CAH.M34.SLL.C72GZ
CAH.M34.SLL.C72GZ
    LEMO(雷莫)
    CONN PLUG FMALE 34P SOLDER CUP
CAH.M34.SLL.C72GZ 数据手册
CAH.M34.SLL.C72GZ www.lemo.com SUMMARY # Wires Low voltage 34 Image is for illustrative purpose only Series 2P Termination type Female solder IP rating 50 AWG wire size 0.00 - 0.00 Cable Ø 5.30 - 7.20 mm Status active Matching parts CLH.M34.SLAG Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model CA*: Straight plug with cable collet and nut for fitting a bend relief Keying 3 keys (alpha=0, gamma=80; Plug: female contacts; Receptacle: male contacts) Housing Material PEI (Polyetherimide), gray Weight 11.35 g Performance Configuration 2P.M34 : 34 Low V. Insulator L: PEEK for solder contacts Rated Current 1.5 Amps Specifications Test voltage (kV rms) Contact-contact: 0.7 Air clearance min.: 0.3 mm Creepage distance min.: 0.3 mm Others Endurance (Shell): >1000 mating cycles Temp (min / max): -50°C / +170°C F ret (min): 150 N LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 F ret (max): 250 N Steam sterilization: > 100 times (with potting on rear connection) DRAWINGS RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
CAH.M34.SLL.C72GZ 价格&库存
很抱歉,暂时无法提供与“CAH.M34.SLL.C72GZ”相匹配的价格&库存,您可以联系我们找货
