SWIM SERIES
Shallow Water IMmersion Connectors
& Overmolded Cable Assemblies
Connector Details
Overview
SWIM Series |
Presentation
THE MOST RELIABLE CONNECTOR FOR SHALLOW WATER IMMERSION
Cabling, Mounting and Maintenance Overmolded Cable Assemblies
The SWIM Series (Shallow Water IMmersion) have been created to answer the most demanding needs for
immersion down to 300 meters/1,000 feet depth. These dry mate connector series solve the common issues
met in shallow water applications such as poor sealing and corroded contacts due to low pressure cycles.
SWIM connectors have been designed following customer feedback combined with our 50 year experience in
the subsea market.
Overmolded cable assemblies can also be provided for a quick, reliable and easy to use turnkey solution for
shallow water immersion applications.
Contents
Overview
06
07
10
14
15
16
17
18
Plug and in-line receptacles cable overmolding ..
Insert wiring .......................................................
Insert mounting .................................................
Bulkhead receptacles preparation ....................
Panel mounting bulkhead receptacles ..............
Plug and receptacle coupling............................
Maintenance ......................................................
36
36
37
38
38
39
39
Other Series
Standard overmolded cable assemblies
description.........................................................
Ordering information.........................................
26
27
Connector Details
Technical features ..............................................
Contacts ............................................................
Contact layouts..................................................
Shell dimensions................................................
Cap dimensions .................................................
Tools ..................................................................
Standard contact layouts ...................................
Cable assemblies dimensions ...........................
24
25
TP Series ............................................................
U Series .............................................................
M Series .............................................................
WET/Underwater mateable - 8810 Series .........
Other Series
Typical applications ...........................................
Features & Benefits ...........................................
Range overview .................................................
(Continued)
42
42
43
43
3
SWIM SERIES
© 2018 SOURIAU - SOURIAU is a registered trademark
SWIM Series
Overview
Typical applications ................................................................................................. 06
Features & Benefits ................................................................................................. 07
Range overview ...................................................................................................... 10
SWIM Series | Overview
Observation Class ROVs
© Vladislav Gajic / Shutterstock
Unmanned Underwater Vehicles
Aquaculture
6
Commercial Diving
© Iakov Filimonov / Shutterstock
Buoys
© Dmitri Ma / Shutterstock
Unmanned Surface Vehicles
© Stefan Kühn
© SOURIAU
© moolyknow / Shutterstock
Overview
Features & Benefits
THE Connector for Shallow Water Immersion
RELIABLE
Perfect watertightness even at low pressure.
Shell to shell sealing with a robust coupling ring.
Double sealing security thanks to 2 O-rings in coupling interface.
No stress on O-rings thanks to a conical mating interface.
Overmolded cable termination.
Designed for Long Term Use
DURABLE
EASY
SECURE
High quality PEEK® thermoplastic shell.
No corrosion.
No cathodic delamination.
UV Resistant.
Keying and Easy Coupling
Up to 19 contacts #20.
Easy to mate even with high number of contacts.
5-key mechanical polarization on shells.
Scoop proof to prevent contact damage.
Lightweight.
Full Interconnect Solution
Cable plugs, bulkhead receptacles, in-line receptacles, pre-terminated
VERSATILE overmolded cable assemblies.
Ready to install.
7
Features & Benefits
Reliable connectors designed for Shallow Water Immersion
• Shell to shell sealing with robust coupling ring
• Perfect sealing even at low pressure. Once the coupling ring is tightened, the connectors are sealed!
• O-ring for insert to shell sealing on both plug and receptacle for open face sealing
• Redundancy with 2 O-rings on plug taper seat for plug to receptacle sealing
• Conical coupling interface to reduce the stress on O-rings
Mating indicator (groove)
Bulkhead O-ring
Plug mating O-rings
Receptacle insert /
Shell O-ring
Plug insert /
Shell O-ring
• Overmolded cable termination
• Standard harness offering:
- Straight or right angle overmold in Polyurethane
- Polyurethane cable jacket
For more information, please see page 23 or consult us
8
Features & Benefits
Overview
High grade materials for long term immersion
• Shells are manufactured from Peek®
- Lightweight
- No corrosion
- No cathodic delamination.
• Nylatron molded insulator
• Nitrile O-rings for excellent fluid compatibility (sea water, mineral oil…) and long service life.
