Additional Resources:
Product Page
3D Model
PCB Footprint
date
02/19/2020
page
1 of 3
SERIES: SD-BV │ DESCRIPTION: STANDARD DIN CONNECTOR
FEATURES
• PCB mount
• vertical
• shielded
PART NUMBER KEY
SD - XX BV
Base Number
Pin Options
30 = 3 pins
50 = 5 pins
60 = 6 pins
70 = 7 pins
80 = 8 pins
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
max
24
units
Vdc
rated input current
1
A
contact resistance
30
mΩ
500
Vac
insulation resistance
at 500 Vdc
voltage withstand
50/60 Hz at 0.5 A for 1 minute
100
MΩ
insertion/withdrawal force
0.5
5.5
kg
operating temperature
-20
60
°C
storage temperature
-25
life
70
5,000
flammability rating
UL94V-0
RoHS
yes
cuidevices.com
°C
cycles
Product Page
3D Model
PCB Footprint
CUI Devices │ SERIES: SD-BV │ DESCRIPTION: STANDARD DIN CONNECTOR
date 02/19/2020 │ page 2 of 3
MECHANICAL DRAWINGS
units: mm[inches]
TOLERANCE: ±0.5mm
contact terminals
(1~8)
brass
tin
PBS
tin
cover
iron sheet
nickel
mouth bushing
PBT-94V0
G15
4.0 0.16
15.8 0.62
11.8 0.46
2.60 0.10
PLATING
sleeve
0.7 0.03
14.0±0.2
0.55
MATERIAL
16.0 0.63
1.00 0.04
14.8±0.2
0.58
7.0 0.28
11.0 0.43
1.00 0.04
(8 PLCS)
SD-30BV
SD-50BV
SD-60BV
45°
1.4 0.06
(4 PLCS)
45°
30°
1.4 0.06
(7 PLCS)
1.4 0.06
(6 PLCS)
SD-80BV
SD-70BV
45°
1.4 0.06
(8 PLCS)
1.4 0.06
(9 PLCS)
2.0 0.08
11.0
0.43
45°
45°
45°
11.0
0.43
11.0
0.43
11.0
0.43
11.0
0.43
66.5°
4.50
0.18
PCB LAYOUT
FRONT VIEW
4.50
0.18
23.5°
PCB LAYOUT
FRONT VIEW
PCB LAYOUT
FRONT VIEW
cuidevices.com
4.50
0.18
4.50
0.18
PCB LAYOUT
FRONT VIEW
1.30 0.05
4.50
0.18
PCB LAYOUT
FRONT VIEW
Product Page
3D Model
PCB Footprint
date 02/19/2020 │ page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
02/23/2006
1.01
new template applied
02/10/2012
1.02
terminal plating changed to tin
01/12/2016
1.03
updated datasheet
09/01/2017
brand update
02/19/2020
1.04
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no
responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any
component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or
effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“SD-30BV”相匹配的价格&库存,您可以联系我们找货
