UTS014E18S
UTS014E18S
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    CONN RCPT FMALE 18P SOLDER CUP
UTS014E18S 数据手册
UTS SERIES Waterproof Plastic Connectors IP68 and IP69K Overview UTS Series | Overview Contacts Typical Applications ........................................... 06 Features & Benefits ........................................... 07 Range Overview ................................................ 08 Layouts .............................................................. 10 General Technical Characteristics ...................... 12 Description ........................................................ 162 Contact Plating Selector Guide ......................... 163 Contact Selector Guide ..................................... 164 Packaging .......................................................... 164 Crimp Contacts ................................................. 165 #16 Coaxial Contacts ........................................ 167 PCB Contacts .................................................... 168 Fiber Optic Contacts ......................................... 170 Technical Information Contacts Tooling ............................................................... 174 Stripping & Crimping Instructions ..................... 176 Handle & Interchangeable Heads ..................... 178 Insertion & Extraction Tools ............................... 179 Overmolded Cable Assembly Dimensions ........ 179 Assembly Instructions ........................................ 180 Mated Connector Lengths ................................ 184 Mating Procedure .............................................. 185 Rated Current & Working Voltage ..................... 186 UV Resistance .................................................... 187 UL94 + UL1977 .................................................. 188 IEC 61984 & IP Codes Explained ...................... 191 IEC 61140 Explained ......................................... 193 What is NEMA Rating ? ..................................... 194 Ethernet for the Layman .................................... 195 Technical Information Overmolded Cable Assembly ........................... 16 2 contacts .......................................................... 20 2 + ground contacts .......................................... 28 3 contacts .......................................................... 36 3 + ground contacts .......................................... 52 4 contacts .......................................................... 60 5 contacts .......................................................... 72 6 contacts .......................................................... 80 6 + ground contacts .......................................... 92 7 contacts .......................................................... 96 8 contacts .......................................................... 100 10 contacts ........................................................ 112 12 contacts ........................................................ 116 14 contacts ........................................................ 128 15 contacts ........................................................ 132 18 contacts ........................................................ 136 19 contacts ........................................................ 140 23 contacts ........................................................ 144 32 contacts ........................................................ 148 LC (Fiber Optic) ................................................. 152 MPO (Fiber Optic) ............................................. 156 Appendices #16 Coaxial Contacts/Cabling Notices ............. 200 Glossary of Terms .............................................. 207 Discrimination/Keying Methods ........................ 208 Part Number Index ............................................ 209 Appendices Connector Connector Contents 3 UTS SERIES © 2015 SOURIAU - SOURIAU is a registered trademark UTS Series Overview Typical Applications ................................................................................................. 06 Features & Benefits ................................................................................................. 07 Range Overview ..................................................................................................... 08 Layouts ................................................................................................................... 10 General Technical Characteristics ............................................................................ 12 5 UTS Series | Overview Off-Road - Mining - Railway © cachoudesign / Fotolia Instrumentation - Measurement Stage - Light 6 Building Automation & Control © Olivier Tuffé / Fotolia © krungchingpixs / Fotolia Energy - Power Telecom - Data infrastructure © Volodymyr Kyrylyuk / Fotolia © Vibe Images / Fotolia © Sergey Milovidov / Fotolia Typical Applications UTS Series | Overview Features & Benefits IP68/69K Dynamic Mated & Unmated Ideal for outdoor and indoor dynamic applications requiring continuous underwater immersion, routine pressure washing and dust protection. Overview WATER PROOF No Degradation Over Time UV RESISTANT No mechanical deterioration or important color variation after 5 years of exposure in natural environment (equivalent exposure to sun and moisture as per ISO4892) and F1 rated per UL 746C. Qualified & Certified UL/IEC COMPLIANT In accordance with: - UL 1977 - Certificate ECBT2, File number: E169916 - CSA C22.2 n°182.3 - Certificate ECBT8, File number: E169916. 1/3 Bayonet Coupling quick mating With only 1/3 twist of the bayonet coupling system, connectors are mated with audible "click" and tactile feel to confirm proper mating. This mating feature eliminates connection uncertainty and reduces time and labor during installation. Mixed Power & Signal Layouts Cost savings Power supply and signal transmission can be combined in a unique interconnect solution to reduce system complexity and minimize component and installation costs. 7 UTS Series | Overview Range UTS Standard UTS Series Cable Sealed Single Wire Sealed Sealed mated: IP68/69K dynamic UV resistant UL/IEC compliant UTS Backshells Corrosion-proof Plastic housing Contacts Supplied Separately Cable Sealing Choice of Crimp Contacts • Machined • Stamped and Formed • Coaxial Plug PCB Contacts Double Sealing (Wires + Cable) Fiber Optic Contacts Loaded Screw Termination Grommet Single Wire Sealed Flexible conduit adaptors Contact us for more information Overmolded Cable Assembly 8 Contacts Loaded Handsolder UTS Sealed Unmated Sealed Unmated: IP68/69K dynamic MIL-C-26482 compatible UV resistant UL/IEC compliant Corrosion-proof Plastic housing UTS Series | Overview Overview UTS Standard Receptacle Contacts Supplied Separately UTS Backshells Choice of Crimp Contacts • Machined • Stamped and Formed • Coaxial Overview Square Flange Cable Sealing PCB Contacts Threaded Receptacle Fiber Optic Contacts Supplied Separately Double Sealing (Wires + Cable) Choice of Crimp Contacts • Machined • Stamped and Formed • Coaxial In-line Grommet PCB Contacts Single Wire Sealed Fiber Optic Contacts Loaded Jam Nut Flexible conduit adaptors Screw Termination PCB UTS Sealed Unmated Receptacle Contact us for more information UTS PCB Contacts Contacts Loaded Jam Nut Stand-offs to allow cleaning after soldering Handsolder Metal hold down clips - to lock the connector easily on the PCB and to release stress on solder joints - suitable for soldering in a metallic hole PCB Square Flange Low profile housing to limit space between panel and PCB Pre-assembled PCB contacts - machined or stamped versions available - different solder tails lengths possible - different plating options 9 UTS Series | Overview Layouts Shell Size (Electrical parameter according to UL1977) Contact #16 (Ø 1.6mm) Contact #20 (Ø 1.0mm) 8E2/8D2(1) 8E3/8D3(1) Page 20 Page 36 8E3A/8D3A(1) 8E98/8D98(1) Page 40 Page 40 8E33/8D33(1) 8E4*/8D4*(1) Page 44 Page 60 7A 250V 3 contacts 7A 250V 3 contacts 103 10 10A 500V 4 contacts 6A 250V 6 contacts Page 28 Page 68 Page 84 12E2/12D2 13A 650V 2 contacts Page 24 102W2 10E98/10D98 10E7(1)/10D7 Page 88 Page 96 12E3/12D3 13A 600V 3 contacts 103W3 20A 500V 4 contacts 10A 500V 6 contacts 2xØ2.4 (#12) 2xØ1.0 (#20) 3xØ1.6 (#16) 3xØ1.0 (#20) Page 64 Page 80 6A 250V 7 contacts 1210* 12E10*/12D10* 5A 250V 10 contacts Page 48 Page 112 124 12E4/12D4 (4) 128(1) (3) 10A 500V 3+ground 10A 500V 8 contacts Page 52 Page 100 1: M12, M16 and M20 threaded receptacle available 10 7A 250V 4 contacts 10A 500V 2+ground 6A 250V 6 contacts 12 7A 250V 3 contacts 106* 10E6*(1)/10D6* 104*(3) Hybrid & others 7A 250V 3 contacts 7A 250V 2 contacts 8 Contact #8 (Ø 3.6mm) 2: NPT available 12E8/12D8 12E14/12D14 Page 104 Page 128 4.5A 250V 8 contacts 4.5A 250V 14 contacts 3: Discrete wire grommet option 4: Screw termination contacts * Ethernet compatible: see pages 195 & 196 UTS Series | Overview Shell Size Contacts #16: from AWG 30 to 14 0.05 to 2.5 mm² Contact #16 (Ø 1.6mm) 14E5/14D5 14 147(3) (4) 14E7/14D7 12A 600V 5 contacts 10A 500V 6+ground Page 72 Page 92 1412(3) 1492(3) 10A 500V 12 contacts 10A 600V 12 contacts Contacts #12: from AWG 22 to 12 0.13 to 4 mm² Contacts #8: from AWG 16 to 8 1.5 to 10 mm² Contact #20 (Ø 1.0mm) Contact #8 (Ø 3.6mm) 14E18/14D18 Hybrid & others 148 142G1(2) 4A 250V 18 contacts 44A 600V 2+ground Page 136 Page 32 25A 250V 8 contacts 4xØ1.6 (#16)+4xØ2.4 (#12) Overview Contacts #20: from AWG 26 to 18 0.13 to 0.93 mm² Page 108 14E12/14D12 4.5A 250V 12 contacts 1419 14E19/14D19 4xØ1.6 (#16)+8xØ1.0 (#20) 5A 250V 19 contacts Page 120 Page 116 14E15/14D15 Page 124 12A 600V 15 contacts Page 140 1xØ1.6 (#16)+14xØ1.0 (#20) Page 132 1823 10A 500V 23 contacts 1832 18E32 5A 250V 32 contacts 183G1(2) 18X2M3(2) 44A 600V 3+ground 44A 600V 5 contacts 3xØ1.6 (#16) + 2xØ3.6 (#8) 1 11 1 12 11 22 2 22 2 5 55 Page 144 Page 148 Page 56 1 1 22 225 5 24 5 2 3 44 33 3 33 11 11 5 55 55 4 33 33 44 5 5 4 44 44 4 4 3 3 Page 763 LC 18 Page 156 MPO Page 160 XXXXXX blue highlighted items: UTS Sealed in Unmated Condition 11 UTS Series | Overview General Technical Characteristics Materials Environmental Electrical • Body connector + Backshell: Thermoplastic • Operating temperature: from -40°C to +105°C 40/100/21 per NFF 61-030 • In accordance with: - UL 1977: Certificate ECBT2 File number: E169916 - CSA C22.2 n°182.3: Certificate ECBT8 File number: E169916 • Insert: - UTS Standard, UTS Single Wire Sealed, UTS Screw Termination Contacts: Thermoplastic - UTS Sealed Unmated Handsolder & UTS Sealed Unmated with PC Tails Contacts: Elastomer • Nut: Metal • Contacts: See page 161 • Halogen free • RoHS compliant & conforms to the Chinese standard SJ/T1166-2006 (Chinese RoHS equivalent) • Flammability rating: - UL94 V-0 (all UTS except the Sealed Unmated version) see page 188 - UL94 HB (UTS Sealed Unmated version only) see page 188 - I2F3 according to NFF 16101 & NFF 16102 • Also see pages 10 & 11 • Salt spray: ≥500 hours per EIA-026A • UV resistant: No mechanical degradation or important color variation after 5 years of exposure in natural environment (equivalent exposure to sun and moisture as per ISO 4892) and F1 rated per UL 746C • Sealing: - UTS Standard: IP68/IP69K dynamic (mated) - UTS Sealed Unmated version: IP68/IP69K dynamic (unmated) - UTS Single Wire Sealed: IP67/69K (up to IP68 with double sealing backshell) - UTS Screw Termination Contacts: IP68/IP69K dynamic (mated) Note: IP68=10 m underwater during 1 week • Fluid resistance: - Gas and Oil - Mineral Oil - Acid Bath - Basic Bath 12 Optical • Please consult us for more information about UTSLC and UTSMPO Mechanical • Durability: 250 matings & unmatings per MIL-C-26482 • Vibration resistance (all UTS versions except UTS Screw Termination contacts): Sinusoidal vibrations per IEC 60512-4 - from 10 to 2000 Hz • Thermal shock: 5 cycles 30 min. from -40°C to 105°C per MIL-STD-1344 method 1003 UTS Series | Overview Overview Notes 13 UTS SERIES © 2015 SOURIAU - SOURIAU is a registered trademark UTS Series Connector Overmolded Cable Assembly ................................................................................. 16 2 contacts 8E2/8D2: 7A 250V.................................................................. 20 12E2/12D2: 13A 650V.................................................................. 24 2 contacts + ground 103: 10A 500V.................................................................. 28 142G1: 44A 600V.................................................................. 32 3 contacts 8E3/8D3: 7A 250V.................................................................. 36 8E3A/8D3A - 8E98/8D98: 7A 250V.................................................................. 40 8E33/8D33: 7A 250V.................................................................. 44 12E3/12D3: 13A 600V.................................................................. 48 3 contacts + ground 124 - 12E4/12D4: 10A 500V.................................................................. 52 183G1: 44A 600V.................................................................. 56 4 contacts 8E4/8D4*: 7A 250V.................................................................. 60 102W2: 20A 500V.................................................................. 64 104*: 10A 500V.................................................................. 68 5 contacts 14E5/14D5: 12A 600V.................................................................. 72 18X2M3: 44A 600V.................................................................. 76 6 contacts 103W3: 10A 500V.................................................................. 80 106* - 10E6*/10D6*: 6A 250V.................................................................. 84. 10E98/10D98: 6A 250V.................................................................. 88 6 contacts + ground 147 - 14E7/14D7: 10A 500V.................................................................. 92 7 contacts 10E7/10D7: 6A 250V.................................................................. 96 8 contacts 128: 10A 500V.................................................................. 100 12E8/12D8: 4.5A 250V.................................................................. 104 148: 25A 250V.................................................................. 108 10 contacts 1210* - 12E10*/12D10*: 5A 250V.................................................................. 112. 12 contacts 1412: 10A 500V.................................................................. 116. 14E12/14D12: 4.5A 250V.................................................................. 120 1492: 10A 600V.................................................................. 124 14 contacts 12E14/12D14: 4.5A 250V.................................................................. 128 15 contacts 14E15/14D15: 12A 600V.................................................................. 132 18 contacts 14E18/14D18: 4A 250V.................................................................. 136 19 contacts 1419 - 14E19/14D19: 5A 250V.................................................................. 140. 23 contacts 1823: 10A 500V.................................................................. 144 32 contacts 1832 - 18E32: 5A 250V.................................................................. 148 LC ........................................................................................................................ 156 MPO .................................................................................................................... 160 Electrical parameters according to UL * Ethernet compatible see pages 195 & 199 15 UTS Series | Connector Overmolded Cable Assembly SOURIAU has provided connectors for various applications for more than 90 years and has been used in the most extreme environments. Conscious about the difficulty in finding a quick and reliable harness manufacturer, we began our own in-house cable assembly production. It allows customers to reduce the number of suppliers and to take advantage of the “best in class” quality of the SOURIAU group. Overmolding is a process that further enhances the sealing properties and helps to minimize stress on the cable termination to the connector. In addition, the wires are encapsulated inside the molding which creates a barrier preventing liquid/moisture from entering the equipment through the connector or cable jacket if breached. How to choose the outer jacket material TPE Static installation OUTDOOR (black outer jacket) PUR Static or dynamic installation SILICON Static installation FEP Static installation PTFE Static installation INDOOR PVC Static or dynamic installation -40°C 16 +80°C Ambient temperature UV resistance Chemical aggression Wet Immersed Cleaner, chlorine Please consult us UTS Series | Connector Overmolding Description O-ring Compound Overmolding adapter PVC or PUR overmolding Connector Thermoplastic or elastomer insert Connector with cable gland backshell If cable jacket is breached... GOOD ...water ingress unhampered, leading to damage. Overmolded connector If cable jacket is breached... BEST ...prevents water ingress via capillary action. 17 UTS Series | Connector UTS Waterproof Plastic Overmold Description Cable • PVC Jacket (Black) • 16 AWG conductors • Multi-conductor 4, 8 or 12 • 300V • Unshielded • Flammability rating UL 1685 (UL1581 Sec.1160) Applications • Industrial Controls • Electronics • Controlled Environment Equipment • LED Lighting Overmolding Specifications PLATING SALT SPRAY TEMPERATURE* WATERPROOF* MECHANICAL No plating 500 H -30°C up to +50°C IP68/IP69K dynamic (mated) 250 matings/unmatings * With appropriate cable and overmolding Example of Customized Cable Assemblies Overmolding on Curly Cable Overmolding with Double Ends Harness for PCB Connection To define your customized cable assembly needs, please contact our Technical Service Team for support. 18 UTS Series | Connector Cable Information Range of temperature: -30°C +50°C Rated voltage: U0/U: 300/500V Wire section : Layouts with #16 contact: wire section 1.5 mm² / 16AWG Harmonized reference: H05 VV - F XX Nomenclature Key Definitions of Cable Types S: Service Grade (also means extra hard service when not followed by J, V, or P) J: Hard Service V: Vacuum cleaner cord (also light duty cable) P: Parallel cord (also known as zip cord) – Always light duty E: Thermoplastic Elastomer (UL/NEC designation ONLY) O: Oil Resistant outer jacket OO: Oil Resistant outer jacket and insulation T: Thermoplastic W: Outdoor-includes sunlight resistant jacket and wet location rated conductors (formerly "W-A") H: Heater cable VW-1: Flame retardant (vertical grade) FT2: Flame retardant (horizontal grade) SVT: Thermoplastic insulated vacuum cleaner cord, with or without 3rd conductor for grounding purposes; 300V (PVC) SJT: Junior hard service, thermoplastic insulated conductors and jacket. 300V (PVC) SJTW: Same as SJT except outdoor rated. (PVC) SJTO: Same as SJT but oil resistant outer jacket. (PVC) SJTOW: Same as SJTO except outdoor rated. (PVC) ST: Hard service cord with all thermoplastic construction, 600V (PVC) STW: Same as ST except outdoor rated. (PVC) STO: Same as ST but with oil resistant outer jacket. (PVC) STOW: Same as STO except outdoor rated. (PVC) Connector Standardization of American Cable 19 UTS Series | Connector 8E2/8D2 (Shell size 8, 2x#20) Layout OR OR OR WITH Connector Part Numbers Contact type Handsolder electrical contacts loaded see page 23 PCB contacts loaded see page 23 Connector type Backshell Square flange receptacle Female insert Without (Fig. 1) UTS08E2P UTS08E2S Without (Fig. 7) UTS68E2P UTS68E2S Cable gland (Fig. 8) UTS6JC8E2P UTS6JC8E2S Jam nut receptacle Without (Fig. 4) UTS78E2P UTS78E2S M12 threaded receptacle Without (Fig. 3) UTS78E2PM12 UTS78E2SM12 Square flange receptacle Without (Fig. 2) UTS08D2P UTS08D2S Jam nut receptacle with stand off and with hold down clips Without (Fig. 6) UTS78D2P32 UTS78D2S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 5) UTS78D2P UTS78D2S M12 threaded receptacle Without (Fig. 3) UTS78D2PM12 UTS78D2SM12 Plug Possibilities of discrimination/keying methods see page 208 20 Part number Male insert Sealed unmated 2 contacts 7A/250V UTS Series | Connector per UL 1977 8E2/8D2 (Shell size 8, 2x#20) 2 Dimensions Square Flange Receptacle - UTS0 0.295" Fig. 1 0.814" 0.342" 0.275" mini Ø0.125" 0.090" 0.866" 0.303" Ø0.472" 0.602" Ø0.472" 0.460" M12 Threaded Receptacle - UTS7 M12x1.5 0.196" Front view Fig. 2 Fig. 3 Front view Jam Nut Receptacle - UTS7 0.133" 0.145" mini 0.133" 0.133" 0.137" 0.137" Fig. 4 0.137" Fig. 5 Front view Fig. 6 Plug - UTS6 0.996" 0.952" 0.165" 0.708" Ø0.472" Ø0.472" Ø0.472" 0.708" 0.952" 0.708" Mated Connector Lengths Fig. 7 2.405" Ø0.885" UTS0 UTS7 2.126" Fig. 8 2.622" Panel Cut Out Square Flange Receptacle - UTS0 Drilling Pattern Jam Nut Receptacle - UTS7 Ø0.122" Ø0.129" 15° 15° 0.541" 0.602" Ø0.696" Front mounting Ø0.492" 0.602" Rear mounting Ø0.570" Hole size: 0.035" Ø0.531" Ø0.157" Ø0.866" 0.574" 0.059" 0.059" Note: all dimensions are in inches 21 UTS Series | Connector 8E2/8D2 (Shell size 8, 2x#20) Accessories Jam Nut or M12 Threaded Receptacle Sealing Caps IP68/69K IP68/69K Metal terminal Square Flange Sealing Cap IP68/69K Metal terminal IP40 Part number Part number Part number Part number UTS8DCG UTS8DCGR UTS8DCGE UTS68C Plastic Protective Cap Gasket Color Coding Rings G for Green Y for Yellow IP68/69K Part numbers 22 Plug Protective Cap Receptacle cap Plug cap 85005585A 85005594 Part numbers UTFD11B Part numbers R for Red Receptacles Plugs UTS78CCRR UTS68CCRR UTS78CCRY UTS68CCRY UTS78CCRG UTS68CCRG 2 contacts 7A/250V UTS Series | Connector per UL 1977 8E2/8D2 (Shell size 8, 2x#20) 2 #20 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 22 to 18 0.196" PCB Contacts Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 Electrical Characteristics UTS 8E2/8D2 Derating Curves Current (A) 18 UL 7A 250V UL94 HB CSA 7A 250V UL94 HB IEC 7A 32V 1.5kV 3 16 Test conditions Contact used: Machined contacts Wires used: 0.518mm² 14 12 10 8 6 4 2 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 23 UTS Series | Connector 12E2/12D2 (Shell size 12, 2x#16) Layout OR OR WITH Connector Part Numbers Contact type Handsolder electrical contacts loaded see page 27 PCB contacts loaded see page 27 Connector type Backshell Square flange receptacle Part number Male insert Female insert Without (Fig. 1) UTS012E2P UTS012E2S Without (Fig. 6) UTS612E2P UTS612E2S Cable gland (Fig. 7) UTS6JC12E2P UTS6JC12E2S Jam nut receptacle Without (Fig. 3) UTS712E2P UTS712E2S Square flange receptacle Without (Fig. 2) UTS012D2P UTS012D2S Jam nut receptacle with stand off and with hold down clips Without (Fig. 5) UTS712D2P32 UTS712D2S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 4) UTS712D2P UTS712D2S Plug Sealed unmated 24 2 contacts 13A/650V UTS Series | Connector per UL 1977 12E2/12D2 (Shell size 12, 2x#16) 2 Dimensions Square Flange Receptacle - UTS0 0.295" 0.295"0.318" mini 1.039" 0.090" 0.818" Ø0.748" 0.444" Ø0.748" 0.444" Ø0.125" 0.090" Fig. 1 Front view Fig. 2 Jam Nut Receptacle - UTS7 0.118" 0.708" 0.118" 0.708" 0.137" 1.255" 0.137" Fig. 3 0.137" Fig. 4 Front view Fig. 5 Plug - UTS6 0.996" 1.070" 0.165" Ø0.748" 0.185" mini Ø0.748" Ø0.748" 0.118" 0.708" Mated Connector Lengths Fig. 6 3.055" Ø1.185" UTS0 UTS7 2.626" Fig. 7 3.216" Panel Cut Out Square Flange Receptacle - UTS0 Drilling Pattern Jam Nut Receptacle - UTS7 Ø0.129" 22° Ø0.122" 68° Front mounting Ø0.720" 0.818" Rear mounting Ø0.877" 0.055" 0.826" 0.818" Ø1.031" Hole size: 0.051" Ø0.866" 0.393" Ø1.200" 0.875" 0.090" 0.090" 30° Note: all dimensions are in inches 25 UTS Series | Connector 12E2/12D2 (Shell size 12, 2x#16) Accessories Jam Nut Sealing Caps IP68/69K IP68/69K Plug Sealing Cap Metal terminal IP68/69K IP68/69K Metal terminal Part number Part number Part number Part number UTS12DCG UTS12DCGR UTS612DCG UTS12DCGE Plastic Protective Cap Gasket Color Coding Rings G for Green Y for Yellow IP68/69K Part numbers 26 Square Flange Sealing Cap Receptacle cap Plug cap 85005587A 85005596 Part numbers UTFD13B Part numbers R for Red Receptacles Plugs UTS712CCRR UTS612CCRR UTS712CCRY UTS612CCRY UTS712CCRG UTS612CCRG 2 contacts 13A/650V UTS Series | Connector per UL 1977 12E2/12D2 (Shell size 12, 2x#16) 2 #16 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 18 to 14 0.196" PCB Contacts Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 Electrical Characteristics UTS 12E2/12D2 Derating Curves Current (A) UL 13A 650V