FGG.3P.306.PLWD75G
FGG.3P.306.PLWD75G
    LEMO(雷莫)
    CONN PLUG MALE 7P GOLD SLDR CUP
FGG.3P.306.PLWD75G 数据手册
FGG.3P.306.PLWD75G www.lemo.com SUMMARY # Wires Low voltage 7 Image is for illustrative purpose only Series 3P Termination type Male solder IP rating 61 AWG wire size 30.00 - 22.00 Cable Ø 6.70 - 7.50 mm Status active Matching parts EGG.3P.306.PLWG Download Request a quote Catalog TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug with key and cable seal Keying User configurable, 1 of 11 key positions. Plug: male contacts; Receptacle: female contacts Housing Material PSU (Polysulfone), gray Weight 19.24 g Performance Configuration 3P.306 : 6 Low Voltage + 1 Ground contact Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 6 Amps Specifications Contact Type: Special Others Endurance (Shell): >1000 mating cycles Temp (min / max): -50°C / +150°C F ret (min): 100 N F ret (max): 200 N Steam sterilization: 20 times (with potting on rear connection) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/2 DRAWINGS Dimensions A L mm. 21.2 63 in. 0,83 2,48 RECOMMENDED BY LEMO Tools Crimp settings: AWG/Selector = 20-22-24/6-5-5 Replacement contact: EGG.3P.661.ZZY LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/2
FGG.3P.306.PLWD75G 价格&库存
很抱歉,暂时无法提供与“FGG.3P.306.PLWD75G”相匹配的价格&库存,您可以联系我们找货
