EGN.2F.319.XLM
EGN.2F.319.XLM
    LEMO(雷莫)
    EGN.2F.319.XLM
EGN.2F.319.XLM 数据手册
COMPACT MULTIPOLE CONNECTORS No reproduction or use without express permission of editorial or pictorial content, in any manner. LEMO reserve the right at all times to modify and improve specifications without any notification. ® ® Table of Contents General production programme....................................................................................................page 2 Main characteristics and types............................................................................................................... 2 Series and types....................................................................................................................................... 3 LEMO’s push-pull self-latching connection system............................................................................. 4 F series production program.................................................................................................................. 4 General characteristics............................................................................................................................ 5 Selection of shell materials, degrees of protection (IP code)............................................................. 5 Selection of contact types (crimp, print, fibre optic)............................................................................ 6 F Series....................................................... Interconnections......................................................................................................................................... 8 Part numbering system.............................................................................................................................. 9 Part section showing internal components.................................................................................................... 9 Technical characteristics........................................................................................................................... 10 Metal housing models.............................................................................................................................. 11 Watertight PCB models............................................................................................................................ 15 Models for Fibre Optic.............................................................................................................................. 16 Alignment key........................................................................................................................................... 17 Insert configuration................................................................................................................................... 18 Housings, contacts, cable fixing............................................................................................................... 20 Variant...................................................................................................................................................... 21 LEMO F1 ECU systems connectors........................................................................................................ 22 Spare parts................................................ Crimp contacts......................................................................................................................................... 24 F7 fibre optic contacts.............................................................................................................................. 25 Locking washers, hexagonal nuts, notched nuts..................................................................................... 25 Conical nuts.............................................................................................................................................. 26 Accessories.............................................. Caps......................................................................................................................................................... 28 Heatshrink boot, insulating washers........................................................................................................ 29 Tooling........................................................ Spanners, taps, manual and pneumatic crimping tools........................................................................... 30 Positioners, extractor for crimp contact.................................................................................................... 31 Banding tool, retention testing tool........................................................................................................... 32 Fibre Optic Tooling............................... Complete workstation for F7 fibre optic contact....................................................................................... 32 Crimping tool, epoxy curing oven, polishing tool...................................................................................... 32 Fibre inspection microscope, microscope adaptor, F7 contact alignment device tool............................. 33 Panel Cut-Outs........................................ Mounting nut torque................................................................................................................................. 33 PCB Drilling Pattern............................. Fixed socket with straight print contact.................................................................................................... 34 Fixed socket with elbow print contact...................................................................................................... 35 Technical Characteristics.................. Outer shell................................................................................................................................................ 37 Insulator.................................................................................................................................................... 37 Electrical contact...................................................................................................................................... 38 Test voltage.............................................................................................................................................. 39 Rated current............................................................................................................................................ 40 Assembly instructions............................................................................................................................... 41 Technical tables....................................................................................................................................... 42 Product safety notice................................................................................................................................ 44 Product safety notice & disclaimers Please read and follow all instructions specified on the last page or on our website carefully and consult all relevent national and international safety regulations for your application. Improper handling, cable assembly, or wrong use of connectors can result in hazardous situations. LEMO products and services are provided “as is.” LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. In no event shall LEMO be liable for any direct, indirect, punitive, incidental, special consequential damages, to property or life, whatsoever arising out of or connected with the use or misuse of LEMO’s products. www.lemo.com 1 ® ® General Production Programme Connectors ● ● ● ● ● ● ● Unipole from 2 to 150 Amps Coaxial 50 and 75 Ω Coaxial 50 Ω (NIM-CAMAC) Coaxial 50 Ω for frequency → 12 GHz Multicoaxial 50 and 75 Ω Multipole from 2 to 68 contacts Multipole up to 106 contacts High Voltage 3, 5, 8, 10, 15, 30 and 50 kV cc Multi High Voltage 3, 5, and 10 kV cc Triaxial 50 and 75 Ω Quadrax Mixed: High Voltage (HV) + Low Voltage (LV) Mixed: Coax + LV and Triax + LV Thermocouple and multithermocouple Fibre optic singlemode and multimode Multi Fibre optic Mixed: fibre optic + LV Mixed: fibre optic + HV + LV Fluidic and Multifluidic Mixed: fluidic + LV Subminiature Miniature Sockets for printed circuit board Remote handling shell Watertight socket Hermaphroditic shell Rectangular connectors Sealed (pressure and/or vacuum) socket Plastic shell With aluminium outer shell With stainless steel outer shell With microswitch Patch Panels All audio-video and HDTV applications Adaptors For BNC, C, UHF, N, CINCH, GEN-RADIO connectors For TNC, SMA connectors Accessories Tooling Insulator for crimp contacts ● Crimp contacts Coaxial contacts Triaxial contacts ● Fibre optic contacts Fluidic contactss ● Caps Bend relief ● Heatshrink boot ● Washers ● Nuts ● ● ● ● ● On request Assembly tool Crimping tools Positioners Extractors Banding tool Fibre optic termination workstation and tools Connectors with special housing Special mixed configuration Custom design Assembly onto cable ● Connectors, accessories and tools found in this catalogue. Main Characteristics and Types Series Standard Watertight Keyed Keyed Watertight Compact keyed Hermaphroditic Rectangular Screw 01 / 00 (unipole) 00 (NIM-CAMAC) 05 / R0 / 1D 0S to 6S 0A / 4A / 2C 1Y-3Y-6Y 0E to 6E 3T 4M 00 (multipole) 0B to 5B 2G / 5G 0K to 5K 2N to 5N FF to 5F SH / MH RR / 0R / 1R 03 0V to 5V 0W to 5W 2U to 5U 0M-1M-2M Latching Key Shell Insert Contact termination Push-Pull Stepped insert Metal or plastic Metal Stepped insert or cylindrical Key (G) or other key-way code Screw Key (N) or other Hermaphroditic shell key-way code Key G or A Key or stepped insert Plastic Metal Stepped insert Rectangular Stepped insert or cylindrical Solder, crimp or print Crimp or print Solder crimp or print Metal Metal or plastic Cylindrical Solder or print Solder, crimp or print Contact type Coaxial, triaxial, unipole, multipole HV, quadrax, fluidic, thermocouple Multipole, fibre optic, HV, fluidic, thermocouple Multipole, fibre optic Multipole, HV, coaxial, fluidic Multipole, coaxial, triaxial Mixed config. LV + coax, LV + HV LV + coax, LV + triax, LV + HV, LV + FO, LV + fluidic LV + FO LV + coax, LV + HV, LV + fluidic LV + coax, LV + triax, LV + FO, LV + fluidic 2 Crimp or print www.lemo.com ® ® Series and Types Standard Watertight Keyed Keyed watertight Compact keyed Hermaphroditic Rectangular Screw 01 00 05 R0 0A 0S 1S 2S 3S 4S 5S 6S 1D 2C 4A 1Y-3Y-6Y 0E 1E 2E 3E 4E 5E 6E 3T 4M 00 0B 1B XB 2B 3B 4B 5B 2G 5G 0K 1K 2K 3K 4K 5K 2N to 5N FF 0F 1F 2F 3F 4F LF 5F SH-MH RR 0R 1R 03 0V to 5V 0W to 5W 2U to 5U 0M-1M-2M ● Thermocouple Mixed fluidic+LV Multi fluidic Fluidic Mixed FO+LV Multi Fibre Optic Fibre Optic Mixed Triax+LV Mixed Coax+LV Mixed HV+LV Multi Coaxial Multi HV Quadrax Triaxial 75 Ω Triaxial 50 Ω High Voltage ● ● Multipole Coaxial 50 Ω ● Series Coaxial 75 Ω Unipole Types ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● Note: ● = included in this catalogue, ● = available but not included in this catalogue. www.lemo.com 3 ® ® LEMO’s Push-Pull Self-Latching Connection System This self-latching system is renowned worldwide for its easy and quick mating and unmating features. It provides absolute security against vibration, shock or pull on the cable, and facilitates operation in a very limited space. The LEMO self-latching system allows the connector to be mated by simply pushing the plug axially into the socket. Once firmly latched, connection cannot be broken by pulling on the cable or any other component part other than the outer release sleeve. When required, the connector is disengaged by a single axial pull on the outer release sleeve. This first disengages the latches and then withdraws the plug from the socket. F Series Production Programme Series FF 0F 1F 2F 3F 4F LF 5F min. 2.2 Cable Ø range (mm) max. 9 3.8 11 3.8 13 3.8 16 3.8 18 5.3 25 6.3 27 7.4 34 40 68 Number of LV contacts Nr of FO contacts 1) 3, 4 4, 8, 10, 2, 3, 4, 5 3, 5, 7, 8 12, 19 22, 30 2 multi – – – – – 2 + 4 LV mixed – 50, 55, 64, 66 – Note: 1) For cable ranging from 3.6 to 6.5 mm in diameter. 