• Gold plated copper alloy contacts
• RoHS compliant
Easy wiring and installation
• Scoop proof: No risk of damaging contacts during the coupling operation when using a female plug and a male
receptacle
• Easy screw coupling even with a high number of contacts
• Removable insulators: Allows for easier wiring, wiring corrections and servicing.
Shells and inserts can be stored separately for a flexible insert configuration.
9
Range
Receptacle
RER
See page 18
Overmolded straight cable assemblies
PCE...SL*
See page 31
In-line receptacle
PCE
See page 19
Plug pressure sealing cap
BEF
See page 20
*L = cable length
10
Overview
overview
FED...SL*
See page 27
Plug
FED
See page 18
Overmolded right angle cable assemblies
FED...RL*
See page 29
Receptacle pressure sealing cap
BER
See page 20
*L = cable length
11
SWIM SERIES
SWIM Series
Connector Details
Technical features ................................................................................................. 14
Ordering information .............................................................................................. 15
Contacts ................................................................................................................. 16
Contact layouts ..................................................................................................... 17
Shell dimensions ................................................................................................. 18
Cap dimensions
................................................................................................. 20
Tools ....................................................................................................................... 21
SWIM Series | Connector Details
Connector technical features
Materials
• Housing:
Thermoplastic (Peek®)
• Insulator:
Nylatron® (PA 6/6 + MoS2)
• Contacts:
Gold over Nickel plated copper alloy solder
cup contacts
Electrical
• Contact dimensions:
Voltage
category
SOURIAU
recommended
service voltage
(Vrms 50Hz)
Dielectric
withstanding
voltage
(Vrms 50Hz)
Service 0
350
1,000
Service 1
600
1,500
Service 2
1,000
2,300
• Insulation resistance:
- Unmated connectors: ≥ 104 MΩ
- Mated connectors: ≥ 5x103 MΩ at 500Vcc
Environmental
• Operating temperature range:
From -20°C to +70°C
From -4°F to +158°F
• Watertighness:
30 bar mated or unmated (430PSI)
• Current rating and contact resistance:
Shell
size
10PL
14PL
10PL
14
Current
rating per
contact(A)
Contact
Resistance
(mΩ)
≤4
16
14
≤3
14
≤ 2.5
12
26
≤2
≤ 2.5
7
≤4
Contact
size
Coaxial
50Ω
Coaxial
75Ω
ØF
Contact
Contact
size
termination
OD
0.9 mm
0.035"
1.4 mm
16
0.055"
1.87 mm
14
0.074"
2.3 mm
12
0.091"
- Pin
- Socket
AWG
Conductor
Section
26 to
0,14 to 0,38 mm²
22
22 to
0,38 to 0,93 mm²
18
18 to
0,93 to 1,34 mm²
16
16 to
1,34 to 1,91 mm²
14
ØF
ØF
Connector part numbers
Shell type:
FED: Straight plug
RER: Jam-nut receptacle
PCE: In-line receptacle
FED
M
14PL
N
0720
SA
Y
BER
C
10PL
Y
Type of contact:
M: Pin contacts
F: Socket contacts
Shell size:
10PL: size 10
14PL: size 14
Connector Details
Insert Material:
N: PA66+MoS2 (Nylatron®)
Contact layouts:
See contact layout designation p.17
Cable termination:
SA: Overmolded cable termination (Only for FED and PCE)
Product version:
Index: Y
Examples:
- Size 14 receptacle with 19 male contacts #20 Ã RERM14PLN1920Y
- Size 10 plug with 4 female contacts #16 Ã FEDF10PLN0416SAY
Pressure sealing cap part numbers
Cap type:
BER: Cap for receptacles
BEF: Cap for plugs
Cord set:
C: With cord
-: Without cord (leave blank)
Shell size:
10PL: size 10
14PL: size 14
Product version:
Index: Y
15
Insert sub assembly part numbers (Inc. pre-loaded contacts)
Insert + contact
BIS
14PL
N
04 12
M
CFE
14PL
SA
Y
Shell size:
10PL: size 10
14PL: size 14
Insert material:
N: Nylatron®
Contact layouts:
Type of contact:
M: Pin contacts
F: Socket contacts
Shell sub assembly part numbers
Shell type:
CFE: Plug
CRER: Receptacle
CPE: In-line receptacle
Shell size:
10PL: size 10
14PL: size 14
Cable termination:
SA: Overmolded cable termination (only for FED and PCE)
Product version:
Index: Y
O-ring part numbers
O-ring type
10PL
14PL
ò Panel O-ring (for REC-RER)
10-01 (Ø1.78 x 18.77 mm) (Ø0.070" x 0.739")
14-01 (Ø2.5 x 26 mm) (Ø0.098" x 1.0236")
ù Insulator/shell O-ring
10-02 (Ø1.78 x 8.73 mm) (Ø0.070" x 0.344")
14-02 (Ø1.9 x 16 mm) (Ø0.075" x 0.629")
ä Taper seat O-rings
10-03 (Ø1.78 x 12.42 mm) (Ø0.070" x 0.489")
14-03 (Ø1.78 x 20.35 mm) (Ø0.070" x 0.801")
ò ù
RER receptacle
16
ä
ù
FED plug
ä
BER cap
Contact layouts
Size 10PL
1C75
1C50
1C50SMA
0214
0314
0416
0516
0720
0920
2#14
3#14
4#16
5#16
7#20
9#20
Service 2
Service 2
Service 2
Service 1
Service 1
Service 0
1C#75 or 1C#50
or 1C#50SMA
Service 1
Connector Details
* Please consult us.