UL94 HB CSA 13A 600V UL94 HB IEC 16A 150V 2.5kV 3 Test conditions Contact used: Machined contacts Wires used: 1.31mm² Current use 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 0 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 27 UTS Series | Connector 103 (Shell size 10, 2 + ground, 3x#16) Layout OR OR WITH Connector Part Numbers Contact type Crimp contacts supplied separately see page 31 PCB contacts supplied separately see page 31 28 Connector type Backshell Free hanging receptacle Part number Male insert Female insert Cable gland (Fig. 1) UTS1JC103P UTS1JC103S Without (Fig. 2) UTS6103P UTS6103S Cable gland (Fig. 3) UTS6JC103P UTS6JC103S Jam nut receptacle Without (Fig. 4) UTS7103P UTS7103S Jam nut receptacle Without (Fig. 4) UTS7103P UTS7103S Plug 2 + ground 10A/500V UTS Series | Connector per UL 1977 103 (Shell size 10, 2 + ground, 3x#16) Dimensions 2+ Free Hanging - UTS1 Ø0.594" 2.755" Fig. 1 Plug - UTS6 1.299" 2.488" Ø1.031" Ø1.031" Male Female 0.996" Fig. 2 Fig. 3 Jam Nut Receptacle - UTS7 Ø0.594" 0.720" Mated Connector Length - UTS7 1.070" 0.484" 0.137" Fig. 4 3.043" 0.885" Drilling Pattern Hole size: 0.051" 0.686" 0.059" 0.651" Jam Nut Receptacle - UTS7 0.118" Panel Cut Out 0.102" 0.102" Note: all dimensions are in inches 29 UTS Series | Connector 103 (Shell size 10, 2 + ground, 3x#16) Accessories and Tooling Jam Nut Sealing Caps IP68/69K Handle (without Head) Tool Kit Metal terminal IP68/69K Part number Part number Part number Part number UTS10DCG UTS10DCGR Shandles Toolkit Plug Sealing Cap Dummy Contact #16 Crimp Tooling (without Shandles) IP68/69K Part number Part number / Polyamide 6.6 UTS610DCG SMSPKE0 See page 212 for more information Plastic Protective Cap Extraction Tool #16 Part numbers Receptacle cap Plug cap 85005586A 85005595 Part number RX2025GE1 Color Coding Rings G for Green Y for Yellow Part numbers R for Red Receptacles Plugs UTS710CCRR UTS610CCRR UTS710CCRY UTS610CCRY UTS710CCRG UTS610CCRG Contacts RM/RC 28M1K(1) RM/RC 24M9K(1) RM/RC 20M13K(1) RM/RC 20M12K(1) RM/RC 16M23K(1) RM/RC 14M30K(1) SM/SC 24ML1TK6(1) SM/SC 20ML1TK6(1) SM/SC 16ML1TK6(1) SM/SC 14ML1TK6(1) SM/SC 16ML11TK6(1) RMDXK10D28K RCDXK1D28K RM/RC DX60xxD28K RM/RC DXK10D28 + york090 RM/RC DX60xxD28 S16RCM20* S16RCM20* S16RCM20* S16RCM20* S16RCM16* S16RCM14* S16SCM20* S16SCM20* S16SCML1* S16SCML1* S16SCML11* Standard contacts #16 Ø 1.6 mm M10S1J with die set & stop bushing see page 202 to 205 Coaxial contacts (1): Example of plating, for other plating options see page 164 * Heads to be used with handle PN: SHANDLES + Handle 30 Part number of head Contact size = Head Complete set 2 + ground 10A/500V UTS Series | Connector per UL 1977 103 (Shell size 10, 2 + ground, 3x#16) Contacts #16 2+ Crimp Machined Stamped & Formed reeled contacts See note (2) for loose piece PCB Wire size Contact type Part number Coaxial Max wire Ø Max insulator Ø RM28M1K(1) RC28M1K(1) 0.021" 0.039" RM24M9K RC24M9K 0.031" 0.062" RM20M13K(1) RC20M13K(1) 0.045" 0.070" RM20M12K (1) RC20M12K 0.045" 0.086" RM16M23K(1) RC16M23K(1) 0.070" 0.125" RM14M30K RC14M30K 0.090" 0.125" SC24M1TK6(1)(2) - 0.035"-0.062" SM20M1TK6(1)(2) SC20M1TK6(1)(2) - 0.047"-0.082" - 0.125" - 0.118" (1)(2) mm² Male 30-28 0.50-0.08 26-24 0.13-0.20 22-20 0.32-0.52 22-20 0.32-0.52 20-16 0.52-1.31 16-14 1.31-2.08 26-24 0.13-0.20 SM24M1TK6(1)(2) 22-20 0.32-0.52 18-16 0.80-1.31 18-16 0.80-1.31 Machined (3) 14 2.08 - - Cable Multipiece Cable Monocrimp Twisted pair Multipiece see pages 167, 200 to 206 Twisted pair Monocrimp Fiber optic Female AWG POF contacts (Plastic Optical Fiber) see page 170 (1) (1) (1) (1) (1) SM16M1TK6 SC16M1TK6 SM16M11TK6(1)(2) SC16M11TK6(1)(2) SM14M1TK6 SC14M1TK6 - 0.125" RM20M12E83K(1) RC20M12E84K(1) - - RMDXK10D28 RCDXK1D28 - - RMDX60xxD28 RCDX60xxD28 - - RMDXK10D28 + york090 RCDXK1D28 + york090 - - RMDX60xxD28 RCDX60xxD28 - - RMPOF1000 RCPOF1000B - - (1)(2) (1)(2) (1)(2) (1): Example of plating, for other plating see page 164 (2): For loose piece contact packaging, place "L" in part number. Example: SM20ML1TK6 (3): For dimensions see page 172 Note: all dimensions are in inches Electrical Characteristics UTS 103 Derating Curves Current (A) 30 UL 10A 500V UL94 V-0 CSA 7A 500V UL94 V-0 IEC 16A 300V 4kV 3 Temperature elevation: 50°C 28 25 Test conditions Contact used: Machined contacts Wires used: 1.31mm² 23 20 18 15 13 10 8 5 3 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 31 UTS Series | Connector 142G1 (Shell size 14, 2 + ground, 3x#8) Layout OR OR OR OR WITH Connector Part Numbers Contact type Crimp contacts supplied separately see page 35 PCB contacts supplied separately see page 35 32 Connector type Backshell Square flange receptacle Free hanging receptacle Part number Male insert Female insert Without (Fig. 1) UTS0142G1P - Cable gland (Fig. 6) UTS1JC142G1P UTS1JC142G1S Without (Fig. 3) UTS6142G1P UTS6142G1S Cable gland (Fig. 4) UTS6JC142G1P UTS6JC142G1S Jam nut receptacle Without (Fig. 2) UTS7142G1P UTS7142G1S NPT 1/2" threaded receptacle Without (Fig. 5) - UTS7142G1SNPT Square flange receptacle Without (Fig. 1) UTS0142G1P - Jam nut receptacle Without (Fig. 2) UTS7142G1P UTS7142G1S NPT 1/2" threaded receptacle Without (Fig. 5) - UTS7142G1SNPT NPT 1/2" threaded receptacle with nut Without (Fig. 5) - UTS7142G1SNPTNUT Plug 2 + ground 44A/600V UTS Series | Connector per UL 1977 142G1 (Shell size 14, 2 + ground, 3x#8) Dimensions 2+ Square Flange Receptacle - UTS0 1.133" 0.913" Ø0.877" 0.708" 0.090" Fig. 1 Fig. 1 0.137" Ø0.125" Front view Fig. 2 Plug - UTS6 1.378" 1.381" 0.062" Ø0.877" 0.862" 1.196" NPT Threaded Receptacle - UTS7 1.389" 2.755" Ø1.381" Ø0.877" Male 1.000" 1.000" 0.444" Jam Nut Receptacle - UTS7 Female 1.263" NPT - 1/2˝ 0.909" Fig. 3 Fig. 5 Fig. 4 Free Hanging - UTS1 Mated Connector Lengths 3.090" 2.952" Ø0.877" UTS0 UTS7 3.228" Fig. 6 1.003" NPT " 40 /2" 1 PT N 7 0. Hole size: 0.129" 0.082" 0.948" Jam Nut Receptacle - UTS7 Drilling Pattern 0.165" Panel Cut Out 0.141" 0.141" Note: all dimensions are in inches 33 UTS Series | Connector 142G1 (Shell size 14, 2 + ground, 3x#8) Accessories and Tooling Jam Nut or NPT Threaded Receptacle Sealing Caps IP68/69K Hand Tool Metal terminal IP68/69K Part number Part number UTS14DCG UTS14DCGR Part number M317 Plug Sealing Cap Positioner + Locator Setting #8 IP68/69K Part number UTS614DCG Plastic Protective Cap Gasket Part number VGE10078A IP68/69K Part numbers Receptacle cap Plug cap 85005588A 85005597 Part numbers UTFD14B Extraction Tool #8 Color Coding Rings G for Green Y for Yellow 34 Part numbers R for Red Receptacles Plugs Part number UTS714CCRR UTS614CCRR 51060210936 UTS714CCRY UTS614CCRY UTS714CCRG UTS614CCRG 2 + ground 44A/600V UTS Series | Connector per UL 1977 142G1 (Shell size 14, 2 + ground, 3x#8) Contacts PCB Crimp #8 2+ Contact type Wire size Part number AWG mm² Male Female Max wire Ø 16 1.31 82913601A 82913600A 0.067" Machined Machined (1) 14 2.08 82913603A 82913602A 0.087" 12 3.31 82913605A 82913604A 0.111" 10 5.26 82913607A 82913606A 0.137" 8 8.37 82913609A 82913608A 0.171" 82911685NPC 82911684NPC - - (1): For dimensions see page 168 Max insulator Ø 0.255" - Note: all dimensions are in inches Electrical Characteristics UTS 142G1 Derating Curves Current (A) 50 UL 44A 600V UL94 V-0 CSA 30A 600V UL94 V-0 IEC 40A 300V 4kV 3 45 40 Test conditions Contact used: Machined contacts Wires used: 6mm² 35 30 25 20 15 10 5 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 35 UTS Series | Connector 8E3/8D3 (Shell size 8, 3x#20) Layout OR OR OR WITH Connector Part Numbers Contact type Handsolder electrical contacts loaded see page 39 PCB contacts loaded see page 39 Connector type Backshell Square flange receptacle Female insert Without (Fig. 1) UTS08E3P UTS08E3S Without (Fig. 7) UTS68E3P UTS68E3S Cable gland (Fig. 8) UTS6JC8E3P UTS6JC8E3S Jam nut receptacle Without (Fig. 4) UTS78E3P UTS78E3S M12 threaded receptacle Without (Fig. 3) UTS78E3PM12 UTS78E3SM12 Square flange receptacle Without (Fig. 2) UTS08D3P UTS08D3S Jam nut receptacle with stand off and with hold down clips Without (Fig. 6) UTS78D3P32 UTS78D3S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 5) UTS78D3P UTS78D3S M12 threaded receptacle Without (Fig. 3) UTS78D3PM12 UTS78D3SM12 Plug Possibilities of discrimination/keying methods see page 208 36 Part number Male insert Sealed unmated 3 contacts 7A/250V UTS Series | Connector per UL 1977 8E3/8D3 (Shell size 8, 3x#20) Dimensions Square Flange Receptacle - UTS0 0.295" Fig. 1 0.814" Ø0.472" 0.275" mini Ø0.125" 0.090" 3 0.866" 0.303" 0.342" 0.602" Ø0.472" 0.460" M12 Threaded Receptacle - UTS7 M12x1.5 0.196" Front view Fig. 2 Fig. 3 Front view Jam Nut Receptacle - UTS7 0.133" 0.145" mini 0.133" 0.708" 0.952" Ø0.472" 0.137" Fig. 5 0.137" Fig. 4 0.165" Ø0.472" 0.708" Ø0.472" 0.708" 0.952" 0.133" 0.137" Fig. 6 Plug - UTS6 Front view Mated Connector Lengths Fig. 7 2.405" 0.996" Ø0.885" UTS0 UTS7 2.622" 2.126" Fig. 8 Panel Cut Out Drilling Pattern Jam Nut Receptacle - UTS7 Front mounting Ø0.492" 0.602" Rear mounting Ø0.570" 0.541" 0.602" 0.035" Ø0.129" 0.574" Ø0.122" Ø0.866" 15° Hole size: 0.035" 15° Ø0.157" Ø0.531" 0.074" Square Flange Receptacle - UTS0 Ø0.696" 0.062" 0.062" Note: all dimensions are in inches 37 UTS Series | Connector 8E3/8D3 (Shell size 8, 3x#20) Accessories Jam Nut or M12 Threaded Receptacle Sealing Caps IP68/69K IP68/69K Metal terminal Square Flange Sealing Cap IP68/69K Metal terminal IP40 Part number Part number Part number Part number UTS8DCG UTS8DCGR UTS8DCGE UTS68C Plastic Protective Cap Gasket Color Coding Rings G for Green Y for Yellow IP68/69K Part numbers 38 Plug Protective Cap Receptacle cap Plug cap 85005585A 85005594 Part numbers UTFD11B Part numbers R for Red Receptacles Plugs UTS78CCRR UTS68CCRR UTS78CCRY UTS68CCRY UTS78CCRG UTS68CCRG 3 contacts 7A/250V UTS Series | Connector per UL 1977 8E3/8D3 (Shell size 8, 3x#20) Contacts Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder 3 Loaded in the connector Min 0.4µ gold over 0.8µ Ni 22 to 18 0.196" PCB #20 Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 Electrical Characteristics UTS 8E3/8D3 Derating Curves Current (A) 18 UL 7A 250V UL94 HB CSA 7A 250V UL94 HB 16 14 Test conditions Contact used: Machined contacts Wires used: 0.518mm² IEC 7A 32V 1.5kV 3 12 10 8 6 4 2 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 39 UTS Series | Connector 8E3A/8D3A - 8E98/8D98 (Shell size 8, 3x#20) Layout OR OR OR WITH Connector Part Numbers Contact type Connector type Square flange receptacle Backshell Without (Fig. 1) Without (Fig. 7) Handsolder electrical contacts loaded see page 43 PCB contacts loaded see page 43 Plug Cable gland (Fig. 8) Jam nut receptacle Without (Fig. 4) M12 threaded receptacle Without (Fig. 3) Square flange receptacle Without (Fig. 2) Jam nut receptacle with stand off and with hold down clips Without (Fig. 6) Jam nut receptacle with stand off and without hold down clips Without (Fig. 5) M12 threaded receptacle Without (Fig. 3) Possibilities of discrimination/keying methods see page 208 40 Part number Male insert Female insert UTS08E3AP UTS08E98P UTS68E3AP UTS68E98P UTS6JC8E3AP UTS6JC8E98P UTS78E3AP UTS08E3AS UTS08E98S UTS68E3AS UTS68E98S UTS6JC8E3AS UTS6JC8E98S UTS78E3AS UTS78E98P UTS78E98S UTS78E3APM12 UTS78E3ASM12 UTS78E98PM12 UTS78E98SM12 UTS08D3AP UTS08D98P UTS78D3AP32 UTS08D3AS UTS08D98S UTS78D3AS32 UTS78D98P32 UTS78D98S32 UTS78D3AP UTS78D3AS UTS78D98P UTS78D98S UTS78D3APM12 UTS78D3ASM12 UTS78D98PM12 UTS78D98SM12 Sealed unmated 3 contacts 7A/250V UTS Series | Connector per UL 1977 8E3A/8D3A - 8E98/8D98 (Shell size 8, 3x#20) Dimensions Square Flange Receptacle - UTS0 0.295" Fig. 1 0.814" Ø0.472" 0.275" mini Ø0.125" 0.090" Fig. 2 3 0.866" 0.303" 0.342" 0.602" Ø0.472" 0.460" M12 Threaded Receptacle - UTS7 M12x1.5 0.196" Front view Fig. 3 Front view Jam Nut Receptacle - UTS7 0.118" 0.118" 0.137" 0.952" 0.137" Fig. 5 Front view Fig. 6 Plug - UTS6 0.996" 0.165" 0.708" 0.137" Fig. 4 0.952" 0.118" Ø0.472" Ø0.472" 0.708" Ø0.472" 0.708" 0.145" mini Mated Connector Lengths Fig. 7 2.405" Ø0.885" UTS0 UTS7 2.126" 2.622" Fig. 8 Panel Cut Out 0.035" Front mounting Ø0.492" 0.602" Rear mounting Ø0.570" 0.574" Ø0.122" Ø0.866" 15° Hole size: 0.035" 15° Ø0.157" Ø0.531" 0.074" 0.541" 0.602" Square Flange Receptacle - UTS0 Ø0.129" Drilling Pattern Jam Nut Receptacle - UTS7 Ø0.696" 0.062" 0.062" Note: all dimensions are in inches 41 UTS Series | Connector 8E3A/8D3A - 8E98/8D98 (Shell size 8, 3x#20) Accessories Jam Nut or M12 Threaded Receptacle Sealing Caps IP68/69K IP68/69K Metal terminal Square Flange Sealing Cap IP68/69K Metal terminal IP40 Part number Part number Part number Part number UTS8DCG UTS8DCGR UTS8DCGE UTS68C Plastic Protective Cap Gasket Color Coding Rings G for Green Y for Yellow IP68/69K Part numbers 42 Plug Protective Cap Receptacle cap Plug cap 85005585A 85005594 Part numbers UTFD11B Part numbers R for Red Receptacles Plugs UTS78CCRR UTS68CCRR UTS78CCRY UTS68CCRY UTS78CCRG UTS68CCRG 3 contacts 7A/250V UTS Series | Connector per UL 1977 8E3A/8D3A - 8E98/8D98 (Shell size 8, 3x#20) Contacts Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder 3 Loaded in the connector Min 0.4µ gold over 0.8µ Ni 22 to 18 0.196" PCB #20 Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 Electrical Characteristics UTS 8E3A/8D3A - 8E98/8D98 Derating Curves Current (A) 18 UL 7A 250V UL94 HB CSA 7A 250V UL94 HB IEC 7A 50V 1.5kV 3 16 14 Test conditions Contact used: Machined contacts Wires used: 0.518mm² 12 10 8 6 4 2 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 43 UTS Series | Connector 8E33/8D33 (Shell size 8, 3x#20) Layout OR OR OR WITH Connector Part Numbers Contact type Handsolder electrical contacts loaded see page 47 PCB contacts loaded see page 47 Connector type Backshell Square flange receptacle Female insert Without (Fig. 1) UTS08E33P UTS08E33S Without (Fig. 7) UTS68E33P UTS68E33S Cable gland (Fig. 8) UTS6JC8E33P UTS6JC8E33S Jam nut receptacle Without (Fig. 4) UTS78E33P UTS78E33S M12 threaded receptacle Without (Fig. 3) UTS78E33PM12 UTS78E33SM12 Square flange receptacle Without (Fig. 2) UTS08D33P UTS08D33S Jam nut receptacle with stand off and with hold down clips Without (Fig. 6) UTS78D33P32 UTS78D33S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 5) UTS78D33P UTS78D33S M12 threaded receptacle Without (Fig. 3) UTS78D33PM12 UTS78D33SM12 Plug Possibilities of discrimination/keying methods see page 208 44 Part number Male insert Sealed unmated 3 contacts 7A/250V UTS Series | Connector per UL 1977 8E33/8D33 (Shell size 8, 3x#20) Dimensions Square Flange Receptacle - UTS0 0.814" 0.275" mini Ø0.125" 0.090" 3 0.866" 0.303" 0.342" 0.602" Ø0.472" Fig. 1 Ø0.472" 0.295" 0.460" M12 Threaded Receptacle - UTS7 M12x1.5 0.196" Front view Fig. 2 Fig. 3 Front view Jam Nut Receptacle - UTS7 0.133" 0.133" 0.137" 0.165" 0.708" 0.952" 0.137" Fig. 4 0.952" 0.133" Ø0.472" Ø0.472" 0.708" Ø0.472" 0.708" 0.145" mini 0.137" Fig. 5 Front view Fig. 6 Plug - UTS6 Mated Connector Lengths Fig. 7 2.405" 0.996" Ø0.885" UTS0 UTS7 2.622" 2.126" Fig. 8 Panel Cut Out Drilling Pattern Jam Nut Receptacle - UTS7 Ø0.122" Ø0.866" 15° Hole size: 0.035" 0.602" Rear mounting Ø0.570" 0.574" 15° Ø0.157" Ø0.531" 0.035" Front mounting Ø0.492" 0.541" 0.602" 0.074" Square Flange Receptacle - UTS0 Ø0.129" Ø0.696" 0.062" 0.062" Note: all dimensions are in inches 45 UTS Series | Connector 8E33/8D33 (Shell size 8, 3x#20) Accessories Jam Nut or M12 Threaded Receptacle Sealing Caps IP68/69K IP68/69K Metal terminal Square Flange Sealing Cap IP68/69K Metal terminal IP40 Part number Part number Part number Part number UTS8DCG UTS8DCGR UTS8DCGE UTS68C Plastic Protective Cap Gasket Color Coding Rings G for Green Y for Yellow IP68/69K Part numbers 46 Plug Protective Cap Receptacle cap Plug cap 85005585A 85005594 Part numbers UTFD11B Part numbers R for Red Receptacles Plugs UTS78CCRR UTS68CCRR UTS78CCRY UTS68CCRY UTS78CCRG UTS68CCRG 3 contacts 7A/250V UTS Series | Connector per UL 1977 8E33/8D33 (Shell size 8, 3x#20) Contacts Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder 3 Loaded in the connector Min 0.4µ gold over 0.8µ Ni 22 to 18 0.196" PCB #20 Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 Electrical Characteristics UTS 8E33/8D33 Derating Curves Current (A) 18 UL 7A 250V UL94 HB CSA 7A 250V UL94 HB IEC 7A 50V 1.5kV 3 16 14 Test conditions Contact used: Machined contacts Wires used: 0.518mm² 12 10 8 6 4 2 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 47 UTS Series | Connector 12E3/12D3 (Shell size 12, 3x#16) Layout OR OR WITH Connector Part Numbers Contact type Handsolder electrical contacts loaded see page 51 PCB contacts loaded see page 51 Connector type Backshell Square flange receptacle Female insert Without (Fig. 6) UTS012E3P UTS012E3S Without (Fig. 1) UTS612E3P UTS612E3S Cable gland (Fig. 2) UTS6JC12E3P UTS6JC12E3S Jam nut receptacle Without (Fig. 3) UTS712E3P UTS712E3S Square flange receptacle Without (Fig. 7) UTS012D3P UTS012D3S Jam nut receptacle with stand off and with hold down clips Without (Fig. 5) UTS712D3P32 UTS712D3S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 4) UTS712D3P UTS712D3S Plug Possibilities of discrimination/keying methods see page 208 48 Part number Male insert Sealed unmated 3 contacts 13A/600V UTS Series | Connector per UL 1977 12E3/12D3 (Shell size 12, 3x#16) Dimensions Plug - UTS6 0.996" 2.626" Ø1.185" 3 Fig. 1 Fig. 2 Jam Nut Receptacle - UTS7 0.118" 0.708" 0.118" 0.708" 0.137" 1.255" 0.137" Fig. 3 1.070" 0.165" Ø0.748" 0.185" mini Ø0.748" Ø0.748" 0.118" 0.708" 0.137" Fig. 4 Square Flange Receptacle - UTS0 Fig. 7 0.318" 0.444" 0.295" mini Front view Fig. 5 Mated Connector Lengths 1.039" 3.055" 0.818" Ø0.748" UTS0 Fig. 6 3.216" Ø0.125" Front view Panel Cut Out Square Flange Receptacle - UTS0 Ø0.129" Drilling Pattern 22° Jam Nut Receptacle - UTS7 Ø0.122" 68° 0.818" Rear mounting Ø0.877" 0.875" Ø0.866" 0.393" 0.110" 0.826" 0.818" Ø1.031" Front mounting Ø0.720" Hole size: 0.051" 0.055" 0.090" UTS7 Ø1.200" 0.090" 0.090" 30° Note: all dimensions are in inches 49 UTS Series | Connector 12E3/12D3 (Shell size 12, 3x#16) Accessories Jam Nut Sealing Caps IP68/69K IP68/69K Plug Sealing Cap Metal terminal IP68/69K Metal terminal IP68/69K Part number Part number Part number Part number UTS12DCG UTS12DCGR UTS612DCG UTS12DCGE Plastic Protective Cap Gasket Color Coding Rings G for Green Y for Yellow IP68/69K Part numbers 50 Square Flange Sealing Cap Receptacle cap Plug cap 85005587A 85005596 Part numbers UTFD13B Part numbers R for Red Receptacles Plugs UTS712CCRR UTS612CCRR UTS712CCRY UTS612CCRY UTS712CCRG UTS612CCRG 3 contacts 13A/600V UTS Series | Connector per UL 1977 12E3/12D3 (Shell size 12, 3x#16) Contacts Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder 3 Loaded in the connector Min 0.4µ gold over 0.8µ Ni 18 to 14 0.196" PCB #16 Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 Electrical Characteristics UTS 12E3/12D3 Derating Curves Current (A) UL 13A 600V UL94 HB CSA 13A 600V UL94 HB IEC 16A 150V 2.5kV 3 Test conditions Contact used: Machined contacts Wires used: 1.31mm² 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 0 0 20 40 80 60 100 Ambient Operating Temperature (°C) Current use Limited use 120 Not recommended use 51 UTS Series | Connector 124 - 12E4/12D4 (Shell size 12, 3 + ground, 4x#16) Layout OR WITH Connector Part Numbers Contact type Crimp contacts supplied separately see page 55 Connector type Backshell Square flange receptacle Without (Fig. 1) Jam nut receptacle Without (Fig. 4) Free hanging receptacle Cable gland (Fig. 12) Handsolder electrical contacts loaded see page 55 PCB contacts loaded see page 55 UTS7124S UTS1JC124S UTS6124S UTS6JC124S UTS7124SSCR UTS6124SSCR UTS6JC124SSCR UTS7124S UTS012E4S UTS712E4S UTS612E4S UTS6JC12E4S UTS012D4S Plug Cable gland (Fig. 11) Square flange receptacle Without (Fig. 3) Jam nut receptacle with stand off and without hold down clips Without (Fig. 9) UTS712D4P UTS712D4S Jam nut receptacle with stand off and with hold down clips Without (Fig. 8) UTS712D4P32 UTS712D4S32 Jam nut receptacle PCB contacts supplied separately see page 55 Female insert UTS0124P UTS7124P UTS1JC124P UTS6124P UTS6JC124P UTS7124PSCR UTS6124PSCR UTS6JC124PSCR UTS1JC124PSCR UTS0124P UTS7124P UTS012E4P UTS712E4P UTS612E4P UTS6JC12E4P UTS012D4P Plug Screw contacts loaded Part number Male insert Plug Without (Fig. 10) Cable gland (Fig. 11) Without (Fig. 6 & 7) Without (Fig. 10) Cable gland (Fig. 11) Free hanging receptacle Cable gland (Fig. 12) Square flange receptacle Without (Fig. 3) Jam nut receptacle Without (Fig. 5) Square flange receptacle Without (Fig. 2) Jam nut receptacle Without (Fig. 9) Plug Without (Fig. 10) Sealed unmated 52 3 + ground 10A/500V UTS Series | Connector per UL 1977 124 - 12E4/12D4 (Shell size 12, 3 + ground, 4x#16) Dimensions Square Flange Receptacle - UTS0 0.318" 0.444" 0.295" 0.444" 0.295" mini 0.444" 0.295" 1.039" 0.090" 0.090" 0.090" Fig. 1 0.818" Ø0.748" Ø0.748" Ø0.748" 3+ Fig. 2 Ø0.125" Front view Fig. 3 Jam Nut Receptacle - UTS7 Fig. 4 0.708" Fig. 6 0.708" 0.094" Fig. 8 0.708" 0.094" Hold down clip 1.255" Ø0.748" Ø0.748" Ø0.748" Male 1.070" 0.165" Female 0.137" 0.137" Fig. 5 0.137" Fig. 7 Front view Fig. 9 Free Hanging - UTS1 / Plug - UTS6 Fig. 10 0.118" Mated Connector Lengths 2.626" Fig. 11 3.055" 0.996" Ø1.185" UTS0 UTS7 3.216" 2.913" Fig. 12 Square Flange Receptacle - UTS0 Ø0.129" Drilling Pattern Jam Nut Receptacle - UTS7 22° Ø0.122" 68° 0.818" Rear mounting Ø0.877" 0.875" Ø0.866" 0.393" 0.122" 0.826" 0.818" Ø1.031" Front mounting Ø0.720" Hole size: 0.051" 0.122" Panel Cut Out Ø1.200" 0.122" 0.122" 30° Note: all dimensions are in inches 53 UTS Series | Connector 124 - 12E4/12D4 (Shell size 12, 3 + ground, 4x#16) Accessories and Tooling Jam Nut Sealing Caps IP68/69K Handle (without Head) Tool Kit Metal terminal IP68/69K Part number Part number Part number Part number UTS12DCG UTS12DCGR Shandles Toolkit Plug Sealing Cap IP68/69K Square Flange Sealing Cap Crimp Tooling (without Shandles) Metal terminal IP68/69K Part number Part number UTS612DCG UTS12DCGE Contacts Plastic Protective Cap Gasket IP68/69K Part numbers Receptacle cap Plug cap 85005587A 85005596 Part numbers UTFD13B Color Coding Rings G for Green Y for Yellow Part numbers R for Red Receptacles Plugs UTS712CCRR UTS612CCRR UTS712CCRY UTS612CCRY UTS712CCRG UTS612CCRG RM/RC 28M1K(1) RM/RC 24M9K(1) RM/RC 20M13K(1) RM/RC 20M12K(1) RM/RC 16M23K(1) RM/RC 14M30K(1) SM/SC 24ML1TK6(1) SM/SC 20ML1TK6(1) SM/SC 16ML1TK6(1) SM/SC 14ML1TK6(1) SM/SC 16ML11TK6(1) RMDXK10D28K RCDXK1D28K RM/RC DX60xxD28K RM/RC DXK10D28 + york090 RM/RC DX60xxD28 54 S16RCM20* S16RCM20* S16RCM20* S16RCM20* S16RCM16* S16RCM14* S16SCM20* S16SCM20* S16SCML1* S16SCML1* S16SCML11* Standard contacts #16 Ø 1.6 mm M10S1J with die set & stop bushing see page 202 to 205 Coaxial contacts (1): Example of plating, for other plating options see p. 168 * Heads to be used with handle PN: SHANDLES + Extraction tool #16 (RX2025GE1) see page 179. Dummy contact (SMSPKE0) see page 208. Part number of head Contact size Handle Coaxial contacts available see pages 167, 200 to 206 = Head Complete set 3 + ground 10A/500V UTS Series | Connector per UL 1977 124 - 12E4/12D4 (Shell size 12, 3 + ground, 4x#16) Contacts for 124 #16 Wire size Contact type Crimp Machined Stamped & Formed reeled contacts PCB Machined (3) Coaxial See note (2) for loose piece Cable Monocrimp Part number Fiber optic Handsolder Loaded in the connector RC28M1K(1) RC24M9K(1) RC20M13K(1) RC20M12K(1) RC16M23K(1) RC14M30K(1) 0.021" 0.039" 0.031" 0.062" 0.045" 0.070" 0.045" 0.086" 0.070" 0.125" 0.090" 0.125" SC24M1TK6 SC20M1TK6(1)(2) SC16M1TK6(1)(2) SC16M11TK6(1)(2) SC14M1TK6(1)(2) - 0.035"-0.062" - 0.047"-0.082" - 0.125" - 0.118" - 0.125" Male Female 30-28 0.50-0.08 26-24 0.13-0.20 22-20 0.32-0.52 22-20 0.32-0.52 20-16 0.52-1.31 16-14 1.31-2.08 RM28M1K(1) RM24M9K(1) RM20M13K(1) RM20M12K(1) RM16M23K(1) RM14M30K(1) 26-24 0.13-0.20 22-20 0.32-0.52 18-16 0.80-1.31 18-16 0.80-1.31 14 2.08 SM24M1TK6 SM20M1TK6(1)(2) SM16M1TK6(1)(2) SM16M11TK6(1)(2) SM14M1TK6(1)(2) - - RM20M12E83K(1) RC20M12E84K(1) - - RMDXK10D28 RMDX60xxD28 RMDXK10D28 + york090 RMDX60xxD28 RCDXK1D28 RCDX60xxD28 RCDXK1D28 + york090 RCDX60xxD28 - - - - - - - - RMPOF1000 RCPOF1000B - - - - see pages 167, 200 to 206 Twisted pair Monocrimp POF contacts (Plastic Optical Fiber) Max insulator Ø mm² Cable Multipiece Twisted pair Multipiece Max wire Ø AWG (1)(2) see page 170 14-18 2.08-0.80 (1)(2) 3+ (1): Example of plating, for other plating see page 168 (2): For loose piece contact packaging, place "L" in part number. Example: SM20ML1TK6 (3): For