EEG.1K.314.CLN
EEG.1K.314.CLN
    LEMO(雷莫)
    CONN RCPT FMALE 14POS GOLD SLDR
EEG.1K.314.CLN 数据手册
EEG.1K.314.CLN www.lemo.com SUMMARY # Wires Low voltage 14 Image is for illustrative purpose only Series 1K Termination type Female print PCB IP rating 68 AWG wire size 34.00 - 28.00 PCB Altium Pattern Cable Ø 0.00 - 0.00 mm PCB KiCad Pattern Status active Catalog Matching parts FGG.1K.314.CLAC50 Download Request a quote PCB Eagle Pattern TECHNICAL DETAILS Mechanics Shell Style/Model EE*: Fixed receptacle, nut fixing, with straight contacts for printed circuit (back panel mounting) Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 19.43 g Performance Configuration 1K.314 : 14 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 2 Amps Specifications Contact Type: Print (straight) Contact Dia.: 0.5 mm (0.02in) R (max): 8.7 mOhm Vtest (contact-shell): 1200 V (AC), 1700 V (DC) Vtest (contact-contact): 800 V (AC), 1130 V (DC) Others LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Endurance (Shell): 5000 mating cycles Temp (min / max): -55°C / +200°C Humidity (max): 1000 hr DRAWINGS Dimensions A B E M N P S1 e mm. 20 20 6.2 3.5 23.8 10 14.5 M16x1.0 in. 0,79 0,79 0,24 0,14 0,94 0,39 0,57 RECOMMENDED BY LEMO Tools LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
EEG.1K.314.CLN 价格&库存
很抱歉,暂时无法提供与“EEG.1K.314.CLN”相匹配的价格&库存,您可以联系我们找货
