UTS08E33S
UTS08E33S
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN RCPT FMALE 3P GOLD SLDR CUP
UTS08E33S 数据手册
4 Holes A B C D E F G H E.2; Validé MALE CONNECTOR FEMALE CONNECTOR 3,2 0,1 8 8 F Maxi INSERT Thread 0.15 0.25 0.25 A B 7 ØE SHELL SOCKET 7 PIN 6 6 D 0.15 C Maxi B 0.25 A 0.25 UTS0 14 5 SHELL SIZE A 0.25 B 0.25 C Maxi D 0.15 ØE 0.15 F Maxi G 0.25 H 0.10 8 21.00 15.10 21.50 2.30 11.90 11.70 15.10 12.50 10 23.80 18.30 21.50 2.30 14.90 11.70 18.30 15.10 12 26.20 20.60 21.50 2.30 18.95 11.70 20.60 18.20 4 14 28.60 23.00 21.50 2.30 22.15 11.70 23.00 21.40 E 12 P . XX 5 Square flange receptacle UTS Thread Shell size E = Handsolder contacts Insert arrangement (See table) P = Male contact S = Female contact Orientations Normal (no digit), W, X, Y, Z = different orientations 7/16 28 UNEF Class 2A 9/16 24 UNEF Class 2A 11/16 24 UNEF Class 2A 13/16 20 UNEF Class 2A 4 Specification MATERIAL : 3 3 Shell:PBT UL94 V-0 Black color Insert:Polychloroprene Seal gasket :Sealing IP68/69K : Silicone O'seal : Nitril Contact: brass + gold plated PANEL CUT OUT Country FR H 0.25 0.10 E 02/11/2017 ISS DATE Designed by: G 2 Operating temperature:-40 C up to 105 C Insulation resistance:5000 M min Test potential:1500Vrms for #20 layout Corrosion salt spray:500 hours Durability:250 matings and unmatings Sealing in mated and unmated conditions: -IP68 1 bar during 1 week : immersion under 10 m of water. (IEC 60529) -IP69K : exposure to high pressure water of cleaning equipement(DIN 40050) TITLE Scale 3/1 1 NOTE: Updating shell material 21774A Latest modification - by: SORIN V. Date: COURTOIS L. 26/10/07 G SOURIAU shall not be liable for any non-conformity or damage due to a use of the Products which does not comply with the Specifications issued by either of the Parties or by a third party (professional recommendation, technical notice.) F E D FORMAT A2 C 2 MOD N CUSTOMER DRAWING SQUARE FLANGE RECEPTACLE UTS HI SEAL General linear Tolerances: 0.1 WWW.SOURIAU.COM Insert arrangements : refer to C144-UTS1-A H NOT LISTED P/N : SEE TABLE 3,2 0,1 PERFORMANCE CHARACTERISTICS : Jurisdiction & Control List NPRDS / PROJECT UTS This document is the property of SOURIAU It must not be reproduced or communicated without permission SOURIAU DRG N° C044-UTS1-A B SHEET 1/1 A 1
UTS08E33S 价格&库存
很抱歉,暂时无法提供与“UTS08E33S”相匹配的价格&库存,您可以联系我们找货
UTS08E33S
  • 15+35.67048
库存:24