4 www.lemo.com ® ® General Characteristics Selection of shell materials Aluminium alloy Brass The aluminium alloy outer shells find numerous applications where light weight is a predominant factor; such as in the aeronautics and space industries, and for portable and mobile equipment. Shells are made of high mechanical strength alloy (Aluminium alloy). Connector shells are protected by a conductive anthracite grey coloured nickel finish. As a standard latch sleeve are made of special bronze or brass, this material offer excellent performances for most of the applications. For very demanding vibrating situation we recommand the use of special latch sleeve in beryllium copper alloy. These parts have an electrolytic nickel plating. As a standard gaskets are made of fluororubber FPM/FKM. This material has excellent resistance to hydrocarbons. The brass outer shells have a chrome nickel-plated surface which ensures very good protection against industrial atmosphere, salt air and most corrosive agents. In case of brass shell standard latch sleeves are made of special bronze or brass. Here standard gaskets are made of silicone rubber MQ/MVQ. This material has excellent weather resistance and a wide temperature range. Other metallic components In general, most metallic components are manufactured in brass. However, bronze or beryllium copper are used where good elasticity is required (for example: earthing crown). Depending on the application, these parts have electrolytic nickel plating. Sealing resin An epoxy resin is used to seal both watertight and vacuumtight socket and coupler models. Degrees of protection (IP code) IEC 60529 outlines an international classification system for the sealing effectiveness of enclosures of electrical equipment against the intrusion into the equipment of foreign bodies (i.e., tools, dust, fingers) and moisture. This classification system utilizes the letters «IP» (Ingress Protection) followed by two digits. Example: IP 64 = IP 6 4 Degrees of protection - First digit Degrees of protection - Second digit The first digit of the IP code indicates the degree that persons are protected against contact with moving parts and the degree that equipment is protected against solid foreign bodies intruding into an enclosure. Second digit indicates the degree of protection of the equipment inside the enclosure against the harmful entry of various forms of moisture (e.g. dripping, spraying, submersion, etc.) 0 No special protection 1 Protection from a large part of the body such as hand or from solid objects greater than 50 mm in diameter 2 Protection against objects not greater than 80 mm in length and 12 mm in diameter 3 Protection from entry by tools, wires, etc., with a diameter or thickness greater than 2.5 mm 4 Protection from entry by solid objects with a diameter or thickness greater than 1.0 mm 5 Protection from the amount of dust that would interfere with the operation of the equipment 6 Dust-tight 0 1 2 3 4 5 6 7 8 IP letter code 1st digit 2nd digit No special protection Protection from vertically dripping water Protection from dripping water when tilted up to 15° Protection from sprayed water Protection from splashed water Protection from water projected from a nozzle Protection against heavy seas, or powerful jets of water Protection against temporary immersion Protection against complete continuous submersion in water UL Recognition LEMO connectors are recognized by the Underwriters Laboratories (UL). The approval of the complete system (LEMO connector, cable and your equipment) will be easier because LEMO connectors are recognized. RoHS LEMO connector specifications conforms the requirements of the RoHS directive (2011/65/EU) of the European Parliament and the latest amendments. This directive specifies the restrictions of the use of hazardous substances in electrical and electronic equipment marketed in Europe. www.lemo.com 5 ® ® Selection of contact types Crimp contacts The crimp contacts are designed to be crimped with the standard four indent method according to MIL-C-22520F, class 1, type 1. Fig. 1 øA Contacts are provided in two forms: with a standard crimp barrel for large conductors (see fig. 1), or with a reduced crimp barrel for smaller conductors (see fig. 2). Contact øC Conductor stranded AWG stranded Section (mm2) min. max. min. max. ø A ø C Form (mm) (mm) per fig. Fig. 2 øA øC øA øC 0.5 0.7 0.9 1.3 0.42 0.80 1.10 1.40 1 1 1 1 Contact ø A ø C Form (mm) (mm) per fig. 0.7 øC øA 0.9 1.3 0.45 0.80 0.45 1.10 281) 221) 20 18 32 26 24 20 2 2 2 2 0.09 0.34 0.50 1.00 12 22 30 40 Conductor stranded AWG stranded Section (mm2) min. max. min. max. Fr (N) 32 26 32 24 28 221) 28 20 0.035 0.140 0.250 0.500 Fr (N) 0.035 0.140 0.035 0.250 0.09 0.34 0.09 0.50 22 30 40 Note: Fr = mean contact retention force in the insulator (according to IEC 60512-8 test 15a). Note: 1) for a given AWG, the diameter of some stranded conductor designs is larger than the solder cup diameter. Make sure that the maximum conductor diameter is smaller than ø C. A detailed range of conductor dimensions that can be crimped into our contacts is given on the table at right. See also the section on tooling (pages 30 to 33). Print contacts Print contacts are available in straight or elbow versions for certain connector types. Connection is possible by soldering on flexible or rigid printed circuit boards. Straight print contacts are gold-plated which guarantees optimum soldering, even after longterm storage. Print elbow contacts include a tinned copper wire crimped into a contact. L dimensions and C ø are detailed in the section on model description (elbow: L = 2 mm). straight elbow L øA øC øA øA øC L L øC Fibre Optic contacts The new miniature F7 fibre optic contact is available for use with single-mode or multi-mode fibres of the following sizes; 9/125, 50/125 and 62.5/125 microns. Contacts are designed with the IEC standard 1.25 mm diameter ceramic ferrules. After mounting on the cable, the contact is very easily installed in the connector insulator, the particular shape of the contact body retains it in the insulator. The alignment tube can be easily removed in order to clean the fibre end face. Female contact 4 1 3 2 5 2 3 1 4 Male contact 1 body with holder 2 ferrule with holder 1 body with holder 3 spring 2 ferrule with holder 4 crimp ferrule 3 spring 5 alignment tube 4 crimp ferrule with support 6 www.lemo.com F SERIES ® ® F Series The F series connectors have been specially developed to meet the most demanding requirements in terms of dimensions, weight and watertightness. Our manufacturing programme includes now 8 series. This series provides customers with many features and benefits including: – push-pull self-latching system for safe connection – sealed to IP67 for environmental protection when mated according to IEC 60529 – compact scoop-proof design and use of aluminium alloy – high shock and vibration resistance – multipole types with 2 to 68 contacts or multifibre optic or mixed FO + LV in 2F series – crimp or print contacts (straight or elbow) – keys ensuring ease of blind mating – colour coded key options for system security. The F series connectors are available in 3 different materials: – for high shock and vibration resistance, LEMO recommends using Y code material (with beryllium copper latch sleeve). – for environmental resistance and latching cycle endurance, LEMO recommends using the C code material (brass outershell). – for lightweight and latching cycle endurance, LEMO recommends using X code material (aluminium shell). – for lightweight and salt spray corrosion resistance, LEMO recommends using I code material (aluminium shell). Each series includes several models of plugs and sockets available in contact configurations adapted to all round cables, including up to 68 conductors, and a maximum diameter of 34 mm. Since LEMO connectors are perfectly screened and designed to guarantee very low resistance to shell electrical continuity, they are particularly adapted to applications where electromagnetic compatibility (EMC) is important. A large number of accessories as well as tooling for cable assembly are available. Metal housing models (page 11) Straight plugs FG Fixed sockets Fixed sockets EC EG ED Free socket PE PH FN EC EE PB EH EF Models for fibre optic (page 16) Straight plug FG 8 Watertight models (page 15) Fixed socket Fixed sockets EH HE HE www.lemo.com ® ® Part Numbering System T = f.o. cable adapter and ø 5): Z = collet nut for bend relief (page 20) T 66 Z FG N . 0F . 305 . Y Plug C or L Variant: (page 21) F = reduced unlatching force 1) S = o-ring & gasket in silicone 2) Free socket PH N . 0F . 305 . X L M Fixed socket HE N . 0F . 