dimensions see page 168 Note: all dimensions are in inches #16 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 18 to 14 0.196" PCB Contacts for 12E4/12D4 Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 Electrical Characteristics UTS 124 - 12E4/12D4 Derating Curves Current (A) 30 UTS 124 UL 10A 500V UL94 V-0 CSA 7A 500V UL94 V-0 UTS 12E4/12D4 UL 10A 500V UL94 HB CSA 7A 500V UL94 HB 28 25 Test conditions Contact used: Machined contacts Wires used: 1.31mm² IEC 16A 300V 4kV 3 Temperature elevation: 50°C 23 20 18 15 13 10 8 5 3 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 55 UTS Series | Connector 183G1 (Shell size 18, 3 + ground, 4x#8) Layout WITH Connector Part Numbers Contact type Crimp contacts supplied separately see page 59 PCB contacts supplied separately see page 59 56 Connector type Backshell NPT 3/4" threaded receptacle Part number Male insert Female insert Without (Fig. 1) - UTS7183G1SNPT Plug Without (Fig. 2) UTS6183G1P - Plug Cable gland (Fig. 3) UTS6JC183G1P - NPT 3/4" threaded receptacle Without (Fig. 1) - UTS7183G1SNPT Plug Without (Fig. 2) UTS6183G1P - 3 + ground 44A/600V UTS Series | Connector per UL 1977 183G1 (Shell size 18, 3 + ground, 4x#8) Dimensions NPT Threaded Receptacle - UTS7 0.681" 0.570" 1.252" Ø0.771" Ø1.126" 3+ NPT - 3/4˝ Fig. 1 Plug - UTS6 3.200" Fig. 2 Fig. 3 Ø1.653" 1.476" Mated Connector Length - UTS6JC 3.563" NPT Drilling Pattern 0.200" 0.200" 0.200" Panel cut Hole size: 0.129" 1" 92 PT N 4 3/ 0.200" 0. Note: all dimensions are in inches 57 UTS Series | Connector 183G1 (Shell size 18, 3 + ground, 4x#8) Accessories and Tooling Jam Nut or NPT Threaded Receptacle Sealing Caps IP68/69K Hand Tool Metal terminal IP68/69K Part number Part number UTS18DCG UTS18DCGR Part number M317 Plug Sealing Cap Positioner + Locator Setting #8 IP68/69K Part number UTS618DCG Plastic Protective Cap Gasket Part number VGE10078A Extraction Tool #8 IP68/69K Part numbers Receptacle cap Plug cap 85005590A 85005599 Part numbers UTFD16B Color Coding Rings G for Green Y for Yellow 58 Part numbers R for Red Receptacles Plugs UTS718CCRR UTS618CCRR UTS718CCRY UTS618CCRY UTS718CCRG UTS618CCRG Part number 51060210936 3 + ground 44A/600V UTS Series | Connector per UL 1977 183G1 (Shell size 18, 3 + ground, 4x#8) Contacts PCB Crimp #8 Contact type Wire size Part number AWG mm² Male Female Max wire Ø 16 1.31 82913601A 82913600A 0.067" Machined Machined (1) 14 2.08 82913603A 82913602A 0.087" 12 3.31 82913605A 82913604A 0.111" 10 5.26 82913607A 82913606A 0.137" 8 8.37 82913609A 82913608A 0.171" - - 82911685NPC 82911684NPC - (1): For dimensions see page 168 Max insulator Ø 3+ 0.255" - Note: all dimensions are in inches Electrical Characteristics UTS 183G1 Derating Curves Current (A) 50 UL 44A 600V UL94 V-0 CSA 26A 600V UL94 V-0 IEC 32A 300V 4kV 3 45 40 Test conditions Contact used: Machined contacts Wires used: 6mm² 35 30 25 20 15 10 5 0 Current use 0 20 40 60 80 Ambient Operating Temperature (°C) Limited use 100 120 Not recommended use 59 UTS Series | Connector 8E4/8D4 (Shell size 8, 4x#20) Layout OR OR OR WITH Connector Part Numbers Contact type Handsolder electrical contacts loaded see page 63 PCB contacts loaded see page 63 Connector type Backshell Square flange receptacle Female insert Without (Fig. 1) UTS08E4P UTS08E4S Without (Fig. 7) UTS68E4P UTS68E4S Cable gland (Fig. 8) UTS6JC8E4P UTS6JC8E4S Jam nut receptacle Without (Fig. 4) UTS78E4P UTS78E4S M12 threaded receptacle Without (Fig. 3) UTS78E4PM12 UTS78E4SM12 Square flange receptacle Without (Fig. 2) UTS08D4P UTS08D4S Jam nut receptacle with stand off and with hold down clips Without (Fig. 6) UTS78D4P32 UTS78D4S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 5) UTS78D4P UTS78D4S Plug Possibilities of discrimination/keying methods see page 208 60 Part number Male insert Sealed unmated 4 contacts 7A/250V UTS Series | Connector per UL 1977 8E4/8D4 (Shell size 8, 4x#20) Dimensions Square Flange Receptacle - UTS0 0.295" Fig. 1 0.814" 0.090" Fig. 2 0.866" 0.303" Ø0.472" 0.342" 0.602" Ø0.472" 0.460" M12 Threaded Receptacle - UTS7 0.275" mini Ø0.125" 4 M12x1.5 0.196" Front view Fig. 3 Front view Jam Nut Receptacle - UTS7 0.145" mini 0.133" 0.133" 0.708" 0.708" 0.137" 0.952" 0.137" 0.137" Fig. 4 Fig. 5 Front view Fig. 6 Plug - UTS6 0.996" 0.165" Ø0.472" Ø0.472" Ø0.472" 0.708" 0.952" 0.133" Mated Connector Lengths Fig. 7 2.405" Ø0.885" UTS0 UTS7 2.622" 2.126" Fig. 8 Panel Cut Out Drilling Pattern Jam Nut Receptacle - UTS7 0.541" 0.602" 0.055" Ø0.129" Front mounting Ø0.492" 0.602" Rear mounting Ø0.570" 0.574" Ø0.122" Ø0.866" 15° Hole size: 0.035" 15° Ø0.157" Ø0.531" 0.055" Square Flange Receptacle - UTS0 Ø0.696" 0.055" 0.055" Note: all dimensions are in inches 61 UTS Series | Connector 8E4/8D4 (Shell size 8, 4x#20) Accessories Jam Nut or M12 Threaded Receptacle Sealing Caps IP68/69K IP68/69K Metal terminal Square Flange Sealing Cap IP68/69K Metal terminal IP40 Part number Part number Part number Part number UTS8DCG UTS8DCGR UTS8DCGE UTS68C Plastic Protective Cap Gasket Color Coding Rings G for Green Y for Yellow IP68/69K Part numbers 62 Plug Protective Cap Receptacle cap Plug cap 85005585A 85005594 Part numbers UTFD11B Part numbers R for Red Receptacles Plugs UTS78CCRR UTS68CCRR UTS78CCRY UTS68CCRY UTS78CCRG UTS68CCRG 4 contacts 7A/250V UTS Series | Connector per UL 1977 8E4/8D4 (Shell size 8, 4x#20) #20 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 22 to 18 0.196" PCB Contacts Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - 4 (1): For dimensions see page 169 Electrical Characteristics UTS 8E4/8D4 Derating Curves Current (A) 18 UL 7A 250V UL94 HB CSA 7A 250V UL94 HB IEC 7A 32V 1.5kV 3 16 14 Test conditions Contact used: Machined contacts Wires used: 0.518mm² 12 10 8 6 4 2 0 0 Current use 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 63 UTS Series | Connector 102W2 (Shell size 10, 2x#20, 2x#12) Layout WITH Connector Part Numbers Contact type Crimp contacts supplied separately see page 67 64 Connector type Backshell Free hanging receptacle Part number Male insert Female insert Cable gland (Fig. 1) UTS1JC102W2P UTS1JC102W2S Plug Without (Fig. 2) UTS6102W2P UTS6102W2S Plug Cable gland (Fig. 3) UTS6JC102W2P UTS6JC102W2S Jam nut receptacle Without (Fig. 4) UTS7102W2P UTS7102W2S 4 contacts 20A/500V UTS Series | Connector per UL 1977 102W2 (Shell size 10, 2x#20, 2x#12) Dimensions Free Hanging - UTS1 Ø0.594" 2.755" 4 Fig. 1 Plug - UTS6 0.996" 2.488" Ø1.031" Ø1.031" 1.299" Fig. 2 Male Fig. 2 Female Jam Nut Receptacle - UTS7 0.094" Mated Connector Length - UTS7 1.070" Ø0.594" 0.720" Fig. 3 Fig. 4 3.043" 0.885" Panel Cut Out Drilling Pattern 0.118" 0.137" 0.686" 0.118" 0.118" 0.118" 0.651" Jam Nut Receptacle - UTS7 Note: all dimensions are in inches 65 UTS Series | Connector 102W2 (Shell size 10, 2x#20, 2x#12) Accessories and Tooling Jam Nut Sealing Caps IP68/69K Crimp Tooling #20 Metal terminal IP68/69K Part number Part number Part number Part number UTS10DCG UTS10DCGR Shandles Toolkit Plug Sealing Cap Extraction Tool #20 IP68/69K Part number Part number UTS610DCG RX20D44 Plastic Protective Cap Gasket Contacts Part number of head Contact size RM/RC 24W3K(1) RM/RC 20W3K(1) RM/RC 18W3K(1) SM/SC 24WL3(1)(2) SM/SC 20WL3(1)(2) S20RCM* S20RCM* S20RCM* S20SCM20* S20SCM20* Standard contacts #20 Ø 1.0 mm (1): Example of plating, for other plating options see page 164 (2): loose contact * Heads to be used with handle PN: SHANDLES + IP68/69K Part numbers Receptacle cap Plug cap 85005586A 85005595 Part numbers Handle = Head Complete set UTFD12B Crimp Tooling #12 Extraction Tool #12 Color Coding Rings G for Green Y for Yellow Part numbers R for Red Receptacles Plugs UTS710CCRR UTS610CCRR UTS710CCRY UTS610CCRY UTS710CCRG UTS610CCRG Part number hand tool M317 51060210924 Part number positioner + locator setting VGE10078A 66 Part number extraction tool 4 contacts 20A/500V UTS Series | Connector per UL 1977 102W2 (Shell size 10, 2x#20, 2x#12) Contacts #20 Contact type Crimp Machined Stamped & Formed reeled contacts See note (2) for loose piece Wire size Part number AWG mm² Male Female Max wire Ø Max insulator Ø 26-24 0.13-0.20 RM24W3K RC24W3K 0.031" 0.062" 22-20 0.32-0.52 RM20W3K RC20W3K 0.045" 0.062" 20-18 0.52-0.80 RM18W3K RC18W3K 0.051" 0.082" 26-24 0.13-0.20 SM24W3TK6(1)(2) SC24W3TK6(1)(2) - 0.035"-0.062" 26-24 0.13-0.20 SM24W3S26 (1)(2) SC24W3S25 - 0.035"-0.062" 22-20 0.32-0.52 SM20W3TK6(1)(2) SC20W3TK6(1)(2) - 0.047"-0.082" 22-20 0.32-0.52 SM20W3S26(1)(2) SC20W3S25(1)(2) - 0.047"-0.082" 22 0.32 82911457NA 82911456A 0.034" (1)(2) Crimp #12 Machined 20 0.52 82911459NA 82911458A 0.044" 18 0.80 82911461NA 82911460A 0.055" 16 1.31 82911463NA 82911462A 0.067" 14 2.08 82911465NA 82911464A 0.087" 12 3.31 82911467NA 82911466A 0.111" (1): Example of plating, for other plating see page 164 (2): For loose piece contact packaging, place "L" in part number. Example: SM20WL3TK6 0.192" Note: all dimensions are in inches Electrical Characteristics UTS 102W2 Derating Curves Current (A) 50 UL 20A 500V UL94 V-0 CSA 18A 500V UL94 V-0 IEC 25A 150V 2.5kV 3 Temperature elevation: 50°C 45 40 Test conditions Contact used: Machined contacts Wires used: 0.518mm² 35 30 25 20 15 10 5 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 67 4 UTS Series | Connector 104 (Shell size 10, 4x#16) Layout OR OR OR OR WITH Connector Part Numbers Contact type Connector type Backshell Square flange receptacle Female insert Without (Fig. 1) UTS0104P UTS0104S Free hanging receptacle Cable gland and grommet* (Fig. 2) UTS1GJC104P - Free hanging receptacle Nut and grommet* (Fig. 3) UTS1GN104P - Free hanging receptacle Cable gland (Fig. 2) UTS1JC104P UTS1JC104S Plug Without (Fig. 4) UTS6104P UTS6104S Plug Cable gland and grommet* (Fig. 5) - UTS6GJC104S Plug Nut and grommet* (Fig. 6) - UTS6GN104S Crimp contacts supplied separately see page 71 PCB contacts supplied separately see page 71 Part number Male insert Plug Cable gland (Fig. 5) UTS6JC104P UTS6JC104S Jam nut receptacle Without (Fig. 7) UTS7104P UTS7104S Jam nut receptacle Cable gland and grommet* (Fig. 9) UTS7GJC104P - Jam nut receptacle Nut and grommet* (Fig. 8) UTS7GN104P - Jam nut receptacle Without (Fig. 7) UTS7104P UTS7104S Possibilities of discrimination/keying methods see page 208 * Grommet for discrete wire sealing Overmolded Cable Assembly Part Numbers Overmolding type Overmolded harnesses, straight ending Description Wire size Part number (length: 3 ft)* D/E assembly 1 male plug & 1 female plug 16 AWG UTS6V1004PS03FT00 S/E assembly 1 female plug 16 AWG UTS6V1004S03FT00 S/E assembly 1 male plug 16 AWG UTS6V1004P03FT00 * Other lengths available: 3, 6, 12 feet only: e.g. UTS6V1004PS06FT00 for a 6 feet version 68 4 contacts 10A/500V UTS Series | Connector per UL 1977 104 (Shell size 10, 4x#16) Dimensions Square Flange Receptacle - UTS0 0.413" Fig. 2 0.944" 0.090" 4 Ø0.125" Fig. 1 2.755" Ø0.594" 0.728" Ø0.594" 0.444" Free Hanging - UTS1 1.610" Front view Fig. 3 Plug - UTS6 1.299" 2.488" 1.279" Ø1.031" Male Female 0.996" Fig. 4 Fig. 5 Fig. 6 Jam Nut Receptacle - UTS7 0.720" 1.614" 0.720" 2.791" UTS0 Ø27.2 Ø0.594" 0.094" Mated Connector Lengths Fig. 8 UTS7 0.137" 0.137" Fig. 7 3.043" 2.783" Fig. 9 Panel Cut Out Square Flange Receptacle - UTS0 Drilling Pattern Hole size: 0.051" Jam Nut Receptacle - UTS7 Front mounting Ø0.598" 0.728" Rear mounting Ø0.704" Note: Overmolded cable assembly dimensions available page 179. 0.118" 0.118" 0.651" 0.728" Ø0.129" 0.686" 0.118" 0.118" Note: all dimensions are in inches 69 UTS Series | Connector 104 (Shell size 10, 4x#16) Accessories and Tooling Jam Nut Sealing Caps IP68/69K Handle (without Head) Tool Kit Metal terminal IP68/69K Part number Part number Part number Part number UTS10DCG UTS10DCGR Shandles Toolkit Plug Sealing Cap IP68/69K Square Flange Sealing Cap Crimp Tooling (without Shandles) Metal terminal IP68/69K Part number Part number UTS610DCG UTS10DCGE Contacts Plastic Protective Cap Gasket IP68/69K Part numbers Receptacle cap Plug cap 85005586A 85005595 Part numbers UTFD12B Color Coding Rings G for Green Y for Yellow Part numbers R for Red Receptacles Plugs UTS710CCRR UTS610CCRR UTS710CCRY UTS610CCRY UTS710CCRG UTS610CCRG RM/RC 28M1K(1) RM/RC 24M9K(1) RM/RC 20M13K(1) RM/RC 20M12K(1) RM/RC 16M23K(1) RM/RC 14M30K(1) SM/SC 24ML1TK6(1) SM/SC 20ML1TK6(1) SM/SC 16ML1TK6(1) SM/SC 14ML1TK6(1) SM/SC 16ML11TK6(1) RMDXK10D28K RCDXK1D28K RM/RC DX60xxD28K RM/RC DXK10D28 + york090 RM/RC DX60xxD28 70 S16RCM20* S16RCM20* S16RCM20* S16RCM20* S16RCM16* S16RCM14* S16SCM20* S16SCM20* S16SCML1* S16SCML1* S16SCML11* Standard contacts #16 Ø 1.6 mm M10S1J with die set & stop bushing see page 202 to 205 Coaxial contacts (1): Example of plating, for other plating options see p. 168 * Heads to be used with handle PN: SHANDLES + Extraction tool #16 (RX2025GE1) see page 179. Dummy contact (SMSPKE0) see page 208. Part number of head Contact size Handle = Head Complete set 4 contacts 10A/500V UTS Series | Connector per UL 1977 104 (Shell size 10, 4x#16) Contacts #16 Crimp Machined Stamped & Formed reeled contacts See note (2) for loose piece PCB Wire size Contact type Part number Coaxial Max wire Ø Max insulator Ø RM28M1K(1) RC28M1K(1) 0.021" 0.039" RM24M9K RC24M9K 0.031" 0.062" RM20M13K(1) RC20M13K(1) 0.045" 0.070" RM20M12K (1) RC20M12K 0.045" 0.086" RM16M23K(1) RC16M23K(1) 0.070" 0.125" RM14M30K RC14M30K 0.090" 0.125" SC24M1TK6(1)(2) - 0.035"-0.062" SM20M1TK6(1)(2) SC20M1TK6(1)(2) - 0.047"-0.082" - 0.125" - 0.118" (1)(2) mm² Male 30-28 0.50-0.08 26-24 0.13-0.20 22-20 0.32-0.52 22-20 0.32-0.52 20-16 0.52-1.50 16-14 1.31-2.08 26-24 0.13-0.20 SM24M1TK6(1)(2) 22-20 0.32-0.52 18-16 0.80-1.31 18-16 0.80-1.31 Machined (3) 14 2.08 - - Cable Multipiece Cable Monocrimp Twisted pair Multipiece see pages 167, 200 to 206 Twisted pair Monocrimp Fiber optic Female AWG POF contacts (Plastic Optical Fiber) see page 170 (1) (1) (1) (1) (1) SM16M1TK6 SC16M1TK6 SM16M11TK6(1)(2) SC16M11TK6(1)(2) SM14M1TK6 SC14M1TK6 - 0.125" RM20M12E83K(1) RC20M12E84K(1) - - RMDXK10D28 RCDXK1D28 - - RMDX60xxD28 RCDX60xxD28 - - RMDXK10D28 + york090 RCDXK1D28 + york090 - - RMDX60xxD28 RCDX60xxD28 - - RMPOF1000 RCPOF1000B - - (1)(2) (1)(2) (1)(2) (1): Example of plating, for other plating see page 164 (2): For loose piece contact packaging, place "L" in part number. Example: SM20ML1TK6 (3): For dimensions see page 168 4 Note: all dimensions are in inches Electrical Characteristics UTS 104 Derating Curves Current (A) 30 UL 10A 500V UL94 V-0 CSA 7A 500V UL94 V-0 IEC 13A 150V 2.5kV 3 28 25 Test conditions Contact used: Machined contacts Wires used: 1.31mm² 23 20 18 15 13 10 8 5 3 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 71 UTS Series | Connector 14E5/14D5 (Shell size 14, 5x#16) Layout OR OR WITH Connector Part Numbers Contact type Handsolder electrical contacts loaded see page 75 PCB contacts loaded see page 75 Connector type Backshell Square flange receptacle Female insert Without (Fig. 6) UTS014E5P UTS014E5S Without (Fig. 1) UTS614E5P UTS614E5S Cable gland (Fig. 2) UTS6JC14E5P UTS6JC14E5S Jam nut receptacle Without (Fig. 3) UTS714E5P UTS714E5S Square flange receptacle Without (Fig. 6) UTS014D5P UTS014D5S Jam nut receptacle with hold down clips Without (Fig. 5) UTS714D5P32 UTS714D5S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 4) UTS714D5P UTS714D5S Plug Possibilities of discrimination/keying methods see page 208 72 Part number Male insert Sealed unmated 5 contacts 12A/600V UTS Series | Connector per UL 1977 14E5/14D5 (Shell size 14, 5x#16) Dimensions Plug - UTS6 0.996" Ø1.381" 2.755" Fig. 1 5 Fig. 2 Jam Nut Receptacle - UTS7 0.188" mini 0.118" 0.118" 0.137" Fig. 3 0.708" 1.381" 0.137" 0.137" Fig. 4 Mated Connector Lengths 1.133" 2.952" 0.913" Ø0.877" 0.444" Front view Fig. 5 Square Flange Receptacle - UTS0 0.318" 0.295" mini 0.165" Ø0.877" Ø0.877" 0.708" Ø0.877" 0.708" 1.196" 0.118" UTS0 UTS7 3.228" Ø0.125" Fig. 6 Front view Panel Cut Out Square Flange Receptacle - UTS0 Ø0.129" Drilling Pattern Jam Nut Receptacle - UTS7 22° Ø0.122" 68° 0.950" 0.913" Rear mounting Ø0.988" Ø0.866" 0.393" 1.005" 0.145" 0.913" Ø1.031" Front mounting Ø0.846" Hole sizes: 0.051" 0.023" 0.098" 0.090" Ø1.200" 0.157" 0.090" 30° Note: all dimensions are in inches 73 UTS Series | Connector 14E5/14D5 (Shell size 14, 5x#16) Accessories and Tooling Jam Nut Sealing Caps IP68/69K IP68/69K Plug Sealing Cap Metal terminal IP68/69K Metal terminal IP68/69K Part number Part number Part number Part number UTS14DCG UTS14DCGR UTS614DCG UTS14DCGE Plastic Protective Cap Gasket Color Coding Rings G for Green Y for Yellow IP68/69K Part numbers 74 Square Flange Sealing Cap Receptacle cap Plug cap 85005588A 85005597 Part numbers UTFD14B Part numbers R for Red Receptacles Plugs UTS714CCRR UTS614CCRR UTS714CCRY UTS614CCRY UTS714CCRG UTS614CCRG 5 contacts 12A/600V UTS Series | Connector per UL 1977 14E5/14D5 (Shell size 14, 5x#16) #16 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 18 to 14 0.196" PCB Contacts Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 5 Electrical Characteristics UTS 14E5/14D5 Derating Curves Current (A) 30 UL 12A 600V UL94 HB CSA 12A 600V UL94 HB 25 Test conditions 20 15 Contact used: Machined contacts Wires used: 1.31mm² IEC 16A 150V 2.5kV 3 10 5 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 75 UTS Series | Connector 18X2M3 (Shell size 18, 3x#16, 2x#8) Layout OR OR WITH Connector Part Numbers Contact type Crimp contacts supplied separately see page 79 PCB contacts supplied separately see page 79 76 Connector type Backshell NPT 3/4" threaded receptacle Part number Male insert Female insert Without (Fig. 1) UTS718X2M3PNPT UTS718X2M3SNPT Plug Without (Fig. 2) UTS618X2M3P UTS618X2M3S Plug Cable gland (Fig. 3) UTS6JC18X2M3P UTS6JC18X2M3S NPT 3/4" threaded receptacle Without (Fig. 1) UTS718X2M3PNPT UTS718X2M3SNPT 5 contacts 44A/600V UTS Series | Connector per UL 1977 18X2M3 (Shell size 18, 3x#16, 2x#8) Dimensions NPT Threaded Receptacle - UTS7 0.566" 1.252" 1.252" Ø1.122" Ø0.767" 0.677" NPT - 3/4˝ 5 Fig. 1 Plug - UTS6 3.200" Ø1.563" Ø0.846" 1.460" Fig. 2 Fig. 3 Mated Connector Length - UTS6JC 3.563" Panel cut NPT " 21 9 PT #16 Hole sizes: 0.051" 0.232" #8 Hole sizes: 0.129" ˝ /4 -3 N 0.255" 0. Drilling Pattern Note: all dimensions are in inches 77 UTS Series | Connector 18X2M3 (Shell size 18, 3x#16, 2x#8) Accessories and Tooling Jam Nut or NPT Threaded Receptacle Sealing Caps IP68/69K Crimp Tooling #16 Metal terminal IP68/69K Part number Part number UTS18DCG UTS18DCGR Part number Part number Shandles Toolkit RX2025GE1 Plug Sealing Cap Dummy Contact #16 Contacts IP68/69K Part number Part number / Polyamide 6.6 UTS618DCG SMSPKE0 See page 208 for more information Plastic Protective Cap Extraction Tool RX2025GE1 51060210936 Part numbers Receptacle cap Plug cap 85005590A 85005599 Part numbers # 16 #8 RX2025GE1 51060210936 Y for Yellow 78 RM/RC 28M1K(1) RM/RC 24M9K(1) RM/RC 20M13K(1) RM/RC 20M12K(1) RM/RC 16M23K(1) RM/RC 14M30K(1) SM/SC 24ML1TK6(1) SM/SC 20ML1TK6(1) SM/SC 16ML1TK6(1) SM/SC 14ML1TK6(1) SM/SC 16ML11TK6(1) RMDXK10D28K RCDXK1D28K RM/RC DX60xxD28K RM/RC DXK10D28 + york090 RM/RC DX60xxD28 Part numbers R for Red S16RCM20* S16RCM20* S16RCM20* S16RCM20* S16RCM16* S16RCM14* S16SCM20* S16SCM20* S16SCML1* S16SCML1* S16SCML11* Standard contacts #16 Ø 1.6 mm Coaxial contacts M10S1J with die set & stop bushing see page 202 to 205 (1): Example of plating, for other plating options see p. 168 * Heads to be used with handle PN: SHANDLES Color Coding Rings G for Green Part number of head Contact size Receptacles Plugs UTS718CCRR UTS618CCRR UTS718CCRY UTS618CCRY UTS718CCRG UTS618CCRG Crimp Tooling #8 Part number hand tool Part number positioner + locator setting M317 VGE10078A 5 contacts 44A/600V UTS Series | Connector per UL 1977 18X2M3 (Shell size 18, 3x#16, 2x#8) Contacts #16 Contact type Crimp Machined Stamped & Formed reeled contacts PCB Machined (3) Coaxial See note (2) for loose piece Cable Monocrimp Wire size AWG Part number RC28M1K RC24M9K RC20M13K RC20M12K RC16M23K RC14M30K 0.021" 0.039" 0.031" 0.062" 0.045" 0.070" 0.045" 0.086" 0.070" 0.125" 0.090" 0.125" SC24M1TK6(1)(2) SC20M1TK6(1)(2) SC16M1TK6(1)(2) SC16M11TK6(1)(2) SC14M1TK6(1)(2) - 0.035"-0.062" - 0.047"-0.082" - 0.125" - 0.118" - 0.125" Female RM28M1K RM24M9K RM20M13K RM20M12K RM16M23K RM14M30K 30-28 0.50-0.08 26-24 0.13-0.20 22-20 0.32-0.52 22-20 0.32-0.52 20-16 0.52-1.31 16-14 1.31-2.08 26-24 0.13-0.20 22-20 0.32-0.52 18-16 0.80-1.31 18-16 0.80-1.31 14 2.08 SM24M1TK6(1)(2) SM20M1TK6(1)(2) SM16M1TK6(1)(2) SM16M11TK6(1)(2) SM14M1TK6(1)(2) - - RM20M12E83K(1) RC20M12E84K(1) - - RMDXK10D28 RMDX60xxD28 RMDXK10D28 + york090 RMDX60xxD28 RCDXK1D28 RCDX60xxD28 RCDXK1D28 + york090 RCDX60xxD28 - - - - - - - - RMPOF1000 RCPOF1000B - - see pages 167, 200 to 206 Twisted pair Monocrimp Fiber optic Max insulator Ø Male Cable Multipiece Twisted pair Multipiece Max wire Ø mm² POF contacts (Plastic Optical Fiber) see page 170 PCB Crimp #8 Machined Machined (3) 16 1.31 82913601A 82913600A 0.067" 14 2.08 82913603A 82913602A 0.087" 12 3.31 82913605A 82913604A 0.111" 10 5.26 82913607A 82913606A 0.137" 8 8.37 82913609A 82913608A 0.171" - - 82911685NPC(1) 82911684NPC(1) - 0.255" - (1): Example of plating, for other plating see page 168 (2): For loose piece contact packaging, place "L" in part number. Example: SM20ML1TK6 (3): For dimensions see page 168 Note: all dimensions are in inches Electrical Characteristics UTS 18X2M3 Derating Curves Current (A) 50 UL 44A 600V UL94 V-0 CSA 34A 600V UL94 V-0 IEC 32A 300V 4kV 3 45 40 Test conditions Contact used: Machined contacts Wires used: 8.37mm² 35 30 25 20 15 10 5 0 Current use 0 20 40 60 80 Ambient Operating Temperature (°C) Limited use 100 120 Not recommended use 79 5 UTS Series | Connector 103W3 (Shell size 10, 3x#20, 3x#16) Layout OR OR WITH Connector Part Numbers Contact type Crimp contacts supplied separately see page 83 PCB contacts supplied separately see page 83 80 Connector type Backshell Free hanging receptacle Part number Male insert Female insert Cable gland (Fig. 1) UTS1JC103W3P UTS1JC103W3S Plug Without (Fig. 2) UTS6103W3P UTS6103W3S Plug Cable gland (Fig. 3) UTS6JC103W3P UTS6JC103W3S Jam nut receptacle Without (Fig. 4) UTS7103W3P UTS7103W3S Jam nut receptacle with stand off and without hold down clips Without (Fig. 4) UTS7103W3P UTS7103W3S 6 contacts 10A/500V UTS Series | Connector per UL 1977 103W3 (Shell size 10, 3x#20, 3x#16) Dimensions Free Hanging - UTS1 Ø0.594" 2.755" Fig. 1 Plug - UTS6 6 0.996" 2.488" Ø1.031" Ø1.031" 1.299" Fig. 2 Male Fig. 2 Female Jam Nut Receptacle - UTS7 0.094" Mated Connector Length - UTS7 1.070" Ø0.594" 0.720" Fig. 3 3.043" Fig. 4 0.885" Drilling Pattern Hole sizes: #20:0.035" #16:0.051" 0.027" 0.651" Jam Nut Receptacle - UTS7 0.098" Panel Cut Out 0.031" 0.137" 0.686" 0.118" 0.098" Note: all dimensions are in inches 81 UTS Series | Connector 103W3 (Shell size 10, 3x#20, 3x#16) Accessories and Tooling Jam Nut Sealing Caps IP68/69K Part number Part number Part number Part number UTS10DCG UTS10DCGR Shandles Toolkit Plug Sealing Cap IP68/69K Square Flange Sealing Cap Part number UTS610DCG UTS10DCGE Plastic Protective Cap Gasket IP68/69K Part numbers Receptacle cap Plug cap 85005586A 85005595 Part numbers UTFD12B Color Coding Rings G for Green Part numbers R for Red Crimp Tooling Metal terminal IP68/69K Part number Receptacles Plugs UTS710CCRR UTS610CCRR UTS710CCRY UTS610CCRY UTS710CCRG UTS610CCRG Extraction tool #16 (RX2025GE1) see page 179. Dummy contact (SMSPKE0) see page 208. 