Size 14PL
0312
0412
0714
1216
3#12
4#12
7#14
12#16
Service 2
Service 2
Service 2
Service 2
Layout caption
1920
03121020
19#20
3#12 & 10#20
Service 1
Service 1
Layout ID for part number
Number of contact & Size
Voltage service rating
17
Connector dimensions
FED - Straight plug
Shell size
10PL
14PL
Ø A max
25.9 mm
1.020"
34 mm
1.339"
ØB
17.8 mm
0.701"
24 mm
0.945"
Ø C max
18.75 mm
0.738"
25 mm
0.984"
ØD
18.75 mm
0.738"
25.75 mm
1.014"
E max
52.5 mm
2.067"
52.5 mm
2.067"
F
20 mm
0.787"
20 mm
0.787"
G min
5 mm
0.197"
5 mm
0.197"
ØH
15 mm
0.591"
22 mm
0.866"
E max
Ø G min
ØD
Ø C max
ØB
ØH
Ø A max
F
Maximum outer cable diameter = ØH (depending on
the fluidity of the compound)
RER - Jam-nut receptacle
Chamfer
0.2 mm max / 0.007" max
Ø K min for Ra.1.2 μm
Ø I mm/0.039"+0.1
J
L max
L min
Shell size
A
B
C
D
ØE
F
C
A on flats
B on flats
Ø G (ACME)
D
ØH
ØE
ØH
ØG
ØI
J
Ø K min
F
10PL: Jam-nut recommended torque: 3.5 N.m
14PL: Jam-nut recommended torque: 5.5 N.m
18
L min
L max
10PL
14PL
22 mm
0.866"
16 mm
0.630"
37 mm
1.457"
14 mm
0.551"
24 mm
0.945"
4 mm
0.157"
30 mm
1.181"
23 mm
0.906"
37 mm
1.457"
14 mm
0.551"
33 mm
1.299"
5 mm
0.197"
7/8"
1"3/16
26 mm
1.024"
18.2 mm
0.717"
16.2 mm
0.638"
25 mm
0.984"
4 mm
0.157"
9 mm
0.354"
34 mm
1.339"
25.2 mm
0.992"
23.2 mm
0.913"
34 mm
1.339"
4 mm
0.157"
9 mm
0.354"
Connector details dimensions
PCE - In-line receptacle
Ø A (ACME)
ØB
Ø C max
ØD
ØE
G max
I max
H max
J max
ØF
ØD
Ø C max
ØF
ØE
Ø B max
Ø A max
G max
H max
I min
J max
K
K on flats
10PL
14PL
7/8"
1’’3/16
26.2 mm
1.031"
20.8 mm
0.819"
18.75 mm
0.738"
17.8 mm
0.701"
15 mm
0.591"
61.3 mm
2.413"
25.4 mm
1.000"
5 mm
0.197"
20 mm
0.787"
21 mm
0.827"
34.2 mm
1.346"
28.6 mm
1.126"
25 mm
0.984"
24 mm
0.945"
22 mm
0.866"
61.3 mm
2.413"
25.4 mm
1.000"
5 mm
0.197"
20 mm
0.787"
29 mm
1.142"
Connector Details
Shell size
Maximum outer cable diameter = ØH (depending on the fluidity of the compound)
Mated connectors
A
Shell size
10PL
14PL
A
55.5 mm
2.185"
55.5 mm
2.185"
B
19.5 mm
0.768"
19.5 mm
0.768"
B
19
Cap dimensions
BEF/BER - Pressure sealing caps
C max
Ø B max
Ø D max
A
ØE
240 mm / 9.448"
240 mm / 9.448"
Shell size
10PL
14PL
A
40 mm
1.575"
40 mm
1.575"
Ø B max
25.9 mm
1.020"
34 mm
1.339"
C max
37.5 mm
1.476"
37.5 mm
1.476"
Ø D max
25.9 mm
1.020"
34 mm
1.339"
ØE
4.2 mm
0.165"
4.2 mm
0.165"
Tools
Connector Details
Insert insertion tool
Connector size
Part numbers
10
OUT542W0000
14
OUT543W0000
Insert retention nut installation tool
Connector size
Part numbers
10
OUT542W5000
14
OUT543W5000
21
SWIM SERIES
SWIM Series
Overmolded Cable
Assemblies
Standard overmolded cable assembly features....................................................... 24
Ordering information .............................................................................................. 25
Standard contact layouts ......................................................................................... 26