305 . X L N P Model: (page 11) Variant 3): (page 21) Alignment key: (page 17) Contact 4): (page 20) Series: (page 11) Insulator: L = PEEK Insert configuration: (page 18) Housing: (page 20) Part Number Example Straight plug: FGN.0F.305.YLC = straight plug with key (N), 0F series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, beryllium copper latch sleeve, PEEK insulator, male crimp contacts. Free socket: PHN.0F.305.XLM = free socket with key (N), 0F series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, female crimp contacts. Fixed socket: HEN.0F.305.XLNP = fixed socket, nut fixing, with key (N), 0F series, multipole type with 5 contacts, outer shell in anthracite nickel-plated aluminium alloy, PEEK insulator, female print contacts, watertight. Note: 1) 5) for straight plug only. 2) with shell material code X or Y. 3) potting for HE● only. 4) HE● available only with print contacts (straight or elbow). connectors for fibre-optic are delivered without the fibre optic contacts, they must be ordered separately (see page 25). Part Section Showing Internal Components Straight socket Straight plug 5 1 2 3 4 5 6 www.lemo.com outer shell earthing crown insulator female contact rear seal front nut 3 2 4 1 6 1 4 5 3 5 2 6 1 2 3 4 5 6 outer shell latch sleeve insulator male contact gasket rear seal 9 ® ® Technical Characteristics Materials and Treatments Shell material code Component I X Y Surface treatment (μm) nickel chrome gold I X Material (Standard) C 0.3 – – – – 14 5 – 0.3 – – – anodized various colour 0.3 – – – – 14 5 – – 3 3 – – 3 3 – – 3 3 – – 3 3 – – 3 3 – anodized natural – 0.5 3 – – – – 1.0 – – – 1.5 without treatment – – – – – Brass (UNS C 38500) Aluminium alloy (AA 6262A or AA 6023) Brass (UNS C 38500) Aluminium alloy (AA 6262A or AA 6023) Brass (UNS C 38500) Aluminium alloy (AA 6262A or AA 6023) Bronze (UNS C 54400) or special brass Special bronze/brass Beryllium Copper (UNS C 17300) Bronze (UNS C 52100) Brass (UNS C 38500) Aluminium alloy (AA 6262A or AA 6023) Brass (UNS C 38500) Brass (UNS C 34500) Bronze (UNS C 54400) Cu-Be or special steel PEEK FPM/FKM (Viton®) Silicone MQ/MVQ Epoxy (Araldite® or Stycast®) Fluorosilicone Outer shell Conical nut Notched nut Earthing crown Latch sleeve Locking washer Hexagonal nut Other metallic components Male crimp contact Female crimp contact Clips Insulator O-ring and gaskets Sealing resin Cable rear seal Notes 1) 4) 5) 6) 2) 3) 1) 3) 6) 7) Notes: standards for surface treatment are as follows: chrome-plated SAE AMS 2460; nickel-plated SAE AMS QQ N 290 or MIL DTL 32119; gold-plated ISO 27874. 1) anthracite colour. 2) the colour match the colour code of the key (see page 17). 3) for the FF series only. 4) FF series available only with material code Y. 5) LF and 5F series available only with material code X. 6) Nickel Teflon® - NiCorAlTM treatment (500 hours salt spray corrosion resistant). 7) Silicone gasket are available as a variant for code material X and Y. Mechanical and Climatical Characteristics Value Endurance Endurance Endurance Humidity Operating temperature Operating temperature Vibration resistance Vibration (Gunfire test) Vibration (Gunfire test) Vibration (ECU profile) Shock resistance Salt spray corrosion test Salt spray corrosion test Salt spray corrosion test Protection index (mated) Climatical category Climatical category Standard 1000 cycles 300 cycles (FF and 0F); 500 cycles (1F to 3F) 5000 cycles up to 95% at 60° C -15° C, +200° C -55° C, +200° C 10-2000 Hz, 15 g pass pass pass 100 g, 6 ms 96 h 500 h 1000 h IP67 (select HE● model only for device protection) 15/200/21 50/175/21 IEC 60512-5 test 9a IEC 60512-5 test 9a IEC 60512-5 test 9a Vibration (ECU profile) new 1) > 1012 > 1010 Contact resistance 2) IEC 60512-2 test 2a ≤ 8.7 10 0.9 1.3 ≤ 6.1 ≤ 4.8 ≤ 3.6 Shell electrical continuity IEC 60512-2 test 2f Value Ω Value ø A (mm) mΩ 10 Value FF-0F 1F 2F-3F 4F LF 5F 5.0 3.0 2.5 2.0 1.5 1.5 mΩ Notes: 1) after humidity test: 21 days at 95% RH according to IEC 60068-2. 2) after 5000 mating cycles and the salt spray test according to IEC 60512-6 test 11 f. Acceleration (G2/Hz) Insulation resistance IEC 60512-2 test 3a 0.7 All; code X All; code Y All; code C All All; code X or Y All; code C All 4F, LF and 5F; all materials FF, 0F, 1F, 2F, 3F; code Y FF, 0F, 1F, 2F; code Y All All; code X or Y All; code I All; code C All All; code X or Y All; code C IEC 60512-4 test 6d MIL-standard 810 F MIL-standard 810 F See diagram below IEC 60512-4 test 6c IEC 60512-6 test 11f IEC 60512-6 test 11f IEC 60512-6 test 11f IEC 60529 IEC 60068-1 IEC 60068-1 Electrical 0.5 Series / Shell material 1 0.1 0.01 0.001 10 20 200 400 435 2000 Frequency (Hz) www.lemo.com ® ® Models FGl Straight plug, key (N) or keys (P, S, T, W and X) Reference L ~M øA øB X Dimensions (mm) Model Series A FGl FF FGl 0F FGl 1F FGl 2F FGl 3F FGW 4F FGX 4F FGW LF FGX LF FGl 5F 8.5 6.3 21.6 13.8 12.0 9.0 27.5 17.8 14.0 10.7 27.8 17.9 17.0 14.0 27.8 17.9 19.0 16.0 27.8 17.9 26.0 21.2 30.3 20.4 26.0 21.2 30.7 20.4 29.0 24.2 34.7 20.4 29.0 24.2 34.7 20.4 36.1 30.2 36.7 20.4 B L M X 5.7 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 Note: this plug can also be supplied with a reduced unlatching force (see page 9). FNl Straight plug, key (N) or keys (P and S) and lanyard release Reference L ~M X Dimensions (mm) Model Series A FNl 0F FNl 1F FNl 2F FNl 3F FNl 4F 12.0 9.0 18.0 27.5 17.8 140 14.0 10.7 20.0 27.8 17.9 140 17.0 14.0 23.0 27.8 17.9 160 19.0 16.0 25.0 27.8 17.9 190 26.0 21.2 32.0 30.3 20.4 230 B C L M N X 8.0 8.0 8.0 8.0 8.1 C øA øB N Note: cable material: stainless steel with protective sheath EGl Fixed socket, nut fixing, key (N) or keys (P, S and T), IP50 N Reference M øA e øB S3 E maxi S1 Dimensions (mm) Model Series A EGl 0F EGl 1F EGl 2F EGN 3F EGP 3F EGS 3F EGT 3F 10 14 18 22 22 22 22 B e 12.4 M9x0.6 15.8 M12x1.0 19.2 M15x1.0 25.0 M18x1.0 25.0 M18x1.0 25.0 M18x1.0 25.0 M18x1.0 E 7.0 6.5 6.5 5.5 5.5 5.5 5.5 M N S1 S3 1.2 1.5 1.8 2.0 2.0 2.0 2.0 19.0 8.2 19.0 10.5 19.0 13.5 19.0 16.5 19.0 16.5 20.5 16.5 20.5 16.5 11 14 17 22 22 22 22 Panel cut-out (page 33) www.lemo.com ­11 ® ® EC● Fixed socket with 2 nuts, key (N) or key (S), protruding shell, IP50 (back panel mounting) N M S3 e øA øB Dimensions (mm) Reference E maxi Model Series EC● FF A B e E M N S3 10 10.2 M7x0.5 1.5 2.5 13.9 9 Panel cut-out (page 33) Note: this socket can be used without the hexagonal nut. It can be directly fastened into the device, the notched nut is used as a tightening nut. EC● Fixed socket with 2 nuts, key (N) or key (S), protruding shell, print contacts, IP50 (back panel mounting) 3 N M S3 Reference øA e øB ø 0.5 E maxi Model Series EC● FF Dimensions (mm) A B e E M N S3 10 10.2 M7x0.5 1.5 2.5 13.9 9 Panel cut-out (page 33) Note: this socket can be used without the hexagonal nut. It can be directly fastened into the device, the notched nut is used as a tightening nut. EE● Fixed socket, nut fixing, key (N) or keys (P, S and T), IP50 (back panel mounting) N S1 M øA Reference e øB S3 S2 E maxi P Dimensions (mm) Model Series A B e E M N P EE● EE● EE● EEN EEP EES EET 0F 1F 2F 3F 3F 3F 3F 13 17 20 22 22 22 22 12 15 19 22 22 22 22 M10x0.75 M13x0.75 M16x1.00 M18x1.00 M18x1.00 M18x1.00 M18x1.00 6.0 6.2 6.4 6.4 6.4 6.4 6.4 2.5 3.2 4.0 4.0 4.0 4.0 4.0 19.0 19.0 19.0 19.0 19.0 20.5 20.5 8.5 9.4 10.4 10.4 10.4 10.4 10.4 S1 S2 S3 9.0 11.5 14.5 16.5 16.5 16.5 16.5 11 14 17 19 19 19 19 10.5 14.0 16.0 20.0 20.0 20.0 20.0 Panel cut-out (page 33) EF● Fixed socket, nut fixing, key (N) or keys (P, S and T), (back panel mounting) N S1 M S2 E maxi øA e øB Reference Dimensions (mm) Model Series A B EF● 1F 17 17 M13x0.75 6.2 3.2 19.0 9.4 11.5 14 e E M N P S1 S2 Panel cut-out (page 33) P 12 www.lemo.com ® ® EH● Fixed socket, nut fixing, key (N) or keys (P, S, T, W and X), (back panel mounting) Reference N P M øA e øB S2 S1 E maxi Dimensions (mm) Model Series A B e E M N P EH● EH● EH● EH● EHN EHP EHS EHT EHW EHX EHW EHX EH● FF 0F 1F 2F 3F 3F 3F 3F 4F 4F LF LF 5F 10 13 17 20 22 22 22 22 29 29 32 32 38 11 14 17 20 23 23 23 23 29 29 32 32 38 M7x0.50 M10x0.75 M13x0.75 M16x1.00 M18x1.00 M18x1.00 M18x1.00 M18x1.00 M24x1.00 M24x1.00 M27x1.00 M27x1.00 M33x1.00 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 6.4 6.4 6.4 2.5 2.5 3.2 4.0 4.0 4.0 4.0 4.0 5.0 5.0 5.0 5.0 5.0 15.0 19.0 19.0 19.0 19.0 19.0 20.5 20.5 19.0 21.0 24.3 24.3 28.4 12.0 14.5 14.5 14.5 14.5 14.5 16.0 16.0 14.5 16.5 20.0 20.0 24.0 S1 S2 6.4 9.0 11.5 14.5 16.5 16.5 16.5 16.5 22.0 22.0 25.0 25.0 31.0 8 11 14 17 19 19 19 19 25 25 28 28 34 Panel cut-out (page 33) ED● Fixed socket with flange, key (N) or keys (P and S), 2 holes fixing, protruding shell Reference N D Model Series ED● 1F Dimensions (mm) A B C d 25.4 5.9 11.5 3.5 D H 14 19.3 M N P 2 19 16.5 øC øB H A Panel cut-out (page 33) M ød P PH● Free socket, key (N) or keys (P, S, T, W and X) Reference L www.lemo.com øA øB X Dimensions (mm) Model Series A B L X PH● PH● PH● PH● PHN PHP PHS PHT PHW PHX PHW PHX PH● FF 0F 1F 2F 3F 3F 3F 3F 4F 4F LF LF 5F 8.5 12.0 14.0 17.0 19.0 19.0 19.0 19.0 26.0 26.0 29.0 29.0 35.0 6.3 9.0 10.7 14.0 16.0 16.0 16.0 16.0 21.2 21.2 24.2 24.2 30.2 20.7 26.7 26.7 26.7 26.7 26.7 28.2 28.2 26.7 28.7 32.2 32.2 37.2 5.7 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 13 ® ® PE● Fixed socket, nut fixing, key (N) or keys (P, S, T, W and X), (back panel mounting) Dimensions (mm) Reference L M e øA S1 øB øC X S2 E maxi Model Series PE● PE● PE● PE● PEN PEP PES PET PEW PEX PEW PEX PE● FF 1) 0F 1F 2F 3F 3F 3F 3F 4F 4F LF LF 5F A B C e E L M S1 S2 X 10 13 17 20 22 22 22 22 29 29 32 32 38 6.3 9.0 10.7 14.0 16.0 16.0 16.0 16.0 21.2 21.2 24.2 24.2 30.2 11 13 17 20 22 22 22 22 29 29 32 32 38 M7x0.50 M10x0.75 M13x0.75 M16x1.00 M18x1.00 M18x1.00 M18x1.00 M18x1.00 M24x1.00 M24x1.00 M27x1.00 M27x1.00 M33x1.00 6.0 6.0 6.2 6.4 6.4 6.4 6.4 6.4 6.4 6.4 6.4 6.4 6.4 20.7 26.7 26.7 26.7 26.7 26.7 28.2 28.2 26.7 28.7 32.2 32.2 37.2 2.5 2.5 3.2 4.0 4.0 4.0 4.0 4.0 5.0 5.0 5.0 5.0 5.0 6.4 9.0 11.5 14.5 16.5 16.5 16.5 16.5 22.0 22.0 25.0 25.0 31.0 – 11 14 17 19 19 19 19 25 25 28 28 34 5.7 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 8.0 Panel cut-out (page 33) Note: 1) fitted with notched nut GEG. PB● Fixed socket with flange, key (N) or keys (P, S, T, W and X), 2 holes fixing Reference D L M N A øB H ød 14 øC X Dimensions (mm) Model Series A B C d D H L M N X PB● PB● PB● PBN PBP PBS PBT PBW PBX PB● 0F 1F 2F 3F 3F 3F 3F 4F 4F 5F 27 27 31 38 38 38 38 41 41 44 9.0 10.7 14.0 16.0 16.0 16.0 16.0 21.2 21.2 30.2 11.0 13.0 16.0 17.5 17.5 17.5 17.5 23.0 23.0 32.0 3.2 3.2 3.2 3.2 3.2 3.2 3.2 3.2 3.2 3.2 15 15 18 20 20 20 20 26 26 33 21.4 21.4 25.9 29.0 29.0 29.0 29.0 32.0 32.0 38.2 26.7 26.7 26.7 26.7 26.7 28.2 28.2 26.7 28.7 37.2 2 2 2 2 2 2 2 2 2 2 4 4 4 4 4 4 4 4 4 4 8 8 8 8 8 8 8 8 8 8 Panel cut-out (page 33) www.lemo.com ® ® Watertight PCB models HEN fixed sockets allow the device on which they are fitted to reach a protection index of IP68 as per IEC 60529 (unmated). These models are identified by a letter «P» at the end of the reference. Epoxy resin is used to seal these models. They can be mated with all plugs of the same series to achieve an IP67 protection index between the plug and socket. Technical Characteristics Mechanical and Climatical Characteristics 1) Value Temperature range Temperature range Protection index unmated Maximum operating pressure 2) Note: 1) see also page 10. 