82 Tool Kit Metal terminal IP68/69K Y for Yellow Handle Contacts RM/RC 28M1K RM/RC 24M9K RM/RC 20M13K RM/RC 20M12K RM/RC 16M23K RM/RC 14M30K SM/SC 24ML1TK6(1) SM/SC 20ML1TK6(1) SM/SC 16ML1TK6(1) SM/SC 14ML1TK6(1) SM/SC 16ML11TK6(1) RMDXK10D28 RCDXK1D28 RMDX60xxD28 RCDX60xxD28 RM/RC DXK10D28 + york090 RM/RC 24W3K(1) RM/RC 20W3K(1) RM/RC 18W3K(1) SM/SC 24WL3S SM/SC 20WL3S Contact size Standard contacts #16 Ø 1.6 mm Coaxial contacts Standard contacts #20 Ø 1.0 mm (1): Example of plating, for other plating see page 164 *: Heads to be used with handle PN: shandles Part number of head S16RCM20* S16RCM20* S16RCM20* S16RCM20* S16RCM16* S16RCM14* S16SCM20* S16SCM20* S16SCML1* S16SCML1* S16SCML11* M10S1J with die set & stop bushing see page 202 to 205 S20RCM* S20RCM* S20RCM* S20SCM20* S20SCM20* 6 contacts 10A/500V UTS Series | Connector per UL 1977 103W3 (Shell size 10, 3x#20, 3x#16) Contacts Contact type PCB Part number mm² Machined 30-28 26-24 22-20 22-20 20-16 16-14 Max insulator Ø 0.021" 0.031" 0.045" 0.045" 0.070" 0.090" 0.039" 0.062" 0.070" 0.086" 0.125" 0.125" SC24M1TK6(1)(2) SC20M1TK6(1)(2) SC16M1TK6(1)(2) SC16M11TK6(1)(2) SC14M1TK6(1)(2) - 0.035"-0.062" 0.047"-0.082" 0.125" 0.118" 0.125" RM20M12E83K(1) RC20M12E84K(1) - - RMDXK10D28 RMDX60xxD28 RMDXK10D28 + york090 RMDX60xxD28 RCDXK1D28 RCDX60xxD28 RCDXK1D28 + york090 RCDX60xxD28 - - - - - - RMPOF1000 RCPOF1000B - - 0.50-0.08 0.13-0.20 0.32-0.52 0.32-0.52 0.52-1.50 1.31-2.08 Female RC28M1K RC24M9K RC20M13K RC20M12K RC16M23K RC14M30K Stamped & Formed reeled contacts 26-24 22-20 18-16 18-16 14 0.13-0.20 0.32-0.52 0.80-1.31 0.80-1.31 2.08 SM24M1TK6(1)(2) SM20M1TK6(1)(2) SM16M1TK6(1)(2) SM16M11TK6(1)(2) SM14M1TK6(1)(2) Machined (3) - - Cable Multipiece Cable Monocrimp Twisted pair Multipiece see pages 167, 200 to 206 Twisted pair Monocrimp Fiber optic Max wire Ø Male RM28M1K RM24M9K RM20M13K RM20M12K RM16M23K RM14M30K See note (2) for loose piece Coaxial Wire size AWG Crimp #16 see page 170 POF contacts (Plastic Optical Fiber) 6 #20 Crimp Machined Stamped & Formed reeled contacts PCB See note (2) for loose piece Machined (3) 26-24 0.13-0.20 RM24W3K(1) RC24W3K(1) 0.031" 0.062" 22-20 0.32-0.52 RM20W3K (1) RC20W3K 0.045" 0.062" 20-18 0.50-0.93 RM18W3K(1) RC18W3K(1) 0.051" 0.082" 26-24 0.13-0.20 SM24W3TK6(2) SC24W3TK6(2) - 0.035"-0.062" 26-24 0.13-0.20 SM24W3S26(2) SC24W3S25(2) - 0.035"-0.062" 22-20 0.32-0.52 SM20W3TK6 SC20W3TK65 - 0.047"-0.082" 22-20 0.32-0.52 SM20W3S26(2) SC20W3S25(2) - 0.047"-0.082" - - RMW5016K RCW5016K - - (1) (2) (2) (1): Example of plating, for other plating see page 168 (2): For loose piece contact packaging, place "L" in part number. Example: SM20ML1TK6 (3): For dimensions see page 168 Note: all dimensions are in inches Electrical Characteristics UTS 103W3 Derating Curves Current (A) UL 10A 500V UL94 V-0 CSA 7A 500V UL94 V-0 IEC 5A 32V 1.5kV 3 Temperature elevation: 50°C 30 28 Test conditions Contact used: Machined contacts Wires used: 1.31mm² 0.518mm² 25 23 20 18 15 13 10 8 5 3 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 83 UTS Series | Connector 106 - 10E6/10D6 (Shell size 10, 6x#20) Layout OR OR OR OR WITH Connector Part Numbers Contact type Crimp contacts supplied separately see page 87 PCB contacts supplied separately see page 87 Handsolder electrical contacts loaded see page 87 Handsolder electrical contacts loaded see page 87 PCB contacts loaded see page 87 Connector type Backshell Free hanging receptacle Cable gland (Fig. 1) Female insert UTS1JC106S UTS6106S UTS6JC106S UTS7106S Plug Without (Fig. 2) Plug Cable gland (Fig. 3) Jam nut receptacle Without (Fig. 4) UTS1JC106P UTS6106P UTS6JC106P UTS7106P Jam nut receptacle Without (Fig. 4) UTS7106P UTS7106S Square flange receptacle Without (Fig. 10) UTS010E6S UTS610E6S UTS6JC10E6S UTS710E6S UTS710E6SM16 Jam nut receptacle Without (Fig. 5) UTS010E6P UTS610E6P UTS6JC10E6P UTS710E6P M16 threaded receptacle Without (Fig. 8) UTS710E6PM16 Square flange receptacle Without (Fig. 9) UTS010D6P UTS010D6S Jam nut receptacle with stand off and with hold down clips Without (Fig. 7) UTS710D6P32 UTS710D6S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 6) UTS710D6P UTS710D6S Plug Possibilities of discrimination/keying methods see page 208 84 Part number Male insert Without (Fig. 2) Cable gland (Fig. 3) Sealed unmated 6 contacts 6A/250V UTS Series | Connector per UL 1977 106 - 10E6/10D6 (Shell size 10, 6x#20) Dimensions Free Hanging - UTS1 Plug - UTS6 1.299" 2.755" 2.488" Ø1.031" Ø0.594" Male Female 0.996" Fig. 1 Fig. 2 M16 Threaded Receptacle - UTS7 Jam Nut Receptacle - UTS7 0.094" 0.720" 1.070" 0.118" M16x0.059" 0.137" 0.165" Fig. 7 Fig. 5 Front view Square Flange Receptacle - UTS0 Fig. 9 0.295" 0.318" 0.444" mini Fig. 8 2.791" UTS0 UTS7 3.043" Ø0.125" Front view Panel Cut Out Square Flange Receptacle - UTS0 Ø0.129" Drilling Pattern Jam nut receptacle UTS7 M16 Chf.45°x0.104" Ø0.122" 59 " x0 .0 16 Hole size: 0.035" 15° Ø0.531" Ø0.157" 0.129" Rear mounting Ø0.704" 68 0. 15° M Front mounting Ø0.598" 6" 0.651" 0.728" Ø0.696" 0.728" Front view Mated Connector Lengths 0.728" Fig. 10 0.547" 0.944" Ø0.594" 0.090" 0.944" 0.196" 0.062" 0.137" 0.846" 0.885" mini Ø0.594" 0.720" 0.185" Ø0.594" Fig. 4 Fig. 6 Fig. 3 Ø0.866" 0.771" 0.110" Note: all dimensions are in inches 85 6 UTS Series | Connector 106 - 10E6/10D6 (Shell size 10, 6x#20) Accessories and Tooling Jam Nut or M16 Threaded Receptacle Sealing Caps IP68/69K Handle (without Head) Tool Kit Metal terminal IP68/69K Part number Part number Part number Part number UTS10DCG UTS10DCGR Shandles Toolkit Plug Sealing Cap IP68/69K Square Flange Sealing Cap Metal terminal IP68/69K Part number Part number UTS610DCG UTS10DCGE Plastic Protective Cap Gasket Receptacle cap Plug cap 85005586A 85005595 Contacts RM/RC RM/RC RM/RC SM/SC SM/SC IP68/69K Part numbers Crimp Tooling (without Shandles) Part numbers UTFD12B Part number of head Contact size 24W3K(1) 20W3K(1) 18W3K(1) 24WL3S 20WL3S S20RCM* S20RCM* S20RCM* S20SCM20* S20SCM20* Standard contacts #20 Ø 1.0 mm (1): Example of plating, for other plating see page 164 *: Heads to be used with handle PN: shandles + Handle = Head Complete set Color Coding Rings G for Green Y for Yellow 86 Part numbers R for Red Receptacles Plugs UTS710CCRR UTS610CCRR UTS710CCRY UTS610CCRY UTS710CCRG UTS610CCRG Extraction Tool #20 Part number RX20D44 6 contacts 6A/250V UTS Series | Connector per UL 1977 106 - 10E6/10D6 (Shell size 10, 6x#20) Contacts for 106 #20 Wire size Contact type Crimp Machined Stamped & Formed reeled contacts PCB See note (2) for loose piece Part number Female Max wire Ø Max insulator Ø RM24W3K(1) RC24W3K(1) 0.031" 0.062" 0.32-0.52 RM20W3K (1) RC20W3K 0.045" 0.062" 0.52-0.80 RM18W3K(1) RC18W3K(1) 0.051" 0.082" 0.13-0.20 SM24W3TK6(2) SC24W3TK6(2) - 0.035"-0.062" 26-24 0.13-0.20 SM24W3S26 (2) SC24W3S25 - 0.035"-0.062" 22-20 0.32-0.52 SM20W3TK6(2) SC20W3TK6(2) - 0.047"-0.082" 22-20 0.32-0.52 SM20W3S26 SC20W3S25 - 0.047"-0.082" - - RMW5016K RCW5016K - - AWG mm² Male 26-24 0.13-0.20 22-20 20-18 26-24 Machined (3) (1) (2) (2) (2) (1): Example of plating, for other plating see page 164 (2): For loose piece contact packaging, place "L" in part number. Example: SM20WL3TK6 (3): For dimensions see page 168 Note: all dimensions are in inches #20 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 22 to 18 0.196" PCB Contacts for 10E6/10D6 Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 Electrical Characteristics UTS 106 - 10E6/10D6 Derating Curves Current (A) UTS 106 UL 5A 250V UL94 V-0 UTS 10E6/10D6 UL 6A 250V UL94 HB CSA 4A 250V UL94 V-0 CSA 6A 250V UL94 HB Test conditions Contact used: Machined contacts Wires used: 0.518mm² IEC 7A 32V 1.5kV 3 Current use 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 87 6 UTS Series | Connector 10E98/10D98 (Shell size 10, 6x#20) Layout OR OR WITH Connector Part Numbers Contact type Handsolder electrical contacts loaded see page 91 PCB contacts loaded see page 91 Connector type Backshell Square flange receptacle Female insert Without (Fig. 6) UTS010E98P UTS010E98S Without (Fig. 1) UTS610E98P UTS610E98S Cable gland (Fig. 2) UTS6JC10E98P UTS6JC10E98S Jam nut receptacle Without (Fig. 3) UTS710E98P UTS710E98S Square flange receptacle Without (Fig. 7) UTS010D98P UTS010D98S Jam nut receptacle with stand off and with hold down clips Without (Fig. 4) UTS710D98P32 UTS710D98S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 5) UTS710D98P UTS710D98S Plug Possibilities of discrimination/keying methods see page 208 88 Part number Male insert Sealed unmated 6 contacts 6A/250V UTS Series | Connector per UL 1977 10E98/10D98 (Shell size 10, 6x#20) Dimensions Plug - UTS6 2.755" Ø1.031" 0.996" Fig. 1 Fig. 2 Jam Nut Receptacle - UTS7 0.118" 0.165" 0.720" 0.137" 0.720" 0.137" Fig. 3 0.137" Square Flange Receptacle - UTS0 Mated Connector Lengths 0.944" 2.791" UTS0 0.728" Ø0.594" Fig. 6 UTS7 3.043" Ø0.125" Front view Panel Cut Out Square Flange Receptacle - UTS0 Drilling Pattern Jam Nut Receptacle - UTS7 Ø0.129" 22° Ø0.122" 68° Front mounting Ø0.598" 0.728" Rear mounting Ø0.704" 0.686" Ø0.531" 0.393" 0.110" 0.651" 0.728" Ø0.696" Hole size: 0.035" 0.129" 0.090" Front view Fig. 5 Fig. 4 Fig. 7 0.295"0.318" 0.444" mini 6 0.881" 1.070" Ø0.594" Ø0.594" Ø0.594" 0.720" 0.185" mini 0.118" 0.118" Ø0.866" 0.129" 0.062" 30° Note: all dimensions are in inches 89 UTS Series | Connector 10E98/10D98 (Shell size 10, 6x#20) Accessories and Tooling Jam Nut Sealing Caps IP68/69K IP68/69K Plug Protective Cap Metal terminal IP68/69K Metal terminal IP68/69K Part number Part number Part number Part number UTS10DCG UTS10DCGR UTS610DCG UTS10DCGE Plastic Protective Cap Gasket Color Coding Rings G for Green Y for Yellow IP68/69K Part numbers 90 Square Flange Sealing Cap Receptacle cap Plug cap 85005586A 85005595 Part numbers UTFD12B Part numbers R for Red Receptacles Plugs UTS710CCRR UTS610CCRR UTS710CCRY UTS610CCRY UTS710CCRG UTS610CCRG 6 contacts 6A/250V UTS Series | Connector per UL 1977 10E98/10D98 (Shell size 10, 6x#20) #20 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 22 to 18 0.196" PCB Contacts Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 6 Electrical Characteristics UTS 10E98/10D98 Derating Curves Current (A) UL 6A 250V UL94 HB CSA 6A 250V UL94 HB Test conditions Contact used: Machined contacts Wires used: 0.518mm² IEC 7A 50V 1.5kV 3 Current use 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 91 UTS Series | Connector 147 - 14E7/14D7 (Shell size 14, 6 + ground, 7x#16) Layout OR OR OR OR OR WITH Connector Part Numbers Contact type Backshell Square flange receptacle Without (Fig. 1) Free hanging receptacle Cable gland and grommet* (Fig. 4) Free hanging receptacle Nut and grommet* (Fig. 5) Free hanging receptacle Cable gland (Fig. 4) Part number Male insert Female insert UTS0147S UTS1JC147S UTS6147S UTS6GJC147S UTS6GN147S UTS6JC147S UTS7147S - Jam nut receptacle Nut and grommet* (Fig. 10) UTS0147P UTS1GJC147P UTS1GN147P UTS1JC147P UTS6147P UTS6JC147P UTS7147P UTS7GJC147P UTS7GN147P PCB contacts supplied separately see page 95 Jam nut receptacle with stand off and hold down clips Without (Fig. 12) UTS7147PSEK9 - Screw contacts loaded Jam nut receptacle Without (Fig. 9) Free hanging receptacle Cable gland (Fig. 4) Plug Cable gland (Fig. 6) UTS7147SSCR UTS6JC147SSCR UTS014E7S UTS6JC14E7S UTS714E7S UTS014D7S Crimp contacts supplied separately see page 95 Plug Without (Fig. 6) Plug Cable gland and grommet* (Fig. 7) Plug Nut and grommet* (Fig. 8) Plug Cable gland (Fig. 7) Jam nut receptacle Without (Fig. 9) Jam nut receptacle Cable gland and grommet* (Fig. 11) Handsolder electrical contacts loaded see page 95 Square flange receptacle Without (Fig. 3) Plug Cable gland (Fig. 7) Jam nut receptacle Without (Fig. 9) Square flange receptacle Without (Fig. 2) UTS7147PSCR UTS1JC147PSCR UTS6JC147PSCR UTS014E7P UTS6JC14E7P UTS714E7P UTS014D7P PCB contacts loaded see page 95 Jam nut receptacle with stand off and hold down clips Without (Fig. 12) UTS714D7P32 UTS714D7S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 12) UTS714D7P UTS714D7S * Grommet for discrete wire sealing 92 Connector type Sealed unmated 6 + ground 10A/500V UTS Series | Connector per UL 1977 147 - 14E7/14D7 (Shell size 14, 6 + ground, 7x#16) Dimensions Square Flange Receptacle - UTS0 Fig. 2 0.444" 0.862" 0.444" 1.145" 1.133" Female 0.913" Ø0.877" Ø0.877" Male 0.413" 0.090" 0.090" 0.866" Ø0.125" Front view Fig. 3 Fig. 1 Free Hanging - UTS1 Fig. 4 Plug - UTS6 3.090" 6+ Fig. 7 2.755" 1.299" Ø0.877" Ø1.381" Male Female 0.996" 1.692" Fig. 6 Fig. 5 Jam Nut Receptacle - UTS7 Fig. 10 1.929" 0.708" 2.952" UTS0 Ø31.8 UTS7 0.165" 0.137" Fig. 8 Mated Connector Lengths Ø0.877" Fig. 9 0.708" 0.062" 1.259" 0.137" 0.118" 3.228" 2.783" Fig. 11 Fig. 12 Panel Cut Out Square Flange Receptacle - UTS0 Drilling Pattern Hole size: 0.051" Jam Nut Receptacle - UTS7 Ø0.122" Ø0.129" Ø0.696" Front mounting Ø0.846" 0.913" Rear mounting Ø0.988" 1.005" 0.393" 0.204" 0.950" 0.913" Ø0.531" Ø0.866" 0.251" 0.125" Note: all dimensions are in inches 93 UTS Series | Connector 147 - 14E7/14D7 (Shell size 14, 6 + ground, 7x#16) Accessories and Tooling Jam Nut Sealing Caps IP68/69K Handle (without Head) Tool Kit Metal terminal IP68/69K Part number Part number Part number Part number UTS14DCG UTS14DCGR Shandles Toolkit Plug Sealing Cap IP68/69K Square Flange Sealing Cap Crimp Tooling (without Shandles) Metal terminal IP68/69K Part number Part number UTS614DCG UTS14DCGE Contacts Plastic Protective Cap Gasket IP68/69K Part numbers Receptacle cap Plug cap 85005588A 85005597 Part numbers UTFD14B Color Coding Rings G for Green Y for Yellow Part numbers R for Red Receptacles Plugs UTS714CCRR UTS614CCRR UTS714CCRY UTS614CCRY UTS714CCRG UTS614CCRG RM/RC 28M1K(1) RM/RC 24M9K(1) RM/RC 20M13K(1) RM/RC 20M12K(1) RM/RC 16M23K(1) RM/RC 14M30K(1) SM/SC 24ML1TK6(1) SM/SC 20ML1TK6(1) SM/SC 16ML1TK6(1) SM/SC 14ML1TK6(1) SM/SC 16ML11TK6(1) RMDXK10D28K RCDXK1D28K RM/RC DX60xxD28K RM/RC DXK10D28 + york090 RM/RC DX60xxD28 94 S16RCM20* S16RCM20* S16RCM20* S16RCM20* S16RCM16* S16RCM14* S16SCM20* S16SCM20* S16SCML1* S16SCML1* S16SCML11* Standard contacts #16 Ø 1.6 mm M10S1J with die set & stop bushing see page 202 to 205 Coaxial contacts (1): Example of plating, for other plating options see page 164 * Heads to be used with handle PN: SHANDLES + Extraction tool #16 (RX2025GE1) see page 179. Dummy contact (SMSPKE0) see page 208. Part number of head Contact size Handle = Head Complete set 6 + ground 10A/500V UTS Series | Connector per UL 1977 147 - 14E7/14D7 (Shell size 14, 6 + ground, 7x#16) Contacts for 147 #16 Wire size Contact type Crimp Machined Stamped & Formed reeled contacts PCB See note (2) for loose piece Machined (3) Part number Coaxial 0.021" 0.039" 0.031" 0.062" 0.045" 0.070" 0.045" 0.086" 0.070" 0.125" 0.090" 0.125" SC24M1TK6 SC20M1TK6(1)(2) SC16M1TK6(1)(2) SC16M11TK6(1)(2) SC14M1TK6(1)(2) - 0.035"-0.062" - 0.047"-0.082" - 0.125" - 0.118" - 0.125" Female 30-28 0.50-0.08 26-24 0.13-0.20 22-20 0.32-0.52 22-20 0.32-0.52 20-16 0.52-1.31 16-14 1.31-2.08 RM28M1K(1) RM24M9K(1) RM20M13K(1) RM20M12K(1) RM16M23K(1) RM14M30K(1) 26-24 0.13-0.20 22-20 0.32-0.52 18-16 0.80-1.31 18-16 0.80-1.31 14 2.08 SM24M1TK6 SM20M1TK6(1)(2) SM16M1TK6(1)(2) SM16M11TK6(1)(2) SM14M1TK6(1)(2) - - RM20M12E83K(1) RC20M12E84K(1) - - RMDXK10D28 RMDX60xxD28 RMDXK10D28 + york090 RMDX60xxD28 RCDXK1D28 RCDX60xxD28 RCDXK1D28 + york090 RCDX60xxD28 - - - - - - - - RMPOF1000 RCPOF1000B - - Twisted pair Monocrimp Fiber optic RC28M1K(1) RC24M9K(1) RC20M13K(1) RC20M12K(1) RC16M23K(1) RC14M30K(1) Male see pages 167, 200 to 206 Twisted pair Multipiece Max insulator Ø mm² Cable Multipiece Cable Monocrimp Max wire Ø AWG POF contacts (Plastic Optical Fiber) (1)(2) see page 170 (1)(2) 6+ (1): Example of plating, for other plating see page 168 (2): For loose piece contact packaging, place "L" in part number. Example: SM20ML1TK6 (3): For dimensions see page 168 Note: all dimensions are in inches #16 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 18 to 14 0.196" PCB Contacts for 14E7/14D7 Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 Electrical Characteristics UTS 147 - 14E7/14D7 Derating Curves Current (A) 30 UTS 147 UL 10A 500V UL94 V-0 UTS 14E7/14D7 UL 10A 500V UL94 HB CSA 7A 500V UL94 V-0 CSA 7A 500V UL94 HB 28 25 Test conditions Contact used: Machined contacts Wires used: 1.31mm² IEC 16A 300V 4kV 3 Temperature elevation: 50°C 23 20 18 15 13 10 8 5 3 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 95 UTS Series | Connector 10E7/10D7 (Shell size 10, 7x#20) Layout OR OR OR WITH Connector Part Numbers Contact type Handsolder electrical contacts loaded see page 99 PCB contacts loaded see page 99 Connector type Backshell Square flange receptacle Female insert Without (Fig. 1) UTS010E7P UTS010E7S Without (Fig. 2) UTS610E7P UTS610E7S Cable gland (Fig. 3) UTS6JC10E7P UTS6JC10E7S Jam nut receptacle Without (Fig. 4) UTS710E7P UTS710E7S M16 threaded receptacle Without (Fig. 7) Square flange receptacle Without (Fig. 1) UTS010D7P UTS010D7S Jam nut receptacle with stand off and hold down clips Without (Fig. 5) UTS710D7P32 UTS710D7S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 6) UTS710D7P UTS710D7S Plug Possibilities of discrimination/keying methods see page 208 96 Part number Male insert UTS710E7PM16 UTS710E7SM16 Sealed unmated 7 contacts 6A/250V UTS Series | Connector per UL 1977 10E7/10D7 (Shell size 10, 7x#20) Dimensions Square Flange Receptacle - UTS0 0.444" Plug - UTS6 0.944" 0.295" 0.996" 2.755" 0.090" Ø1.031" 0.728" Ø0.594" 0.318" mini Ø0.125" Fig. 1 Fig. 2 Front view Fig. 3 Jam Nut Receptacle - UTS7 0.185" 0.118" 0.137" 0.137" Fig. 4 Fig. 5 0.137" 0.165" Front view Fig. 6 M16 Threaded Receptacle - UTS7 0.846" 7 1.070" Ø0.594" 0.720" Ø0.594" 0.720" Ø0.594" 0.720" 0.881" 0.118" mini Mated Connector Lengths 0.944" 2.791" Ø0.594" UTS0 UTS7 0.196" 3.043" Fig. 7 0.728" Rear mounting Ø0.704" Ø0.122" Ø0.866" 15° Hole size: 0.035" 15° 16 x0 .0 59 " M16 Chf.45°x0.104" M " 86 6 0. 0.651" 0.728" Front mounting Ø0.598" Drilling Pattern Jam nut receptacle UTS7 0.062" Panel Cut Out Square Flange Receptacle - UTS0 Ø0.129" Ø0.157" Ø0.531" 0.129" 0.547" M16x0.059" Ø0.696" 0.771" 0.110" Note: all dimensions are in inches 97 UTS Series | Connector 10E7/10D7 (Shell size 10, 7x#20) Accessories and Tooling Jam Nut or M16 Threaded Receptacle Sealing Caps IP68/69K IP68/69K Metal terminal Plug Sealing Cap IP68/69K Metal terminal IP68/69K Part number Part number Part number Part number UTS10DCG UTS10DCGR UTS610DCG UTS10DCGE Plastic Protective Cap Gasket Color Coding Rings G for Green Y for Yellow IP68/69K Part numbers 98 Square Flange Sealing Cap Receptacle cap Plug cap 85005586A 85005595 Part numbers UTFD12B Part numbers R for Red Receptacles Plugs UTS710CCRR UTS610CCRR UTS710CCRY UTS610CCRY UTS710CCRG UTS610CCRG 7 contacts 6A/250V UTS Series | Connector per UL 1977 10E7/10D7 (Shell size 10, 7x#20) #20 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 22 to 18 0.196" PCB Contacts Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 7 Electrical Characteristics UTS 10E7/10D7 Derating Curves Current (A) UL 6A 250V UL94 HB CSA 6A 250V UL94 HB IEC 7A 50V 1.5kV 3 Test conditions Contact used: Machined contacts Wires used: 0.518mm² Current use 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 99 contacts loaded see page UTS Series | Connector 128 (Shell size 12, 8x#16) Layout OR OR OR OR OR OR WITH Connector Part Numbers Contact type Connector type Backshell Female insert Without (Fig. 1) UTS0128P UTS0128S Cable gland and grommet* (Fig. 2) UTS1GJC128P - Nut and grommet* (Fig. 3) UTS1GN128P - Gasket and nut (Fig. 8) Gasket (Fig. 9) UTS7128PM20NUT UTS7128PM20 UTS7128SM20NUT UTS7128SM20 Cable gland (Fig. 2) UTS1JC128P UTS1JC128S Plug Without (Fig. 10) UTS6128P UTS6128S Plug Cable gland and grommet* (Fig. 11) - UTS6GJC128S Plug Nut and grommet* (Fig. 12) - UTS6GN128S Plug Cable gland (Fig. 11) UTS6JC128P UTS6JC128S Without (Fig. 4) UTS7128P UTS7128S Cable gland and grommet* (Fig. 7) UTS7GJC128P - Nut and grommet* (Fig. 6) UTS7GN128P - Without (Fig. 5) UTS7128PSEK9 - Square flange receptacle Free hanging receptacle Free hanging receptacle M20 threaded receptacle Crimp contacts supplied separately see page 103 Part number Male insert Free hanging receptacle Jam nut receptacle Jam nut receptacle Jam nut receptacle PCB Jam nut receptacle with contacts loaded see page 103 stand off and hold down clips Possibilities of discrimination/keying methods see page 208 * Grommet for discrete wire sealing Overmolded Cable Assembly Part Numbers Overmolding type Overmolded harnesses, straight ending Description Wire size Part number (length: 3 ft)* D/E assembly 1 male plug & 1 female plug 16 AWG UTS6V1208PS03FT00 S/E assembly 1 female plug 16 AWG UTS6V1208S03FT00 S/E assembly 1 male plug 16 AWG UTS6V1208P03FT00 * Other lengths available: 3, 6, 12 feet only: e.g. UTS6V128PS06FT00 for a 6 feet version 100 8 contacts 10A/500V UTS Series | Connector per UL 1977 128 (Shell size 12, 8x#16) Dimensions Square Flange Receptacle - UTS0 0.712" Fig. 2 0.818" 0.413" 0.090" Fig. 1 Ø0.125" 2.933" Ø0.751" 1.039" Ø0.751" 0.444" Free Hanging - UTS1 1.610" Front view Fig. 3 Jam Nut & M20 Threaded Receptacle - UTS7 0.062" 0.708" 1.933" 1.000" Ø0.751" 8 0.165" 0.137" 0.137" 0.118" 0.767" 2.933" Fig.7 Fig. 9 Plug - UTS6 1.259" M20X0.059" Mated Connector Lengths Fig. 11 2.586" 1.299" 1.063" Ø1.255" Fig. 4 Fig. 5 0.240" Panel gasket Fig. 8 Fig. 6 Ø0.751" 0.708" 3.055" UTS0 Female UTS7 0.996" 3.216" 1.299" Fig. 12 Panel Cut Out Drilling Pattern Jam Nut Receptacle - UTS7 Front mounting Ø0.720" 0.818" Rear mounting Ø0.877" Note: Overmolded cable assembly dimensions available page 179. 0.078" 0.177" 0.157" 0.826" 0.818" Square Flange Receptacle - UTS0 Ø0.129" Hole size: 0.051" 0.035" Fig. 10 0.110" Ø1.185" Male 0.875" 0.173" 0.133" Note: all dimensions are in inches 101 UTS Series | Connector 128 (Shell size 12, 8x#16) Accessories and Tooling Jam Nut or M20 Threaded Receptacle Sealing Caps IP68/69K Handle (without Head) Tool Kit Metal terminal IP68/69K Part number Part number Part number Part number UTS12DCG UTS12DCGR Shandles Toolkit Plug Sealing Cap IP68/69K Square Flange Sealing Cap Crimp Tooling (without Shandles) Metal terminal IP68/69K Part number Part number UTS612DCG UTS12DCGE Contacts Plastic Protective Cap Gasket IP68/69K Part numbers Receptacle cap Plug cap 85005587A 85005596 Part numbers UTFD13B Color Coding Rings G for Green Y for Yellow Part numbers R for Red Receptacles Plugs UTS712CCRR UTS612CCRR UTS712CCRY UTS612CCRY UTS712CCRG UTS612CCRG RM/RC 28M1K(1) RM/RC 24M9K(1) RM/RC 20M13K(1) RM/RC 20M12K(1) RM/RC 16M23K(1) RM/RC 14M30K(1) SM/SC 24ML1TK6(1) SM/SC 20ML1TK6(1) SM/SC 16ML1TK6(1) SM/SC 14ML1TK6(1) SM/SC 16ML11TK6(1) RMDXK10D28K RCDXK1D28K RM/RC DX60xxD28K RM/RC DXK10D28 + york090 RM/RC DX60xxD28 102 S16RCM20* S16RCM20* S16RCM20* S16RCM20* S16RCM16* S16RCM14* S16SCM20* S16SCM20* S16SCML1* S16SCML1* S16SCML11* Standard contacts #16 Ø 1.6 mm M10S1J with die set & stop bushing see page 202 to 205 Coaxial contacts (1): Example of plating, for other plating options see page 164 * Heads to be used with handle PN: SHANDLES + Extraction tool #16 (RX2025GE1) see page 179. Dummy contact (SMSPKE0) see page 208. Part number of head Contact size Handle = Head Complete set 8 contacts 10A/500V UTS Series | Connector per UL 1977 128 (Shell size 12, 8x#16) Contacts #16 Contact type Crimp Machined Stamped & Formed reeled contacts Part number Female Max wire Ø Max insulator Ø RM28M1K(1) RC28M1K(1) 0.021" 0.039" RM24M9K RC24M9K 0.031" 0.062" RM20M13K(1) RC20M13K(1) 0.045" 0.070" RM20M12K (1) RC20M12K 0.045" 0.086" RM16M23K(1) RC16M23K(1) 0.070" 0.125" RM14M30K RC14M30K 0.090" 0.125" SC24M1TK6(1)(2) - 0.035"-0.062" SM20M1TK6(1)(2) SC20M1TK6(1)(2) - 0.047"-0.082" - 0.125" - 0.118" (1)(2) AWG mm² Male 30-28 0.50-0.08 26-24 0.13-0.20 22-20 0.32-0.52 22-20 0.32-0.52 20-16 0.52-1.31 16-14 1.31-2.08 26-24 0.13-0.20 SM24M1TK6(1)(2) 22-20 0.32-0.52 18-16 0.80-1.31 18-16 0.80-1.31 2.08 - - (1) (1) (1) (1) SM16M1TK6 SC16M1TK6 SM16M11TK6(1)(2) SC16M11TK6(1)(2) SM14M1TK6 SC14M1TK6 - 0.125" RM20M12E83K(1) RC20M12E84K(1) - - (1)(2) (1)(2) (1)(2) PCB 14 (1) Machined (3) Cable Multipiece RMDXK10D28 RCDXK1D28 - - Coaxial See note (2) for loose piece Wire size Cable Monocrimp RMDX60xxD28 RCDX60xxD28 - - RMDXK10D28 + york090 RCDXK1D28 + york090 - - RMDX60xxD28 RCDX60xxD28 - - RMPOF1000 RCPOF1000B - - Twisted pair Multipiece see pages 167, 200 to 206 Fiber optic Twisted pair Monocrimp POF contacts (Plastic Optical Fiber) see page 170 (1): Example of plating, for other plating see page 164 (2): For loose piece contact packaging, place "L" in part number. Example: SM20ML1TK6 (3): For dimensions see page 172 8 Note: all dimensions are in inches Electrical Characteristics UTS 128 Derating Curves Current (A) 30 UL 10A 500V UL94 V-0 CSA 7A 500V UL94 V-0 IEC 10A 80V 1.5kV 3 28 25 Test conditions Contact used: Machined contacts Wires used: 1.31mm² 23 20 18 15 13 10 8 5 3 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 103 UTS Series | Connector 12E8/12D8 (Shell size 12, 8x#20) Layout OR OR WITH Connector Part Numbers Contact type Handsolder electrical contacts loaded see page 107 PCB contacts loaded see page 107 Connector type Backshell Square flange receptacle Female insert Without (Fig. 6) UTS012E8P UTS012E8S Without (Fig. 1) UTS612E8P UTS612E8S Cable gland (Fig. 2) UTS6JC12E8P UTS6JC12E8S Jam nut receptacle Without (Fig. 3) UTS712E8P UTS712E8S Square flange receptacle Without (Fig. 7) UTS012D8P UTS012D8S Jam nut receptacle with stand off and with hold down clips Without (Fig. 4) UTS712D8P32 UTS712D8S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 