XLR CHASSIS CONNECTORS
5 PIN E SERIES - VERTICAL PCB MOUNT
Locking vertical PCB Mount 5 pin chassis
connector with plastic body for audio and
lighting control.
Other Available Mounting Option: Horizontal
PCB Mount
SPECIFICATIONS
IO-XLR5-M-EV
IO-XLR5-F-EV
MECHANICAL
PRODUCT
Gender: Male (IO-XLR5-M-EV)
Female (IO-XLR5-F-EV)
Lifetime: > 1000 Mating Cycles
Wiring: Vertical PCB Mount
Locking Device: Latch Lock
Contacts: 5
Mounting Direction: Rear
ELECTRICAL
Capacitance Between Contacts: ≤ 2 pF
Capacitance Between Contact and Ground: ≤ 2.4 pF
Contact Resistance: < 6 mΩ
Solderability: Complies with IEC
60068-2-20
MATERIAL
Contacts: Brass
Insulation Resistance: ≥ 5000 MΩ
Dielectric Strength: 1500V @ 60s
Current Rating: 3 A / 50 V AC
Grounding: Separate ground contact to shell of
mating connector and panel
Contact Plating: .05μm Au
Ground Terminal: Brass
Ground Terminal Finish: Nickel
Shell: PA
Shell Finish: Black
ENVIRONMENTAL
Push Button: Stainless Steel
Standard Compliance: IEC 61076-2-103
Push Button Finish: Nickel
UL Flammability: Meets UL 94 HB
Latch: Stainless Steel
Temperature Range: -40°C ~ +70° C (-40°F ~ +158°F)
Latch Finish: Nickel
Product specifications may change without prior notification
Io Audio Technologies® is a registered trademark of Knight Electronics, Inc.
10557 Metric Dr. Dallas, TX 75243 | 214-340-0265 | 800-323-2439 | Fax: 214-340-5870 |
www.ioaudiotechnologies.com
DRAWINGS
IO-XLR5-F-EV
IO-XLR5-M-EV
FEATURES & APPLICATIONS
Panel Cutout
E Series XLR chassis connectors offer the most cost-effective
solution for design-in applications where the termination method
is to a printed circuit board. The small footprint makes this our XLR
receptacle with the highest packing density available.These
connectors feature a compact all plastic housing with precision
machined, one piece, gold plated contacts to help prolong the
useful life of the connectors. They also come with a separate nickel
plated ground pin that grounds the connector to the panel. The
compact form factor of the these connectors makes them perfect
for situations where space saving is a priority or space for a
connector is limited.
Available in 3 or 5 pin, Male or Female variations with options for
vertical or horizontal PCB mounting.
PART NUMBER BREAKDOWN:
STANDARDS & CLASSIFICATIONS
IO-XLR5-M-EV
Series Identifier
IO-XLR5-M-EV
Number of Pins
IO-XLR5-M-EV
Gender
IO-XLR5-M-EV
Series Identifier
IO-XLR5-M-EV
H = Horizontal PCB Mount
V = Vertical PCB Mount
很抱歉,暂时无法提供与“IO-XLR5-F-EV”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+31.690371+4.09783