2) Standard Series / Shell material -15° C, +100° C -50° C, +150° C IEC 60529 IEC 60512-7 test 14d IP68 5 bars All; code I, X or Y All; code C or variant with silicone gasket final code (S) All All this value corresponds to the maximum allowed pressure difference for the assembled socket. HE● Fixed socket, nut fixing, key (N) or keys (P, S, T, W and X), for printed circuit, (back panel mounting) Reference L X P M S2 H e øA ø 0.9 øB 3 E maxi S1 Epoxy resin Dimensions (mm) Model Series A B e E H L M P S1 S2 X HE● HE● HE● HE● HEN HEP HES HET HEW HEX HEW HEX HE● 1) 10 13 17 20 22 22 22 22 29 29 32 32 38 11 14 17 20 23 23 23 23 29 29 32 32 38 M7x0.50 M10x0.75 M13x0.75 M16x1.00 M18x1.00 M18x1.00 M18x1.00 M18x1.00 M24x1.00 M24x1.00 M27x1.00 M27x1.00 M33x1.00 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 6.4 6.4 6.4 5.08 5.08 7.62 8.89 11.43 11.43 11.43 11.43 15.24 15.24 16.51 16.51 20.32 18.2 21.5 21.5 21.5 21.5 21.5 23.0 23.0 21.5 23.5 26.3 26.3 32.2 2.5 2.5 3.2 4.0 4.0 4.0 4.0 4.0 5.0 5.0 5.0 5.0 5.0 12.0 14.5 14.5 14.5 14.5 14.5 16.0 16.0 14.5 16.5 20.0 20.0 24.0 6.4 9.0 11.5 14.5 16.5 16.5 16.5 16.5 22.0 22.0 25.0 25.0 31.0 8.2 11.0 14.0 17.0 19.0 19.0 19.0 19.0 25.0 25.0 28.0 28.0 34.0 15.0 17.5 17.5 17.5 17.5 17.5 19.0 19.0 17.5 19.5 23.5 23.5 27.4 FF 0F 1F 2F 3F 2) 3F 2) 3F 2) 3F 2) 4F 4F LF LF 5F Panel cut-out (page 33) PCB drilling pattern (page 34) 1) Note: fitted with notched nut GEG. 2) for chrome plated version (material code «C»), A = 24 mm and S2 = 20 mm. HE● Fixed socket, nut fixing, key (N) or key (P), with elbow (90°) contacts for printed circuit, (back panel mounting) Reference N H mini øA S2 e øB P M Dimensions (mm) Model Series A B e E H HE● HE● HE● 0F 1F 2F 13 17 20 14 17 20 M10x0.75 M13x0.75 M16x1.00 3.0 3.0 3.0 20 20 20 Panel cut-out (page 33) M N P S1 S2 2.5 18.5 14.5 9.0 3.2 18.5 14.5 11.5 4.0 18.5 14.5 14.5 11 14 17 PCB drilling pattern (page 35) S1 E maxi 2 www.lemo.com 15 ® ® Models for Fibre Optic The 2F series has also been designed to allow fibre optic transmissions. This compact connector uses our F7 fibre optic contact but requires a specific plug with extended shell (T-adapter). The main features are: – Multi fibre option with 2 optical contacts – Mixed option with 2 FO + 2 LV contacts – Optical contact with ceramic ferrules diametre 1.25 mm Technical Characteristics of optical contacts Mechanical and Climatical Optical Characteristic Value Standard Mating durability Damp heat steady state High temperature Low temperature Cable retention Vibration (3 axes) Change of temperature Temperature/humidity > 1000 cycles up to 93 % RH at 40°C +85°C -40°C 100 N 100 to 2000 Hz, 2 hrs -40 to +75°C -10 to +65°C at 93 % RH IEC IEC IEC IEC IEC – IEC IEC Characteristic Value Standard Method 61300-02-02 61300-02-19 61300-02-18 61300-02-17 61300-02-04 Average insertion loss fibre 9/125 µm 0.18 dB IEC 61300-03-34 Method 2 Average insertion loss fibre 50/125 µm 0.25 dB IEC 61300-03-34 Method 2 Return loss fibre 9/125 µm (UPC) ≥45 dB IEC 61300-03-06 Coupler Method 61300-02-22 61300-02-21 Return loss fibre 9/125 µm (Hand polish) >25 dB IEC 61300-03-06 Coupler Method FG● Straight plug, key (N) or keys (P and S) ~L Dimensions (mm) Reference Model Series FG● 2F A B L M S1 S2 17.0 14.0 89.5 79.5 15.0 14.0 øA øB ~M S2 S1 EH● Fixed socket, nut fixing, key (N) or keys (P and S), (back panel mounting) L P M S2 E maxi S1 øA e øB Reference Dimensions (mm) Model Series A B e E L M EH● 2F 20 20 M16x1 3 21.8 4 P S1 S2 14.5 14.5 17 Panel cut-out (page 33) Note: Other models of socket can be made available. Connectors for fibre-optic are delivered without the fibre optic contacts, they must be ordered separately (see page 25). For T-type cable adapter see page 20. 16 www.lemo.com ® ® Alignment Key Alignment Key and Polarized Keying System F series connector model part numbers are composed of three letters. The LAST LETTER indicates the keys corresponding to a particular contact type. For example, straight plugs with N, P or W keys, are fitted with male contacts; whereas with S, T or X keys, plugs are fitted with female contacts. Sockets with N, P or W keys, are fitted with female contacts; whereas with S, T or X keys, sockets are fitted with male contacts. Model Front view of a socket Nb of keys Series FF γ 165° – 155° – 30° – 50° – Angles β γ Series 3F β γ 150° 145° 140° 135° 60° 70° 80° 90° Colour code Contact type Electrical or Optical Plug Socket male male female female female female male male N P ●●S ●●T 3 Model β β Series 0F to 2F Nb of keys ●● ●● γ Front view of a socket α β δ γ ● First choice alternative www.lemo.com W X ●● ●● 5 165° 150° 155° 160° 30° 60° 50° 40° Series 4F-LF-5F blue yellow red green Colour code Angles α β γ δ 95° 100° 115° 125° 35° 40° 25° 20° blue red Note ● ● ● ● Contact type Note Plug Socket male female female male ● ● ● Special order alternative 17 ® ® Insert configuration Multipole Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) Contact-shell Rated current (A)1) Male crimp contacts Female crimp contacts FF 303 3 0.5 ● ● – 28-30-32 1.35 1.10 3.0 304 4 0.5 ● ● – 28-30-32 1.05 1.05 2.0 0F 302 2 0.9 ● ● ● 20-22-24 1.45 1.20 10.0 303 3 0.9 ● ● ● 20-22-24 1.70 1.60 8.0 304 4 0.7 ● ● ● 22-24-26 1.35 1.10 7.0 305 5 0.7 ● ● ● 22-24-26 1.25 1.20 6.5 1F 303 3 1.3 ● ● ● 1.60 1.85 12.0 305 5 0.9 ● ● ● 20-22-24 1.30 1.55 9.0 307 7 0.7 ● ● ● 22-24-26 1.45 1.45 7.0 308 8 0.7 ● ● ● 22-24-26 1.30 1.30 5.0 2F 3F 3) 4) 2 1 1 2 3 4 4 3 304 4 1.3 ● – – 2.70 1.85 15.0 308 8 0.9 ● ● ● 20-22-24 1.95 1.95 10.0 310 10 0.9 ● ● ● 20-22-24 1.80 2.10 8.0 312 12 0.7 ● ● ● 22-24-26 1.65 2.00 7.0 319 19 0.7 ● ● ● 22-24-26 1.55 1.65 5.0 322 22 0.7 ● ● – 22-24-26 1.70 1.45 5.5 330 30 0.7 ● ● – 22-24-26 1.35 1.20 3.5 340 40 0.7 ● ● – 22-24-26 1.35 1.30 2.0 4F AWG2) Print (elbow) Contact type Print (straight) 2 Crimp 3 ø A (mm) 1 Number of contacts 4 3 Reference 4 2 øA 1 18-20 18-20 Note: Other types available on request, based on existing contact configurations of the B series. 1) see calculation method, caution and suggested standard on pages 39 and 40. 2) the mentioned AWG range apply to the standard crimp contact of fig.1. Contacts with reduced crimp barrel are available for smaller conductor. See page 20 for explanation and availability. 3) view for EHS socket. 4) view for FGS plug. 18 www.lemo.com ® ® Multipole Print (elbow) AWG2) Test voltage (kV rms)1) Contact-contact Test voltage (kV rms)1) Contact-shell Rated current (A)1) Contact type Print (straight) 2 Crimp 3 ø A (mm) 1 3 Number of contacts 4 2 Reference 4 368 68 0.7 ● ● – 22-24-26 1.5 1.5 2.5 350 50 0.9 ● ● – 20-22-24 1.20 1.45 6.0 355 55 0.9 ● ● – 20-22-24 2.00 2.10 5.0 364 64 0.9 ● ● – 20-22-24 1.35 1.85 3.0 366 66 0.9 ● ● – 20-22-24 1.30 1.80 3.0 øA 1 Male crimp contacts Female crimp contacts LF 5F Note: Other types available on request, based on existing contact configurations of the B series. 1) see calculation method, caution and suggested standard on pages 39 and 40. 2) the mentioned AWG range apply to the standard crimp contact of fig.1. Contacts with reduced crimp barrel are available for smaller conductor. See page 20 for explanation and availability. Multi fibre and Mixed fibre optic + LV Low Voltage contact 2 Rated current (A) 1 3 Test voltage (kV rms)1) Contact-shell 4 3 Test voltage (kV rms)1) Contact-contact 4 2 Crimp 1 ø A (mm) 2F Contact No Female crimp contacts Fibre optic No Male crimp contacts Crimp contact Reference øA Contact type 03A 2 – – – – – – 93B 2 4 0.7 ● 0.85 1.25 6.0 Note: Other types available on request, based on existing contact configurations of the B series. 1) see calculation method, caution and suggested standard on pages 39 and 40. 2) the mentioned AWG range apply to the standard crimp contact of fig.1. Contacts with reduced crimp barrel are available for smaller conductor. See page 20 for explanation and availability. www.lemo.com 19 ® ® Housings Availability for plug for sockets FF 0F 1F 2F 3F 4F LF 5F FF 0F 1F 2F 3F 4F LF 5F Ref. – – ● – I X Y C ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● ● – ● ● – – ● ● – – ● ● – – ● ● – ● ● ● – ● ● ● – ● ● ● – ● ● ● – – ● ● – – ● ● – – Outer shell Latch sleeve Material Surface treatment Material Surface treatment Gaskets Aluminium alloy Aluminium alloy Aluminium alloy Brass NiCorAl Nickel1) Nickel1) Chrome Special bronze/brass Special bronze/brass Beryllium copper Special bronze/brass NiCorAl Nickel Nickel Nickel FPM/FKM FPM/FKM FPM/FKM Silicone MQ/MVQ ● First choice alternative    ● Special order alternative Note: 1) anthracite colour. See page 10 for detail on Material and Treatments. Contacts Crimp contacts for plugs, free or fixed sockets There are 2 forms of crimp barrels: – per fig. 1, the standard design – per fig. 2, with reduced crimp barrel for small conductors. Fig. 1 øA øC øA øC Ref. Contact type Ref. Contact type C B G D Z Male crimp (fig. 1) Male crimp (fig. 2) Male crimp (fig. 2) Male straight print No contact (for multi FO) M P U N V Female crimp (fig. 1) Female crimp (fig. 2) Female crimp (fig. 2) Female straight print Male or female elbow print Dimension of crimp barrels Contact Fig. 2 Ref. contact type ø A ø C Form (mm) (mm) per fig. Male Female C C B C B G C M M P M P U M øC øA 0.5 0.7 øC øA 0.9 1.3 0.42 0.80 0.45 1.10 0.80 0.45 1.40 1 1 2 1 2 2 1 Conductor AWG Section (mm2) min. max. min. max. 32 26 32 24 26 32 20 281) 22 28 20 22 28 18 0.035 0.140 0.035 0.250 0.140 0.035 0.500 0.09 0.34 0.09 0.50 0.34 0.09 1.00 1) Note: for a given AWG, the diameter of some stranded conductor designs is larger than the solder cup diameter. Make sure that the maximum conductor diameter is smaller than ø C. Cable Fixing øA T type cable adapter Reference 2F Adapter øA T46Z T56Z T66Z 4.6 5.6 6.6 Cable ø max. min. 4.5 5.5 6.5 3.6 4.6 5.6 Adapter with gasket part number Bend relief to be used 1) FGG.2F.846.TNV FGG.2F.856.TNV FGG.2F.866.TNV GMA.2B.040.D● GMA.2B.050.D● GMA.2B.060.D● Note: 1) to order separately. 