2D Drawing
IGES
STEP
Solder Profile
CofC RoHS Compliant
CofC REACH Compliant
UL Plastic File
Certificate of Origin
Check Stock
Request a Sample
Send Us An Email
3D PDF
Generated Part Number
KPJX-CM-4S
Part Number Builder
KPJX-CM
4
S
Series
No. of
Contacts
Contact
Type
DC POWER CONNECTORS: KPJX-CM Series
Snap and Lock Cable Mount
Series
KPJX-CM - Receptable, Cable Mount
Product Features
Laptop Computers, Power Supplies and Other Portable
Digital Equipment Applications
Snap & Lock Feature Helps to Prevent Accidental
Disconnects
3 or 4 Pins Transmit Power, or One Pin Can Be Used For
Signal Transmission
For Signal and DC Power Applications
Supplied in a Kit Ready for Assembly
Number of Contacts
3 Pin
4 Pin
Contact Type
S - Socket
Recommended to be used with Kycon KPPX Series Plugs
Contact Kycon for Other Options
Performance Specifications
Materials and Finish
Inner Shield: Copper Alloy, Nickel Plated
Body: ABS Thermoplastic, UL94HB Rated
Insert: Nylon, UL94V-2 Rated
Contacts: Brass, Tin Plated
KPJX-CM Series
Dimensions in mm
Electrical Characteristics
Contact Rating
3 Position: Pin 1 and 2, 48V DC at 7.5A Max.,
Pin 3, 48V DC 1.0A Max.
4 Position: 48V DC 7.5A Max. For All Pins.
Insulation Resistance: 50 Megohms Min. at 250V DC
Dielectric Withstanding Voltage: 500V AC For 1 Minute
Contact Resistance: 30 milliohms Max.
Mechanical Characteristics:
Durability Test: 1000 Cycles
Suggested Wire Awg. : #18 For Power Wires, #24 for
Signal Wire.
Click here for our assembly videos
Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 1018
很抱歉,暂时无法提供与“KPJX-CM-3S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+58.961211+7.37722
- 10+50.1334510+6.27269
- 25+46.9897025+5.87935
- 50+44.7467450+5.59871
- 200+40.57623200+5.07689
- 400+38.64060400+4.83471
- 600+37.55162600+4.69846
- 1000+36.223431000+4.53227
