5000484
5000484
    GES(GES)
    VP-CL-3HV-BU AWG 14 AG
5000484 数据手册
MOD Series M Series MC Series MCS Series VP Series 100 Series S Series Series Operating voltages up to 13 kVDC  Operating current 13 Amps / 30 Amps  Ideal for internal cabling  Quick assembly  Several mounting options offering enhanced flexibility  General characteristics and technical data Series VarioPro CL Electrical values Operating voltage (DC) 13 kV Test voltage (DC) 20 kV Housing Number of HV contacts 1-3 Insulation material PBT Flammability class UL94 V-0 Operating temperature -40°C to +150°C Insulating material group I (DIN IEC 60664) VP Series Contacts 1.6 mm Termination method crimp Rated current 13 A Contact resistance ≤ 5 mΩ Contact diameter 1.6 mm [.063"] Wire size (AWG / cross section) AWG 26 - 14 (0.14 - 2.5 mm²) Contact material brass (CuZn) Contact plating silver (Ag), gold (Au) Mating cycles ≥ 1,000 Rated temperature +120°C Suitable cable dimensions max. Ø 4.0 mm [.157"] AWG 26 - 14 52 © GES Electronic & Service GmbH www.ges-electronic.de Series Type VarioPro CL Series 3-pole 13 kVDC VarioPro CL3 - receptacle VarioPro CL3 - plug Drawing Drawing (Cable not included) panel cut out feedthrough mounting VP Series max. cable OD holes for surface mounting max. cable OD drawing - dimensions in mm [inch] Plug male contact P/N Description 5000480 VP-CL-3HV-BU AWG 26 - 22 Ag Receptacle female contact Number of contacts Including contacts Contacts silver plated — 3 — — 5000481 VP-CL-3HV-BU AWG 20 Ag — 3 — — 5000482 VP-CL-3HV-BU AWG 20 - 16 Ag — 3 — — Contacts gold plated 5000483 VP-CL-3HV-BU AWG 16 - 15 Ag — 3 — — 5000484 VP-CL-3HV-BU AWG 14 Ag — 3 — — 5000485 VP-CL-3HV-BU AWG 26 - 22 Au — 3 — — 5000486 VP-CL-3HV-BU AWG 20 Au — 3 — — 5000487 VP-CL-3HV-BU AWG 20 - 16 Au — 3 — — 5000488 VP-CL-3HV-BU AWG 16 - 15 Au — 3 — — 5000489 VP-CL-3HV-BU AWG 14 Au — 3 — — 5000490 VP-CL-3HV-ST AWG 26 - 22 Ag — 3 — — 5000491 VP-CL-3HV-ST AWG 20 Ag — 3 — — 5000492 VP-CL-3HV-ST AWG 20 - 16 Ag — 3 — — 5000493 VP-CL-3HV-ST AWG 16 - 15 Ag — 3 — — — 5000494 VP-CL-3HV-ST AWG 14 Ag — 3 — 5000495 VP-CL-3HV-ST AWG 26 - 22 Au — 3 — — 5000496 VP-CL-3HV-ST AWG 20 Au — 3 — — 5000497 VP-CL-3HV-ST AWG 20 - 16 Au — 3 — — 5000498 VP-CL-3HV-ST AWG 16 - 15 Au — 3 — — 5000499 VP-CL-3HV-ST AWG 14 Au — 3 — — For cables and tools - please see page 69 © GES Electronic & Service GmbH www.ges-electronic.de 55 Assembly Instructions Series VP ClipLock - plug 5. 1. Part as supplied Shrinking tube (1), male contact (2), connector shell (3) VP Series 2. Slide contact (2) completely into connector shell (3) until contact snaps ... P  ull gently to check that contact is correctly located and remains in position 6. Place shrinking tube (1) on cable Slide shrinking tube (1) on connector shell (3) 3. 7. Remove dielectric insulation (L1 = 5-8 mm) 4. Shrink tube - shrinking temperature 110°C 8. Solder or crimp contact (2) on conductor ! P  lease notice for soldering: Tin-solder must not remain on contact surface ! 56 Series Note – important! Assembly finished 1. Please carefully read assembly instructions before cable assembly. © GES Electronic & Service GmbH 2. Cable assembly must only be done by trained and qualified personnel. www.ges-electronic.de Assembly Instructions Series VP ClipLock - receptacle Series 6. 1. Solder or crimp contact (2) on conductor ! P  lease notice for soldering: Tin-solder must not remain on contact surface Part as supplied Shrinking tube (1), female contact (2), connector shell (3) 7. Panel cut out – feedthrough mounting Type D1 mm [inch] L1 mm [inch] L2 mm [inch] L3 mm [inch] VP-CL-1HV-BU 2.10 [.083"] 18.70 [.736"] 11.20 [.441"] 15.80 [.622"] VP-CL-2HV-BU 3.10 [.122"] 33.00 [1.299"] 11.20 [.441"] 25.50 [1.004"] VP-CL-3HV-BU 3.10 [.122"] 42.00 [1.654"] 11.20 [.441"] 34.50 [1.358"] Slide contact (2) completely into connector shell (3) until contact snaps ... P  ull gently to check that contact is correctly located and remains in position VP Series 2. 8. 3. Panel cut out – surface mounting Type Slide shrinking tube (1) on connector shell (3) D2 mm [inch] L4 mm [inch] VP-CL-1HV-BU 2.80 [.110"] 8.50 [.335"] VP-CL-2HV-BU 2.80 [.110"] 17.50 [.689"] VP-CL-3HV-BU 2.80[.110"] 26.50 [1.043"] 9. 4. Shrink tubes - shrinking temperature 110°C Place shrinking tube (1) on cable 10. 5. Assembly finished Remove dielectric insulation (L5 = 5-8 mm [.197" - .315"]) ! Note – important! 1. Please carefully read assembly instructions before cable assembly. © GES Electronic & Service GmbH 2. Cable assembly must only be done by trained and qualified personnel. www.ges-electronic.de 57
5000484 价格&库存
很抱歉,暂时无法提供与“5000484”相匹配的价格&库存,您可以联系我们找货