20 www.lemo.com ® ® Variant Some options are available, they are identify with specific letters in the variant position. – F apply to plug with a reduced unlatching force, such option allows disconnection if the cable is pulled accidentally. – Connectors with code material I, X or Y are delivered with FPM/FKM gasket as a standard. As an option they can be delivered with Silicone gasket. Add the «S» in the variant position. – P indicated that the watertight models HE● are potted with epoxy resin. Reference Model FG● E●● HE● www.lemo.com Reduced unlatching force Silicone gasket Potted Potted and silicone gasket F – – S S – – – P – – PS 21 ® ® LEMO F1 ECU systems connectors LEMO F Series connectors feature on the new ECU being provided by Microsoft® and McLaren Electronic Systems® for the FIA Formula One World Championship in 2008, 2009 and 2010. The applications include the hub interface unit, lap trigger receiver, powerbox and display connections. To assist users, information on corresponding LEMO connectors that are required to connect to the system are described here below giving full part numbers and application. LEMO connectors can also be idealy used for HIL setups (hardware in the loop), for vehicle electronic development, crash test setups, for ECU calibration and test, and also in battery status diagnosis. LEMO connectors have full EMC screening and offer secure push-pull connections for Flexray, CAN bus or USB protocol, PWM (pulse width modulation), digital I/O and power supply. F1 ECU SYSTEM Based on diagram courtesy of McLaren Electronic Systems Ltd HIU-3 Hub Interface Unit HIU-3 Hub Interface Unit LRX-310B Lap Trigger Receiver LEMO Connector HES.1F.308.XLDP HIU-3 IN 4 POS. LEMO Connector EHS.0F.303.XLCY LEMO Connector HES.1F.308.XLDP LEMO Connector HEN.FF.304.SLNP (2 off) HEN.FF.304.SLNPY (2 off) PCU-6C Dashboard Display LIU-4 LVDT Interface Unit SIU-300 Switch Interface Unit PB2006 Powerbox TAG-31B Main Control Unit LEMO Connector HEP.2F.310.XLNP Ignition Battery LEMO Connector EHS.2F.304.XLY Injection LEMO Connector HEN.2F.319.XLNP Alternator HIU-3 Hub Interface Unit HIU-3 Hub Interface Unit HIU (1, 2, 3 & 4) Hub Interface Unit Unit connectors PB2006 Powerbox Interface connectors HES.1F.308.XLDP FGS.1F.308.YLM HEN.FF.304.SLNP 1) FGN.FF.304.YLC HEN.FF.304.SLNPY 1) FGN.FF.304.YLC Spare contacts EGG.0B.655.ZZM FGG.00.554.ZZC FGG.00.554.ZZC Notes: 1) outershell in stainless steel (AISI 303, 304). Unit connectors Interface connectors EHS.2F.304.XLY FGS.2F.304.YLY HEP.2F.310.XLNP HEN.2F.319.XLNP FGP.2F.310.YLC FGN.2F.319.YLC Spare contacts FGN.1F.565.ZZC 1) EGN.1F.665.ZZM 2) FGG.0B.560.ZZC FGG.0B.555.ZZC Notes: 1) male contact. 2) female contact. LRX 310B Lap Trigger Receiver Unit connector EHS.0F.303.XLCY 22 Interface connector FGS.0F.303.YLM PCU-6C Dashboard display Spare contact Unit connector EGG.0B.660.ZZM HES.1F.308.XLDP Interface connector FGS.1F.308.YLM Spare contact EGG.0B.655.ZZM www.lemo.com SPARE PARTS ® ® Spare parts FGG-EGG Crimp contacts øA øC øA øC FF 0.5 0.42 FGG.00.554.ZZC EGG.00.654.ZZM FGG.00.554.ZZC EGG.00.654.ZZM 0F 0.9 1.10 0.7 0.80 1F 1.3 1.40 0.9 1.10 0.7 0.80 FGG.0B.560.ZZC EGG.0B.660.ZZM FGG.0B.560.ZZC EGG.0B.660.ZZM FGG.0B.555.ZZC EGG.0B.655.ZZM FGG.0B.555.ZZC EGG.0B.655.ZZM 2F 1.3 1.40 0.9 1.10 0.7 0.80 FGN.1F.565.ZZC EGN.1F.665.ZZM FGN.1F.565.ZZC EGN.1F.665.ZZM FGG.0B.560.ZZC EGG.0B.660.ZZM FGG.0B.560.ZZC EGG.0B.660.ZZM FGG.0B.555.ZZC EGG.0B.655.ZZM FGG.0B.555.ZZC EGG.0B.655.ZZM 3F 0.7 0.80 FGG.0B.555.ZZC EGG.0B.655.ZZM FGG.0B.555.ZZC EGN.3F.655.ZZM 4F 0.7 0.80 FGG.2B.555.ZZC EGG.0B.655.ZZM FGG.0B.555.ZZC EGG.2B.655.ZZM LF 0.7 0.80 FGG.3B.555.ZZC EGG.2B.655.ZZM FGG.0B.555.ZZC EGG.3B.655.ZZM 5F 0.9 1.10 FGG.3B.560.ZZC EGG.3B.660.ZZM FGG.3B.560.ZZC EGG.3B.660.ZZM Contact (mm) ø A øC 0F 0.80 0.9 0.45 0.7 0.45 FGG.0B.561.ZZC EGG.0B.661.ZZM FGG.0B.561.ZZC EGG.0B.661.ZZM FGG.0B.562.ZZC EGG.0B.662.ZZM FGG.0B.562.ZZC EGG.0B.662.ZZM FGG.0B.556.ZZC EGG.0B.656.ZZM FGG.0B.556.ZZC EGG.0B.656.ZZM 1F 0.80 0.9 0.45 0.7 0.45 FGG.0B.561.ZZC EGG.0B.661.ZZM FGG.0B.561.ZZC EGG.0B.661.ZZM FGG.0B.562.ZZC EGG.0B.662.ZZM FGG.0B.562.ZZC EGG.0B.662.ZZM FGG.0B.556.ZZC EGG.0B.656.ZZM FGG.0B.556.ZZC EGG.0B.656.ZZM 2F 0.80 0.9 0.45 0.7 0.45 FGG.0B.561.ZZC EGG.0B.661.ZZM FGG.0B.561.ZZC EGG.0B.661.ZZM FGG.0B.562.ZZC EGG.0B.662.ZZM FGG.0B.562.ZZC EGG.0B.662.ZZM FGG.0B.556.ZZC EGG.0B.656.ZZM FGG.0B.556.ZZC EGG.0B.656.ZZM 3F 0.7 0.45 FGG.0B.556.ZZC EGG.0B.656.ZZM FGG.0B.556.ZZC EGN.3F.656.ZZM 4F 0.7 0.45 FGG.2B.556.ZZC EGG.0B.656.ZZM FGG.0B.556.ZZC EGG.2B.656.ZZM LF 0.7 0.45 FGG.3B.556.ZZC EGG.2B.656.ZZM FGG.0B.556.ZZC EGG.3B.656.ZZM 5F 0.9 0.80 FGG.3B.561.ZZC EGG.3B.661.ZZM FGG.3B.561.ZZC EGG.3B.661.ZZM Fig. 2 øA øA ­24 øC øC Contact part number female for socket male for socket Contact (mm) ø A øC Fig. 1 male for plug female for plug FGN.1F.565.ZZC EGN.1F.665.ZZM FGN.1F.565.ZZC EGN.1F.665.ZZM FGG.0B.560.ZZC EGG.0B.660.ZZM FGG.0B.560.ZZC EGG.0B.660.ZZM FGG.0B.555.ZZC EGG.0B.655.ZZM FGG.0B.555.ZZC EGG.0B.655.ZZM male for plug Contact part number female for socket male for socket female for plug www.lemo.com ® ® FFS.F7 Male F7 Fibre Optic Contact Part number FFS.F7.125.LCE23 125 FFS.F7.126.LCE23 126 FFS.F7.128.LCE23 128 ø 3.3 ø 1.25 ~L Ferrule hole Fibre ø ø (µm) core/cladding (µm) Note l l 9/125 50/125 62.5/125 PSS.F7 Female F7 Fibre Optic Contact Ferrule hole Fibre ø ø (µm) core/cladding (µm) PSS.F7.125.LCE23 125 PSS.F7.126.LCE23 126 PSS.F7.128.LCE23 128 8.2 ø 3.3 ~L ø 1.25 Part number Note l l 9/125 50/125 62.5/125 Note: alignment device part number: PSS.F7.290.NZZ GBA Locking washers øA L øC Part number GBA.00.250.FN GBA.0S.250.FN GBA.1S.250.FN GBA.2S.250.FN GBA.3S.250.FN Dimensions (mm) For Series models A C L FF 9.5 7.1 1.0 ECl 0F 12.5 9.1 1.0 EGl 1F 16.0 12.1 1.0 EGl 2F 19.5 15.1 1.2 EGl 3F 25.0 18.1 1.4 EGl, PEl, EEl, EHl Note: to order this accessory separately, use the above part numbers. l Material: Nickel-plated bronze (3 µm) GEA Hexagonal nuts Part number A L øB e GEA.00.240.LN GEA.0S.240.LN GEA.1S.240.LN GEA.2S.240.LN GEA.3S.240.LN Dimensions (mm) Series A B e L FF 0F 1F 2F 3F 9 10.2 M7x0.50 2.0 11 12.4 M9x0.60 2.0 14 15.8 M12x1.00 2.5 17 19.2 M15x1.00 2.7 22 25.0 M18x1.00 3.0 For models ECl EGl EGl EGl EGl Note: to order this part separately use the above part numbers. Also available in aluminium alloy (GEA.ll.240.RT). l Material: Nickel-plated brass (3 µm) GEG Notched nut øA L e øB Part number GEG.00.240.RN Dimensions (mm) Series A B e L For models FF 8.7 10 M7x0.50 2.5 HEl, ECl, PEl l Material: Nickel-anthracite aluminium alloy www.lemo.com ­25 ® ® GEC Conical nut Part number A L øB e GEC.FF.240.Rl GEC.0F.240.Rl GEC.1F.240.Rl GEC.2F.240.Rl GEC.3F.240.Rl GEC.4F.240.Rl GEC.LF.240.Rl GEC.5F.240.Rl Ref. A J Colour blue yellow Dimensions (mm) Series A B e L FF 0F 1F 2F 3F 4F LF 5F For models 8 10 M7x0.50 2.5 PEl, EHl, HEl 11 13 M10x0.75 2.5 PEl, EEl, EHl, HEl 14 17 M13x0.75 3.2 PEl, EEl, EHl, HEl 17 20 M16x1.00 4.0 PEl, EEl, EHl, HEl 19 22 M18x1.00 4.0 PEl, EEl, EHl, HEl 25 29 M24x1.00 5.0 PEl, EHl, HEl 28 32 M27x1.00 5.0 PEl, EHl, HEl 34 38 M33x1.00 5.0 PEl, EHl, HEl Keying N or W P Ref. R V Colour red green Keying S or X T Note: the last position “l” of the part number indicates the colour. To obtain the required colour, refer to the above table and change the position “l” of the part number to the corresponding letter. l Material: Anodized aluminium alloy ­26 www.lemo.com TOOLING ACCESSORIES ® ® Accessories BFl Plug caps, with keys (N or P) L B øA Part number BFl.1F.100 PCSG BFl.2F.100.PCSG l l l l N Dimensions (mm) Series A B L N1) 1F 12.0 13.3 12.6 62 2F 15.0 16.4 12.8 75 Body material: PA6.6 grey Cord material: Polyamide 6 Maximum operating temperature: 100°C Protection index: IP51 according to IEC 60529 Note: 1) the tolerance on this dimension is ± 5 mm. BRA Blanking caps for fixed sockets L øA M Part number øB N BRA.1F.200.PZSG BRA.2F.200.PZSG l l l l Dimensions (mm) Series A B L M N 1F 14.0 13.7 12.1 5.3 65.5 2F 18.0 16.5 12.0 5.6 65.5 Body material: PA6.6 grey Band: PET Maximum operating temperature: 100°C Protection index: IP51 according to IEC 60529 BRF Blanking caps, with latching for free sockets Part number L N øA M sliding loop BRF.FF.200.YAV BRF.0F.200.XAV BRF.1F.200.XAV BRF.2F.200.XAV BRF.3F.200.XAV BRF.4F.200.XAV BRF.LF.200.XAV Dimensions (mm) Series A L M N1) FF 0F 1F 2F 3F 4F LF 8.5 20.0 12.0 60 12.0 25.5 15.6 85 14.0 25.8 15.7 85 17.0 25.8 15.6 85 19.0 27.8 17.6 120 26.0 30.3 20.1 120 29.0 34.7 20.1 120 Note: 1) the tolerance on this dimension is ± 5 mm. This cap is suitable for use with any alignment key configuration. l Lanyard material: Stainless steel l Crimp ferrule material: Nickel-plated brass + polyolefin l Maximum operating temperature: 135°C l Watertightness: IP67 according to IEC 60529 BRE Blanking caps, with latching for fixed sockets Part number L ø 3.5 N øA M BRE.FF.200.YAV BRE.0F.200.XAV BRE.1F.200.XAV BRE.2F.200.XAV BRE.3F.200.XAV BRE.4F.200.XAV BRE.LF.200.XAV Dimensions (mm) Series A L M N1) FF 0F 1F 2F 3F 4F LF 8.5 20.0 12.0 60 12.0 25.5 15.6 85 14.0 25.8 15.7 85 17.0 25.8 15.6 85 19.0 27.8 17.6 120 26.0 30.3 20.1 120 29.0 34.7 20.1 120 Note: 1) the tolerance on this dimension is ± 5 mm. This cap is suitable for use with any alignment key configuration. The BRE.0F cap has no keying and can be therefore used with any socket. l Lanyard material: Stainless steel l Crimp ferrule material: Nickel-plated brass + polyolefin ­28 l Maximum operating temperature: 135°C l Watertightness: IP67 according to IEC 60529 www.lemo.com ® ® BFG Plug caps L Dimensions (mm) Series A B L N1) Part number N øA B sliding loop FF 8.5 0F 12.0 1F 14.0 2F 17.0 3F 19.0 4F 26.0 LF 30.0 BFG.FF.100.XAZ BFG.0F.100.XAZ BFG.1F.100.XAZ BFG.2F.100.XAZ BFG.3F.100.XAZ BFG.4F.100.XAZ BFG.LF.100.XAZ 4 6 6 6 8 8 8 14 60 18 85 18 85 18 85 20 120 20 120 24 120 Note: 1) the tolerance on this dimension is ± 5 mm. This cap is suitable for use with any alignment key configuration. l Lanyard material: Stainless steel l Crimp ferrule material: Nickel-plated brass + polyolefin Heatshrink boot Elbow boot Supplier BEFORE HEATING BEFORE HEATING LEMO FF GMA.10.290.DN GHA.10.210.DN 202 A 111-25/86 222 A 111-25/86 0F-1F-2F-3F 202 A 111-25 222 A 111-25 202 A 121-25/86 222 A 121-25/86 Raychem® 1F-2F-3F-4F 202 A 121-25 222 A 121-25 4F-LF-5F 202 A 142-25/86 222 A 142-25/86 4F-5F 202 A 142-25 222 A 142-25 104-1-G 1108-1-G 0F-1F-2F-3F Hellermann® 105-1-G 1106-1-G 1F-2F-3F-4F 101-1-G 1104-2-G 4F-5F AFTER HEATING AFTER HEATING Part number cable ø Series min. Straight Elbow 90° (mm) Note Straight boot l Maximum operating temperature: 135°C l Watertightness: IP67 according to IEC 60529 2) 2.2 1) 3.8 2) 3.8 1) 5.3 2) 5.3 1) 7.4 2) 7.4 2) 3.8 2) 5.6 2) 7.1 Note: 1) modified elastomer resistant to fluids with hot melt sealant. 