BCC0ATE
BCC0ATE
    BALLUFF(巴鲁夫)
    BCC0ATE
BCC0ATE 数据手册
Field-Attachable Connectors BCC A333-0000-20-000-71X3A5-000 Order Code: BCC0ATE Basic features Environmental conditions Approval/Conformity CE Ambient temperature -25...85 °C cURus IP rating IP67 EAC WEEE Material Electrical connection Cable diameter D 10...12 mm Connection 7/8"-16 UN-Male, Straight, 3-pin Number of connectable contacts 3 System Can be fabricated Electrical data Operating voltage Ub 600 VDC / 600 VAC Rated current (40 °C) 9.0 A Material contact carrier PUR, PA Material contacts Brass Material cover nut Die-cast zinc Material grip PBT Mechanical data Connection cross-section 0.14...1.5 mm² Tightening torque pigtail 1.5 Nm Type of wire mounting Screw terminals Remarks Enclosure rating per IEC 60529, only in screwed state with the associated mating piece. Connector Drawings PIN 1-3 usable Internet www.balluff.com eCl@ss 9.1: 27-44-01-02 Subject to change without notice: 215829 ETIM 6.0: EC002062 BCC0ATE_0.52_2021-08-19 1/1
BCC0ATE 价格&库存
很抱歉,暂时无法提供与“BCC0ATE”相匹配的价格&库存,您可以联系我们找货