Cable assembly dimensions .................................................................................... 27
SWIM Series | Overmolded Cable Assemblies
Standard overmolded
Cable
• Polyurethane outer sheath
• Silicone compound filled
• FEP insulated conductors
• Operating temperature: -30°C + 70°C
-22°F + 158°F
• Operating voltage: 1000V
• Unshielded
• Cable length tolerance: +-2% up to 100m
100 m (328.08 ft)
+-5% above 100 m (328.08 ft)
Overmolding
• Polyurethane overmolding
Cable details
Shell size
10
14
Connector
contact layout
Cable conductor number
and section
Cable outer diameter
Static bending radius
0214
2 x 2.0 mm² / 2 x 14 AWG
8 mm / 0.315"
≥ 50 mm / 1.969"
0314
3 x 2.0 mm² / 3 x 14 AWG
8 mm / 0.315"
≥ 50 mm / 1.969"
0416
4 x 0.93 mm² / 4 x 18 AWG
8 mm / 0.315"
≥ 50 mm / 1.969"
0516
5 x 0.93 mm² / 5 x 18 AWG
8 mm / 0.315"
≥ 55 mm / 2.165"
0720
7 x 0.38 mm² / 7 x 22 AWG
8 mm / 0.315"
≥ 50 mm / 1.969"
0920
9 x 0.34 mm² / 9 x 22 AWG
8 mm / 0.315"
≥ 50 mm / 1.969"
1216
12 x 0.6 mm² / 12 x 20 AWG
12.7 mm/ 0.500"
≥ 130 mm / 5.118"
1920
19 x 0.34 mm² / 19 x 22 AWG
11 mm/ 0.433"
≥ 65 mm / 2.559"
Cable assembly electrical characteristics
Shell size
10
14
24
Connector contact layout
Harness Service Voltage
Harness current rating per line
0214
1,000V
20A
0314
1,000V
20A
0416
1,000V
14A
0516
600V
14A
0720
600V
7A
0920
350V
5A
1216
1,000V
10A
1920
600V
5A
Overmolded cable assembly part numbers
Shell type:
FED: Straight plug
FED
M
14PL
N
0720
SA
Y
S
1
Type of contact:
M: Pin contacts
F: Socket contacts
Shell size:
10PL: size 10
14PL: size 14
Insert Material:
Contact layouts:
Cable termination:
Product version:
Index: Y
Overmolded type:
S: Straight
R: Right angle
Standard available cable length (For custom cable length, please consult us):
1: 1m (3.28 ft)
5: 5m (16.40 ft)
10: 10m (32.81 ft)
Example:
- Size 14 plug right angled overmolded cable assembly with 12 female contacts size 16 and 5m cable: FEDF14PLN1216SAYR5
25
Contacts layouts (Please consult us for other layouts)
Size 10PL
0214
0314
0416
0516
0720
0920
2#14
3#14
4#16
5#16
7#20
9#20
Service 2
Service 2
Service 1
Service 1
Service 1
Service 0
Size 14PL
26
Layout caption
1216
1920
12#16
19#20
Service 2
Service 1
Overmolded cable assembly dimensions
Straight plug - Size 10
L
90.5 mm / 3.563"
Ø 25.9 mm
Ø 1.020"
59 mm / 2.323"
Contact
Layout
Cable conductors
number and section
0214
2 x 2.0 mm
2 x 14 AWG
0.314
3 x 2.0 mm2
3 x 14 AWG
0416
4 x 0.93 mm2
4 x 18 AWG
0516
5 x 0.93 mm2
5 x 18 AWG
0720
7 x 0.38 mm2
7 x 22 AWG
0920
9 x 0.34 mm2
9 x 22 AWG
Cable
diameter
2
8 mm
0.315"
Contact number
Cable conductors
1
Brown
2
Red
3
Orange
4
Yellow
5
Green
6
Blue
7
Violet
8
Grey
9
White
Ø 25 mm
Ø 0.984"
Note: Other cables can be accomodated on request ranging
from 4 to 10 mm (0.157" to 0.394") OD.
