SR38-4P-3P(71)
SR38-4P-3P(71)
    HRS(广濑)
    CONN PLUG MALE 3P SILV SLDR CUP
SR38-4P-3P(71) 数据手册
High Performance Microminiature Circular Connectors SR38 Series Mating Condition Feb.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. φ5 φ5.9 Panel 5.4 15.5 ■Features 1. High density, microminiature design 2. Simple wire installation ·With a nominal outside diameter of 5.3mm, the SR38 is designed to save space and fits well in tight spaces. ·The simple lock is designed to resist external forces, such as vibration. Shielding function is also provided. The plug is easy to assemble and no special tools are required. The receptacle is a PCB dip type. ■Product Specifications Ratings Rated Current 0.5A Operating Temperature Range −15 to 60ç Rated Voltage AC30V, DC42V Storage Temperature Range −10 to 60ç Items 1. Contact Resistance 2. Insulation Resistance 3. Withstanding Voltage Specifications 30mø max. 100Mø min. No flashover or breakdown 4. Vibration Resistance No electrical discontinuity of 10µs or greater 5. Shock No electrical discontinuity of 10µs or greater 6. Durability Contact Resistance : 50mø max. 7. Temperature Cycles Insulation Resistance : 100Mø min. 8. Humidity Resistance Insulation resistance : 1Mø min. (in high humidity) 10Mø min. (after drying) Conditions Measured with DC 100mA Measured with DC 100V AC 100V for 1 minute Tested 3 directions with 10 to 55Hz/cycle, vibration width 0.75mm, 2 hours each. Tested 3 directions with acceleration 490m/s2 and duration 11ms, 3 times each. 100 mating cycles -25ç : 30minutes ⇒ Ordinary temperature: 10 to 15minutes ⇒ 70ç : Left for 30minutes ⇒ Ordinary temperature: 10 to 15minutes, Total 5 cycles. Left at temperature 40ç and humidity 90 to 95% for 96 hours. ■Materials / Finish Items Outer Case Plug Insulator Male Contact Outer Shell Receptacle Insulator Female Contact Materials Brass Polypropylene resin (Black) PBT resin (Black) Phosphor bronze Brass Phosphor bronze PBT resin (Black) Phosphor bronze Finish Tin plated Remarks − − UL94V-0 − Silver plating Nickel plating Tin plated − Silver plating UL94V-0 − − − UL94V-0 − In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2015.11w 1 SR38 Series●High Performance Microminiature Circular Connectors ■Product Number Structure SR38 - 4 P - 3 P (**) ❶ ❷ ❸ ❹ ❺ ❻ ❶ Model Name: SR38 Series ❷ Shell size: This describes the outer diameter of the case on the mating plug ❸ Shell Type P: Plug R: Receptacle ❹ No. of Contacts: Feb.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❺ Contact Gender P: Male Contact S: Female contact ❻ Other Specifications: A two digit number will denote specific product changes 5.9 0.4 φ3.5 4.2 14.5 Part No. HRS No. SR38-4P-3P(71) 103-0372-2 71 (Applicable cable) φ5.3 φ3.7 ■Plug When this connector is assembled with the applicable cable, the clamp will perform well between 10 to 20N. If you plan on using cable other than the type we recommended, please check with your cable manufacturer to make sure it meets our requirements. This is especially important when the cable is being flexed as it may affect the performance of the connector. φ5 ■Receptacle 1.9 0.65±0.05 0.25±0.05 Part No. HRS No. 103-0373-5 71 0 0.65±0.05 As shown in the figure below, pinch the panel and PCB for fixation. Position the PCB, receptacle and panel together, as shown in the figure below. Also, make sure no loads are applied to the contact dip. Make sure that no direct force is placed onto the receptacle. .05 .5 5 4.5 Ø 0 4-Ø Ø3.8 (Ground location) 1.65±0.05 Dip Post Arrangement 2 BInstallation of the Receptacle + 0 .1 +0 0 1.35 0.8 SR38-4R-3S(71) BDip Post Arrangement and Panel Installation Dimensions 0.75±0.05 5.4 +0.1 0 Panel Recommended panel thickness: 0.8mm +0.05 0 PCB Panel Cutout SR38 Series●High Performance Microminiature Circular Connectors BContact Arrangement 1 3 Reference 1.This diagram displays a view of the receptacle from the mating side (plug termination side) 2.The inner diameter of the solder pot is 0.5mm.   2 BTermination Procedure (Plug side) Feb.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Large, rectangular slot Heat shrink tubing Plug unit shell cover Small, concave recess Plug body Outer shell cover Large, concave recess Plug Unit Small lug Plug unit shell Large lug Small rectangular slot Soldering point Hinge Shield Wire or drain wire Wire grip portion or strain relief Cable 1. Solder the prepared wires of the cable to the plug unit. (When using a soldering iron, apply heat of no more than 280°C for a maximum of 3 seconds.) 2. Place the heat shrink tubing over the soldered termination area and apply heat. Make sure that the heat shrink tubing does not contact the plug body. Doing so will affect the diameter of the plug body causing it to not fit properly in the plug unit shell 3. Solder the shield or drain wire to the bottom of the connector shell as shown in the diagram. 4. Install the cable into the wire grip portion of the plug unit shell. 5. Install the large and small lugs of the of the plug unit into the matching rectangular slots in the shell. Then install the plug unit shell cover. 6. Match the corresponding large and small recesses on the outer shell cover with the large and small lug parts on the plug body. Then close the outer shell cover and snap shut. 3 Feb.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. SR38 Series●High Performance Microminiature Circular Connectors Powered by TCPDF (www.tcpdf.org) USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS 2300 Warrenville Road, Suite 150, Downers Grove, Illinois 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, Ca. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Herzog-Carl-Strasse 4 D-73760 Ostfildern (Scharnhauser Park) Phone : +49-711-4560-02-1 Fax : +49-711-4560-02-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUERNBERG OFFICE Muggenhofer Str. 136 90429 Nuernberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE Regus La Garenne Colombes,Place de La Belgique, 71 Boulevard National La Garenne Colombes, 92250, France Phone : +33 (0) 1 7082 3170 Fax : +33 (1) 7082 3101 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 1601, Henderson Metropolitan, NO.300, East Nanjing Road, Huangpu District, Shanghai, China 200001 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD. Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7350 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO., LTD. 250, Huimanggongwon-ro, Siheung-si, Gyeonggi-do, Korea, 429-849 Phone : +82-31-496-7000,7124 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 10 Anson Road #26-16, International Plaza Office NO.519, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India 079903, Singapore Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ MALAYSIA: HIROSE ELECTRIC MALAYSIA PTE. LTD. 1-10-07, Suntech @ Penang Cybercity (1164),Lintang Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia. Phone : +604-619-2564 Fax : +604-619-2574 http://www.hirose.com/sg/ ® 4 INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ THAILAND: BANGKOK OFFICE (REPRESENTATIVE OFFICE) Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Phone : +66-2-686-1255 Fax : +66-2-686-3433 http://www.hirose.com/sg/ 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 11/2015. Contents are subject to change without notice for the purpose of improvements.
SR38-4P-3P(71) 价格&库存
很抱歉,暂时无法提供与“SR38-4P-3P(71)”相匹配的价格&库存,您可以联系我们找货