2) elastomer resistant to fluids. We recommend a thermosetting sealant with this type of boot. GRA Insulating washers Part number GRA.0F.269.Gl GRA.1F.269.Gl GRA.2F.269.Gl GRA.3F.269.Gl GRA.4F.269.Gl GRA.5F.269.Gl Dimensions (mm) Series A B E L M T 0F 1F 2F 3F 4F 5F 15 12.0 4 19 15.0 4 22 18.5 4 24 20.5 4 31 27.5 4 40 36.5 4 1.8 1.0 11 2.0 1.1 14 2.2 1.2 17 2.2 1.2 19 2.2 1.2 25 2.2 1.2 34 For EGl sockets with a particular thread dimension, use B series insulating washers (see below). Part number L øB M E maxi øA T GRA.0S.269.Gl GRA.1S.269.Gl GRA.2S.269.Gl GRA.3S.269.Gl Dimensions (mm) Series A B E L M T 0F 1F 2F 3F 12.0 10.8 6.0 16.0 13.8 6.5 21.1 17.9 7.3 25.0 21.8 10.3 1.8 1.8 2.3 2.2 1.0 9.9 1.0 12.2 1.3 16.2 1.2 20.2 Note: the last position “l” of the part number indicates the colour. To obtain the required colour, refer to the above table and change position “l” of the part number to the corresponding letter. Ref. A J Colour blue yellow Keying N or W P Ref. R V Colour red green Keying S or X T l Material: Polyamide www.lemo.com ­29 ® ® Tooling DCG Spanners for hexagonal nuts N L Part number øB DCG.91.149.0TN DCG.91.161.1TN DCG.91.201.4TN DCG.91.231.7TN DCG.91.282.2TN Dimensions (mm) B L N 14 16 20 23 28 40 45 52 62 76 50 52 65 68 73 Part number of the nut GEA.00.240.LN GEA.0S.240.LN GEA.1S.240.LN GEA.2S.240.LN GEA.3S.240.LN ● Material: blackened steel øA DCH Spanners for notched nut øB L Part number DCH.91.101.PA Dimensions (mm) A B L N 10.1 12.8 124 Part number of the nut 48.3 GEG.00.240.RN ● Material: Blue polyurethane N DTA Taps Part number DTA.99.700.5Z DTA.99.900.6Z Series 00 0S-0B Thread M7 x 0.5 M9 x 0.6 DPC Manual crimping tool Part number DPC.91.701.V According to specification MIL-C-22520/7-01. For LEMO contacts ø 0.5-0.7-0.9-1.3 mm Pneumatic crimping tools Supplier LEMO BALMAR BUCHANAN Part number DPC.91.701.C 85230 621101 According to specification MIL-C-22520/7-01. For LEMO contacts ø 0.5-0.7-0.9-1.3 mm 30 www.lemo.com ® DCE Positioners for crimp contacts ø 0.5-0.7-0.9 and 1.3 mm male ® DCF Extractor for crimp contact ø 0.5-0.7-0.9 and 1.3 mm female These positioners are suitable for use with both manual and pneumatic crimping tools according to the MIL-C-22520/7-01 standard. FF 303 304 0F 302 303 Fig. øC Type øA Connector + Contact Conductor AWG 0.5 0.42 1 28-30-32 0.9 0.9 0.9 0.7 0.7 1.10 0.80 0.45 0.80 0.45 1 2 2 1 2 20-22-24 22-24-26 28-30-32 22-24-26 28-30-32 1.3 0.9 305 0.9 0.9 0.7 307/308 0.7 1.40 1.10 0.80 0.45 0.80 0.45 1 1 2 2 1 2 304 1.40 1.10 0.80 0.45 0.80 0.45 Positioners part number For male contacts into plug For female contacts into socket For male contacts into socket For female contacts into plug Extractors part number DCE.91.050.0VC DCE.91.050.0VM DCE.91.050.0VC DCE.91.050.0VM DCF.91.050.2LT DCE.91.090.BVC DCE.91.090.BVM DCE.91.090.BVC DCE.91.090.BVM DCF.93.090.4LT DCE.91.090.AVC DCE.91.090.AVM DCE.91.090.AVC DCE.91.090.AVM DCF.93.090.4LT DCE.91.070.BVC DCE.91.070.BVM DCE.91.070.BVC DCE.91.070.BVM DCF.93.070.4LT 18-20 20-22-24 22-24-26 28-30-32 22-24-26 28-30-32 DCE.91.131.FVC DCE.91.131.FVM DCE.91.131.FVC DCE.91.131.FVM DCF.93.131.4LT DCE.91.090.BVC DCE.91.090.BVM DCE.91.090.BVC DCE.91.090.BVM DCF.93.090.4LT DCE.91.090.AVC DCE.91.090.AVM DCE.91.090.AVC DCE.91.090.AVM DCF.93.090.4LT DCE.91.070.BVC DCE.91.070.BVM DCE.91.070.BVC DCE.91.070.BVM DCF.93.070.4LT 1 1 2 2 1 2 18-20 20-22-24 22-24-26 28-30-32 22-24-26 28-30-32 DCE.91.131.FVC DCE.91.131.FVM DCE.91.131.FVC DCE.91.131.FVM DCF.93.131.4LT DCE.91.090.BVC DCE.91.090.BVM DCE.91.090.BVC DCE.91.090.BVM DCF.93.090.4LT DCE.91.090.AVC DCE.91.090.AVM DCE.91.090.AVC DCE.91.090.AVM DCF.93.090.4LT 312 319 1.3 0.9 0.9 0.9 0.7 0.7 DCE.91.070.BVC DCE.91.070.BVM DCE.91.070.BVC DCE.91.070.BVM DCF.93.070.4LT 3F 322 330 0.7 0.80 1 0.7 0.45 2 22-24-26 28-30-32 DCE.91.070.BVC DCE.91.070.BVM DCE.91.070.BVC DCE.91.071.FVM DCF.93.070.4LT 4F 340 0.7 0.80 1 0.7 0.45 2 22-24-26 28-30-32 DCE.91.072.BVC DCE.91.070.BVM DCE.91.070.BVC DCE.91.072.BVM DCF.93.070.4LT LF 368 0.7 0.80 1 0.7 0.45 2 22-24-26 28-30-32 DCE.91.073.BVC DCE.91.072.BVM DCE.91.070.BVC DCE.91.073.BVM DCF.93.070.4LT 5F 350/354 0.9 1.10 1 355/364 0.9 0.80 2 366 20-22-24 22-24-26 DCE.91.093.BVC DCE.91.093.BVM DCE.91.093.BVC DCE.91.093.BVM DCF.91.093.5LT 304 305 1F 2F 303 308 310 Note: see table on page 20 for connector selection and the table on page 24 for contact selection. A wide variation of strand number and diameter combinations are quoted as being AWG, some of which do not have a large enough cross section to guarantee a crimp as per either MIL-C-22520/1-01 or /7-01. Our technical department is at your disposal to study and propose a solution to all your applications. Fig. 1 www.lemo.com øA øC øA øC Fig. 2 øA øC øA øC 31 ® ® Banding tool Part number GLEN-AIR® TIE-DEX® Banding tool Tie wrap AXON® 600-061 A30199 ACDBS100 600-057 A31189 AXCL0Z Note: the banding tool is to be used with screened cables to ensure a good ground contact. DRV Complete workstation for F7 fibre optic contact Description Comprehensive range of tools for terminating both singlemode and multi-mode fibres. Includes specific tools for F7 fibre optic contacts. Detachable termination case lid for use as polishing platform during field termination. Rugged but aesthetically pleasing termination case which is ideal for field use or in-house terminations. Curing oven and inspection microscope should be ordered separately. Part number DRV.91.CF7.PN Note: See details in F7 catalogue. DPE Crimping tool for F7 fibre optic contact Description Crimping tool for capturing KEVLAR® strand on contact body. 2.7 3.1 Part number DPE.99.003.1K 1) Note: 1) Included in the LEMO F7 workstation. WST Epoxy curing oven Description Oven for assisting in curing epoxy. Part number WST.FR.220.VA WST.FR.110.VA Voltage 220 volts 110 volts DCS Polishing tool for fibre optic contacts Description Precision tool for polishing terminated fibre optic contacts with 1.25 mm ferrule. Part number DCS.91.D01.LC 1) ­32 Note: 1) Included in the LEMO F7 workstation. www.lemo.com ® ® WST Fibre Inspection Microscope Description Microscope to assist in viewing termination operations and verifying fibre end finish. Zoom with 200 ➞ 400 x magnification. See adaptor on page 33. Part number WST.FB.G00.301 DCS Microscope adaptor for fibre optic contacts Description Adaptor for final inspection of fibre optic contacts with 1.25 mm ferrule. To be used with microscope WST.FB.G00.301. Part number DCS.91.G90.6E125 1) Note: 1) Included in the LEMO F7 workstation. DCS F7 contact alignment device tool Description Simple tool with two threaded end for installation/extraction of the F7 contact alignment device. Part number DCS.F7.035.PN 1) Note: 1) Included in the LEMO F7 workstation. Panel Cut-out Panel cut-outs Models EG●-EE●-EH●-PE●-HE● ED●-PB● EC● L + 0.1 0 L H øA + 0.1 0 + 0.1 0 +0.1 0 øA B EC● + 0.1 0 L øA øB + 0.1 0 Mounting nut torque Series Torque (Nm) Series Torque (Nm) FF 0F 1F 2F 0.25 1.00 1.50 2.00 3F 4F LF 5F 2.50 5.00 6.00 8.00 www.lemo.com Series – EE● EE● EE● EE● – – – A Dimensions (mm) B L H FF 7.1 – 11.5 – FF 0F 1F 2F 3F 4F LF 5F 7.1 10.1 13.1 16.1 18.2 24.2 27.2 33.2 6.5 9.1 11.6 14.6 16.6 22.2 25.1 31.2 11.5 16.0 20.0 23.0 25.0 32.0 35.0 41.0 – – – – – – – EG● EG● EG● EG● 0F 1F 2F 3F 9.1 12.1 15.1 18.1 8.3 10.6 13.6 16.6 13.5 17.0 21.5 27.0 – – – – ED● 1F 6.2 3.5 15.0 19.3 PB● PB● PB● PB● PB● PB● 0F 1F 2F 3F 4F 5F 11.1 13.1 16.1 17.6 23.2 32.3 3.2 3.2 3.2 3.2 3.2 3.2 16.0 16.0 19.0 21.0 27.0 34.0 21.4 21.4 25.9 29.0 32.0 38.2 EH● EH● EH● EH● EH● EH● EH● EH● HE● HE● HE● HE● HE● HE● HE● HE● PE● PE● PE● PE● PE● PE● PE● PE● – 33 ® ® PCB drilling pattern Fixed socket with straight print contact +0.1 0 +0.1 0 90° 90° 4xø1 +0.1 0 19 x ø 0.6 26' 51° +0.1 0 4xø1 +0.1 0 8.89 ø 3.5 15° +0.1 0 +0.1 0 4xø1 +0.1 0 2.2 11.43 ø 5.7 18° 22° 4xø1 27°41 ' 9° ' 11.43 ø 8.8 ø5 7.62 ° 60 ° 30 15.24 11°15' 30 +0.1 0 4F.340 36° 43 ' +0.1 0 ø 6.7 90° ø 6.3 12 x ø 0.6 +0.1 0 25° ø 3.8 ø 3.7 8 x ø 0.6 ø 11.64 ° 45 +0.1 0 22°30' 4 x ø 1 ° +0.1 0 +0.1 0 2F.319 45° +0.1 0 45 3F.330 22°30' 4xø1 ° 7 x ø 0.6 ø 2.19 45 10 x ø 0.6 12°52' 4xø1 ' °26 51 ø 7.94 22°30' 4 x ø 1 +0.1 0 3F.322 60 +0.1 0 2F.312 +0.1 0 8.89 ø 6.4 8 x ø 0.6 30° +0.1 0 ø 4.24 5 x ø 0.6 ° ° 45 1F.308 4xø1 7.62 +0.1 0 2F.310 4xø1 +0.1 0 7.62 ø3 ° 72 8.89 2F.308 1F.307 4xø1 +0.1 0 4 x ø 0.6 8.89 3 x ø 0.6 +0.1 0 ø 6.5 +0.1 0 +0.1 0 ø9 5 x ø 0.6 12 0° 7 4xø1 5.08 ø 2.8 2° +0.1 0 3 x ø 0.6 1F.305 1F.303 4xø1 7.62 0F.305 +0.1 0 ø 2.8 4 x ø 0.6 ø 3.4 +0.1 0 5.08 ø 1.35 3 x ø 0.6 +0.1 0 4xø1 45° ø 2.5 2 x ø 0.6 0F.304 4xø1 ø 2.3 +0.1 0 5.08 0F.303 4xø1 12 0° 12 0° ø 1.6 45° +0.1 0 ø 2.2 4xø1 5.08 0F.302 +0.1 0 5.08 FF.304 4xø1 5.08 FF.303 22 x ø 0.6 LF.368 2.6 40 x ø 0.6 +0.1 0 5F.355 9° 7°50’ 13°51’ +0.1 0 ° 90 7°30’ 20.32 ø19.4 ø14.2 ø 3.8 ø9 ø 8.36 20.32 36° ø 3.1 40° ø19.2 ° 15 16.51 ø8 15° ° 24 ø15.5 ø 4.25 27° 41 ’30 ’’ °4 +0.1 0 120 4xø1 50 x ø 0.8 68 x ø 0.8 4xø1 0’ ø13.73 ° 51°25’30’’ 55 x ø 0.8 +0.1 0 +0.1 0 21°11' +0.1 0 5F.366 ' °26 51 ' 1 °5 13 4xø1 +0.1 0 20.32 ø 5.6 18° 20.32 ø19.84 ø14.96 ø 10.08 6°55'30'' ø19.84 4xø1 '30 27°41 '' '' '30 27°41 64 x ø 0.8 6°55'30'' ø 5.05 18° 57 ' ' °51 13 ø 10.08 6 +0.1 0 57 ' 0° ø14.96 5F.364 34 +0.1 0 5F.350 6°40’ 0’ 3°2 18 30 x ø 0.6 ø11.75 1 +0.1 0 +0.1 0 66 x ø 0.8 +0.1 0 www.lemo.com ® ® Fixed socket with elbow print contact A 0F.303 0F.304 2 3 7 1 3 2.54 2.54 1.27 1.27 10 1 4 4 2 3 ø 0.7 6 5 9 1.27 2.54 2 5 7 8 1 8 2 3 2.54 2.54 2F.319 8 7 6 12 11 1 9 10 2 3 9 10 5 11 12 8 4 17 18 19 13 1 2.54 2.54 2.54 7 16 14 15 3 4 2 2.54 2.54 2.54 www.lemo.com 6 4 2.54 2.54 2F.312 7 5 2 2.54 2.54 6 ø 0.9 1 3 2 2F.310 7 4 0.92 1.27 1.27 6 ø 0.7 1 1 8 2.54 2.54 5 4 2 3 1F.308 5 3 2 ø 0.7 1F.307 ø 0.9 2F.308 2 4 2.54 1F.305 2.54 1 5 1 1.27 1F.303 2.54 3 ø 0.7 1.27 2.54 4 1.27 1 2 2.54 2.54 2.54 1 2.54 3 ø 0.7 ø 0.7 ø 0.7 ø 0.7 0F.305 ø 0.7 1.27 0F.302 ø 0.7 A 6 5 1.27 35 ® 36 ® www.lemo.com ® ® Technical characteristics Outer shell Mechanical latching characteristics Latch sleeve in special bronze/brass Force (N) Fv Fv Fd Fa 0F 1F 2F Series 3F 4F LF 5F 10 11 20 18 23 40 50 11 13 29 20 25 40 55 160 120 170 210 180 250 400 Latch sleeve in Beryllium copper Fd Force (N) Series FF 0F 1F 2F 3F Fv Fd Fa 16 22 21 29 34 20 21 23 33 17 110 300 250 420 400 Notes: forces were measured on outer shells not fitted with contacts. 1N = 0.102 kg. 1N = 0.2248 pounds force Fa Fv: average latching force. Fd: average unmating force with axial pull on the outer shell. Fa: average pull-out force with axial pull on the back shell. Insulator Plastic material used by LEMO for manufacturing insulators is selected according to the electric and thermal properties required for the various connector types. Characteristics examined for the two connector types are: – Dielectric strength – Comparative tracking index – Surface and volume resistivity – Continuous service temperature – Water absorption – Radiation resistance – Flammability rating – Resistance to hydrocarbon. PEEK is selected as it provides all the required characteristics for multipole connectors. Radiation resistance PEEK 103 rads Gray (Gy) 101 Damage Mechanical and electrical properties Mechanical characteristics of thermoplastics, such as PEEK, are improved by the addition of glass fibres. By adding glass fibres in the resin the performance of this material (mechanical strength and radiation resistance) is enhanced and water absorption rate is reduced. From an electric point of view, the addition of glass fibres improves dielectric strength. www.lemo.com 104 102 105 103 106 104 107 105 108 109 1010 106 107 108 Radiation dose γ Minimum to slight (almost available usable) Slight to medium (often satisfactory) Medium to serious (not usable) Note: technical data in this chapter provide general information on plastics used by LEMO as electrical insulators. LEMO reserves the right to propose new materials with better technical characteristics, and to withdraw, without notice, any material mentioned in the present catalogue or any other publications edited by LEMO S.A. and/or its subsidiaries. LEMO SA and its subsidiaries use only plastic granules, powder or bars supplied by specialized companies, and thus cannot in any case take responsibility with regard to this material. 