27
Straight plug - Size 14 - Contact layouts 1216 and 1920
L
Ø 34 mm
Ø 1.339"
98.6 mm / 3.882"
Ø 25 mm
Ø 0.984"
Layout 1216
Outer
layer
Inner
layer
Layout 1920
Contact number
Cable conductors
Contact number
Cable conductors
1
Brown
1
Red
2
Red
2
Black
3
Orange
3
White
4
Yellow
4
Yellow
5
Green
5
White
6
Yellow
7
White
6
Blue
7
Violet
8
Grey
8
Yellow
9
White
9
White
10
Black
10
Yellow
11
Brown
11
White
12
Red
12
Yellow
Inner
layer
13
Black
14
White
15
Yellow
16
White
Contact
Layout
Cable conductors
number and section
Cable
diameter
17
Yellow
0312
Consult us
18
Red
0412
Consult us
19
Grey
0714
Consult us
1216
12 x 0.6 mm2
12 x 20 AWG
12.7 mm
0.500"
1920
19 x 0.34 mm2
19 x 22 AWG
11 mm
0.433"
03121020
Consult us
Note: Other cables can be accomodated on request ranging from
8 to 16 mm (0.315" to 0.630") OD.
28
Outer
layer
Right angle plug - Size 10
L
62 mm / 2.441"
82 mm / 3.228"
Ø 25 mm
Ø 0.984"
Contact
Layout
Cable conductors
number and section
0214
2 x 2.0 mm2
2 x 14 AWG
0.314
3 x 2.0 mm2
3 x 14 AWG
0416
4 x 0.93 mm
4 x 18 AWG
0516
5 x 0.93 mm2
5 x 18 AWG
0720
7 x 0.38 mm2
7 x 22 AWG
0920
9 x 0.34 mm
9 x 22 AWG
Cable
diameter
2
8 mm
0.315"
2
Contact number
Cable conductors
1
Brown
2
Red
3
Orange
4
Yellow
5
Green
6
Blue
7
Violet
8
Grey
9
White
Ø 25.9 mm
Ø 1.020"
29
Right angle plug - Size 14 - Contact layouts 1216 and 1920
L
67 mm / 2.638"
97.5 mm / 3.839"
Ø 32 mm
Ø 1.260"
Ø 34 mm
Ø 1.339"
Layout 1216
Outer
layer
Inner
layer
Layout 1920
Contact number
Cable conductors
Contact number
Cable conductors
1
Brown
1
Brown
2
Red
2
Red
3
Orange
3
Orange
4
Yellow
4
Yellow
5
Green
5
Green
6
Blue
7
Violet
8
Grey
6
Blue
7
Violet
8
Grey
9
White
9
White
10
Black
10
Yellow
11
Brown
11
White
12
Red
12
Yellow
Contact
Layout
Cable conductors
number and section
Cable
diameter
0312
Consult us
0412
Consult us
0714
Consult us
1216
12 x 0.6 mm2
12 x 14 AWG
12.7 mm
0.500"
1920
19 x 0.34 mm2
19 x 22 AWG
11 mm
0.433"
03121020
Consult us
30
Outer
layer
Inner
layer
13
Black
14
White
15
Yellow
16
White
17
Yellow
18
Red
19
Grey
Straight in-line receptacle - Size 10
L
Ø 26 mm
Ø 1.024"
98 mm / 3.858"
Contact
Layout
Cable conductors
number and section
0214
2 x 2.0 mm2
2 x 141 AWG
0.314
3 x 2.0 mm2
3 x 14 AWG
0416
4 x 0.93 mm
4 x 18 AWG
0516
5 x 0.93 mm2
5 x 18 AWG
0720
7 x 0.38 mm2
7 x 22 AWG
0920
9 x 0.34 mm2
9 x 22 AWG
Cable
diameter
2
8 mm
0.315"
20 mm on flats
0.787" on flats
Contact number
Cable conductors
1
Brown
2
Red
3
Orange
4
Yellow
5
Green
6
Blue
7
Violet
8
Grey
9
White
Ø 25 mm
Ø 0.984"
31
Straight in-line receptacle - Size 14 - Contact layouts 1216 and 1920
L
Ø 34 mm
Ø 1.339"
107 mm / 4.213"
20 mm on flats
0.787" on flats
Ø 32 mm
Ø 1.260"
Layout 1920
Layout 1216
Outer
layer
Inner
layer
Contact number
Cable conductors
Contact number
Cable conductors
1
Brown
1
Red
2
Red
2
Black
3
Orange
3
White
4
Yellow
4
Yellow
5
Green
5
White
6
Blue
6
Yellow
7
White
Outer
layer
7
Violet
8
Grey
8
Yellow
9
White
9
White
10
Black
10
Yellow
11
Brown
11
White
Red
12
Yellow
12
Inner
layer
Contact
Layout
Cable conductors
number and section
Cable
diameter
0312
Consult us
0412
Consult us
0714
Consult us
1216
12 x 0.6 mm2
12 x 20 AWG