5) UTS712D8P UTS712D8S Plug Possibilities of discrimination/keying methods see page 208 104 Part number Male insert Sealed unmated 8 contacts 4.5A/250V UTS Series | Connector per UL 1977 12E8/12D8 (Shell size 12, 8x#20) Dimensions Plug - UTS6 2.626" Ø1.185" 0.996" Fig. 1 Fig. 2 Jam Nut Receptacle - UTS7 0.118" 0.122" 0.708" 0.137" Fig. 3 8 0.137" Fig. 4 Front view Fig. 5 Square Flange Receptacle - UTS0 Fig. 7 0.444" 0.295" 0.318" mini 1.070" 1.255" Ø0.748" Ø0.748" 0.137" 0.185" mini 0.118" 0.165" 0.708" Ø0.748" 0.708" Mated Connector Lengths 1.039" 3.055" 0.818" Ø0.748" UTS0 UTS7 3.216" 0.090" Ø0.125" Front view Panel Cut Out Square Flange Receptacle - UTS0 Drilling Pattern Jam Nut Receptacle - UTS7 Ø0.129" 22° Ø0.122" 68° 0.062" Front mounting Ø0.720" 0.818" Rear mounting Ø0.877" 0.875" 0.393" 0.118" 0.169" 0.826" 0.818" Ø1.031" Ø0.866" Hole sizes: 0.035" 0.043" 0.153" Fig. 6 Ø1.200" 0.169" 0.118" 30° Note: all dimensions are in inches 105 UTS Series | Connector 12E8/12D8 (Shell size 12, 8x#20) Accessories and Tooling Jam Nut Sealing Caps IP68/69K IP68/69K Plug Sealing Cap Metal terminal IP68/69K Metal terminal IP68/69K Part number Part number Part number Part number UTS12DCG UTS12DCGR UTS612DCG UTS12DCGE Plastic Protective Cap Gasket Color Coding Rings G for Green Y for Yellow IP68/69K Part numbers Receptacle cap Plug cap 85005587A 85005596 106 Square Flange Sealing Cap Part numbers UTFD13B Part numbers R for Red Receptacles Plugs UTS712CCRR UTS612CCRR UTS712CCRY UTS612CCRY UTS712CCRG UTS612CCRG 8 contacts 4.5A/250V UTS Series | Connector per UL 1977 12E8/12D8 (Shell size 12, 8x#20) #20 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 22 to 18 0.196" PCB Contacts Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 8 Electrical Characteristics UTS 12E8/12D8 Derating Curves Current (A) UL 4.5A 250V UL94 HB CSA 4.5A 250V UL94 HB Test conditions Contact used: Machined contacts Wires used: 0.518mm² IEC 6A 32V 1.5kV 3 Current use 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 107 UTS Series | Connector 148 (Shell size 14, 4x#16, 4x#12) Layout OR OR WITH Connector Part Numbers Contact type Crimp contacts supplied separately see page 111 108 Connector type Backshell Free hanging receptacle Part number Male insert Female insert Cable gland (Fig. 1) UTS1JC148P UTS1JC148S Plug Without (Fig. 2) UTS6148P UTS6148S Plug Cable gland (Fig. 3) UTS6JC148P UTS6JC148S Jam nut receptacle Without (Fig. 4) UTS7148P UTS7148S 8 contacts 25A/250V UTS Series | Connector per UL 1977 148 (Shell size 14, 4x#16, 4x#12) Dimensions Free Hanging - UTS1 Ø1.381" 3.090" Fig. 1 Plug - UTS6 2.815" 0.996" Ø1.381" Ø1.381" 1.299" 8 Fig. 2 Male Fig. 2 Female Jam Nut Receptacle - UTS7 0.484 " Mated Connector Length - UTS7 1.381" Ø0.877" 0.708" Fig. 3 0.137" 3.228" 1.196" Fig. 4 Drilling Pattern 0.102" 0.015" 0.011" 0.177" 0.950" 0.177" Jam Nut Receptacle - UTS7 1.005" 0.216" 0.200" 0.102" 0.122" 0.173" 0.007" 0.031" 0.137" 0.220" Panel Cut Out Note: all dimensions are in inches 109 UTS Series | Connector 148 (Shell size 14, 4x#16, 4x#12) Accessories and Tooling Jam Nut Sealing Caps IP68/69K Crimp Tooling #16 Metal terminal IP68/69K Part number Part number UTS14DCG UTS14DCGR Plug Sealing Cap IP68/69K Part number UTS614DCG UTS14DCGE Plastic Protective Cap Gasket IP68/69K Plug cap 85005588A 85005597 Part numbers UTFD14B Color Coding Rings HEAD (without Shandles) Contacts Part number of head Contact size RM/RC 28M1K RM/RC 24M9K RM/RC 20M13K RM/RC 20M12K Standard contacts RM/RC 16M23K RM/RC 14M30K #16 SM/SC 24ML1TK6(1) Ø 1.6 mm SM/SC 20ML1TK6(1) SM/SC 16ML1TK6(1) SM/SC 14ML1TK6(1) SM/SC 16ML11TK6(1) S16RCM20* S16RCM20* S16RCM20* S16RCM20* S16RCM16* S16RCM14* S16SCM20* S16SCM20* S16SCML1* S16SCML1* S16SCML11* Coaxial contacts available see pages 167, 200 to 206 (1): Example of plating, for other plating see page 164 *: Heads to be used with handle PN: shandles Part numbers G for Green Y for Yellow Toolkit (without Head) Metal terminal Part number Receptacle cap Shandles Part number Square Flange Sealing Cap IP68/69K Part numbers Part number R for Red Receptacles Plugs UTS714CCRR UTS614CCRR UTS714CCRY UTS614CCRY UTS714CCRG UTS614CCRG + Handle = Head Complete set Crimp Tooling #12 Extraction Tool Part number Extraction tool #12 Part number Extraction tool #16 M317 RX2025GE1 Dummy contact (SMSPKE0) see page 208. 110 Part number hand tool M317 Part number positioner + locator setting VGE10078A 8 contacts 25A/250V UTS Series | Connector per UL 1977 148 (Shell size 14, 4x#16, 4x#12) Contacts #16 Contact type Crimp Machined Stamped & Formed reeled contacts See note (2) for loose piece Wire size Coaxial Female Max wire Ø Max insulator Ø RM28M1K(1) RC28M1K(1) 0.021" 0.039" RM24M9K RC24M9K 0.031" 0.062" RM20M13K(1) RC20M13K(1) 0.045" 0.070" RM20M12K (1) RC20M12K 0.045" 0.086" RM16M23K(1) RC16M23K(1) 0.070" 0.125" RM14M30K RC14M30K 0.090" 0.125" SC24M1TK6(1)(2) - 0.035"-0.062" SM20M1TK6(1)(2) SC20M1TK6(1)(2) - 0.047"-0.082" - 0.125" - 0.118" - 0.125" AWG mm² Male 30-28 0.50-0.08 26-24 0.13-0.20 22-20 0.32-0.52 22-20 0.32-0.52 20-16 0.52-1.31 16-14 1.31-2.08 26-24 0.13-0.20 SM24M1TK6(1)(2) 22-20 0.32-0.52 18-16 0.80-1.31 18-16 0.80-1.31 14 2.08 (1) (1) (1) (1) (1) SM16M1TK6 SC16M1TK6 SM16M11TK6(1)(2) SC16M11TK6(1)(2) SM14M1TK6 SC14M1TK6 (1)(2) (1)(2) (1)(2) (1)(2) Cable Multipiece RMDXK10D28 RCDXK1D28 - - Cable Monocrimp RMDX60xxD28 RCDX60xxD28 - - RMDXK10D28 + york090 RCDXK1D28 + york090 - - RMDX60xxD28 RCDX60xxD28 - - RMPOF1000 RCPOF1000B - - Twisted pair Multipiece see pages 167, 200 to 206 Twisted pair Monocrimp Fiber optic Part number POF contacts (Plastic Optical Fiber) see page 170 8 Crimp #12 Machined 22 0.32 82911457NA(1) 82911456A(1) 0.034" 20 0.52 82911459NA (1) 82911458A 0.044" 0.80 82911461NA (1) 82911460A 0.055" 16 1.31 82911463NA (1) (1) 82911462A 0.067" 14 2.08 82911465NA(1) 82911464A(1) 0.087" 3.31 82911467NA 82911466A 0.111" 18 12 (1) (1) (1) (1) (1): Example of plating, for other plating see page 168 (2): For loose piece contact packaging, place "L" in part number. Example: SM20ML1TK6 Electrical Characteristics 0.192" Note: all dimensions are in inches UTS 148 Derating Curves Current (A) 45 UL 25A 250V UL94 V-0 CSA 17A 230V UL94 V-0 IEC 17A 230V 1.5kV 3 40 35 Test conditions Contact used: Machined contacts Wires used: 1.31mm² 30 25 20 15 10 5 0 Current use 0 25 45 65 85 105 Ambient Operating Temperature (°C) Limited use 125 Not recommended use 111 UTS Series | Connector 1210 - 12E10/12D10 (Shell size 12, 10x#20) Layout OR OR OR WITH Connector Part Numbers Contact type Crimp contacts supplied separately see page 115 Handsolder electrical contacts loaded see page 115 PCB contacts loaded see page 115 Connector type Backshell Free hanging receptacle Female insert Cable gland (Fig. 1) UTS1JC1210P UTS1JC1210S Plug Without (Fig. 2) Plug Cable gland (Fig. 3) UTS61210P UTS6JC1210P UTS61210S UTS6JC1210S Jam nut receptacle Without (Fig. 4) UTS71210P UTS71210S Square flange receptacle Without (Fig. 8) UTS012E10S UTS612E10S UTS6JC12E10S UTS712E10S UTS012D10S Jam nut receptacle Without (Fig. 5) Square flange receptacle Without (Fig. 8) UTS012E10P UTS612E10P UTS6JC12E10P UTS712E10P UTS012D10P Jam nut receptacle with stand off and with hold down clips Without (Fig. 6) UTS712D10P32 UTS712D10S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 7) UTS712D10P UTS712D10S Plug Possibilities of discrimination/keying methods see page 208 112 Part number Male insert Without (Fig. 2) Cable gland (Fig. 3) Sealed unmated 10 contacts 5A/250V UTS Series | Connector per UL 1977 1210 - 12E10/12D10 (Shell size 12, 10x#20) Dimensions Free Hanging - UTS1 Plug - UTS6 2.913" 2.626" 1.299" Ø1.185" Ø0.751" Male Female 0.996" Fig. 1 Fig. 3 Fig. 2 Jam Nut Receptacle - UTS7 0.708" 0.137" Fig. 5 0.118" 0.708" 0.444" 1.070" 1.255" 0.137" Fig. 6 0.137" Fig. 7 Square Flange Receptacle - UTS0 0.318" 0.295" mini 0.185" mini 0.118" 0.165" Ø0.751" Ø0.751" 0.708" 0.122" 0.484" Ø0.751" Fig. 4 10 Front view Mated Connector Lengths 1.039" 3.055" 0.818" Ø0.751" UTS0 UTS7 3.216" Fig. 8 Ø0.125" Front view Panel Cut Out Square Flange Receptacle - UTS0 Ø0.129" Drilling Pattern Jam Nut Receptacle - UTS7 22° Ø0.122" Hole size: 0.035" 68° 0.118" 0.090" 0.826" 0.818" Ø1.031" Front mounting Ø0.720" 0.818" Rear mounting Ø0.877" Ø0.866" 0.393" Ø1.200" 0.875" 0.062" 0.129" 0.192" 30° Note: all dimensions are in inches 113 UTS Series | Connector 1210 - 12E10/12D10 (Shell size 12, 10x#20) Accessories and Tooling Jam Nut Sealing Caps IP68/69K Handle (without Head) Tool Kit Metal terminal IP68/69K Part number Part number Part number Part number UTS12DCG UTS12DCGR Shandles Toolkit Plug Sealing Cap IP68/69K Square Flange Sealing Cap Metal terminal IP68/69K Part number Part number UTS612DCG UTS12DCGE Plastic Protective Cap Gasket Receptacle cap Plug cap 85005587A 85005596 Contacts RM/RC RM/RC RM/RC SM/SC SM/SC IP68/69K Part numbers Crimp Tooling (without Shandles) Part numbers UTFD13B Part number of head Contact size 24W3K(1) 20W3K(1) 18W3K(1) 24WL3S 20WL3S S20RCM* S20RCM* S20RCM* S20SCM20* S20SCM20* Standard contacts #20 Ø 1.0 mm (1): Example of plating, for other plating see page 164 *: Heads to be used with handle PN: shandles + Handle = Head Complete set Color Coding Rings G for Green Y for Yellow 114 Part numbers R for Red Extraction Tool #20 Receptacles Plugs UTS712CCRR UTS612CCRR UTS712CCRY UTS612CCRY Part number UTS712CCRG UTS612CCRG RX20D44 10 contacts 5A/250V UTS Series | Connector per UL 1977 1210 - 12E10/12D10 (Shell size 12, 10x#20) Contacts for 1210 #20 Wire size Contact type Crimp Machined Stamped & Formed reeled contacts Female Max wire Ø Max insulator Ø RM24W3K(1) RC24W3K(1) 0.031" 0.062" 0.32-0.52 RM20W3K (1) RC20W3K 0.045" 0.062" 0.50-0.80 RM18W3K(1) RC18W3K(1) 0.051" 0.082" 0.13-0.20 SM24W3TK6(2) SC24W3TK6(2) - 0.035"-0.062" 0.13-0.20 SM24W3S26 SC24W3S25(2) - 0.035"-0.062" 22-20 0.32-0.52 SM20W3TK6 (2) SC20W3TK6 - 0.047"-0.082" 22-20 0.32-0.52 SM20W3S26(2) SC20W3S25(2) - 0.047"-0.082" AWG mm² Male 26-24 0.13-0.20 22-20 20-18 26-24 26-24 See note (2) for loose piece Part number (1) (2) (2) (1): Example of plating, for other plating see page 164 (2): For loose piece contact packaging, place "L" in part number. Example: SM20WL3TK6 #20 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 22 to 18 0.196" PCB Contacts for 12E10/12D10 Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 10 Note: all dimensions are in inches Electrical Characteristics UTS 1210 - 12E10/12D10 Derating Curves Current (A) 13 UTS 1210 UL 5A 250V UL94 V-0 CSA 4A 250V UL94 V-0 UTS 12E10/12D10 UL 4.5A 250V UL94 HB CSA 4.5A 250V UL94 HB IEC 6A 50V 1.5kV 3 12 11 Test conditions Contact used: Machined contacts Wires used: 0.518mm² 10 9 8 7 6 5 4 3 2 1 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 115 UTS Series | Connector 1412 (Shell size 14, 12x#16) Layout OR OR OR OR OR OR WITH Connector Part Numbers Contact type Crimp contacts supplied separately see page 119 PCB contacts supplied separately see page 119 Connector type Backshell Square flange receptacle Part number Male insert Female insert Without (Fig. 1) UTS01412P UTS01412S Free hanging receptacle Cable gland and grommet* (Fig. 2) UTS1GJC1412P - Free hanging receptacle Nut and grommet* (Fig. 3) UTS1GN1412P - Free hanging receptacle Cable gland (Fig. 2) UTS1JC1412P UTS1JC1412S Plug Without (Fig. 4) UTS61412P UTS61412S Plug Cable gland and grommet* (Fig. 5) - UTS6GJC1412S Plug Nut and grommet* (Fig. 6) - UTS6GN1412S Plug Cable gland (Fig. 5) UTS6JC1412P UTS6JC1412S Jam nut receptacle Without (Fig. 7) UTS71412P UTS71412S Jam nut receptacle Cable gland and grommet* (Fig. 9) UTS7GJC1412P - Jam nut receptacle Nut and grommet* (Fig. 8) UTS7GN1412P - Square flange receptacle Without (Fig. 1) UTS01412P UTS01412S Jam nut receptacle Without (Fig. 7) UTS71412P Possibilities of discrimination/keying methods see page 208 UTS71412S * Grommet for discrete wire sealing Overmolded Cable Assembly Part Numbers Overmolding type Overmolded harnesses, straight ending Description Wire size Part number (length: 3 ft)* D/E assembly 1 male plug & 1 female plug 16 AWG UTS6V1412PS03FT00 S/E assembly 1 female plug 16 AWG UTS6V1412S03FT00 S/E assembly 1 male plug 16 AWG UTS6V1412P03FT00 * Other lengths available: 3, 6, 12 feet only: e.g. UTS6V1412PS06FT00 for a 6 feet version 116 12 contacts 10A/500V UTS Series | Connector per UL 1977 1412 (Shell size 14, 12x#16) Dimensions Square Flange Receptacle - UTS0 0.444" Free Hanging - UTS1 Fig. 2 1.133" 0.862" 3.090" Female 0.413" 0.090" Fig. 1 Ø0.877" 0.913" Ø0.877" Male Ø0.125" 1.692" Front view Fig. 3 Plug - UTS6 1.299" 2.755" 1.259" Fig. 5 Fig. 6 Ø1.381" Male Female 0.996" Fig. 4 Jam Nut Receptacle - UTS7 1.929" 0.708" 12 2.952" UTS0 Ø0.877" 0.062" UTS7 0.137" 3.228" 2.783" Fig. 9 Drilling Pattern 0.913" Rear mounting Ø0.988" Note: Overmolded cable assembly dimensions available page 179. 1.005" 0.200" Hole size: 0.051" 0.055" 0.011" 0.086" 0.149" 0.114" 0.078" 0.086" Front mounting Ø0.846" 0.232" 0.913" 0.950" Jam Nut Receptacle - UTS7 0.216" Panel Cut Out Square Flange Receptacle - UTS0 Ø0.129" 0.177" Fig. 7 0.039" 0.137" 0.039" Ø0.877" 0.708" Mated Connector Lengths Fig. 8 0.027" 0.228" Note: all dimensions are in inches 117 UTS Series | Connector 1412 (Shell size 14, 12x#16) Accessories and Tooling Jam Nut Sealing Caps IP68/69K Handle (without Head) Tool Kit Metal terminal IP68/69K Part number Part number Part number Part number UTS14DCG UTS14DCGR Shandles Toolkit Plug Sealing Cap IP68/69K Square Flange Sealing Cap Crimp Tooling (without Shandles) Metal terminal IP68/69K Part number Part number UTS614DCG UTS14DCGE Contacts Plastic Protective Cap Gasket IP68/69K Part numbers Receptacle cap Plug cap 85005588A 85005597 Part numbers UTFD14B Color Coding Rings G for Green Y for Yellow Part numbers R for Red Receptacles Plugs UTS714CCRR UTS614CCRR UTS714CCRY UTS614CCRY UTS714CCRG UTS614CCRG RM/RC 28M1K(1) RM/RC 24M9K(1) RM/RC 20M13K(1) RM/RC 20M12K(1) RM/RC 16M23K(1) RM/RC 14M30K(1) SM/SC 24ML1TK6(1) SM/SC 20ML1TK6(1) SM/SC 16ML1TK6(1) SM/SC 14ML1TK6(1) SM/SC 16ML11TK6(1) RMDXK10D28K RCDXK1D28K RM/RC DX60xxD28K RM/RC DXK10D28 + york090 RM/RC DX60xxD28 118 S16RCM20* S16RCM20* S16RCM20* S16RCM20* S16RCM16* S16RCM14* S16SCM20* S16SCM20* S16SCML1* S16SCML1* S16SCML11* Standard contacts #16 Ø 1.6 mm M10S1J with die set & stop bushing see page 202 to 205 Coaxial contacts (1): Example of plating, for other plating options see page 164 * Heads to be used with handle PN: SHANDLES + Extraction tool #16 (RX2025GE1) see page 179. Dummy contact (SMSPKE0) see page 208. Part number of head Contact size Handle = Head Complete set 12 contacts 10A/500V UTS Series | Connector per UL 1977 1412 (Shell size 14, 12x#16) Contacts #16 Contact type Crimp Machined Stamped & Formed reeled contacts PCB See note (2) for loose piece Wire size Part number Coaxial Max wire Ø Max insulator Ø RM28M1K(1) RC28M1K(1) 0.021" 0.039" RM24M9K RC24M9K 0.031" 0.062" RM20M13K(1) RC20M13K(1) 0.045" 0.070" RM20M12K (1) RC20M12K 0.045" 0.086" RM16M23K(1) RC16M23K(1) 0.070" 0.125" RM14M30K RC14M30K 0.090" 0.125" SC24M1TK6(1)(2) - 0.035"-0.062" SM20M1TK6(1)(2) SC20M1TK6(1)(2) - 0.047"-0.082" - 0.125" - 0.118" (1)(2) mm² Male 30-28 0.50-0.08 26-24 0.13-0.20 22-20 0.32-0.52 22-20 0.32-0.52 20-16 0.52-1.31 16-14 1.31-2.08 26-24 0.13-0.20 SM24M1TK6(1)(2) 22-20 0.32-0.52 18-16 0.80-1.31 18-16 0.80-1.31 Machined (3) 14 2.08 - - Cable Multipiece Cable Monocrimp Twisted pair Multipiece see pages 167, 200 to 206 Twisted pair Monocrimp Fiber optic Female AWG POF contacts (Plastic Optical Fiber) see page 170 (1) (1) (1) (1) (1) SM16M1TK6 SC16M1TK6 SM16M11TK6(1)(2) SC16M11TK6(1)(2) SM14M1TK6 SC14M1TK6 - 0.125" RM20M12E83K(1) RC20M12E84K(1) - - RMDXK10D28 RCDXK1D28 - - RMDX60xxD28 RCDX60xxD28 - - RMDXK10D28 + york090 RCDXK1D28 + york090 - - RMDX60xxD28 RCDX60xxD28 - - RMPOF1000 RCPOF1000B - - (1)(2) (1)(2) (1)(2) (1): Example of plating, for other plating see page 164 (2): For loose piece contact packaging, place "L" in part number. Example: SM20WL3TK6 (3): For dimensions see page 172 Note: all dimensions are in inches Electrical Characteristics UTS 1412 Derating Curves Current (A) 30 UL 10A 500V UL94 V-0 CSA 7A 500V UL94 V-0 IEC 10A 63V 1.5kV 3 28 25 Test conditions Contact used: Machined contacts Wires used: 1.31mm² 23 20 18 15 13 10 8 5 3 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 119 12 UTS Series | Connector 14E12/14D12 (Shell size 14, 8x#20, 4x#16) Layout OR OR OR WITH Connector Part Numbers Contact type Handsolder electrical contacts loaded see page 123 PCB contacts loaded see page 123 Connector type Backshell Square flange receptacle Without (Fig. 6) Female insert UTS014E12P UTS014E12S Without (Fig. 1) UTS614E12P UTS614E12S Cable gland (Fig. 2) UTS6JC14E12P UTS6JC14E12S Jam nut receptacle Without (Fig. 3) UTS714E12P UTS714E12S Square flange receptacle Without (Fig. 6) UTS014D12P UTS014D12S Jam nut receptacle with stand off and with hold down clips Without (Fig. 4) UTS714D12P32 UTS714D12S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 5) UTS714D12P UTS714D12S Plug Possibilities of discrimination/keying methods see page 208 120 Part number Male insert Sealed unmated 12 contacts 4.5A/250V UTS Series | Connector per UL 1977 14E12/14D12 (Shell size 14, 8x#20, 4x#16) Dimensions Plug - UTS6 2.755" Ø1.381" 0.996" Fig. 1 Fig. 2 Jam Nut Receptacle - UTS7 0.118" 0.118" 0.118" 0.165" 0.137" 0.137" Fig. 4 Mated Connector Lengths 1.133" 12 2.952" 0.913" Ø0.877" 0.444" Front view Fig. 5 Square Flange Receptacle - UTS0 0.318" 0.295" mini 1.196" 1.381" 0.137" Fig. 3 0.188" mini 0.708" Ø0.877" Ø0.877" 0.708" Ø0.877" 0.708" UTS0 UTS7 3.228" Ø0.125" Front view Panel Cut Out Drilling Pattern Jam Nut Receptacle - UTS7 0.950" 0.913" Ø0.129" Front mounting Ø0.846" 0.913" Rear mounting Ø0.988" 22° Ø0.122" Ø1.200" 68° Hole sizes: #20:0.035" #16:0.051" Ø1.031" Ø0.866" 0.090" Square Flange Receptacle - UTS0 0.393" 1.005" 0.161" 0.177" 0.062" 0.263" Fig. 6 0.177" 0.090" 30° Note: all dimensions are in inches 121 UTS Series | Connector 14E12/14D12 (Shell size 14, 8x#20, 4x#16) Accessories and Tooling Jam Nut Sealing Caps IP68/69K IP68/69K Plug Sealing Cap Metal terminal IP68/69K Metal terminal IP68/69K Part number Part number Part number Part number UTS14DCG UTS14DCGR UTS614DCG UTS14DCGE Plastic Protective Cap Gasket Color Coding Rings G for Green Y for Yellow IP68/69K Part numbers Receptacle cap Plug cap 85005588A 85005597 122 Square Flange Sealing Cap Part numbers UTFD14B Part numbers R for Red Receptacles Plugs UTS714CCRR UTS614CCRR UTS714CCRY UTS614CCRY UTS714CCRG UTS614CCRG 12 contacts 4.5A/250V UTS Series | Connector per UL 1977 14E12/14D12 (Shell size 14, 8x#20, 4x#16) #16 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 18 to 14 0.196" PCB Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - #20 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 22 to 18 0.149" PCB Contacts Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 12 Electrical Characteristics UTS 14E12/14D12 Derating Curves Current (A) UL 4.5A 250V UL94 HB CSA 4.5A 250V UL94 HB IEC 4A 50V 1.5kV 3 14 12 Test conditions Contact used: Machined contacts Wires used: 0.518mm² 10 8 6 4 2 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 123 UTS Series | Connector 1492 (Shell size 14, 12x#16) Layout OR OR WITH Connector Part Numbers Contact type Crimp contacts supplied separately see page 127 PCB contacts supplied separately see page 127 Connector type Backshell Free hanging receptacle Female insert Cable gland (Fig. 1) UTS1JC1492P UTS1JC1492S Plug Without (Fig. 2) UTS61492P UTS61492S Plug Cable gland (Fig. 3) UTS6JC1492P UTS6JC1492S Jam nut receptacle Without (Fig. 4) UTS71492P UTS71492S Jam nut receptacle Without (Fig. 4) UTS71492P UTS71492S Possibilities of discrimination/keying methods see page 208 124 Part number Male insert 12 contacts 10A/600V UTS Series | Connector per UL 1977 1492 (Shell size 14, 12x#16) Dimensions Free Hanging - UTS1 Ø0.877" Fig. 1 3.090" Plug - UTS6 1.299" 2.755" Ø1.381" Male Female 0.996" Fig. 2 Fig. 3 Jam Nut Receptacle - UTS7 0.708" Mated Connector Lengths 0.062" 12 Ø1.381" UTS7 0.137" 3.228" Fig. 4 Drilling Pattern 0.102" 0.208" 0.200" 0.055" 0.031" 0.181" 0.224" Hole size: 0.051" 0.074" 0.090" 1.005" 0.141" 0.094" 0.950" Jam Nut Receptacle - UTS7 0.232" Panel Cut Out Note: all dimensions are in inches 125 UTS Series | Connector 1492 (Shell size 14, 12x#16) Accessories and Tooling Jam Nut Sealing Caps IP68/69K Handle (without Head) Tool Kit Metal terminal IP68/69K Part number Part number Part number Part number UTS14DCG UTS14DCGR Shandles Toolkit Plug Sealing Cap IP68/69K Square Flange Sealing Cap Crimp Tooling (without Shandles) Metal terminal IP68/69K Part number Part number UTS614DCG UTS14DCGE Contacts Plastic Protective Cap Gasket IP68/69K Part numbers Receptacle cap Plug cap 85005588A 85005597 Part numbers UTFD14B Color Coding Rings G for Green Y for Yellow Part numbers R for Red Receptacles Plugs UTS714CCRR UTS614CCRR UTS714CCRY UTS614CCRY UTS714CCRG UTS614CCRG RM/RC 28M1K(1) RM/RC 24M9K(1) RM/RC 20M13K(1) RM/RC 20M12K(1) RM/RC 16M23K(1) RM/RC 14M30K(1) SM/SC 24ML1TK6(1) SM/SC 20ML1TK6(1) SM/SC 16ML1TK6(1) SM/SC 14ML1TK6(1) SM/SC 16ML11TK6(1) RMDXK10D28K RCDXK1D28K RM/RC DX60xxD28K RM/RC DXK10D28 + york090 RM/RC DX60xxD28 126 S16RCM20* S16RCM20* S16RCM20* S16RCM20* S16RCM16* S16RCM14* S16SCM20* S16SCM20* S16SCML1* S16SCML1* S16SCML11* Standard contacts #16 Ø 1.6 mm M10S1J with die set & stop bushing see page 202 to 205 Coaxial contacts (1): Example of plating, for other plating options see page 164 * Heads to be used with handle PN: SHANDLES + Extraction tool #16 (RX2025GE1) see page 179. Dummy contact (SMSPKE0) see page 208. Part number of head Contact size Handle = Head Complete set 12 contacts 10A/600V UTS Series | Connector per UL 1977 1492 (Shell size 14, 12x#16) Contacts #16 Contact type Crimp Machined Stamped & Formed reeled contacts PCB See note (2) for loose piece Wire size Part number Coaxial Max wire Ø Max insulator Ø RM28M1K(1) RC28M1K(1) 0.021" 0.039" RM24M9K RC24M9K 0.031" 0.062" RM20M13K(1) RC20M13K(1) 0.045" 0.070" RM20M12K (1) RC20M12K 0.045" 0.086" RM16M23K(1) RC16M23K(1) 0.070" 0.125" RM14M30K RC14M30K 0.090" 0.125" SC24M1TK6(1)(2) - 0.035"-0.062" SM20M1TK6(1)(2) SC20M1TK6(1)(2) - 0.047"-0.082" - 0.125" - 0.118" (1)(2) mm² Male 30-28 0.50-0.08 26-24 0.13-0.20 22-20 0.32-0.52 22-20 0.32-0.52 20-16 0.52-1.31 16-14 1.31-2.08 26-24 0.13-0.20 SM24M1TK6(1)(2) 22-20 0.32-0.52 18-16 0.80-1.31 18-16 0.80-1.31 Machined (3) 14 2.08 - - Cable Multipiece Cable Monocrimp Twisted pair Multipiece see pages 167, 200 to 206 Twisted pair Monocrimp Fiber optic Female AWG POF contacts (Plastic Optical Fiber) see page 170 (1) (1) (1) (1) (1) SM16M1TK6 SC16M1TK6 SM16M11TK6(1)(2) SC16M11TK6(1)(2) SM14M1TK6 SC14M1TK6 - 0.125" RM20M12E83K(1) RC20M12E84K(1) - - RMDXK10D28 RCDXK1D28 - - RMDX60xxD28 RCDX60xxD28 - - RMDXK10D28 + york090 RCDXK1D28 + york090 - - RMDX60xxD28 RCDX60xxD28 - - RMPOF1000 RCPOF1000B - - (1)(2) (1)(2) (1)(2) (1): Example of plating, for other plating see page 164 (2): For loose piece contact packaging, place "L" in part number. Example: SM20WL3TK6 (3): For dimensions see page 172 Note: all dimensions are in inches Electrical Characteristics UTS 1492 Derating Curves Current (A) 30 UL 10A 600V UL94 V-0 CSA 7A 500V UL94 V-0 IEC 10A 63V 1.5kV 3 28 25 Test conditions Contact used: Machined contacts Wires used: 1.31mm² 23 20 18 15 13 10 8 5 3 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 127 12 UTS Series | Connector 12E14/12D14 (Shell size 12, 14x#20) Layout OR OR WITH Connector Part Numbers Contact type Handsolder electrical contacts loaded see page 131 PCB contacts loaded see page 131 Connector type Backshell Square flange receptacle Female insert Without (Fig. 6) UTS012E14P UTS012E14S Without (Fig. 1) UTS612E14P UTS612E14S Cable gland (Fig. 2) UTS6JC12E14P UTS6JC12E14S Jam nut receptacle Without (Fig. 3) UTS712E14P UTS712E14S Square flange receptacle Without (Fig. 7) UTS012D14P UTS012D14S Jam nut receptacle with stand off and with hold down clips Without (Fig. 4) UTS712D14P32 UTS712D14S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 5) UTS712D14P UTS712D14S Plug Possibilities of discrimination/keying methods see page 208 128 Part number Male insert Sealed unmated 14 contacts 4.5A/250V UTS Series | Connector per UL 1977 12E14/12D14 (Shell size 12, 14x#20) Dimensions Plug - UTS6 2.626" Ø1.185" 0.996" Fig. 1 Fig. 2 Jam Nut Receptacle - UTS7 0.118" 0.122" 0.137" 0.708" 0.137" Fig. 3 0.137" Fig. 4 Front view Fig. 5 Square Flange