GT7-26DP-DS(70)
GT7-26DP-DS(70)
    HRS(广濑)
    排针 2x13P 插件
GT7-26DP-DS(70) 数据手册
GT5 Interface Connector GT13 GT16 PO5G GT7 Series GT21 GT26 GT36 GT11 GT17 GT3 These automotive crimp terminals are equivalent to 040 and 070 tab width items. The contact point of the F connector side has been given a double structure to make these connectors compatible with low insertion force and high contact pressure at the time of coupling. GT32 GT10 GT18W GT25 GT8E GT9 GT15 In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 179 Interface Connector GT7 Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT19 Features F Connectors 2.3 A Terminals GT21 GT26 GT36 HRS No. Material Plating GT7-2022SCF(70) GT7A-2022SCF(70) GT3-2024SCF(70) 757-0001-1 70 757-0003-7 70 753-0006-0 70 Copper palloy Tin plating Conductor Size (AWG) Outer A B Diameter Dimension Dimension φ1.4 to 2.4 φ2.6 to 3.1 20 to 24 AWG φ1.4 to 2.4 20 to 22 AWG 2.8 19 2.3 18.2 Housing 16 Pos. 5,000 pcs/reel 3,000 pcs/reel 5,000 pcs/reel YES 21 5.2 GT32 15.7 15 25 22 GT3 GT7 RoHS 3 Part No. GT7-16DS-HU HRS No. 757-0008-0 Color Light Gray Material PBT 25.5 Packaging RoHS 1 YES Retainer (Only for GT7-16DS-HU) 16.8 25.5 13.2 14.4 GT18W GT10 Packaging Note 1: Sold in reel. Note 2: This component is used only with applicable HRS housings. GT17 GT11 Part No. GT9 GT8E GT25 14.7 GT15 Interface Connector Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT19 PO5G B GT16 GT13 GT5 GT7 Series ● Interface Connector 180 Part No. GT7-16R HRS No. 757-0010-2 Color Dark Gray Material PBT Packaging RoHS 1 YES GT7 Series ● Interface Connector 3.1 22 Pos. 21 3.1 GT5 3.5 3 GT13 5.2 5.2 Housing 35.8 16.8 PO5G 15.7 GT16 35.2 Color Light Gray Material PBT Packaging RoHS 1 YES 13.2 35.95 GT26 15.4 Retainer (Only for GT7-22DS-HU) GT21 14.7 GT36 Color Dark Gray Material PBT Packaging RoHS 1 YES 7 3.1 3 3.5 21 3.1 3.5 16.8 42.8 14.7 GT25 14.4 13.2 GT18W 42.95 Retainer (Only for GT7-26DS-HU) 22 15 Packaging RoHS 1 YES GT8E GT9 Part No. GT7-26R HRS No. 757-0011-5 Color Dark Gray Material PBT Packaging RoHS 1 YES GT15 181 Interface Connector Material PBT GT10 Color Light Gray GT7 HRS No. 757-0009-3 GT3 15.7 42.2 Part No. GT7-26DS-HU GT32 5.2 26 Pos. GT17 Housing HRS No. 757-0016-9 5.2 Part No. GT7-22R GT11 Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. HRS No. 757-0015-6 GT19 Part No. GT7-22DS-HU GT5 GT7 Series ● Interface Connector BRecommended PCB pattern Board Type 26 Pos. 18.5 5.7 21.9 PO5G 4 GT19 A 5.7 4.5 8.4 15.3 GT21 GT26 GT36 0.65 HRS No. Material / Plating or Color Packaging RoHS A Dimension 757-0014-3 70 Housing:PBT/Light Gray 3 1 YES 757-0006-5 70 Terminal:Brass/Tin plating Shaded portion without stand-off Board Type / Hybrid Type 42 Pos. (26pos.+16pos.) 18.5 GT17 GT11 Part No. GT7A-26DP-DS(70) GT7-26DP-DS(70) 72.1 21.9 GT32 BRecommended PCB pattern (Tolerance of unmarked values is +- 0.05.) 4 Mates with a 26-pos. + 16-pos. F connector. A □0.64 4.5 3.1 3.5 8.4 15.3 GT7 5.7 3.5 21 3.1 3 3.5 26.95 21 3 5.7 4.5 GT3 1 1. -φ 39 □0.64 GT7 has shaded portion without stand-off GT10 GT18W GT25 GT8E GT9 3.5 26 Part No. GT7A-42DP-DS(70) GT7-42DP-DS(70) HRS No. Material / Plating or Color Packaging RoHS A Dimension 757-0013-0 70 Housing:PBT/Light Gray 3 1 YES 757-0007-8 70 Terminal:Brass/Tin plating Shaded portion without stand-off 1.1 -φ 3.5 3-φ 42 0.4 24.25 65.7 182 3.1 4.5 45.4 GT7 has shaded portion without stand-off GT15 Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.1 21 3 Mates with a 26-pos. F connector. Interface Connector (Tolerance of unmarked values is +- 0.05.) 3.5 3.5 GT16 GT13 M Connectors GT7 Series ● Interface Connector GT5 Board Type / Hybrid Type 64 Pos. 18.5 GT13 GT16 4 □0.64 3.2 4.5 GT19 111.4 117.8 A 5.7 PO5G 21.9 109 GT7 has shaded portion without stand-off 8.4 15.3 6.4 GT21 BRecommended PCB pattern 3 3.1 36.65 21 3 3.1 3.5 5.05 3.5 111.4 GT17 BCrimping tools GT11 4-φ 38.85 65.55 GT36 3 Part No. HRS No. Packaging RoHS A Dimension GT7A-64DP-DS(70) 757-0012-8 70 3 1 YES 757-0005-2 70 Shaded portion without stand-off GT7-64DP-DS(70) 63.6 21 4.5 3.1 3.1 3.5 21 5.7 1.1 -φ 3.5 3.5 GT26 (Tolerance of unmarked values is +- 0.05.) 64 User manuals are available. Please ask your Hirose Electric account representative. GT32 Automatic Crimping Machine GT3 Picture reference only Specifications Specification Remarks 1.5ton 30mm 200spm(50 Hz) Weight 75 kg 0.2kw 2,000 to 4,000 pcs/hour AC100V GT18W Motor Crimping speed 240spm(60 Hz) GT10 Stroke Length Number of strokes Part No. CM-105C GT25 Harness tool Terminal HRS No. 757-0001-1 70 757-0003-7 70 Tool Part No. AP 105-GT7-2022 AP 105-GT7A-2022 Tool HRS No. 901-5004-9 901-5039-3 GT9 *Crimp height setting tables are available for each cable type. Please contact your nearest Hirose Electric account representative. Different cables will require different crimp height settings. GT8E Terminal Part No. GT7-2022SCF(70) GT7A-2022SCF(70) GT15 183 Interface Connector Item Press capacity GT7 Dec.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Mates with a 26-pos. + 16-pos. + 22-pos. F connector.
GT7-26DP-DS(70) 价格&库存
很抱歉,暂时无法提供与“GT7-26DP-DS(70)”相匹配的价格&库存,您可以联系我们找货