12.7 mm
0.500"
1920
19 x 0.34 mm2
19 x 22 AWG
11 mm
0.433"
03121020
Consult us
32
13
Black
14
White
15
Yellow
16
White
17
Yellow
18
Red
19
Grey
Notes
33
SWIM SERIES
SWIM Series
Maintenance
Plug and in-lin receptacle cable overmolding ......................................................... 36
Insert wiring.............................................................................................................. 36
Insert mounting........................................................................................................ 37
Bulkhead receptacles preparation............................................................................ 38
Panel mounting bulkhead receptacles..................................................................... 38
Plug and receptacle coupling................................................................................... 39
Maintenance............................................................................................................. 39
SWIM Series | Cabling, Mounting and Maintenance
Plug and in-line receptacle cable overmolding
Recommendations
SWIM plugs and In-line receptacles are designed for overmolded cable termination.
We suggest the use of a polyurethane cable jacket with a polyurethane overmold.
It is recommended to encapsulate the inside of plugs and in-line receptacles bodies with an appropriate potting
compound prior to overmolding.
Note:
- We provide SWIM overmolded cable assemblies. Please consult page 23 of SWIM Series catalog.
- Receptacles can be backpotted to increase the pressure rating and to provide greater strain relief to the
conductors.
Insert wiring
The following procedure is recommended:
1 - Slide the insert retaining nut over the cable with the notches oriented backward.
2 - Strip off the cable outer sheath as shown.
3 - Fit a heat shrink sleeve on each wire.
4 - Strip off the wires as shown.
C
Shell size
Size 10
Size 14
A
13 mm
0.512"
19 mm
0.748"
C
4 mm
0.157"
4 mm
0.157"
A
5 - Solder the conductors into the contact buckets starting with the central pin, then in a circular motion, move outwards
toward the periphery until all contacts have been soldered.
6 - Slide the heat shrink sleeves over the terminations and up against the insulator; then with a heat gun, shrink the
sleeves ensuring that they are correctly positioned against the insulator.
36
Insert mounting
Tools:
Size
Retaining nut mounting tool
10
OUT542W0000
OUT542W5000
14
OUT543W0000
OUT543W5000
Once the insulator is wired, the following procedure is recommended:
4 - Tighten the retaining nut using the retaining nut
mounting tool.
2 - Align the insertion tool with the insulator keys.
5 - Check that the insulator is fully engaged and aligned.
3 - Pre align the main insert keyway with the plug main
keyway and fully push the insert into the plug body from
the rear. Make sure the insulator is fully engaged in the
connector body and that it can’t rotate.
37
1 - Assemble the insertion tool around the cable.
Before installing the bulkhead receptacle, the following procedure is recommended:
1 - Inspect the bulkhead receptacle groove and panel O-ring.
