3
View in direction B
4:1
5
4
6
50
Keying indication
Color coding
12
B
B
K10W
BC-P16LBC0-0000
K10W
SW 10
Mechanical coding: B
Color coding: red
A c-P16LBC0-0000
Mechanical coding: A
Color coding: light brown
Nur rot gestempelte oder auf Laufkarte gedruckte Dokumente
unterliegen dem Aenderungsdienst und sind zur Fertigung freigegeben.
Only red stamped or on jobcard printed documents
are managed. These documents are approved for production.
30
40
A
10.5
A
8
7
12.8
2
7.5
Additional coding
Fuer
Fall
ohne
noch
diese Unterlage behalten wir uns alle Rechte vor, auch fuer den
der Patenterteilung oder Gebrauchsmustereintragung. Sie darf
unsere vorherige schriftliche Zustimmung weder vervielfaeltigt
sonstwie benutzt, noch Dritten zugaenglich gemacht werden.
1
0.8
A
0.8
2.5
B
19.5
C
In-Line Receptacle
Crimp sleeve
1)
Backshell
C
Only insert and earth tag
Keying
indication
View in direction A
10:1
Color coding
1)
pos. 11
pos. 1
pos. 12
D
K10W
C C-P16LBC0-0000
D
pos. 16
Mechanical coding: C
Color coding: blue
Delivery condition
CAD: Creo Parametric
All Rights reserved, including possible patents
or trademarks. Documents shall not be provided
to a third party or duplicated in any form
without prior written permission.
2:1
E
E
Technical information
K10W
D C-P16LBC0-0000
2) Maximal operating voltage at sea level up to 2.000 m.
Rated voltage applies no other electrical safety standard. In
case other standards rule a specific use of the connector, the
application specific safety criteria shall be considered first.
This must be evaluated in the frame of equipment engineering.
Mechanical coding: D
Color coding: green
1
Max. cable n 7.0mm (Based on cable with one braided shield)
Solder contacts: AWG 28
Current load: 1A
@D t40 $ (Single contact)
Test voltage: 750V (acc. SAE AS 13441:1998, Contact to contact)
Rated voltage: 250V (acc. SAE AS 13441:1998)
2)
1) For crimp information, torque, etc. see
assembly instruction 010.650.001.000.002
(www.odu.de/downloads)
F
2
Bei den hier dargestellten ODU-Steckverbindern handelt es sich nach
DIN EN 61984:2009 um Steckverbinder ohne Schaltleistung (COC) !
/the pictured ODU-connectors are in relation to DIN EN 61984:2009
connectors without switching capacity (COC) !
3
4
Benennung/description:
R
Allgemeintoleranz/general tol.:
DIN ISO 2768-mH
Tolerierung / Tolerancing:
DIN ISO 8015
Status/state:
Version:
Approved revision:
Erstellt/prepared
12.01.2016prock
Kabelteil cpl.
CAD-Nr.:
design-ID:
Teile-ID:
part-ID:
Oxaion-Nr.:
ODU-MUEHLDORF
Ursprung/origin.:
Datum/date
Name/name
see BOM
Maßstab:
scale:
In-Line Receptacle
Geaendert/revised
12.01.2016prock
Freigabe/released
29.01.2016mmeier
Werkstoff:
material:
00101596
K10W_C-P16LBC0-0000
Format:
size:
5:1
Einheit:
dim.:
Bl.:
A3
mm
sheet: 1
K10WBC-P16LBC0-0000 价格&库存
很抱歉,暂时无法提供与“K10WBC-P16LBC0-0000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+1418.425901+184.39078
