FFA.1S.304.CLAC42
FFA.1S.304.CLAC42
    LEMO(雷莫)
    CONN CIRC PLUG 4P GOLD SLDR CUP
FFA.1S.304.CLAC42 数据手册
FFA.1S.304.CLAC42 www.lemo.com SUMMARY # Wires Low voltage 4 Image is for illustrative purpose only Series 1S Termination type Male solder IP rating 50 AWG wire size 30.00 - 22.00 Cable Ø 3.20 - 4.20 mm Status active Matching parts ERA.1S.304.CLL Download Request a quote Eplan Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FFA*: Straight plug, cable collet Keying Hermaphroditic keying (half moon insert) with male pin 1 Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 17.59 g Performance Configuration 1S.304 : 4 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 10 Amps Specifications Contact Type: Solder Contact Dia.: 0.9 mm (0.0354in) Bucket Dia.: 0.8 mm (0.031in) Max. Solid Conductor: 0.34 mm^2 (AWG 22) R (max): 4.8 mOhm Vtest: 1200 V (AC), 1800 V (DC) Air clearance min.: 1.1 mm Creepage distance min.: 1.1 mm LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +250°C Humidity (max): 144 hr DRAWINGS Dimensions A L M S2 mm. 12 42.5 31.5 8.5 in. 0,47 1,67 1,24 0,33 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.1S.015.PA085 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables 40080 PVC Black 40086 PVC Blue 40140 PVC Black 40240 PTFE White 4260 PTFE White LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FFA.1S.304.CLAC42
PDF文档中提到的物料型号为“FFA.1S.304.CLAC42”,属于LEMO公司的产品。
以下是文档中关于该物料的详细信息:
- 器件简介:文档中未明确提供器件的简介,但根据型号可以推测这是一款LEMO品牌的连接器。
- 引脚分配:1S.304 表示4个低压信号的配置。
- 参数特性: - 额定电流:10安培 - 接触类型:焊接 - 接触直径:0.9毫米 - 桶直径:0.8毫米 - 最大实心导体:0.34平方毫米(AWG 22) - 最大电阻:4.8毫欧姆 - 测试电压:1200伏交流,1800伏直流 - 空气间隙最小:1.1毫米 - 爬电距离最小:1毫米 - 功能详解:文档中未提供详细的功能解释,但根据参数特性可以了解到该连接器适用于低压信号传输,具有较高的电流承载能力和电气性能。
- 应用信息:文档中未明确提供应用信息,但根据其电气特性,可能适用于需要高电流和电气性能的场合。
- 封装信息:提供了详细的尺寸信息,包括A、L、M、S2等尺寸,以及推荐的扳手工具型号“DCD.1S.015.PA085”。
请注意,文档中强调LEMO产品及服务是“按现状”提供的,LEMO不对产品或服务的使用做出任何明示或暗示的保证,包括准确性、完整性或安全性。
用户需要对使用LEMO组件的产品和应用负全责。
FFA.1S.304.CLAC42 价格&库存
很抱歉,暂时无法提供与“FFA.1S.304.CLAC42”相匹配的价格&库存,您可以联系我们找货
FFA.1S.304.CLAC42
  • 1+385.533231+49.70267
  • 10+327.6621610+42.24198
  • 30+303.2278730+39.09192
  • 50+292.5015050+37.70909
  • 100+278.55398100+35.91098
  • 250+261.13946250+33.66592
库存:83
