ECG.0B.302.CLN
ECG.0B.302.CLN
    LEMO(雷莫)
    ECG.0B.302.CLN
ECG.0B.302.CLN 数据手册
ECG.0B.302.CLN www.lemo.com SUMMARY # Wires Low voltage 2 Image is for illustrative purpose only Series 0B Termination type Female print PCB IP rating 50 AWG wire size 28.00 - 20.00 PCB Altium Pattern Cable Ø 0.00 - 0.00 mm PCB KiCad Pattern Status active Catalog Matching parts FGG.0B.302.CLAD42 Download Request a quote PCB Eagle Pattern TECHNICAL DETAILS Mechanics Shell Style/Model EC*: Fixed receptacle with two nuts and straight contacts for printed circuit (back panel mounting) Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 4.83 g Performance Configuration 0B.302 : 2 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Type: Print (straight) Contact Dia.: 0.9 mm (0.035in) R (max): 4.8 mOhm Vtest (contact-contact): 1300 V (AC), 1840 V (DC) Vtest (contact-shell): 1050 V (AC), 1490 V (DC) Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E Lmax M Nmax S1 S3 e mm. 12 12.4 5.5 19.55 2.5 16.3 8.2 11 M9x0.6 in. 0,47 0,49 0,22 0,77 0,10 0,64 0,32 0,43 RECOMMENDED BY LEMO Tools Spanner 2: DCH.91.121.PA LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
ECG.0B.302.CLN
物料型号:ECG.0B.302.CLN
器件简介:LEMO的EC系列连接器,适用于低电压应用,具有2个导线。
引脚分配:2个低电压导线。
参数特性: - 额定电流:10安培 - 接触电阻:最大4.8毫欧 - 绝缘材料:PEEK - 工作温度范围:-55°C至+250°C - 湿度:最大95%(在60°C/140°F时) - 振动:15g(10Hz至2000Hz) - 冲击抵抗力:100g(6ms) - 气候类别:50/175/21 - 屏蔽效能:最小75dB(10MHz)和40dB(1GHz) - 盐雾腐蚀:超过1000小时
功能详解:该连接器设计用于印刷电路板(PCB)的后面板安装,具有固定插座和直接触点。
应用信息:适用于需要高可靠性和性能的电子设备。
封装信息:提供匹配的零件FGG.0B.302.CLAD42,以及推荐的LEMO工具,如扳手DCH.91.121.PA。
ECG.0B.302.CLN 价格&库存
很抱歉,暂时无法提供与“ECG.0B.302.CLN”相匹配的价格&库存,您可以联系我们找货