37 ® ® Technical characteristics of plastic materials Type Density Tensile strength (at 23°C) Flexurale strength (at 23°C) Dielectric strength Volume resistivity at 50% HR and 23°C Surface resistivity Thermal conductivity Comparative tracking index Dielectric constant (106 Hz) Dissipation factor (106 Hz) Maximum continuous service temperature Minimum continuous service temperature Maximum short-time service temperature Water absorption in 24h at 23°C Radiation resistance Flammability rating Notes: 1) Norme Units ASTM D 792 ASTM D 638/ ISO R527 ASTM D 790/ ISO R178 ASTM D 149/IEC 60243 ASTM D 257/IEC 60093 ASTM D 257 ASTM C 177 IEC 60112 ASTM D 150/IEC 60250 ASTM D 150/IEC 60250 UL 746 UL 746 – ASTM D 570/ISO R62A – ASTM D 635/UL 94 – MPa MPA kV/mm Ω l cm Ω W/K l m V – – °C °C °C % Gy1) – PEEK 1.3-1.4 92-142 170 19-25 1016 1015 0.25 CTI 150 3.2-3.5 < 0.005 250 -50 300 < 0.3 107 V-0/1.5 Silicone FPM/FKM Epoxy ~­1.2 ~1.9 1.58 > 9 > 12 16 – – 24 18-30 – 15 1014 – 1014 ­– – – – – 0.8 – – CTI>600 – – – – – – 200 200 80 -50 -20 -20 > 250 300 120 – – 0.25 105 8x104 2x106 – – V-0/4 1 Gy (Gray) = 100 rad ASTM = American Society for Testing Material ISO = International Standards Organisation UL = Underwriters Laboratories IEC = International Electrotechnical Commission Electrical contact Technical description The secure reliable electromechanical connection achieved with LEMO female cylindrical contacts is mainly due to two important design features: 1. Prod proof entry on the mating side which ensures perfect concentric mating even with carelessly handled connectors. 2. The pressure spring, with good elasticity, maintains a constant even force on the male contact when mated. The leading edge of the pressure spring preserves the surface treatment (gold-plated) and prevents undue wear. Contact material and treatment LEMO female contacts are made of bronze beryllium (QQ-C-530) or bronze (UNS C 54400). These materials are chosen because of their high modulus of elasticity, their excellent electrical conductivity and a high mechanical strength. LEMO male print contacts are made of brass (UNS C 38500). Male crimp contacts are made of brass (UNS C 34500) or annealed brass (UNS C 38500) with optimum hardness (HV) for crimping onto the wire. Au Ni Cu Bronze or brass ­38 Type Material (standard) Surf. treatment (µm) Cu Ni Au1) Male print Brass (UNS C 34500) Brass (UNS C 38500) 0.5 Brass (UNS C 38500) Female crimp Female print Bronze (UNS C 54400) Cu-Be (FS QQ-C-530) 0.5 3 1.5 Clips Cu-Be (FS QQ-C-530) Stainless steel – – – Wire2) Brass – 33) – Male crimp 3 1.0 Notes: the standard surface treatment are as follows: – nickel: SAE AMS QQ N 290 or MIL DTL 32119 – gold: ISO 27874. 1) minimum value 2) for elbow print contacts 3) treatment completed by 6 µm Sn-Pb tin-plating www.lemo.com ® ® Thickness comparison between the outside and the inside of female contacts P 2.5 P 2.5 Contact øA (mm) 0.5 0.7 0.9 1.3 Gold thickness female male outside inside (µm) (µm) (%) 1.0 1.5 65 1.0 1.5 70 1.0 1.5 75 1.0 1.5 75 Note: P = inspection point Crimp contacts Advantages of crimping The square form crimp method is used (MIL-C-22520F, class I, type 2) photo 1 for unipole contacts. – practical, quick contact fixing outside the insulator – possible use at high temperature – no risk of heating the insulator during the conductor-contact fixing – high tensile strength For multipole contacts the standard four identer crimp method is used, (MIL-C-22520F, class I, type 1), photo 2. The crimp method requires a controlled compression to obtain a symmetrical deformation of the conductor strand and of the contact material. The radial hole in the side of the contact makes it possible to check whether the conductor is correctly positioned within the contact. A good crimping is characterized by only slightly reduced conductor section and practically no gap. For optimum crimping of bronze or brass contacts they are annealed to relieve internal stress and reduce material hardening during the crimping process. Only the crimping zone is annealed with the help of an induction heating machine designed by the LEMO Research and Development Department (see photo 3). Crimp contacts are available in standard version (form 1) for mounting maximum size conductors. For some dimensions, these crimp contacts can be produced with reduced crimp barrels (form 2) for mounting reduced size conductors. 1 2 3 Test voltage Test voltage (Ue): (measured according to the IEC 60512-2 test 4a standard) It corresponds to 75% of the mean breakdown voltage. Test voltage is applied at 500 V/s and the test duration is 1 minute. This test has been carried out with a mated plug and socket, with power supply only on the plug end. The operating voltage value definition is at the entire responsibility of the customer who defines this value according to the safety factors that they apply to their equipment and system. Caution: For a number of applications, safety requirements for electrical appliances are more severe with regard to operating voltage. In such cases operating voltage is defined according to creepage distance and air clearance) between live parts. Please consult us for the choice of a connector by indicating the safety standard to be met by the product. www.lemo.com Voltage values are given in the table on insulator types for each series. They correspond with values measured at sea level. They are adapted to all applications up to an altitude of 2000 m. In case a device is used at a higher altitude, air clearance between live parts has to be multiplied by the following coefficients. It means also that test voltage has to be divided by this coefficient altitude (m) coefficient 2000 3000 4000 5000 1.00 1.14 1.29 1.48 ­39 ® ® Rated current The current values are indicated in the table of insulator types in each series. For use at higher temperatures acceptable rated current will be lower. It tends towards zero as the material is used at the maximum operating temperature accepted for the insulator. Rated current (A) 100% 75% 50% In most case the current depend on the conductor dimension (see table on page 43) or on the printed circuit dimension. Caution: In general, connectors should not be unmated while live. 40 for the insulator The specified rated current can be applied simultaneously to all the contacts. It corresponds with an average temperature rise of 40°C of the connector. For connectors with PEEK insulator, maximum admissible current will follow the curve below depending on the operating temperature T. Maximum operating temperature (measured according to IEC 60512-3 test 5a) 25% T (°C) 0 50 100 150 200 250 www.lemo.com ® ® Assembly instructions Assembly instructions for plugs and sockets 3 2 1 2 1 FGN 3 PHN 3 PEN 1. L ± 0.5 T First place the heatshrink boot ➀ over the cable. Strip the cable according to dimensions of the table, then widen the shield. 1 ± 0.2 Cable preparation Series L S T FF 0F-5F 14 20 9 15 3 4 S ± 0.5 2. 2 Crimp 2 Crimp Cable termination 2.1 With shielded cables, widen and pull the shield all the way to the back. Fix the appropriate positioner onto the crimping tool and set the selector to the number corresponding to the AWG of the conductor used as indicated on the positioner label. Fit the conductor into the contact ➁; make sure it is visible through the contact’s inspection hole. Slide the conductor-contact assembly into the open crimping tool; make sure that the contact is pushed fully into the positioner. Close the tool. Remove from crimping tool and check that conductor is secure in contact and shows in inspection hole. 2.2 Arrange the conductor-contact assemblies according to the markings, into the rear cable seal. Push them deeply into the insulator, using tweezers if necessary; check that all the contacts are correctly located in the insulator: 1) by verifying the alignment of the contacts at the front of the insulator and 2) by gently pulling on each conductor. Verification should also be made using the appropriate retention testing tool. With FF series the rear cable seal can be replaced with a silicone RTV compound that is filled on the rear of the connector once the contacts are correctly installed. 3 3 2.3 Bring the shield around the rear of connector. Secure it with a band-it tie-wrap (not furnished) to fix the shield in place. Cut off the possible shield surplus. Tie wrap Tie wrap 2.4 Put the heatshrink boot in place and heat gently until it retracts. Heat www.lemo.com Heat 41 ® ® Technical tables Table of American Wire Gauge Construction AWG 4 6 8 8 10 10 10 12 12 12 12 1) 12 14 14 14 1) 14 16 1) 16 16 16 1) 16 18 1) 18 1) 18 18 18 18 20 1) 20 20 20 20 22 22 22 24 1) 24 24 24 26 26 26 28 1) 28 28 30 30 32 32 34 36 38 40 Note: 42 1) Strand nb AWG/ strand 133 133 168 133 105 37 1 65 37 19 7 1 41 19 7 1 65 26 19 7 1 65 42 19 16 7 1 42 19 10 7 1 19 7 1 42 19 7 1 19 7 1 19 7 1 7 1 7 1 1 1 1 1 25 27 30 29 30 26 10 30 28 25 20 12 30 27 22 14 34 30 29 24 16 36 34 30 30 26 18 36 32 30 28 20 34 30 22 40 36 32 24 38 34 26 40 36 28 38 30 40 32 34 36 38 40 Table of wire gauges according to IEC-228 standard ø wire max (mm) 6.9596 5.5118 4.4450 4.3942 3.3020 2.9210 2.6162 2.5146 2.3114 2.3622 2.5400 2.0828 2.0574 1.8542 2.0828 1.6510 1.5748 1.5748 1.4986 1.5494 1.3208 1.2700 1.2700 1.3208 1.2954 1.2700 1.0414 1.0160 1.0414 1.0160 0.9906 0.8382 0.8382 0.7874 0.6604 0.6604 0.6858 0.6350 0.5588 0.5588 0.5080 0.4318 0.4318 0.4064 0.3302 0.3302 0.2794 0.2794 0.2286 0.1693 0.127 0.1016 0.078 Wire section (in) (mm2) (sq in) 0.274 0.217 0.175 0.173 0.13 0.115 0.103 0.099 0.091 0.093 0.1 0.082 0.081 0.073 0.082 0.065 0.062 0.062 0.059 0.061 0.052 0.05 0.05 0.052 0.051 0.05 0.041 0.04 0.041 0.04 0.039 0.033 0.033 0.031 0.026 0.026 0.027 0.025 0.022 0.022 0.02 0.017 0.017 0.016 0.013 0.013 0.011 0.011 0.009 0.007 0.005 0.004 0.003 21.5925 13.5885 8.5127 8.6053 5.3204 4.7397 5.2614 3.2936 2.9765 3.0847 3.6321 3.3081 2.0775 1.9413 2.2704 2.0820 1.3072 1.3174 1.2293 1.4330 1.3076 0.8234 0.8447 0.9627 0.8107 0.8967 0.8229 0.5320 0.6162 0.5067 0.5631 0.5189 0.3821 0.3547 0.3243 0.2045 0.2407 0.2270 0.2047 0.1540 0.1408 0.1281 0.0925 0.0887 0.0804 0.0568 0.0507 0.0341 0.0324 0.0201 0.0127 0.0081 0.0049 0.0335 0.0211 0.0132 0.0133 0.0082 0.0073 0.0082 0.0051 0.0046 0.0048 0.0056 0.0051 0.0032 0.0030 0.0035 0.0032 0.0020 0.0020 0.0019 0.0022 0.0020 0.0013 0.0013 0.0015 0.0013 0.0014 0.0013 8.2x10-4 0.0010 7.9x10-4 8.7x10-4 8.0x10-4 5.9x10-4 5.5x10-4 5.0x10-4 3.2x10-4 3.7x10-4 3.5x10-4 