Receptacle - UTS0 Fig. 7 0.444" 0.295" 0.318" mini 1.070" 1.255" Ø0.748" Ø0.748" 0.708" Ø0.748" 0.708" 0.149" mini 0.118" 0.165" Mated Connector Lengths 1.039" 3.055" 14 0.818" Ø0.748" UTS0 UTS7 3.216" 0.090" Ø0.125" Fig. 6 Front view Drilling Pattern Ø0.129" 22° Ø0.122" 0.078" Front mounting Ø0.720" 0.818" Rear mounting Ø0.877" 0.875" Ø0.866" 0.070" 0.818" 0.826" Ø1.031" Hole size: 0.035" 68° 0.055" 0.149" Jam Nut Receptacle - UTS7 0.393" Ø1.200" 30° 0.173" 0.185" Panel Cut Out Square Flange Receptacle - UTS0 0.106" Note: all dimensions are in inches 129 UTS Series | Connector 12E14/12D14 (Shell size 12, 14x#20) Accessories and Tooling Jam Nut Sealing Caps IP68/69K IP68/69K Plug Sealing Cap Metal terminal IP68/69K Metal terminal IP68/69K Part number Part number Part number Part number UTS12DCG UTS12DCGR UTS612DCG UTS12DCGE Plastic Protective Cap Gasket Color Coding Rings G for Green Y for Yellow IP68/69K Part numbers Receptacle cap Plug cap 85005587A 85005596 130 Square Flange Sealing Cap Part numbers UTFD13B Part numbers R for Red Receptacles Plugs UTS712CCRR UTS612CCRR UTS712CCRY UTS612CCRY UTS712CCRG UTS612CCRG 14 contacts 4.5A/250V UTS Series | Connector per UL 1977 12E14/12D14 (Shell size 12, 14x#20) #20 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 22 to 18 0.196" PCB Contacts Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 14 Electrical Characteristics UTS 12E14/12D14 Derating Curves Current (A) UL 4.5A 250V UL94 HB CSA 4.5A 250V UL94 HB IEC 5A 32V 1.5kV 3 11 10 9 Test conditions 8 Contact used: Machined contacts Wires used: 0.518mm² 5 7 6 4 3 2 1 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 131 UTS Series | Connector 14E15/14D15 (Shell size 14, 14x#20, 1x#16) Layout OR OR WITH Connector Part Numbers Contact type Handsolder electrical contacts loaded see page 135 PCB contacts loaded see page 135 Connector type Backshell Square flange receptacle Female insert Without (Fig. 6) UTS014E15P UTS014E15S Without (Fig. 1) UTS614E15P UTS614E15S Cable gland (Fig. 2) UTS6JC14E15P UTS6JC14E15S Jam nut receptacle Without (Fig. 3) UTS714E15P UTS714E15S Square flange receptacle Without (Fig. 7) UTS014D15P UTS014D15S Jam nut receptacle with stand off and with hold down clips Without (Fig. 4) UTS714D15P32 UTS714D15S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 5) UTS714D15P UTS714D15S Plug Possibilities of discrimination/keying methods see page 208 132 Part number Male insert Sealed unmated 15 contacts 12A/600V UTS Series | Connector per UL 1977 14E15/14D15 (Shell size 14, 14x#20, 1x#16) Dimensions Plug - UTS6 0.996" Ø1.381" 2.755" Fig. 1 Fig. 2 Jam Nut Receptacle - UTS7 0.118" 0.118" 0.137" 0.708" 0.137" Fig. 3 0.137" Fig. 4 Fig. 7 0.295"0.318" mini Front view Fig. 5 Square Flange Receptacle - UTS0 Mated Connector Lengths 1.133" 2.952" UTS0 0.913" Ø0.877" 0.444" 1.196" 1.381" Ø0.877" Ø0.877" 0.708" Ø0.877" 0.708" 0.188" mini 0.118" 0.165" 15 UTS7 3.228" 0.090" Ø0.125" Front view Drilling Pattern Jam Nut Receptacle - UTS7 0.913" Rear mounting Ø0.988" 1.005" 0.240" 0.106" 68° 0.039" 0.011" 0.098" 0.074" 0.137" 0.950" 0.913" Front mounting Ø0.846" 22° Hole sizes: #20: 0.035" 0.125" #16: 0.051" 0.216" 0.224" Panel Cut Out Square Flange Receptacle - UTS0 Ø0.129" 0.110" 0.208" 0.244" Fig. 6 0.200" 30° Note: all dimensions are in inches 133 UTS Series | Connector 14E15/14D15 (Shell size 14, 14x#20, 1x#16) Accessories and Tooling Jam Nut Sealing Caps IP68/69K IP68/69K Plug Sealing Cap Metal terminal IP68/69K Metal terminal IP68/69K Part number Part number Part number Part number UTS14DCG UTS14DCGR UTS614DCG UTS14DCGE Plastic Protective Cap Gasket Color Coding Rings G for Green Y for Yellow IP68/69K Part numbers Receptacle cap Plug cap 85005588A 85005597 134 Square Flange Sealing Cap Part numbers UTFD14B Part numbers R for Red Receptacles Plugs UTS714CCRR UTS614CCRR UTS714CCRY UTS614CCRY UTS714CCRG UTS614CCRG 15 contacts 12A/600V UTS Series | Connector per UL 1977 14E15/14D15 (Shell size 14, 14x#20, 1x#16) #16 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 18 to 14 0.196" PCB Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - #20 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 22 to 18 0.149" PCB Contacts Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 15 Electrical Characteristics UTS 14E15/14D15 Derating Curves Current (A) 30 UL 12A 600V UL94 HB CSA 12A 600V UL94 HB IEC 4A 50V 1.5kV 3 28 25 23 Test conditions 20 Contact used: Machined contacts Wires used: 1.31mm² 13 18 15 10 8 5 3 0 Current use 0 20 40 60 80 100 120 Ambient Operating Temperature (°C) Limited use Not recommended use 135 UTS Series | Connector 14E18/14D18 (Shell size 14, 18x#20) Layout OR OR WITH Connector Part Numbers Contact type Handsolder electrical contacts loaded see page 139 PCB contacts loaded see page 139 Connector type Backshell Square flange receptacle Female insert Without (Fig. 6) UTS014E18P UTS014E18S Without (Fig. 1) UTS614E18P UTS614E18S Cable gland (Fig. 2) UTS6JC14E18P UTS6JC14E18S Jam nut receptacle Without (Fig. 3) UTS714E18P UTS714E18S Square flange receptacle Without (Fig. 7) UTS014D18P UTS014D18S Jam nut receptacle with stand off and with hold down clips Without (Fig. 4) UTS714D18P32 UTS714D18S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 5) UTS714D18P UTS714D18S Plug Possibilities of discrimination/keying methods see page 208 136 Part number Male insert Sealed unmated 18 contacts 4A/250V UTS Series | Connector per UL 1977 14E18/14D18 (Shell size 14, 18x#20) Dimensions Plug - UTS6 2.755" Ø1.381" 0.996" Fig. 1 Fig. 2 Jam Nut Receptacle - UTS7 0.118" 0.118" 0.708" 0.137" 0.137" Fig. 4 Fig. 7 0.295" 0.318" mini Front view Fig. 5 Square Flange Receptacle - UTS0 Mated Connector Lengths 1.133" 2.952" UTS0 0.913" Ø0.877" 0.444" 1.196" 1.381" Ø0.877" Ø0.877" 0.137" Fig. 3 0.188" mini 0.118" 0.165" 0.708" Ø0.877" 0.708" UTS7 3.228" 0.090" 18 Ø0.125" Front view Drilling Pattern Jam Nut Receptacle - UTS7 0.913" 0.950" Ø0.129" Front mounting Ø0.846" 0.913" Rear mounting Ø0.988" 1.005" 22° Ø0.122" Ø1.200" Ø1.031" Ø0.866" 68° 0.393" 0.062" 0.129" 0.259" 30° 0.192" Hole size: 0.035" 0.251" Panel Cut Out Square Flange Receptacle - UTS0 0.110" 0.224" Fig. 6 Note: all dimensions are in inches 137 UTS Series | Connector 14E18/14D18 (Shell size 14, 18x#20) Accessories and Tooling Jam Nut Sealing Caps IP68/69K IP68/69K Plug Sealing Cap Metal terminal IP68/69K Metal terminal IP68/69K Part number Part number Part number Part number UTS14DCG UTS14DCGR UTS614DCG UTS14DCGE Plastic Protective Cap Gasket Color Coding Rings G for Green Y for Yellow IP68/69K Part numbers Receptacle cap Plug cap 85005588A 85005597 138 Square Flange Sealing Cap Part numbers UTFD14B Part numbers R for Red Receptacles Plugs UTS714CCRR UTS614CCRR UTS714CCRY UTS614CCRY UTS714CCRG UTS614CCRG 18 contacts 4A/250V UTS Series | Connector per UL 1977 14E18/14D18 (Shell size 14, 18x#20) #20 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 22 to 18 0.196" PCB Contacts Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 18 Electrical Characteristics UTS 14E18/14D18 Derating Curves Current (A) 10 UL 4A 250V UL94 HB CSA 4A 250V UL94 HB IEC 5A 50V 1.5kV 3 9 8 Test conditions 7 Contact used: Machined contacts Wires used: 0.518mm² 4 6 5 3 2 1 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 139 UTS Series | Connector 1419 - 14E19/14D19 (Shell size 14, 19x#20) Layout OR OR OR WITH Connector Part Numbers Contact type Crimp contacts supplied separately see page 143 PCB contacts supplied separately see page 143 Handsolder electrical contacts loaded see page 143 PCB contacts loaded see page 143 Connector type Backshell Free hanging receptacle Cable gland (Fig. 1) Female insert UTS1JC1419S UTS61419S UTS6JC1419S UTS71419S Plug Without (Fig. 2) Plug Cable gland (Fig. 3) Jam nut receptacle Without (Fig. 4) UTS1JC1419P UTS61419P UTS6JC1419P UTS71419P Jam nut receptacle Without (Fig. 4) UTS71419P UTS71419S Square flange receptacle Without (Fig. 8) UTS014E19P UTS014E19S Without (Fig. 2) UTS614E19P UTS614E19S Plug Cable gland (Fig. 3) UTS6JC14E19P UTS6JC14E19S Jam nut receptacle Without (Fig. 5) UTS714E19P UTS714E19S Square flange receptacle Without (Fig. 9) UTS014D19P UTS014D19S Jam nut receptacle with stand off and with hold down clips Without (Fig. 6) UTS714D19P32 UTS714D19S32 Jam nut receptacle with stand off and without hold down clips Without (Fig. 7) UTS714D19P UTS714D19S Possibilities of discrimination/keying methods see page 208 140 Part number Male insert Sealed unmated 19 contacts 5A/250V UTS Series | Connector per UL 1977 1419 - 14E19/14D19 (Shell size 14, 19x#20) Dimensions Free Hanging - UTS1 Plug - UTS6 2.755" 1.299" 3.090" Ø1.381" Ø0.877" Male Female 0.996" Fig. 2 Fig. 1 Fig. 3 Jam Nut Receptacle - UTS7 0.118" 0.484" 0.165" 0.137" 0.118" Fig. 5 0.708" 0.137" 0.137" Fig. 6 Front view Fig. 7 Square Flange Receptacle - UTS0 Fig. 9 0.444" 0.295"0.318" mini 1.196" 1.381" Ø0.877" 0.708" Ø0.877" 0.708" 0.188" mini 0.118" Ø0.877" Fig. 4 Mated Connector Lengths 1.133" 2.952" 0.913" Ø0.877" UTS0 UTS7 3.228" Ø0.125" Front view Fig. 8 Panel Cut Out Jam Nut Receptacle - UTS7 0.913" 0.950" Ø0.129" Front mounting Ø0.846" 0.913" Rear mounting Ø0.988" 22° Ø0.122" Ø1.200" Ø1.031" Hole size: 0.035" 68° Ø0.866" 0.110" Square Flange Receptacle - UTS0 19 Drilling Pattern 0.224" 0.090" 0.393" 1.005" 0.192" 0.062" 30° 0.129" 0.259" Note: all dimensions are in inches 141 UTS Series | Connector 1419 - 14E19/14D19 (Shell size 14, 19x#20) Accessories and Tooling Jam Nut Sealing Caps IP68/69K Handle (without Head) Tool Kit Metal terminal IP68/69K Part number Part number Part number Part number UTS14DCG UTS14DCGR Shandles Toolkit Plug Sealing Cap IP68/69K Square Flange Sealing Cap Metal terminal IP68/69K Part number Part number UTS614DCG UTS14DCGE Plastic Protective Cap Gasket Receptacle cap Plug cap 85005588A 85005597 Contacts RM/RC RM/RC RM/RC SM/SC SM/SC IP68/69K Part numbers Crimp Tooling (without Shandles) Part numbers UTFD14B Part number of head Contact size 24W3K(1) 20W3K(1) 18W3K(1) 24WL3S 20WL3S S20RCM* S20RCM* S20RCM* S20SCM20* S20SCM20* Standard contacts #20 Ø 1.0 mm (1): Example of plating, for other plating see page 164 *: Heads to be used with handle PN: shandles + Handle = Head Complete set Color Coding Rings G for Green Y for Yellow 142 Part numbers R for Red Extraction Tool #20 Receptacles Plugs UTS714CCRR UTS614CCRR UTS714CCRY UTS614CCRY Part number UTS714CCRG UTS614CCRG RX20D44 19 contacts 5A/250V UTS Series | Connector per UL 1977 1419 - 14E19/14D19 (Shell size 14, 19x#20) Contacts for 1419 #20 Wire size Contact type Crimp Machined Stamped & Formed reeled contacts PCB See note (2) for loose piece Machined (3) Part number Female Max wire Ø Max insulator Ø RM24W3K(1) RC24W3K(1) 0.031" 0.062" 0.32-0.52 RM20W3K (1) RC20W3K 0.045" 0.062" 0.50-0.80 RM18W3K(1) RC18W3K(1) 0.051" 0.082" 0.13-0.20 SM24W3TK6(2) SC24W3TK6(2) - 0.035"-0.062" 26-24 0.13-0.20 SM24W3S26 (2) SC24W3S25 - 0.035"-0.062" 22-20 0.32-0.52 SM20W3TK6(2) SC20W3TK6(2) - 0.047"-0.082" 22-20 0.32-0.52 SM20W3S26 SC20W3S25 - 0.047"-0.082" - - RMW5016K RCW5016K - - AWG mm² Male 26-24 0.13-0.20 22-20 20-18 26-24 (1) (2) (2) (2) (1): Example of plating, for other plating see page 164 (2): For loose piece contact packaging, place "L" in part number. Example: SM20WL3TK6 (3): For dimensions see page 172 #20 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder Loaded in the connector Min 0.4µ gold over 0.8µ Ni 22 to 18 0.196" PCB Contacts for 14E19/14D19 Machined, loaded in the connector (1) Min 0.4µ gold over 0.8µ Ni - - (1): For dimensions see page 169 Electrical Characteristics UTS 1419 - 14E19/14D19 Derating Curves Current (A) UTS 1419 UL 5A 250V UL94 V-0 UTS 14E19/14D19 UL 4A 250V UL94 HB CSA 4A 250V UL94 V-0 CSA 4A 250V UL94 HB 10 9 Test conditions Contact used: Machined contacts Wires used: 0.518mm² IEC 5A 32V 1.5kV 3 8 7 6 5 4 3 2 1 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 143 19 UTS Series | Connector 1823 (Shell size 18, 23x#16) Layout OR OR OR WITH Connector Part Numbers Contact type Crimp contacts supplied separately see page 147 PCB contacts supplied separately see page 147 Connector type Backshell Square flange receptacle Free hanging receptacle Female insert Without (Fig. 1) UTS01823P UTS01823S Cable gland (Fig. 2) UTS1JC1823P UTS1JC1823S Plug Without (Fig. 3) UTS61823P UTS61823S Plug Cable gland (Fig. 4) UTS6JC1823P UTS6JC1823S Jam nut receptacle Without (Fig. 5) UTS71823P UTS71823S Square flange receptacle Without (Fig. 1) UTS01823P UTS01823S Jam nut receptacle Without (Fig. 5) UTS71823P UTS71823S Possibilities of discrimination/keying methods see page 208 144 Part number Male insert 23 contacts 10A/500V UTS Series | Connector per UL 1977 1823 (Shell size 18, 23x#16) Dimensions Square Flange Receptacle - UTS0 0.444" 0.744" Free Hanging - UTS1 1.318" 3.503" Female 0.405" 0.098" Ø1.126" 1.066" Ø1.126" Male Ø0.125" Fig. 1 Fig. 2 Front view Plug - UTS6 1.299" 3.200" Female Ø1.653" Ø1.653" Male 0.996" Fig. 3 Fig. 4 Jam Nut Receptacle - UTS7 Mated Connector Lengths 1.452" 0.708" 3.311" 0.484" 1.633" Ø1.126" UTS0 UTS7 0.137" 3.574" Front view Drilling Pattern 1.066" 1.195" Front mounting Ø1.098" 1.066" Rear mounting Ø1.255" 1.253" 0.263" 0.137" 0.145" Hole size: 0.051" 0.212" 0.326" 0.196" 0.074" Ø0.129" 0.338" 0.303" Jam Nut Receptacle - UTS7 0.188" Panel Cut Out Square Flange Receptacle - UTS0 0.133" Fig. 5 Note: all dimensions are in inches 145 23 UTS Series | Connector 1823 (Shell size 18, 23x#16) Accessories and Tooling Jam Nut Sealing Caps IP68/69K Handle (without Head) Tool Kit Metal terminal IP68/69K Part number Part number Part number Part number UTS18DCG UTS18DCGR Shandles Toolkit Plug Sealing Cap IP68/69K Square Flange Sealing Cap Crimp Tooling (without Shandles) Metal terminal IP68/69K Part number Part number UTS618DCG UTS18DCGE Contacts Plastic Protective Cap Gasket IP68/69K Part numbers Receptacle cap Plug cap 85005590A 85005599 Part numbers UTFD16B Color Coding Rings G for Green Y for Yellow Part numbers R for Red Receptacles Plugs UTS718CCRR UTS618CCRR UTS718CCRY UTS618CCRY UTS718CCRG UTS618CCRG RM/RC 28M1K(1) RM/RC 24M9K(1) RM/RC 20M13K(1) RM/RC 20M12K(1) RM/RC 16M23K(1) RM/RC 14M30K(1) SM/SC 24ML1TK6(1) SM/SC 20ML1TK6(1) SM/SC 16ML1TK6(1) SM/SC 14ML1TK6(1) SM/SC 16ML11TK6(1) RMDXK10D28K RCDXK1D28K RM/RC DX60xxD28K RM/RC DXK10D28 + york090 RM/RC DX60xxD28 146 S16RCM20* S16RCM20* S16RCM20* S16RCM20* S16RCM16* S16RCM14* S16SCM20* S16SCM20* S16SCML1* S16SCML1* S16SCML11* Standard contacts #16 Ø 1.6 mm M10S1J with die set & stop bushing see page 202 to 205 Coaxial contacts (1): Example of plating, for other plating options see page 164 * Heads to be used with handle PN: SHANDLES + Extraction tool #16 (RX2025GE1) see page 179. Dummy contact (SMSPKE0) see page 208. Part number of head Contact size Handle = Head Complete set 23 contacts 10A/500V UTS Series | Connector per UL 1977 1823 (Shell size 18, 23x#16) Contacts #16 Crimp Machined Stamped & Formed reeled contacts See note (2) for loose piece PCB Wire size Contact type Part number Coaxial Max wire Ø Max insulator Ø RM28M1K(1) RC28M1K(1) 0.021" 0.039" RM24M9K RC24M9K 0.031" 0.062" RM20M13K(1) RC20M13K(1) 0.045" 0.070" RM20M12K (1) RC20M12K 0.045" 0.086" RM16M23K(1) RC16M23K(1) 0.070" 0.125" RM14M30K RC14M30K 0.090" 0.125" SC24M1TK6(1)(2) - 0.035"-0.062" SM20M1TK6(1)(2) SC20M1TK6(1)(2) - 0.047"-0.082" - 0.125" - 0.118" (1)(2) mm² Male 30-28 0.50-0.08 26-24 0.13-0.20 22-20 0.32-0.52 22-20 0.32-0.52 20-16 0.52-1.31 16-14 1.31-2.08 26-24 0.13-0.20 SM24M1TK6(1)(2) 22-20 0.32-0.52 18-16 0.80-1.31 18-16 0.80-1.31 Machined (3) 14 2.08 - - Cable Multipiece Cable Monocrimp Twisted pair Multipiece see pages 167, 200 to 206 Twisted pair Monocrimp Fiber optic Female AWG POF contacts (Plastic Optical Fiber) see page 170 (1) (1) (1) (1) (1) SM16M1TK6 SC16M1TK6 SM16M11TK6(1)(2) SC16M11TK6(1)(2) SM14M1TK6 SC14M1TK6 - 0.125" RM20M12E83K(1) RC20M12E84K(1) - - RMDXK10D28 RCDXK1D28 - - RMDX60xxD28 RCDX60xxD28 - - RMDXK10D28 + york090 RCDXK1D28 + york090 - - RMDX60xxD28 RCDX60xxD28 - - RMPOF1000 RCPOF1000B - - (1)(2) (1)(2) (1)(2) Note: all dimensions are in inches (1): Example of plating, for other plating see page 164 (2): For loose piece contact packaging, place "L" in part number. Example: SM20WL3TK6 (3): For dimensions see page 172 Electrical Characteristics UTS 1823 Derating Curves Current (A) 30 UL 10A 500V UL94 V-0 CSA 7A 500V UL94 V-0 IEC 9A 63V 1.5kV 3 28 23 25 Test conditions Contact used: Machined contacts Wires used: 1.31mm² 23 20 18 15 13 10 8 5 3 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 147 UTS Series | Connector 1832 - 18E32 (Shell size 18, 32x#20) Layout OR OR OR WITH Connector Part Numbers Contact type Connector type Backshell Free hanging receptacle Female insert Cable gland (Fig. 2) UTS1JC1832P UTS1JC1832S Plug Without (Fig. 3) UTS61832P UTS61832S Plug Cable gland (Fig. 4) UTS6JC1832P UTS6JC1832S Jam nut receptacle Without (Fig. 5) UTS71832P UTS71832S PCB contacts supplied separately see page 151 Jam nut receptacle Without (Fig. 5) UTS71832P UTS71832S Handsolder electrical contacts loaded see page 151 Square flange receptacle Without (Fig. 1) UTS018E32P - Crimp Contact supplied separately see page 151 Possibilities of discrimination/keying methods see page 208 148 Part number Male insert Sealed unmated 32 contacts 5A/250V UTS Series | Connector per UL 1977 1832 - 18E32 (Shell size 18, 32x#20) Dimensions Square Flange Receptacle - UTS0 0.444" 0.744" Free Hanging - UTS1 1.318" 3.503" Ø1.126" 1.066" Ø1.126" Male Female 0.405" 0.098" Fig. 1 Ø0.125" Front view Fig. 2 Plug - UTS6 1.299" 3.200" Ø1.653" Ø1.653" Male Female 0.996" Fig. 3 Fig. 4 Mated Connector Lengths Jam Nut Receptacle - UTS7 0.708" 1.452" 0.484" 3.311" 1.633" Ø1.126" UTS0 UTS7 0.137" 3.574" Front view Drilling Pattern 0.220" 0.228" 0.094" Front mounting Ø1.098" Rear mounting Ø1.255" 0.149" 0.192" 1.253" 0.358" 1.066" 1.195" 0.094" Ø0.129" 0.318" 0.342" 0.283" Hole size: 0.035" 0.188" 0.334" 0.350" 0.208" 0.122" 0.263" 0.303" Jam Nut Receptacle - UTS7 0.094" 0.157" 0.216" Panel Cut Out Square Flange Receptacle - UTS0 1.066" 0.031" Fig. 5 32 0.129" 0.062" 0.173" 0.240" 0.381" 0.224" Note: all dimensions are in inches 149 UTS Series | Connector 1832 - 18E32 (Shell size 18, 32x#20) Accessories and Tooling Jam Nut Sealing Caps IP68/69K Handle (without Head) Tool Kit Metal terminal IP68/69K Part number Part number Part number Part number UTS18DCG UTS18DCGR Shandles Toolkit Plug Sealing Cap IP68/69K Square Flange Sealing Cap Metal terminal IP68/69K Part number Part number UTS618DCG UTS18DCGE Plastic Protective Cap Gasket Receptacle cap Plug cap 85005590A 85005599 Contacts RM/RC RM/RC RM/RC SM/SC SM/SC IP68/69K Part numbers Crimp Tooling (without Shandles) Part numbers UTFD16B Part number of head Contact size 24W3K(1) 20W3K(1) 18W3K(1) 24WL3S 20WL3S S20RCM* S20RCM* S20RCM* S20SCM20* S20SCM20* Standard contacts #20 Ø 1.0 mm (1): Example of plating, for other plating see page 164 *: Heads to be used with handle PN: shandles + Handle = Head Complete set Color Coding Rings G for Green Y for Yellow 150 Part numbers R for Red Extraction Tool #20 Receptacles Plugs UTS718CCRR UTS618CCRR UTS718CCRY UTS618CCRY Part number UTS718CCRG UTS618CCRG RX20D44 32 contacts 5A/250V UTS Series | Connector per UL 1977 1832 - 18E32 (Shell size 18, 32x#20) Contacts #20 Contact type Crimp Machined Stamped & Formed reeled contacts PCB See note (2) for loose piece Wire size Part number Female Max wire Ø Max insulator Ø Wire stripping length RM24W3K(1) RC24W3K(1) 0.031" 0.062" 0.188" 0.32-0.52 RM20W3K (1) RC20W3K 0.045" 0.062" 0.188" 0.50-0.80 RM18W3K(1) RC18W3K(1) 0.051" 0.082" 0.188" 0.13-0.20 SM24W3TK6(2) SC24W3TK6(2) - 0.035"-0.062" 0.157" SM24W3S6 (2) SC24W3S25 - 0.035"-0.062" 0.157" SM20W3TK6(2) SC20W3TK6(2) - 0.047"-0.082" 0.157" SM20W3S6 SC20W3S25 - 0.047"-0.082" 0.157" RCW5016K - - - AWG mm² Male 26-24 0.13-0.20 22-20 20-18 26-24 26-24 0.13-0.20 22-20 0.32-0.52 22-20 0.32-0.52 - - Machined (3) (1) (2) (2) (2) RMW5016K Note: all dimensions are in inches #20 Contact type Plating Cable acceptance (AWG) Wire stripping length Handsolder (1): Example of plating, for other plating see page 164 (2): For loose piece contact packaging, place "L" in part number. Example: SM20WL3TK6 (3): For dimensions see page 172 Loaded in the connector Min 0.4µ gold over 0.8µ Ni 22 to 18 0.196" Electrical Characteristics UTS 1832 - 18E32 Derating Curves Current (A) 10 UL 5A 250V UL94 V-0 CSA 4A 250V UL94 V-0 IEC 4A 32V 1.5kV 3 9 8 Test conditions Contact used: Machined contacts Wires used: 0.518mm² 7 6 32 5 4 3 2 1 0 Current use 0 20 40 60 80 100 Ambient Operating Temperature (°C) Limited use 120 Not recommended use 151 UTS Series | Connector LC (Fiber Optic) Layout OR OR WITH Connector Part Numbers Connector type Backshell Free hanging receptacle Cable gland (Fig. 1) Plug Jam nut receptacle LC contacts not included For IP rating and general details please consult us 152 Part number Male insert Female insert UTS1JC18LCN - Cable gland (Fig. 2) - UTS6JC18LCN Without (Fig. 3) UTS718LCN - UTS Series | Connector LC (Fiber Optic) Dimensions Free Hanging Receptacle -UTS1JC18LCN 4.803" max 1.653" maxi Ø 0.236" max Ø 0.118" min Fig. 1 Plug - UTS6JC18LCN 4.409" max 1.653" maxi Ø 0.236" max Ø 0.118" min Fig. 2 Mated Connector Length - UTS7 Jam Nut Receptacle - UTS718LCN 4.566" 0.688" max Ø 1.791" max 0.196" max Fig. 3 Panel Cut Out Jam Nut Receptacle - UTS7 1.195" 0.728" max 1.253" LC 153 UTS Series | Connector LC (Fiber Optic) Accessories Sealing Caps For UTS1JC18LCN & UTS718LCN For UTS6JC18LCN 154 Part number Part number UTS618DCG2 UTS18DCG2 UTS Series | Connector LC 155 UTS Series | Connector MPO (Fiber Optic) Layout OR OR WITH Connector Part Numbers Connector type Part number Male insert Female insert Free hanging receptacle Cable gland (Fig. 1) UTS1JC18MPN - Plug Cable gland (Fig. 2) - UTS6JC18MPN Jam nut receptacle Without (Fig. 3) UTS718MPN - LC contacts not included For IP rating and general details please consult us 156 Backshell UTS Series | Connector MPO (Fiber Optic) Dimensions Free Hanging Receptacle -UTS1JC18MPN 4.803" max 1.653" maxi Ø 0.236" max Ø 0.118" min Fig. 1 Plug - UTS6JC18MPN 4.409" max 1.653" maxi Ø 0.236" max Ø 0.118" min Fig. 2 Mated Connector Length - UTS7 Jam Nut Receptacle - UTS718MPN 4.566" 0.688" max Ø 1.791" max 0.196" max Fig. 3 Panel Cut Out Jam Nut Receptacle - UTS7 1.195" 0.728" max 1.253" MPO 157 UTS Series | Connector MPO (Fiber Optic) Accessories Sealing Caps For UTS1JC18MPN & UTS718MPN For UTS6JC18MPN 158 Part number Part number UTS618DCG2 UTS18DCG2 UTS Series | Connector MPO 159 UTS SERIES © 2015 SOURIAU - SOURIAU is a registratred trademark UTS Series Contacts Description ................................................................................................................ 162 Contact Plating Selector Guide ................................................................................. 163 Contact Selector Guide ............................................................................................. 164 Packaging .................................................................................................................. 164 Crimp Contacts ......................................................................................................... 165 #16 Coaxial Contacts ................................................................................................ 167 PCB Contacts ............................................................................................................ 168 Fiber Optic Contacts ................................................................................................. 