2 - If necessary, clean the groove, the O-ring and panel seal surface with isopropyl alcohol.
3 - Always apply silicone grease (Loctite 8104®, Rodhorsil Paste 4® or equivalent) on the receptacle panel O-ring,
preferably with the finger.
It is recommended to apply silicone grease also on the inner
cone of the receptacle body.
Grease
Fit the receptacle to the panel and check that the O-ring remains in its groove.
Locate the jam nut and tighten by hand. Use a torque wrench to complete
the process using the following recommended torque values:
Shell size
Torque
On flats dim.
10M
3.5 N.m
22 mm
0.866"
14M
5.5 N.m
30 mm
1.181"
Panel cut-outs are available page 18 of the catalog
38
Grease
Torque
wrench
Offer the plug to the receptacle, align the keyways and screw the coupling ring by hand until the receptacle groove
mating indicator is fully covered by the coupling ring.
Groove mating
indicator
Groove mating indicator
fully covered by coupling ring
Additional recommendations
- Don’t pull on the cable when unmating plug and receptacle
- Avoid sharp bends in cable
Maintenance
It is recommended to place a cap on the connector whenever it is unmated (a plastic cap is delivered and pressure
sealed caps are available).
In case mated connectors have been underwater for a long time and are recovered with fouling growth or are
particularly dirty, apply the following procedure.
To unmate the connectors:
- Remove shells and other large deposits from the coupling rings by hands or using a pressure jet.
- If necessary, brush any remaining deposits in the mating area and on the coupling ring with a hard nylon brush.
- Rinse with fresh water.
- Unscrew the coupling ring by hand.
After the connectors are unmated:
- Rinse the mating face of the connectors with fresh water.
- Clean the mating face of the connectors using compressed air.
- Inspect the O-rings
- Clean O-rings seal seats with isopropyl alcohol
- Apply grease on the O-rings
- Place a cap on the connectors
39
SWIM SERIES
SWIM Series
Other Series
Brass shell - TP Series .............................................................................................. 42
Stainless steel shell - U Series .................................................................................. 42
Bronze shell - M Series ............................................................................................ 43
Wet/Underwater mateable - 8810 Series ................................................................ 43
SWIM Series
Other Series
TP Series
Economic connectors similar to M Series with nickel
plated brass shells and PA6/6 molded inserts.
See specific catalog available online.
Sealed:
. Down to 300 meters depth.
Large range:
. 4 shell sizes: 8TP, 10TP, 14TP and 20TP.
. Receptacles, cable receptacles, plugs and feedthroughs.
. Signal, power, high voltage, coax and triax contacts.
Economic underwater connectors
RoHS compliant
COMPLIANT
See «Marine TP Series» catalog on
www.esterline-connection-technologies.com
U Series
Dry mate connectors for deep immersion with
316L stainless steel shells.
High sealing performances:
. Down to 3,000 meters depth.
High pressure withstand:
. High corrosion resistant stainless steel shell (AISI 316L).
. Robust screw coupling mechanism.
. High temperature resistance (up to 170°C with PTFE insulators).
. Nylatron, Teflon or Tefzel insulators.
RoHS compliant
COMPLIANT
See «Marine U Series» catalog on
42
SWIM Series
Other Series
M Series
marine bronze stainless steel shells.
. Down to 3,000 meters.
Large range:
. 5 shell sizes.
Robust:
. High corrosion resistant marine bronze shells.
RoHS compliant
COMPLIANT
See «Marine M Series» catalog on
8810 Series
Wet mate/underwater mateable connectors for
deep immersion.
. Marine bronze shells.
COMPLIANT
Other Series
RoHS compliant
43
SWIM Series
Notes
44
SWIM Series
Notes
45
SWIM Series
Notes
46
Your local contact
Our contribution to environmental
protection:
This catalog is printed on PEFC
certified paper
Advancement of sustainable
wood cultivation. www.pefc.org
technical-emear-ect@esterline.com (Europe - Asia - Africa)
technical-americas-ect@esterline.com (North America)
CASWIMWUSEN01 © Copyright SOURIAU 2018 - SOURIAU is a registered trademark
All information in this document presents only general particulars and shall not form part of any contract. All rights reserved to SOURIAU for changes without prior notification or public announcement. Any duplication is prohibited, unless approved in writing.
Reliable People, Reliable Solutions