3.2x10-4 2.4x10-4 2.2x10-4 2.0x10-4 1.4x10-4 1.4x10-4 1.2x10-4 8.8x10-5 7.9x10-5 5.3x10-5 5.0x10-5 3.1x10-5 2.0x10-5 1.3x10-5 7.5x10-6 Conductor no x Ø (mm) 196x0.40 7x2.14 125x0.40 7x1.72 1x4.50 80x0.40 7x1.38 1x3.60 84x0.30 7x1.50 1x2.76 56x0.30 7x0.86 1x2.25 50x0.25 7x0.68 1x1.78 30x0.25 7x0.52 1x1.4 32x0.20 7x0.43 1x1.15 42x0.15 28x0.20 1x1.0 28x0.15 16x0.20 1x0.80 7x0.25 1x0.60 14x0.15 7x0.20 18x0.10 14x0.10 21x0.07 14x0.10 Max Ø (mm) 7.50 6.10 6.00 4.90 4.50 4.70 3.95 3.60 3.70 3.15 2.76 2.80 2.58 2.25 2.15 2.04 1.78 1.60 1.56 1.40 1.35 1.29 1.15 1.20 1.15 1.00 0.95 0.90 0.80 0.75 0.60 0.75 0.65 0.50 0.40 0.40 0.40 Max Ø (in) Section (mm2) Section (sq in) 0.295 0.240 0.236 0.192 0.177 0.155 0.155 0.141 0.145 0.124 0.108 0.110 0.098 0.082 0.084 0.080 0.070 0.062 0.061 0.055 0.053 0.050 0.045 0.047 0.045 0.039 0.037 0.035 0.031 0.029 0.023 0.029 0.023 0.019 0.015 0.015 0.015 25.00 25.00 16.00 16.00 16.00 10.00 10.00 10.00 6.00 6.00 6.00 4.00 4.00 4.00 2.50 2.50 2.50 1.50 1.50 1.50 1.00 1.00 1.00 0.75 0.75 0.75 0.50 0.50 0.50 0.34 0.28 0.25 0.22 0.14 0.11 0.09 0.09 0.0387 0.0387 0.0248 0.0248 0.0248 0.0155 0.0155 0.0155 0.0093 0.0093 0.0093 0.0062 0.0062 0.0062 0.0038 0.0038 0.0038 0.0023 0.0023 0.0023 0.0015 0.0015 0.0015 0.0011 0.0011 0.0011 7.7x10-4 7.7x10-4 7.7x10-4 5.2x10-4 4.3x10-4 3.8x10-4 3.4x10-4 2.1x10-4 1.7x10-4 1.3x10-4 1.3x10-4 not included in the standard www.lemo.com ® ® Maximum current rating for conductor Maximum current on insulated conductors up to an ambiant temperature of 30° C (from VDE 0100, parts 430 and 532 as well as other VDE regulations). Nominal section mm2 Group 2 Intens. max. A Group 3 Intens. max. A 0.08 0.14 0.25 0.34 0.50 0.75 1.00 1.50 2.50 1.0 2.0 4.0 6.0 9.0 12.0 15.0 18.0 26.0 1.5 3.0 5.0 8.0 12.0 15.0 19.0 24.0 32.0 Group 2 Multi-conductor, e. g. solid cable under sheath, shielded cable, lead-sheath cables, … Group 3 Single conductor and single conductor cable laid on open air in a way to leave at least a space between them equal to their diameter Conversion of some units: millimeters into inches: 1 mm = 0.0394 in inches into millimeters: 1 in = 25.4 mm centimeters into feet: 1 cm = 0.0328 ft feet (12 in) into centimeters: 1 ft = 30.48 cm square centimeters into square inches: 1 cm2 = 0.155 sq in square inches into square centimeters: 1 sq in = 6.4516 cm2 bar into pounds per square inch: 1 bar = 14.51 psi bar into Pascal: 1 bar = 105 Pa °C into °F: °F = °C 1.8 + 32 ● newtonmeter (Nm) into inch pound (in lb) ● mbar l s-1 into Torr l s-1 ● ● www.lemo.com ● ● 1 Nm = 8.85 in lb ● 1 mbar l s-1 = 1.33 Torr l s-1 ● ● ● ● 43 ® ® Product safety notice PLEASE READ AND FOLLOW ALL INSTUCTIONS CAREFULLY AND CONSULT ALL RELEVENT NATIONAL AND INTERNATIONAL SAFETY REGULATIONS FOR YOUR APPLICATION. IMPROPER HANDLING, CABLE ASSEMBLY, OR WRONG USE OF CONNECTORS CAN RESULT IN HAZARDOUS SITUATIONS. 1. SHOCK AND FIRE HAZARD Incorrect wiring, the use of damaged components, presence of foreign objects (such as metal debris), and / or residue (such as cleaning fluids), can result in short circuits, overheating, and / or risk of electric shock. Mated components should never be disconnected while live as this may result in an exposed electric arc and local overheating, resulting in possible damage to components. 2. HANDLING Connectors and their components should be visually inspected for damage prior to installation and assembly. Suspect components should be rejected or returned to the factory for verification. Connector assembly and installation should only be carried out by properly trained personnel. Proper tools must be used during installation and / or assembly in order to obtain safe and reliable performance. 3. USE Connectors with exposed contacts should never be live (or on the current supply side of a circuit). Under general conditions voltages above 30 VAC and 42 VDC are considered hazardous and proper measures should be taken to eliminate all risk of transmission of such voltages to any exposed metal part of the connector. 4. TEST AND OPERATING VOLTAGES The maximum admissible operating voltage depends upon the national or international standards in force for the application in question. Air and creepage distances impact the operating voltage; reference values are indicated in the catalog however these may be influenced by PC board design and / or wiring harnesses. The test voltage indicated in the catalog is 75% of the mean breakdown voltage; the test is applied at 500 V/s and the test duration is 1 minute. 5. CE MARKING CE marking means that the appliance or equipment bearing it complies with the protection requirements of one or several European safety directives. CE marking applies to complete products or equipment, but not to electromechanical components, such as connectors. 6. PRODUCT IMPROVEMENTS The LEMO Group reserves the right to modify and improve to our products or specifications without providing prior notification. 7. WARNING (Prop 65 State of California) Proposition 65 requires businesses to provide warnings to Californians about significant exposures to chemicals that cause cancer, birth defects or other reproductive harm. LEMO products are exempt from proposition 65 warnings because they are manufactured, marketed, and sold solely for commercial and industrial use. For further information, please visit https://www.lemo.com/quality/LEMO-Prop-65-compliance-declaration.pdf. Disclaimers LEMO works constantly to improve the quality of its products; the information and illustrations figuring in this document may therefore vary and are not binding. In any case, LEMO makes no specific warranty of merchantability, fitness for a particular purpose, third party components as such or included in assembly, non-infringement, title, accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO component. In no event shall LEMO, its affiliates, officers, agents or employees be liable for any incidental, indirect, special or consequential damages in connection with the products or services provided by LEMO, including (without limitation) loss of profits or revenues, interruption of business, loss of use of the products or any associated equipment, materials, components or products, damages to associated equipment or in combination with other components, materials. Reproduction of significant portions of LEMO information in LEMO data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. LEMO is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. ­44 www.lemo.com LEMO complete product range B S K E F 00 01 0A 3T 4A 4M 3K. 1D 93C Y 05 5G 2G 2C L H M R N 03 V W T7 P D K/S 01 DIN Unipole • Multipole Coaxial 50 Ω Coaxial 75 Ω Multi Coaxial Mixed Coax + LV Triaxial 50 Ω Triaxial 75 Ω Mixed Triax + LV Quadrax High Voltage Multi High Voltage Mixed HV + LV Fibre Optic Multi Fibre Optic • Mixed FO + LV • Thermocouple Fluidic Multi Fluidic Mixed Fluidic + LV Most frequently used in darker colour • included in this catalogue B Series Keyed S Series K Series Keyed E Series F Series Keyed 00 Series 01 Series 0A Series 3T Series 4A Series 4M Series Keyed 3K.93C Series Keyed 1D Series Y Series 05 Series 5G Series Keyed 2G Series Keyed 2C Series L Series Keyed H Series M Series Keyed R Series Keyed N Series Keyed 03 Series Keyed V Series W Series Keyed Cable assembly K/S Series Keyed REDEL T7 Series REDEL P Series Keyed REDEL D Series 01 Series Keyed VAA Series SAA Series TAA Series No reproduction or use without express permission of editorial or pictorial content, in any manner. LEMO SA reserves the right to modify and improve specifications, at all times, without any notification. LEMO HEADQUARTERS SWITZERLAND LEMO SA Chemin des Champs-Courbes 28 - P.O. Box 194 - CH-1024 Ecublens Tel. +41 21 695 16 00 - e-mail: info@lemo.com SUBSIDIARIES AUSTRIA LEMO Elektronik GesmbH Lemböckgasse 49/E6-3 1230 Wien Tel: +43 1 914 23 20 0 Fax:+43 1 914 23 20 11 salesAT@lemo.com BRAZIL LEMO Latin America Ltda Av. Dr. Adhemar de Barros, 566 – Sala 1407, Vila Adyana CEP: 12245-011 São José dos Campos - SP - Brazil Tel: +55 11 94242 4293 info-la@lemo.com CANADA LEMO Canada Inc 44 East Beaver Creek Road, unit 20 Richmond Hill, Ontario L4B 1G8 Tel: +1 905 889 56 78 Fax: +1 905 889 49 70 info-canada@lemo.com CHINA / HONG KONG LEMO Electronics (Shanghai) Co., Ltd First Floor, Block E, 18 Jindian Road, Pudong Shanghai, China, 201206 Tel: +86 21 5899 7721 Fax: +86 21 5899 7727 cn.sales@lemo.com DENMARK LEMO Denmark A/S Mandal Allé 16A 5500 Middelfart Tel: +45 45 20 44 00 Fax: +45 45 20 44 01 info-dk@lemo.com FRANCE LEMO France Sàrl 24/28 Avenue Graham Bell Bâtiment Balthus 4 Bussy Saint Georges 77607 Marne la Vallée Cedex 3 Tel: +33 1 60 94 60 94 Fax: +33 1 60 94 60 90 info-fr@lemo.com GERMANY LEMO Elektronik GmbH Hanns-Schwindt-Str. 6 81829 München Tel: +49 89 42 77 03 Fax: +49 89 420 21 92 info@lemo.de HUNGARY REDEL Elektronika Kft Nagysándor József u. 6-12 1201 Budapest Tel: +36 1 421 47 10 Fax: +36 1 421 47 57 info-hu@lemo.com ITALY LEMO Italia srl Viale Lunigiana 25 20125 Milano Tel: +39 02 66 71 10 46 Fax: +39 02 37 90 80 46 sales.it@lemo.com JAPAN LEMO Japan Ltd 2-7-22, Mita, Minato-ku, Tokyo, 108-0073 Tel: +81 3 54 46 55 10 Fax: +81 3 54 46 55 11 info-jp@lemo.com LEMO NETHERLANDS / BELGIUM LEMO Connectors Nederland B.V. Jacques Meuwissenweg 6 2031 AD Haarlem Tel. +31 23 206 07 01 info-nl@lemo.com NORWAY / ICELAND LEMO Norway A/S Soerumsandvegen 69, 1920 Soerumsand Tel: +47 22 91 70 40 Fax: +47 22 91 70 41 info-no@lemo.com SINGAPORE LEMO Asia Pte Ltd 4 Leng Kee Road, #06-09 SiS Building Singapore 159088 Tel: +65 6476 0672 Fax: +65 6474 0672 sg.sales@lemo.com SPAIN / PORTUGAL IBERLEMO SAU Brasil, 45, 08402 Granollers Barcelona Tel: +34 93 860 44 20 Fax: +34 93 879 10 77 info-es@lemo.com SWEDEN / FINLAND LEMO Nordic AB Gunnebogatan 30, Box 8201 163 08 Spånga Tel: +46 8 635 60 60 Fax: +46 8 635 60 61 info-se@lemo.com SWITZERLAND LEMO Verkauf AG Grundstrasse 22 B, 6343 Rotkreuz Tel: +41 41 790 49 40 ch.sales@lemo.com TAIWAN TAOYUAN TAIWAN Tel: +886 967 132 824 speng@lemo.com UNITED ARAB EMIRATES LEMO Middle East Connectors LLC Concorde Tower 11th Floor, Office 1102, Dubai Media City, P.O. Box 449849 Dubai, United Arab Emirates Tel: +971 4 568 1904 info-me@lemo.com UNITED KINGDOM LEMO UK Ltd 12-20 North Street, Worthing, West Sussex, BN11 1DU Tel: +44 1903 23 45 43 lemouk@lemo.com USA LEMO USA Inc P.O. Box 2408 Rohnert Park, CA 94927-2408 Tel: +1 707 578 88 11 +1 800 444 53 66 Fax: +1 707 578 08 69 info-US@lemo.com DISTRIBUTORS ARGENTINA, AUSTRALIA, BRAZIL, CHILE, COLOMBIA, CZECH REPUBLIC, GREECE, INDIA, ISRAEL, NEW ZEALAND, PERU, POLAND, RUSSIA, SOUTH AFRICA, SOUTH KOREA, TURKEY, UKRAINE www.lemo.com CAT.MF.LEN.P1108, © LEMO / Data subject to change, printed in Switzerland, pdf updated June 2021 LEMO
EGN.2F.319.XLM 价格&库存
很抱歉,暂时无法提供与“EGN.2F.319.XLM”相匹配的价格&库存,您可以联系我们找货