170 161 UTS Series | Contacts Contacts Description The UTS series is delivered with (solder, PCB versions and screw termination) or without contact (crimp version) and offers the unique feature to use the same contact style in any layout with the same active part size (i.e. #20, #16, #12, etc.). This provides our customers with an easy solution to buy only one type of contact to equip all their connectors even if housings/shell sizes are different. This provides the benefit of standardization and subsequent reduced inventory costs. In addition, it eliminates the need for added tooling and simplifies the assembly process. Souriau contacts are designed for simple snap-in installation and further eliminate the need for insertion tooling. In addition to the below “crimp” style contact options, the UTS series can also be equipped with PCB contacts. Crimp contacts are available in different versions: • Machined 162 • Stamped & Formed • Coaxial • Fiber Optic UTS Series | Contacts Contact Plating Selector Guide Once the contact size has been selected, the next step is to decide on which type to use. Souriau offers two main types of electrical contacts: • Machined • Stamped & Formed Machined contacts are generally chosen as a better solution for power applications or when lower quantities are needed. Stamped & Formed contacts offer the ability to be crimped automatically which makes them more suitable for high volume production applications. The next decision to make is: What plating should I choose? The graph below can help guide you to plating recommendations based on application, mating cycles and current/voltage needs. Note: To avoid galvanic couples, fretting corrosion and at the end interruption of electrical signal do not mix different platings (i.e. tin plated pin contacts with gold plated socket contacts). If customer mixes different contact platings, Souriau can’t guarantee electrical performances. Number of cycles Vibration 250 100 0.4μm of gold min Contacts Gold flash Silver Tin Current / Voltage 1Amp 5mV Contact size #20 #12 #16 #8 163 UTS Series | Contacts Contact Selector Guide Contacts supplied separately Electrical characteristics: contact resistance #20 Ø0.039" #16 Ø0.062" Machined Available platings (contacts supplied separately) < 6mΩ A 2μm Nickel + 2μm Ag J Gold flash over Nickel 2μm mini K 0.4 μm Gold over 2 μm Nickel mini Stamped & Formed < 6mΩ Machined < 3mΩ Stamped & Formed < 6mΩ Machined < 5mΩ S18 Machined < 5mΩ S25 S26 Active part: Gold flash over Nickel Crimp area: 1.3μm Tin mini over Nickel Other: 1.3μm Tin mini Active part: 0.75μm Gold mini over Nickel Crimp area: 1.3μm Tin mini over Nickel Other: 1.3μm Tin mini Active part: 0.75μm Au over Nickel Crimp area: flash Au over Nickel TK6 0.5μm - 2.5μm Sn pre-plated D70 Superseded by S31 S6 Superseded by S18 #12 Ø0.094" #8 Ø0.141" S31 Other platings on request (contacts supplied separately) Contact preloaded T Tin 3μm (-0/+2) over 1.3μm Nickel mini D28* 0.75μm mini Gold over 2μm Nickel mini NPC 2 μm Ni * For Coax contacts only Electrical characteristics: contact resistance #20 Ø0.039" #16 Ø0.062" Machined < 4mΩ Machined < 3mΩ Available plating (contact preloaded) Min 0.4μm gold over 0.8μm Nickel Packaging Due to the wide variety of applications, contact packaging is offered for small series (bulk package) and high volume production (reeled contacts): Size contacts #20 (Ø0.039") & #16 (Ø0.062") • 25 pieces loose package (Stamped & Formed contacts) • 50 pieces bulk package (Machined contacts) • 1,000 pieces bulk package (Machined contacts) • 3,000 pieces reeled (Stamped & Formed contacts) Size contacts #12 (Ø0.094") & #8 (Ø0.141") • 100 pieces bulk package (Machined contacts) Note: 1,000 pieces bulk package available by adding 1000 at the end of the part number: e.g. RC16M23K1000 2,000 pieces reeled package available by adding K at the beginning of the part number: e.g. KRC16M23K 164 • 2,000 pieces reeled (Machined contacts) size #16 only UTS Series | Contacts Crimp Contacts Standard Version Wire size Type Machined #20 Ø1.0mm Ø0.039" #16 Ø1.6mm Ø0.062" #8 Ø3.0mm Ø0.141" AWG mm² Male 26-24 0.13-0.20 RM24W3K 26-24 0.13-0.20 Machined 22-20 0.32-0.52 Female Max wire Ø Max insulator Ø Available plating see page 164 RC24W3K - 0.062" max K SM24W3- SC24W3- SM24WL3-(2) SC24WL3-(2) - RM20W3K RC20W3K - (1) Stamped & Formed (1) SM20W3- SC20W3- SM20WL3-(2) SC20WL3-(2) 0.52-0.80 RM18W3K RC18W3K (1) Stamped & Formed 22-20 0.33-0.52 Machined 20-18 (1) - - TK6 0.035"-0.062" S25 (female) S26 (male) 0.062" max K TK6 0.046"-0.081" S25 (female) S26 (male) 0.082" max K Machined 30-28 0.05-0.08 RM28M1- RC28M1- 0.021" 0.043" K, J Machined 26-24 0.13-0.20 RM24M9- RC24M9- 0.031" 0.062" K, J SM24M1SM24ML1-(2) SC24M1SC24ML1-(2) 0.035"-0.050" No insulation grip S31, S18, TK6 RM20M13- RC20M13- RM20M12- RC20M12- SM20M1-(1) SM20ML1-(2) SC20M1-(1) SC20ML1-(2) 0.046"-0.081" (1) (1) Stamped & Formed 26-24 0.13-0.20 Machined 22-20 0.32-0.52 Stamped & Formed 22-20 0.35-0.52 Machined 20-16 0.52-1.31 RM16M23- RC16M23SC16M1-(1) SC16ML1-(2) 0.046" 0.070" 0.086" K, J No insulation grip S31, S18, TK6 0.070" 0.125" K, J 0.118" No insulation grip S31, S18, TK6 Stamped & Formed 18-16 0.80-1.31 SM16M1-(1) SM16ML1-(2) Stamped & Formed 18-16 0.80-1.31 SM16M11-(1) SM16ML11-(2) SC16M11-(1) SC16ML11-(2) 0.078"-0.118" Insulation grip S31, S18, TK6 Machined 16-14 1.31-20.8 RM14M30- RC14M30- 0.089" 0.125" K, J 2.08 SM14M1SM14ML1-(2) SC14M1SC14ML1-(2) 0.125" No insulation grip S31, S18, TK6 - 0.192" A, K - 0.255" A Stamped & Formed #12 Ø2.4mm Ø0.094" Part number Machined Machined 14 (1) (1) 22 0.32 82911457N- 82911456- 20 0.52 82911459N- 82911458- 18 0.80 82911461N- 82911460- 16 1.31 82911463N- 82911462- 14 2.08 82911465N- 82911464- 12 3.31 82911467N- 82911466- 16 1.31 82913601A 82913600A 14 2.08 82913603A 82913602A 12 3.31 82913605A 82913604A 10 5.26 82913607A 82913606A 8 8.37 82913609A 82913608A (1) contact reeled (2) loose contact Example: RM24W3K - Size #20, Machined, AWG24 wire. Contacts Contact size Note: all dimensions are in inches, other wise noted 165 UTS Series | Contacts Crimp Contacts (Continued) First Mate Last Break Contacts Contact size Type #16 Ø0.062" Machined Longer male contact (+0.039") #16 Ø0.062" Shorter female contact (-0.027") Machined Wire size Part number AWG mm² Male 30-28 0.05-0.08 26-24 0.13-0.20 22-20 0.32-0.52 - 20-16 0.52-1.31 RM28M1GE1K RM24M9GE1K RM20M13GE1K RM20M12GE1K RM16M23GE1K RM14M30GE1K - RC28M1GE7K RC24M9GE7K RC20M13GE7K RC20M12GE7K RC16M23GE7K RC14M30GE7K 16-14 1.31-2.08 30-28 0.05-0.08 26-24 0.13-0.20 22-20 0.32-0.52 20-16 0.52-1.31 16-14 1.31-2.08 Female Color band Max wire Ø (mm) Max insulator Ø (mm) Front 0.021" 0.043" - Red 0.031" 0.062" Red Red 0.046" 0.070" Rear 0.070" Black Red 0.086" Blue Red 0.125" - Red 2.28 - - Red 0.021" 0.043" - Blue 0.031" 0.062" Red Blue 0.070" Black Blue 0.086" Blue Blue 0.070" 0.125" - Blue 0.089" - - Blue 0.046" Available plating see p. 164 K K How to make FMLB / LMFB connection Contact 1 Contact 2 Standard male contact Standard female contact Longer male contact Standard male contact Standard female contact Shorter female contact Note: all dimensions are in inches 166 First Mate Last Break contacts should be chosen only if the cavity is not marked with the ground symbol. For cavities marked with the ground symbol, standard contacts will fulfill the same role as a first mate, last break contact used in a standard cavity. FMLB LMFB Ground symbol UTS Series | Contacts #16 Coaxial Contacts Coaxial Contact Range souriau provides 2 types of coaxial contacts suitable for 50 or 75Ω, coaxial cable or twisted pair cable. Monocrimp coaxial contact • The monocrimp one-piece coaxial contacts offer high reliability plus the economic advantage of a 95% reduction in installation time over conventional assembly methods. • This economy is achieved by simultaneously crimping both the inner conductor and outer braid or drain wire. Multipiece crimp coaxial contact • The inner conductor and outer braid is crimped individually. • The thermoplastic insulating bushing in the outer body is designed to accept and permanently retain the inner contact. • An outer ferrule is used to connect the braid to the outer contact and provide cable support to ensure against bending and vibration. Suitable for coaxial cable or twisted cable Contacts • For jacket diameter from 0.025" to 0.057" Inner conductor from AWG30 to AWG24 • For jacket diameter from 0.070" to 0.120" Inner conductor up to 0.096" diameter Contacts for coaxial cable summary Contact range Contact type Male contact Female contact Multipiece RMDXK10D28 RCDXK1D28 Monocrimp RMDX60xxD28 RCDX60xxD28 Contact part number with cable combination See page 200 Cabling notice See pages 204 & 205 See page 206 Contacts for twisted pairs cable summary Contact range Male contact Female contact Contact part number with cable combination Multipiece RMDXK10D28 + YORK090 RCDXK1D28 + YORK090 See page 201 Monocrimp RMDX60xxD28 RCDX60xxD28 Contact type Cabling notice See page 202 See page 203 167 UTS Series | Contacts PCB Contacts PCB Contacts Supplied Separately - UTS Standard Series PCB soldering The UTS Series can be used in a wave soldering process, but not reflow soldering process. All high temperature processes are prohibited. Part number Contact size Male Female #20 Ø0.039" RMW50A7K RMW5016K #16 Ø0.062" RM20M12E8K RM20M12E83K RM20M12E84K RCW50A7K RCW5016K RC20M12E8K RC20M12E83K RC20M12E84K RC20M12E85K RC20M12E86K RC20M12E87K #8 Ø0.141" 82911685NPC Plating see page 164 K K 82911684NPC 2 μm Ni G Nominal length G (inches) Dimension of dipsolder contacts out of connector (contacts to be ordered separately). UTS0 with PCB contacts #16 Connector size Pin contact RM20M 12E83K* RM20M 12E8K* RM20M 12E84K* RC20M 12E8K* Socket contact RC20M RC20M 12E83K* 12E84K* RC20M 12E87K* 10 0.165" 0.370" 0.507" 0.165" 0.370" 0.507" 0.255" 12 0.141" 0.346" 0.484" 0.165" 0.370" 0.507" 0.255" 14 0.129" 0.334" 0.472" 0.102" 0.307" 0.444" 0.192" 18 0.165" 0.366" 0.507" 0.165" 0.370" 0.507" 0.255" RMW 5016K* RC20M 12E84K* Socket contact RCW 50A7K* RCW 5016K* 0.366" 0.141" 0.330" 0.366" 0.366" UTS7 with PCB contacts #20 and #16 Connector size RM20M 12E83K* 10 0.287" Pin contact RM20M RMW 12E84K* 50A7K* 0.425" 0.330" 12 0.287" 0.425" 0.330" 0.366" 0.153" 0.330" 14 0.287" 0.425" 0.330" 0.366" 0.141" - - 18 0.318" 0.456" 0.330" 0.366" 0.141" - - UTS7 with PCB contacts #16 and #8 Connector type Socket contact RC20M12E87K* 82911684NPC* 82911685NPC* UTS7142G1P - 0.251" - - UTS7142G1S - - - 0.322" UTS7142G1SNPT - 0.228" - 0.212" UTS718X2M3 0.192" 0.177" 0.114" 0.204" UTS7183G1SNPT - - - 0.164" * Plating indication see page 164 Note: all dimensions are in inches 168 Pin contact RM20M12E83K* UTS Series | Contacts PCB Contacts Loaded - UTS Sealed Unmated Series PCB soldering The UTS Series can be used in a wave soldering process, but not reflow soldering process. All high temperature processes are prohibited. UTS0 UTS7 G G Nominal length G (inches) Dimension of dipsolder contacts out of connector (contacts to be ordered separately). UTS0 8 10 12 14 Connector Part Number Pin contact Socket contact G mini G maxi G mini G maxi 8D2 - 8D3 8D4 0.283" 0.362" 0.275" 0.354" 8D3A/8D98 8D33 0.318" 0.409" 0.318" 0.397" 10D6 - 10D98 10D7 0.318" 0.401" 0.318" 0.405" 12D2 - 12D3 12D8 - 12D10 0.318" 0.401" 0.318" 0.405" 12D4 0.322" 0.393" 0.318" 0.405" 12D14 0.283" 0.354" 0.279" 0.362" 14D5 - 14D12 - 14D15 14D18 - 14D19 0.318" 0.401" 0.318" 0.405" 14D7 0.322" 0.393" 0.318" 0.405" Connector Part Number G mini G maxi G mini G maxi 8D2 - 8D3 8D4 0.149" 0.240" 0.145" 0.232" 8D3A/8D98 8D33 0.185" 0.287" 0.185" 0.275" 10D6 - 10D98 10D7 0.185" 0.287" 0.185" 0.275" 12D2 - 12D3 12D8 - 12D10 0.185" 0.287" 0.185" 0.275" 12D4 0.192" 0.279" 0.185" 0.275" Contacts Connector size UTS7 Connector size 8 10 12 14 Pin contact Socket contact 12D14 0.149" 0.232" 0.149" 0.232" 14D5 - 14D12 - 14D15 14D18 - 14D19 0.188" 0.287" 0.192" 0.275" 14D7 0.192" 0.279" 0.192" 0.275" Note: all dimensions are in inches 169 UTS Series | Contacts Fiber Optic Contacts Description Size 16 fiber optic contacts for UTS and other TRIM TRIO® connectors Size 16 fiber optic contacts are designed for the integration of optical links in UTS and other TRIM TRIO® cable connectors. The Fiber optic contacts are designed to accommodate: • Plastic Optical Fiber (POF) 0.039" core and 0.086" jacket Typical features and benefits are: • Socket contact is spring loaded to avoid any air gap between the two optical faces. • Low insertion loss is provided by high precision pieces. • Single jumpers, multiway harness and active device housings can be supplied regarding customer requirement. Technical Characteristics Performance • Fiber type:................................................................................................... POF • Wave length:................................................................................................ 650 nm • Optical insertion loss (typ.):......................................................................... 2 dB max. • Jacketed external diameter:........................................................................ 0.086" • Temperature range:..................................................................................... -25°C to +70°C • Cable retention:........................................................................................... 49N • Mating cycles without cleaning:.................................................................. 50 • Max. mating cycles:..................................................................................... 500 Construction • Contact body: Copper alloy Connector accommodation Any TRIM TRIO® size 16 contact can be used in any contact position in any connector in the TRIM TRIO® size 16 interconnection system: UTP, UTS, UTG, UTO, UTL. 170 UTS Series | Contacts Ordering Information POF Contacts (Plastic Optical Fiber) Male contact......................................... RMPOF1000 Female contact................................... RCPOF1000B POF Contact (Plastic Optical Fiber) Part numbers Descriptions SPECIFIC TOOLING LIST - Can only be ordered separately Part numbers Descriptions 80WD0005 Stripping tool 80WG0010 Needle 80WD0025 Automatic stripping tool for Ø 0.019", 0.023", 00.027" & 0.149" 80WG0015 Capsule 80WM0006 Ruler 80WG0016 Syringe 80WP0005 Polishing plate 80WN0005 Dry air spray 80WP0013 Non slip base (to hold the polishing plate) 80WN0006 Optical paper 80WP0014 Polishing disk (grain size 9µm) 80WN0012 Dropper bottle 80WP0018 Polishing tool 80WN0008 Wiping solvent 80WP0019 Polishing disk (grain size 30µm) 80WS0002 Crimping plier Contacts STANDARD TOOLING KIT - P/N 80MS0004 The standard tooling kit is made of the part numbers below that can be ordered separately as well. 171 UTS SERIES © 2015 SOURIAU - SOURIAU is a registratred trademark UTS Series Technical Information Tooling ..................................................................................................................... 174 Stripping & Crimping Instructions ........................................................................... 176 Handle & Interchangeable Heads ........................................................................... 178 Insertion & Extraction Tools ..................................................................................... 179 Overmolded Harnesses Dimensions ....................................................................... 179 Assembly Instructions .............................................................................................. 180 Mated Connector Lengths ...................................................................................... 184 Mating Procedure .................................................................................................... 185 Rated Current & Working Voltage ........................................................................... 186 UV Resistance .......................................................................................................... 187 UL94 + UL1977 ........................................................................................................ 188 IEC 61984 & IP Codes Explained ............................................................................ 191 IEC 61140 Explained ............................................................................................... 193 What is NEMA Rating ? ........................................................................................... 194 Ethernet for the Layman .......................................................................................... 195 173 UTS Series | Technical Information Automatic Crimping Tools Mecal is a leader in manufacturing tooling for crimping terminals over a stripped wire. Established in 1976, Mecal has become one of the world's leading companies dedicated to the design and manufacture of semi automatic production tools for strip fed, open barrel crimp terminals, serving the Automotive, Telecom and Datacom industries. The extreme environment interconnect specialist “from deep sea to deep space”. SOURIAU designs, manufactures and markets high performance interconnect solutions for severe environments dedicated to the aerospace, defense, light and heavy industry markets. SOURIAU has been working in partnership with Mecal for many years. With sales offices located in all major industrial regions of the world, the combined strengths of both organizations has resulted in a truly global solution to all your production tooling needs. Mini Applicator Stripper Mecal sales network: http://www.mecalbystarn.com/ 174 Presses UTS Series | Technical Information Tooling Crimp Tool Table Standard contacts Contact size #16 Ø0.062" (1) loose contact Head* S20RCM RX20D44 S20SCM20 S16RCM20 SHANDLES S16RCM16 S16RCM14 RX2025GE1 S16SCM20 S16SCML1 S16SCML11 Part number Hand tool 82911457N* / 82911456* 82911459N* / 82911458* 82911461N* / 82911460* 82911463N* / 82911462* M317 82911465N* / 82911464* 82911467N* / 82911466* 82913601A / 82913600A #8 Ø0.141" Extraction tools * endurance of SHANDLES & Head tools = 50,000 cycles Contact size #12 Ø0.094" Handles* 82913603A / 82913602A 82913605A / 82913604A M317 82913607A / 82913606A 82913609A / 82913608A Tool with separate locator Positioner + locator setting 1-2 2 2 VGE10077A 3 3 4 3 3 4 VGE10078A 5 6/7 Extraction tools 51060210924 51060210936 Technical Information #20 Ø0.039" Part number RM/RC 24W3K RM/RC 20W3K RM/RC 18W3K SM 24WL3S*(1) SC 24WL3S*(1) SM/SC 20WL3S*(1) RM/RC 28M1* RM/RC 24M9* RM/RC 20M13* RM/RC 20M12* RM/RC 16M23* RM/RC 14M30* SM/SC 24ML1*(1) SM/SC 20ML1*(1) SM/SC 16ML1*(1) SM/SC 14ML1*(1) SM/SC 16ML11*(1) * see page 165 for plating options and other contact details Specific contacts (First mate Last break contacts) Contact size #16 Ø0.062" Longer RM contact Part number* RM28M1GE1K RM24M9GE1K RM20M13GE1K RM16M23GE1K RM20M12GE1K RM14M30GE1K Hand tools (SHANDLES) head Tool with separate locator Hand tool Positioner + locator setting S16RCM20 - - - S16RCM16 S16RCM14 MH860 - MH86186 - 6/8 MH860 MH86164G RC28M1GE7K #16 Ø0.062" Shorter RC contact RC24M9GE7K RC20M13GE7K RC20M12GE7K RC16M23GE7K RC14M30GE7K * see page 164 for plating options and other contact details S16RCM20 S16RCM16 S16RCM14 M317 UH25 4/6 5/6 Extraction tools RX2025GE1 5/7 6/8 3 Coaxial contacts See coax contacts details on page 167 and cabling notice pages 202 to 206. 175 UTS Series | Technical Information Stripping & Crimping Instructions Wire Stripping Crimp Version Part number Male Female Machined contact Stripping length L (inches) #20 (Ø0.039") RM24W3- / RM20W3RM18W3- RC24W3- / RC20W3RC18W3- 0.188" #16 (Ø0.062") L RM28M1- / RM24M9RM20M13- / RM20M12- RC28M1- / RC24M9RC20M13- / RC20M12- 0.188" RM16M23- /RM14M30- RC16M23- /RC14M30- 0.279" #8 (Ø0.141") 82913601- / 8291360382913605- / 8291360782913609Stamped & Formed 82913600- / 8291360282913604- / 8291360682913608- 0.255" to 0.295" #16 (Ø0.062") With insulation support SM24M1- / SM24ML1SM20M1- / SM20ML1- SC24M1- / SC24ML1SC20M1- / SC20ML1- 0.157" SM16M11- / SM16ML11- SC16M11- / SC16ML11- 0.183" SM24W3- / SM24WL3SM20W3- / SM20WL3- SC24W3- / SC24WL3SC20W3- / SC20WL3- #20 (Ø0.039") L Without insulation support 0.157" #16 (Ø0.062") L SM16M1- / SM16ML1- SC16M1- / SC16ML1- 0.250" SM14M1- / SM14ML1- SC14M1- / SC14ML1- 0.250" Power Contacts Machined #12 (Ø0.094") L 82911457- / 8291145982911461- / 8291146382911465- / 82911467- 82911456- / 8291145882911460- / 8291146282911464- / 82911466- 0.275" to 0.314" #8 (Ø0.141") L 82913601- / 8291360382913605- / 8291360782913609- 82913600- / 8291360282913604- / 8291360682913608- 0.255" to 0.295" Note: See page 165 for plating options and other contact details Wire Stripping Solder and Screw Versions Stripping length L Solder contact delivered with connector L #16 (Ø0.062") & #20 (Ø0.039") 0.196" Screw contact delivered with connector L Note: all dimensions are in inches 176 #16 (Ø0.062") 0.228" UTS Series | Technical Information Crimping One of the key factors which affects the performance of a connector is the way contacts are terminated. Crimped connections are nowadays seen as the best solution to ensure quality throughout the lifetime of the product. Here are some reasons why we recommend this method of termination for UTS connectors: To ensure that the crimp tooling is performing according to original specifications, it is important to carry out regular checks. A common way to check the performance of tooling is with a simple pull test, ideally using a dedicated electric pull tester. Minimum recommended pull forces are indicated in the tables below: Active contact part Machined contacts size #20 Ø0.039" S&F contacts size #20 Ø0.039" Machined contacts size #16 Ø0.062" W Contact type Die location on heads RM24W3K RC24W3K 26/24 RM20W3K RC20W3K 22/20 RM18W3K RC18W3K 20/18 SM24WL3TK6* SC24WL3TK6* 26/24 SM20WL3TK6* SC20WL3TK6* 22/20 RM28M1K* RC28M1K* 30/28 RM24M9K* RC24M9K* 26/24 RM20M13K* RC20M13K* RM20M12K* RC20M12K* S&F contacts size #16 Ø0.062" 18 16 18 16 0.004" min 0.009" max 0.012" min 0.019" max 0.019" max 0.032" max 0.004" min 0.009" max 0.012" min 0.019" max 0.001" min 0.08 max 0.004" min 0.009" max 0.012" min 0.019" max 0.012" min 0.019" max 0.019" max 0.032" max 0.059" max 0.059" min 0.098" min 0.004" min 0.009" max 0.012" min 0.019" max 0.032" min 0.059" max 0.032" min 0.059" max Tensile straight test (mini) 15 N 32 N 40 N 60 N 60 N 90 N 15 N 32 N 40 N 60 N 11 N 11 N 15 N 32 N 40 N 60 N 40 N 60 N 60 N 90 N 150 N 150 N 230 N 15 N 32 N 40 N 60 N 90 N 150 N 90 N 150 N 14 AWG 14 0.098" max 230 N 20 18 16 16 14 RM14M30K* RC14M30K* SM24ML1TK6* SC24ML1TK6* 26/24 SM20ML1TK6* SC20ML1TK6* 22/20 SM16ML11TK6* SC16ML11TK6* SM16ML1TK6* SC16ML1TK6* SM14ML1TK6* SC14ML1TK6* W Wire section range AWG 26 AWG 24 AWG 22 AWG 20 AWG 20 AWG 18 AWG 26 AWG 24 AWG 22 AWG 20 AWG 30 AWG 28 AWG 26 AWG 24 AWG 22 AWG 20 AWG 22 AWG 20 AWG 20 AWG 18 AWG 16 AWG 16 AWG 14 AWG 26 AWG 24 AWG 22 AWG 20 AWG 18 AWG 16 AWG 18 AWG 16 22/20 RM16M23K* RC16M23K* Stamped & Formed contact Section (inches²) Height Width (inches) (inches) H (±0.002") W (±0.002") 0.037" 0.050" 0.049" 0.070" 0.053" 0.073" 0.031" 0.058" 0.039" 0.060" 0.044" 0.055" 0.045" 0.055" Tooling head p/n S20RCM S20SCM20 S16RCM20 0.049" 0.069" 0.065" 0.070" 0.077" 0.082" 0.090" 0.085" 0.089" 0.095" 0.105" 0.109" 0.033" 0.059" 0.040" 0.060" 0.051" 0.053" 0.058" 0.066" 0.082" 0.082" 0.079" 0.080" 0.070" 0.1001" Technical Information Machined contact H H Advantages (Extract from the IEC 60352-2): - Efficient processing of connections at each production level - Processing by fully-automatic or semi- automatic crimping machines, or with hand operated tools - No cold-soldered joints - No degradation of the spring characteristic of female contacts by the soldering temperature - No health risk from heavy metal and flux steam - Preservation of conductor flexibility behind the crimped connection - No burnt, discolored and overheated wire insulation - Good connections with reproducible electrical and mechanical performances - Easy production control. S16RCM16 S16RCM14 S16SCM20 S16SCML11 S16SCML1 * example of plating options, for other plating see page 164 177 UTS Series | Technical Information Handle & Interchangeable Heads User Guide 1) Fully close then release the tool, keep it open. Open the 2 pins. 2) Choose the adapter head (sold separately), keep vertical and slide it into the handle until the mechanical end. 3) Close the two pins simultaneously to maintain the head. 4) Strip the cable properly check the recommended size in the catalog on page 180. GOOD 178 WRONG WRONG 5) Place conductors, with no deteriorations, in the bucket contact. All strands to be located in the crimp bucket. 6) Position the contact in the bottom of the tool by checking its orientation. 7) To crimp contact assembly-cable, tighten sharply the clip to the end of the mechanism (maxi 175N). 