RZB92DHAS-S250
RZB92DHAS-S250
    SULLINS
    CONN PCI CARDEDGE FEMALE 184POS
RZB92DHAS-S250 数据手册
8 7 4 5 3 2 6 1 ITEM NO. QTY. DESCRIPTION 1 1 B92CD-A351 2 184 EZB-DHM 2.490 63.25 DRAW ING # REF 10127 256 1.657 42.09 .590 14.99 F F .500 12.70 2.400 60.96 1.550 39.37 .080 2.03 CARDSLOT E .070 1.78 .050 1.27 .150 3.81 .150 3.81 .370 9.40 5.040 128.02 .300[7.62] INSERTION DEPTH 1 B A .250 6.35 D E D .125 3.18 3x .100[2.54] A .100[2.54] B SECTION B-B 2 SECTION A-A 11 POSITION 49 POSITION 32 POSITION C .125 3.18 5.326 135.28 B A .010 NOTES: 1. THIS SPECIFICATION COVERS THE REQUIREMENT FOR A DUAL 92/184 ROW EDGECARD CONNECTOR 2. INSULATOR MATERIAL: POLYPHENYLENE SULFIDE. (BLACK) 3. CONTACT MATERIAL: PHOSPHOR BRONZE. 4. PLATING: .00001" GOLD ON CONTACT SURFACE .00001" TIN/LEAD ON TERMINAL .00005" NICKEL UNDERPLATE 5. TEMPERATURE: -65 C TO 125 C 6. UL FLAMMABILITY RATING: 94V-0 7. VOLTAGE RATING: 125 VDC MINIMUM AT SEA LEVEL. 8. CURRENT RATING: 1 AMP 9. VOLTAGE DROP: 30 MILLI VOLT AT RATED CURRENT COMPUTER 10. INSULATION RESISTANCE: 1000 MEGA OHM GENERATED DOCUMENT DO 11. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NOT CHANGE MANUALLY NUMBER AND DATE CODE. 12. BOARD THICKNESS ACCOMMMODATED: .062[1.57] PROPRIETARY AND CONFIDENTIAL 13. BOARD INSERTION FORCE: 6 OUNCE AVERAGE PER CONTACT PAIR USING .062[1.57] PCB THIS DRAWING AND DESIGN IS THE 14. BOARD WITHDRAWAL FORCE: 1 OUNCE MINIMUM PER CONTACT PAIR USING .062[1.57] PCB PROPERTY OF SULLINS ELECTRONICS. IT MAY NOT BE USED FOR ANY 15. TOLERANCE: .010" UNLESS OTHERWISE NOTED. PURPOSE OTHER THAN BY THE OWNER. SULLINS ELECTRONICS DOES NOT 16. MODIFICATION: MOLDED KEY BETWEEN POSITIONS 49 AND 52, 62 AND 65 AUTHORIZE THE REPRODUCTION OR CONVEYANCE OF ANY INFORMATION CONTAINED HEREIN. 8 1 1 7 6 5 C 4 B A REV. 120 ORIGINAL RELEASE ECO NO. DESCRIPTION UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES TOLERANCES: FRACTIONAL 1/32 ANGULAR: 1 TWO PLACE DECIMAL .02 THREE PLACE DECIMAL .005 FOUR PLACE DECIMAL .0005 DATE NAME DRAWN 01/09/04 ARIA CHECKED 01/09/04 AJT COMMENTS: USED ON APPLICATION 3 MATERIAL NOTED FINISH N/A AN AJT DATE BY APPV'D SULLINS ELECTRONICS A PART NO./DESCRIPTION: RZB92DHAS-S250 INTERPRET GEOMETRIC TOLERANCING PER: NEXT ASSY 01/09/04 SIZE DWG. NO. C REV 10126 SCALE: 2:1 DO NOT SCALE DRAWING 2 A SHEET 1 OF 1 1
RZB92DHAS-S250 价格&库存
很抱歉,暂时无法提供与“RZB92DHAS-S250”相匹配的价格&库存,您可以联系我们找货
