GREC001SBSN-M89RC
GREC001SBSN-M89RC
    SULLINS
    CONN HEADER SMD R/A 1POS
GREC001SBSN-M89RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO DESCRIPTION DATE BY A 2268 INITIAL RELEASE 03/21/2011 LH B 2422 ADD 'P' PLATING OPTION 08/09/2011 GC F F E E A .098 2.50 D D A .025 0.64 .100 2.54 .100 2.54 .118 3.00 B .012[ 0.30] C .050 1.27 C HEAD DIM. RECOMMENDED PCB LAYOUT .138 3.50 .050 1.27 TAIL DIM. B A B NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING, UL 94V-0, BLACK. 2. CONTACT MATERIAL: SEE PART NUMBER CODING. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 3 AMPS PER CONTACT. 5. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 6. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 7. DIELECTRIC WITHSTANDING: 1000 VAC. 8. OPERATING TEMPERATURE: SEE PART NUMBER CODING. 9. *PROCESSING TEMP.: SEE PART NUMBER CODING. DRAWN *INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME. 8 7 6 5 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES [MM] Pb TOLERANCES: .XX= .XXX= .XXXX= RoHS COMPLIANT 4 ANGULAR: .012 [.30] .008 [.20] .0040 [.100] INTERPRET DIMENSIONS AND TOLERANCING PER: ASME Y14.5M-2009 3 DATE NAME 03/21/2011 LH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER .100" PITCH, HORIZONTAL SMT PART NUMBER SIZE C _ R _C_ _ _S_ _N-M89RC CAGE CODE 54453 SCALE: 4:1 2 DWG. NO. REV 11659 SHEET 1 OF 1 1 B FILE NAME: Z:\ECO PENDING\2422, TAIWAN HEADER 100 CC ADD P PLATING\11659, _R_C_ _ _S_ _N-M89RC PRINT: 8/26/2011 A
GREC001SBSN-M89RC
- 物料型号:N-M89RC - 绝缘体/接触材料:Nylon 9T/Brass - 处理温度:最高230°C持续60秒(或260°C持续10秒) - 接触镀层:纯锡,哑光 - 引脚分配:2至40个位置,具体尺寸根据头尾尺寸代码(BS, GS, ZC, ZU)有所不同 - 参数特性:每个接触点的电流额定值为3安培,绝缘体电阻至少5000兆欧,接触电阻最大20毫欧,耐电压1000V交流电,工作温度根据型号编码而定 - 功能详解:文档中未提供具体功能详解,但根据参数特性可以推断该物料适用于需要电气连接和信号传输的应用 - 应用信息:适用于SMT(表面贴装技术)的电子组件 - 封装信息:提供了不同尺寸的引脚间距,从0.100英寸(2.54mm)到4.000英寸(101.60mm) - 修订记录:初始发布于2011年3月21日,后于2011年8月9日增加了'P'镀层选项 - PCB布局推荐:提供了不同型号的引脚间距和尺寸,以适应不同的PCB设计需求
GREC001SBSN-M89RC 价格&库存
很抱歉,暂时无法提供与“GREC001SBSN-M89RC”相匹配的价格&库存,您可以联系我们找货