8) To control crimp quality, slighty pull cable with two fingers to control retention. UTS Series | Technical Information Insertion & Extraction Tools Contact size Insertion tool #20 Ø0.039" RTM205 #16 Ø0.062" RTM205 Contact size Extraction tools #20 Ø0.039" RX20D44 #16 Ø0.062" RX2025GE1  #12 Ø0.094" 51060210924 #8 Ø0.141" 51060210936 RX2025GE1 RTM205 RX20D44 51060210936 51060210924 Contact extraction instruction Technical Information Place the tool into the cavity from front face of the connector, push on the handle, then remove the contact. Overmolded Cable Assembly Dimensions L L1 UTS7 UTS0 UTS0 UTS7 Shell size L max L1 max L max L1 max 10 3.44" 3.2" 3.67" 3.2" 12 3.55" 3.3" 3.79" 3.3" 14 3.85" 3.6" 4.08" 3.6" L Note: all dimensions are in inches 179 UTS Series | Technical Information Assembly Instructions UTS0 Assembly (Mounting Suggestion) • Strip wires, crimp or solder contacts (see pages 176 & 177) • Insert contacts into connector cavities (insert manually or use tool RTM205 crimp contacts) • Place receptacle in the panel cut-out • Secure receptacle with screws (not supplied) Tighten screws: M2.5 (recommended torque: see table below) • For complete sealing of the system use optional gasket and sealed screw solution (not sold by Souriau). Front mounting: Crimp version Rear mounting: Crimp version 1 1 Optional coding ring Gasket (optional) Front mounting: Solder version 2 Optional coding ring 3 Gasket (optional) Optional coding ring Rear mounting: Solder version 2 Gasket (optional) Optional coding ring 3mm max 3 Gasket (optional) 0.118" max Receptacle flange Receptacle flange Panel thickness: 0.098" max Panel Shell size Screw tightening torque (Nm) 180 8 10 12 14 18 0.30/0.40 0.30/0.40 0.30/0.40 0.30/0.40 0.35/0.45 UTS Series | Technical Information UTS7 Assembly (Mounting Suggestion) • Strip wires and crimp contacts (see pages 176 & 177) • Insert contacts into connector cavities (insert manually or use tool RTM205 crimp contacts ) • Seat o-ring, place receptacle in the panel cut-out • Tighten jam nut Shell size Jam nut torque (Nm) maxi Exterior jam nut dim. (inches) 8 1.5 0.748" 10 3 0.874" 12 4 1.063" 14 5 1.185" 18 5 1.437" Crimp or solder version Optional coding ring O-ring Ø Wire Standard version Discrete wire sealing 0.125" max. From 0.066" to 0.118" Jam nut Panel thickness: 3.2mm max Threaded version Threaded receptacle Shell size Jam nut torque (Nm) maxi Threading P mini (mm) 8 2.5 M12 x 1.5 0.303" 10 3.75 M16 x 1.5 0.303" 12 3.75 M20 x 1.5 0.409" 14 4.18 1/2" 0.326" 18 4.76 3/4" 0.456" P Receptacle Panel thickness • Strip wires and crimp contacts (see pages 176 & 177) • Insert first contact into the grommet (first contact in cavity A, no tool is required). Then insert the contact in the connector cavity A (insert manually or use tool RTM205) • Insert the other contacts • Tighten the nut to rear of either UTS6 or UTS7 (recommended torque values to be applied according to the table below). Technical Information UTS6 or UTS7 with GN Backshell Assembly UTS6 Nut Optional coding ring Shell size layout Nut tightening torque (Nm) 10 4 1 12 8 1.5 14 7 1.5 14 12 1.5 Ø Wire From 0.066" to 0.118" Grommet + Compression ring UTS7 181 UTS Series | Technical Information Assembly Instructions (Continued) • UTS1JC or UTS6JC Assembly: Crimp Version • Slide accessories onto the cable Adapter + mounted gasket UTS6   Make sure the seal is positioned as shown. Reducing Coding ring Standard (optional) • Mate the plug with a corresponding counter part • Strip external cable jacket • Strip wires and crimp contacts (see pages 176 & 177) • Insert contacts into connector cavities (insert manually or use tool RTM205) • Tighten adapter with plug UTS6 or receptacle UTS1, choose right seal (waste the other seal) • Tighten the nut to rear of either UTS1 or UTS6 (recommended torque values to be applied according table to the right) • Caution: only one of both delivered gasket should be used ! • Nut Cable range UTS1 Cable ranges Recommended Adapter Nut Ø Cable range Ø Cable range Ø jacket strip Shell tightening tightening Standard seal Reducing seal Wire size length (inches) torque torque (inches) (inches) (inches) (Nm) (Nm) Male Female 10 0.826" 1.141" 1.5 1 0.098"/0.0314" 0.059"/0.196" From 12 0.984" 1.299" 2 2.5 0.196"/0.472" 0.118"/0.354" 0.066" to 14 1.141" 1.417" 3 2.5 0.275"/0.551" 0.196"/0.472" 0.118" 18 1.456" 1.771" 4 3.5 0.354"/0.708" 0.275"/0.629" UTS6JC Assembly: Solder Version • Slide accessories onto the cable Adapter + mounted gasket   Cable range Reducing Make sure the seal is positioned as shown. • Mate the plug with a corresponding receptacle • Strip external cable jacket • Strip wires and crimp contacts (see pages 176 & 177) • Insert contacts into connector cavities (insert manually or use tool RTM205) • Tighten adapter with plug, choose right seal (waste the other seal) • Tighten the nut to rear of either UTS6 (recommended torque values to be applied according table to the right) • Caution: only one of both delivered gasket should be used ! Note: all dimensions are in inches 182 Nut Standard Coding ring (optional) Shell size 8 10 12 14 Recommended jacket strip length (inches) Male 0.669" 0.826" 0.984" 1.141" Cable ranges Adapter Nut Ø Cable range Ø Cable range tightening tightening Ø Wire Standard seal Reducing seal torque torque (inches) (inches) (inches) (Nm) (Nm) 1 1.5 2 3 0.75 1 2.5 2.5 0.098"/0.255" 0.098"/0.314" 0.196"/0.472" 0.275"/0.551" 1.5/0.196" 1.5/0.196" 0.118"/0.354" 0.196"/0.472" From 0.066" to 0.118" UTS Series | Technical Information • UTS6JC Screw Termination Assembly • Mate the plug with a corresponding receptacle equiped with its contacts • Choose and place right seal depending on cable diameter (see table below) 1 • Slide accessories on the cable • Strip external jacket (see table below). 2 Receptacle Plug Nut • Strip the wires (strip length 0.228") • Place the conductors in the contact barrel. Make sure all conductor strands are inside the barrel • Tight the contact screws, advised torque 20 Ncm 3 4 0.228" Torque: 20Ncm Head dimension 0.157"x 0.078" • Check the mechanical cable retention, by gently pulling the cable with 2 fingers • Tighten adapter with the plug (recommended torque: see table) 5 Technical Information • Tighten backshell nut with adapter (recommended torque: see table below) (cables should not turn into the backshell during this operation). 6 Shell size Recommended jacket strip length (inches) Male Female Adapter tightening torque (Nm) Nut tightening torque (Nm) Ø Cable range Standard seal (inches) Ø Cable range Reducing seal (inches) 12 0.897" max 0.594" max 2 2.5 0.196"/0.472" 0.118"/0.354" 14 1.051" max 0.74" max 3 2.5 0.275"/0.551" 0.196"/0.472" Ø Wire (inches) From 0.066" to 0.118" Note: all dimensions are in inches 183 UTS Series | Technical Information Assembly Instructions (Continued) UTS1GJC or UTS6GJC Assembly • Slide accessories onto the cable (make sure to keep compression ring on the grommet) • Strip external cable jacket • Strip wires and crimp contacts (see pages 176 & 177) • Insert first contact into the grommet (first contact in cavity A, no tool is required). Then insert the contact in the connector cavity A (insert manually or use tool RTM205) • Place the grommet and compression ring on the insulator • Insert the other contacts • Tighten adapter with plug UTS6 or receptacle UTS1, choose right seal (waste the other seal) • Tighten the nut to rear of either UTS1 or UTS6 (recommended torque values to be applied according to the table right). Adapter + mounted gasket Coding ring (optional) Cable range UTS6 Nut Reducing Grommet + Compression ring Standard UTS1 Cable ranges 10 12 Recommended Adapter jacket strip tightening length (inches) torque (Nm) Male Female 0.826" 1.141" 1.5 0.984" 1.299" 2 14 1.141" 1.417" Shell size 3 Nut tightening torque (Nm) Ø Cable range Ø Cable range Standard seal Reducing seal (inches) (inches) 2 2.5 0.098"/8.0 0.196"/0.472" 0.059"/0.196" 0.118"/0.354" 2.5 0.275"/0.551" 0.196"/0.472" Mated Connector Lengths UTS0 + UTS6 UTS7 + UTS6 UTS6JC or UTS6GJC UTS6JC or UTS6GJC UTS0 UTS7 UTS6GN B D A Shell size UTS0 + UTS6JC or UTS6GJC UTS0 + UTS6GN A max 8 2.405" C UTS7 + UTS6JC or UTS6GJC UTS7 + UTS6GN B max C max D max - 3.622" - 10 2.881" 1.559" 3.043" 1.720" 12 3.055" 1.551" 3.216" 1.712" 14 3.287" 1.574" 3.448" 1.736" 18 3.665" - 3.826" - Note: all dimensions are in inches 184 UTS6GN Ø Wire (inches) From 0.066" to 0.118" UTS Series | Technical Information Mating Procedure UTS Coupling Procedure The pictures below provide step by step instructions on how to mate a plug and receptacle connector in order to avoid damaging any of the contacts. • Identify the primary key of each connector. 1 • Align the primary keys of the connectors. 2 • Offer the plug to the receptacle. • Incorrect positioning: 3 4 • Turn coupling ring until you hear a 'click' • If the cable is free, a mechanical stress can appear on the plug and receptacle, at the end you can have a break of the plug or receptacle if there is a high vibration level. 5 6 Technical Information 7 Example of installation 185 UTS Series | Technical Information Rated Current & Working Voltage Current Carrying Capacity The current carrying capacity of a connector is limited by the thermal properties of materials used in its construction. The amount of current that can be handled depends on the size of cable used, the ambient temperature and the heat that is generated inside the connector. Part 3 of the IEC 60512 standard determines through a derating curve, the maximum current permissible, which varies from one layout to another (Fig.1 & Fig.2). Wire size plays an important role in dissipating heat and avoid overheating (Fig.1 & Fig.3). Please note that the curve should be adjusted when dealing with potential hot spots, which can occur as a result of unequal loading of current across a number of contacts. As a general rule, it is best to avoid placing power handling contacts in the middle of the connector; try to locate them towards the edge where heat can be dissipated more effectively. Eventually you should find a level which represents the permissible operating range: Fig.1: UTS 12-4 – 1.5mm² wires 28 28 25 25 23 23 20 18 15 13 10 18 15 13 10 8 5 5 3 3 0 20 40 60 80 100 Ambient Operating Temperature (°C) 120 0 0 20 40 60 80 100 Ambient Operating Temperature (°C) 120 Fig.3: UTS 12-4 – 2.5mm² wires 35 33 Current (A) 20 8 0 Fig.2: UTS 12-8 – 1.5mm² wires 30 Current (A) Current (A) 30 30 28 25 23 Current use 20 18 Limited use 15 13 Not recommended use 10 8 5 3 0 0 20 40 60 80 100 Ambient Operating Temperature (°C) 120 The rated current is defined as uninterrupted continuous current that a connector can take when all contacts are energized simultaneously without exceeding the maximum limit of temperature. The earth contact is never loaded. 186 UTS Series | Technical Information UV Resistance Exposure in Natural Environment Solar radiation affects all materials, but plastics can be susceptible to extreme degradation over time. The choice of materials for the UTS series was therefore a critical consideration. Yearly mean of daily irradiation in UV (280-400 nm) on horizontal plane (J/cm²) (1990-2004) 90° 60° All over the world we are not exposed to the same amount of energy given by the sun. The chart shown here clearly illustrates this. 30° 0° So we performed test according to the ISO 4892-2 and simulated 5 years exposure to outdoor environments (temperature, humidity, etc.). After this period there was no significant colour variation, no crazing, no cracking and no major variation of mechanical properties. - 30° - 60° - 90° - 180° - 150° - 120° - 90° - 60° - 30° 0° 30° 60° 90° 120° 150° 180° Technical Information 190 180 170 160 150 140 130 120 110 100 90 70 80 60 50 40 30 20 0 10 J/cm² In addition, we asked UL to perform UV test per the UL746C. Our material has been rated F1 which is the highest level in this standard. 187 UTS Series | Technical Information UL94 + UL1977 Underwriter Laboratories There are two main standards for industrial connectors: UL94 & UL1977 UL94 This standard is dedicated to plastics flammability. It characterises how the material burns in various orientation and thicknesses. The UTS series has been rated at V-0 for UTS sealed mated & HB for UTS sealed unmated. Procedure: A specimen is supported in a vertical or horizontal position and a flame is applied to the bottom of the specimen. The flame is applied for ten seconds and then removed until flaming stops, at which time the flame is reapplied for another ten seconds and then removed. Two sets of five specimens are tested. V-0 Vertical burning: • Specimens must not burn with flaming combustion for more than 10 seconds after each test flame application • Total flaming combustion time must not exceed 50 seconds for each set of 5 specimens • Specimens must not burn with flaming or glowing combustion up to the specimen holding clamp • Specimens must not drip flaming particles that ignite the cotton • No specimen can have glowing combustion remain for longer than 30 seconds after removal of the test flame. Material 13±0.5mm 125±1mm 45° 300±1mm ~ ~ Cotton 100±1mm HB Horizontal burning: • A material classified HB shall not have a burning rate exceeding 40 mm per minute over a 75 mm span for specimens having a thickness of 3.0 to 13 mm • A material classified HB shall not have a burning rate exceeding 75 mm per minute over a 75 mm span for specimens having a thickness less than 3.0 mm • A material classified HB shall cease to burn before the 100 mm reference mark. 188 25±1mm Material 13±0.5mm 45° Wire gauze 45° 10±1mm Wire gauze UTS Series | Technical Information Underwriter Laboratories UL1977 There are several standards which deal with plug and receptacle. Each of them is only for a small area of applications. It could be telecommunication, etc. The UL 1977 covers single and multipole connectors intended for factory assembly. Requirements apply to devices taking into account intensity and voltage. The categories are as follows: 30 V (42 V peak) 0 600 V 0 Type 0 Type 1A Type 2 31 A Tybe 1B Type 3 Type 4 1000 A According to above table, the level of performance that has to be reached could be different. Most of them are explained in the following page. Insulating materials: Technical Information Material uses for electrical insulation, as a minimum, have to comply with the characteristics shown below: • Minimum ratings for polymeric materials Type Flame rating Relative thermal index (RTI) Electrical/mechanical w/o impact */** 0 - 50/50 1A HB 50/50 1B HB 50/50 2 HB 50/50 3 HB 50/50 4 HB 50/50 * The RTI of the material shall not be lower than the temperature measured during the Temperature Test. ** For a thickness less than that for which a value has been established, the RTI of the minimum thickness with an established value shall be used. Assembly: Connector has to be keyed to prevent any mismating that can damage the machine or hurt the user. In the same way, plugs and sockets have to be equipped to protect persons against contact with live parts. Finally the identified grounding contact shall be located so that the corresponding electrical continuity has to be completed before any other contact. 189 UTS Series | Technical Information UL94 + UL1977 (Continued) Underwriter Laboratories UL1977 Spacing: For a 250V max connector, distance through air or over material shall be 1.2mm whereas from 250V to 600V connector the spacing is 3.2mm minimum. These distances have to be taken between uninsulated live parts as shown in the matrix below: • Applicability of spacing requirements Type Uninsulated live part - uninsulated live part of opposite polarity Uninsulated live part - uninsulated grounded metal part Uninsulated live part - exposed dead metal part 0 No No No 1A Yes Yes Yes 1B Yes Yes No 2 Yes Yes Yes 3 Yes Yes Yes 4 Yes Yes Yes An alternative way to determine voltage rating is with the Dielectric-Withstand test. If during one minute there is no arc-over or breakdown the rated voltage is given as shown below: a) 500 volts for a type 1B device b) 1000 volts plus twice rated voltage for types 1A, 2, 3 and 4 devices. Marking: A device shall be legibly marked with the manufacturer's trade name, trade mark, or other descriptive marking by which the organization responsible for the product may be identified. (Exception: If the device is too small, or where the legibility would be difficult to attain, the manufacturer’s name, trademark, or other descriptive marking may appear on the smallest unit container or carton) The following shall be marked on the device or on the smallest unit container or carton or on a stuffer sheet in the smallest unit container or carton: a) The catalog number or an equivalent designation b) The electrical rating in both volts and amperes, if assigned c) Whether ac or dc, if restricted d) Flammability class, if identified Example - Marking for the arrangement 10-3: 190 10A 500V UL94 V-0 UTS Series | Technical Information IEC 61984 & IP Codes Explained IEC 61984 The norm is dedicated to connectors with rated voltage above 50V and up to 1000V and rated currents up to 125A per contact. Depending on your application connectors should be compliant with another standard. This has to be double checked with the customer. There are a lot of constructional requirements and performances specified in that standard. Most of them are illustrated in greater details hereafter. Provisions for earthing: The UTS connector is intended to be used on Class I or Class III (see IEC 61140) systems. Even if the purpose of our connector is not to interrupt current, there is a need to add a protective earth contact. This one shall be a “First mate, last break” style. Critically, among all of the normal assumptions we make in designing a connector, this contact has to be considered as a live part and must be protected attached to the ground wire. First digit (foreign bodies protection) IP Code: IP is a coding system defined by the IEC 60529 to indicate the degrees of protection provided by an enclosure. The aim of this is to give information regarding the accessibility of live parts against ingress of water and other foreign bodies. 5 6 Full protection against contact. Protection against interior injurious dust deposits. Total protection against contact. Protection against penetration of dust. UTS offers high sealing performance IP68 / 69K… Even in dynamic situations. IP 6 8 Second digit (water protection) 2nd digit Degree of protection 0 No protection against water. 1 2 Drip-proof. Protection against vertical water drips. Drip-proof. Protection against water drips up to a 15° angle. 3 Spray-proof. Protection against diagonal water drips up to a 60° angle. 4 Splash-proof. Protection against splashed water from all directions. Hose-proof. Protection against water (out of a nozzle) from all directions. Protection against temporary flooding. 5 6 7 8 Technical Information 1st digit Degree of protection 0 No protection against accidental contact. No protection against solid foreign bodies. 1 Protection against contact with any large area by hand and against large solid foreign bodies with a diameter bigger than 50 mm. 2 Protection against contact with the fingers. Protection against solid foreign bodies with a diameter bigger than 12 mm. 3 Protection against tools, wires or similar objects with a diameter bigger than 2.5 mm. Protection against small solid bodies with a diameter bigger than 2.5 mm. 4 Same as 3 however diameter is bigger than 1 mm. Code letters (international Protection) Protection against temporary immersions. Protection against water pressure. Pressure to be specified by supplier. In addition to the IEC 60529 we conjointly use the DIN 40050 part 9 which are dedicated to road vehicles. The main differences are: • First digit: 5 replaced by 5K, 6 by 6K. In the DIN the tested equipment is not depressurized as it is in the IEC. • Second digit: 5K and 6K has been added and are equivalent respectively to 5 and 6 but with higher pressure. 9K which represents the High pressure cleaning. 9K High pressure hose-proof. Protection against high pressure water (out of a nozzle) from all directions. IEC 61984 ed.2.0 “Copyright © 2008 IEC Geneva, Switzerland.www.iec.ch" IEC 60664-1 ed.2.0 “Copyright © 2007 IEC Geneva, Switzerland.www.iec.ch” 191 UTS Series | Technical Information IEC 61984 & IP Codes Explained (Continued) IEC 61984 Overvoltage UTS connectors are qualified to be used on systems rated at Overvoltage category III Per the IEC 60664-1 (formely VDE 0110) each category is linked to the end application and where the device will be implemented: • Category IV (primary overcurrent protection equipment): Origin of the installation • Category III (any fixed installation with a permanent connection) Fixed installation and equipment and for cases where the reliability and the availability is subject to special requirements • Category II (domestic appliances): Energy consuming equipment to be supplied from the fixed installation • Category I (protected electronic circuit): For connection to circuit in which measures are taken to limit transient overvoltage. Pollution degree Per the IEC 60664-1 (formerly VDE 0110) the environment affects the performance of the insulation. Particles can build a bridge between two metal parts. As a rule dust mixed with water can be conductive and more generally speaking metal dust is conductive. Finally, the standard defines 4 levels of pollution: • Degree 1 (Air conditioned dry room): No pollution or only dry, non conductive pollution occurs. The pollution has no influence. • Degree 2 (Personal computer in a residential area): Only non conductive pollution occurs except that occasionally a temporary conductivity caused by condensation is to be expected. • Degree 3 (Machine tools): Conductive pollution occurs or dry non-conductive pollution occurs which becomes conductive due to condensation which is to be expected. • Degree 4 (Equipments on roof, locomotives): Continuous conductivity occurs due to conductive dust, rain or other wet conditions. Finally, the harsher the environment is, the longer clearance and creepage distances should be. Nonetheless, according the IEC 61984, enclosure rated at IP54 or higher can be dimensioned for a lower pollution degree. This applies to mated connectors disengaged for test and maintenance. Marking The marking should give enough details to the user to know what the main characteristics are and without going deep in technical documentation. Below examples identify the suitability of the connector: • Example 1: Marking of a connector with rated current 16A, rated voltage 400V, rated impulse voltage 6kV and pollution degree 3, 2 and 1 for use in any system, preferably unearthed or delta-earthed systems: 16A 400V 6kV 16A 400V 6kV 33 • Example 2: Marking of a connector with rated current 16A, rated insulation voltages line-to-earth 250V, line-to-line 400V, rated impulse voltage 4kV and pollution degree 3, 2 and 1 for use in earthed systems: 16A250V 250V400V 400V4kV 4kV3 3 16A 192 UTS Series | Technical Information IEC 61140 Explained IEC 61140 On a daily basis, we are using many electrical appliances, some are grounded, and some are not. The levels of grounding protection are clearly defined by the International Electrotechnical Commission standard IEC 61140, a standard that has an influence on our connectors and how they should be used; our customers therefore need to pay particular attention to the three categories defined within this standard to ensure compatibility with their system. Everything explained hereafter is valid for connectors not intended to interrupt current. Class I: Devices which belong to this category have their chassis grounded via the ground wire (green/yellow in Europe, green in the US, Canada and Japan). A fault in the appliance might cause a live conductor to energize the casing. In this case, the current flows to the ground conductor and the circuit interrupter will cut off the power supply. In case of the UTS series, it means the envelope (coupling ring, backshell and housing) may become live, therefore, care needs to be taken to attach the connector to the ground. This is usually done via the ground conductor using a splice between the ground contact and the housing. Class II: Products in this category have reinforced insulation, meaning that the casing does not need to be connected to ground. In this case, the possibility of electric shock has been removed. Most of the time, reinforced insulation means double insulation, i.e. the second layer will take over the first one in case the first one fails. The UTS series is not designed to comply with this standard, so we cannot recommend it for this product category. Note: UL 1310 also defines a class II device, but in that case this is just to set the upper limit of use, like a wall charger for our cell phone. Class III: In this category, electrical appliances are fed by a low voltage source (
UTS014E18S 价格&库存
很抱歉,暂时无法提供与“UTS014E18S”相匹配的价格&库存,您可以联系我们找货
