.0 3.96 G The cap used above 3pins F Pin 1 Pin 1 Recommended PCB Layout General Tolerance ±0.05 2° max. Toe C±0.25 E±0.25 3.18 D XX C XXXX XXXX XXXX (Available from 3 contacts and above) D = Tube (Available from 3 contacts and above) G = Box Contact Plating C=Tin All Over Dimension E (1/100mm) (PCB to Top of Insulator) 0573 = 5.73mm (Standard) Or specify custom dimension (Minimum 0482=4.82mm) Dimension C (1/100mm) (Post Height) 0850 = 8.50mm (Standard) Or specify Custom Post Height (Maximum 1500=15.00mm) (Minimum 0050=0.50mm) 1 Request Samples and Quotation Packing Options E = Tube with Cap (Standard) No. of Contacts 02 to 18 A X Dimension D (1/100mm) (Footprint Width) 0840 = 8.40mm (Standard) Or specify Custom Footprint Width (Tooling charge may apply) 2 3 4 7.92 3 7.92 11.88 4 11.88 15.84 5 15.84 19.80 6 19.80 23.76 7 23.76 27.72 8 27.72 31.68 11 39.60 43.56 12 43.56 47.52 Material Insulator: LCP, UL94V-0 Contact:Brass 13 47.52 51.48 14 51.48 55.44 15 55.44 59.40 Plating Contact:Tin All Over Underplating: Nickel all over 16 59.40 63.36 17 63.36 67.32 18 67.32 71.28 Mechanical & Environmental Operating Temperature: -40°C to +105°C Soldering Process IR Reflow: 260°C for 10 sec. Manual Solder: 350°C for 3-5 sec Ordering Grid BH010 B 0.15 3.96 31.68 35.64 Electrical Current Rating: 7.9 Amp Per Pin Contact Resistance: 30 mΩ max. Insulation Resistance: 1000 MΩ min. Dielectric Withstand Voltage: 1000 V AC D±0.30 1.14 sq. Pin C 5.00 Either Direction E 20mm Maximum 12.00 Either Direction 2 35.64 39.60 Specifications 5.00 2° max. Sway B 9 A±0.25 3.96±0.15 A 10 Solder Area B±0.38 Dimensions Mates with (Subject to Pin Length) BH015 Part Number Product Description BH010 3.96mm Pitch Pin Header, Single Row, Surface Mount, Vertical Drawing Date 10th August 2017 By Detail Revision Date 5 CC Tolerances (Except as Noted) Drawing Release A1 14/07/21 X. ± 0.30 X.° ± 5° X.X° ± 3° X.X ± 0.25 X.XX ± 0.15 X.XX° ± 2° X.XXX ± 0.10 X.XXX° ± 1° Length Angle 6 Units: Metric (mm) C 3rd Angle Projection 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CC 8 Sheet No. 1/1
BH010-08-C-0850-0840-0573-G 价格&库存
很抱歉,暂时无法提供与“BH010-08-C-0850-0840-0573-G”相匹配的价格&库存,您可以联系我们找货
  • 1+11.501871+1.48880
  • 40+8.8813240+1.14960
  • 120+8.21849120+1.06380
  • 520+7.40999520+0.95915
  • 1000+7.075691000+0.91588
  • 5000+6.316425000+0.81760
  • 10000+6.0152310000+0.77861
库存:2029
