FGG.2B.306.CLAD62
FGG.2B.306.CLAD62
    LEMO(雷莫)
    FGG.2B.306.CLAD62
FGG.2B.306.CLAD62 数据手册
FGG.2B.306.CLAD62 www.lemo.com SUMMARY # Wires Low voltage 6 Image is for illustrative purpose only Series 2B Termination type Male solder IP rating 50 AWG wire size 28.00 - 20.00 Catalog Cable Ø 5.30 - 6.20 mm See video assembly instructions Status active Matching parts EGG.2B.306.CLL Download Request a quote Eplan PHG.2B.306.CLLD62 TECHNICAL DETAILS Mechanics Shell Style/Model FG*: Straight plug, cable collet Keying 1 key (alpha=0, plug: male contacts, receptacle: female contacts) Housing Material Brass (chrome plated [SAE AMS 2460]) shell and collet nut, nickel plated [SAE AMS QQ N 290] brass latch sleeve and mid pieces Weight 29.42 g Performance Configuration 2B.306 : 6 Low Voltage Insulator L: PEEK (UL 94 / V-0/1.5) Rated Current 12 Amps Specifications Contact Type: Solder Contact Dia.: 1.3 mm (0.051in) Bucket Dia.: 1 mm (0.039in) Max. Solid Conductor: 0.5 mm^2 (AWG 20) Max. Stranded Conductor: 0.5 mm^2 (AWG 20) R (max): 3.6 mOhm Vtest (contact-shell): 1450 V (AC), 2050 V (DC) Vtest (contact-contact): 1350 V (AC), 1910 V (DC) LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 1/3 Others Endurance (Shell): 5000 Temp (min / max): -55°C / +250°C Humidity (max): 1000 hr DRAWINGS Dimensions A L M S1 S2 mm. 15 50 38 13 12 in. 0,59 1,97 1,50 0,51 0,47 RECOMMENDED BY LEMO Tools Spanner wrench: DCD.2B.025.PA120 Caps: BFG.2B.100.PCSG LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 2/3 Cables CMN.06.T20.062PGZE Grey CMN.06.T20.062PNZE CMN.06.T20.062QGZE TPR (medical) Grey 106220 PVC Black 12080 PVC Grey 160240 PVC Black 260250 PVC Grey LEMO products and services are provided “as is”. LEMO makes no warranties or representations with regard to LEMO product & services or use of them, express, implied or statutory, including for accuracy, completeness, or security. The user is fully responsible for his products and applications using LEMO components. 3/3
FGG.2B.306.CLAD62
物料型号:EMP FGG.2B.306.CLAD62
器件简介:LEMO提供的是一款用于低电压应用的6线连接器。
引脚分配:文档中提到了6个低电压线,但没有具体引脚分配信息。
参数特性: - 端接类型:焊接 - 额定电流:12安培 - 绝缘体材料:PEEK - 接触类型:焊接接触 - 接触直径:1.3毫米 - 最大固体导体截面积:0.5平方毫米(AWG 20) - 最大绞合导体截面积:0.5平方毫米(AWG 20) - 最大电阻:3.6毫欧 - 接触-外壳电压测试:1450伏交流/2050伏直流 - 接触-接触电压测试:1350伏交流/1910伏直流
功能详解:文档提供了连接器的机械结构、性能参数和环境适应性信息,但没有详细说明每个功能的具体应用。
应用信息:适用于低电压应用,推荐使用LEMO提供的工具和配件。
封装信息:提供了连接器的尺寸和重量数据,包括外壳样式、材料、耐温性、湿度、振动、冲击抗性等。
FGG.2B.306.CLAD62 价格&库存
很抱歉,暂时无法提供与“FGG.2B.306.CLAD62”相匹配的价格&库存,您可以联系我们找货
FGG.2B.306.CLAD62
  • 1+640.595001+81.58800
  • 10+557.5061010+71.00560
  • 25+503.9910025+64.18980
  • 50+486.1604050+61.91880
  • 100+463.03550100+58.97360
库存:11
FGG.2B.306.CLAD62
  • 1+630.339941+81.87796
  • 10+535.8001510+69.59772
  • 30+495.8587530+64.40954
  • 50+478.3213950+62.13152
  • 100+455.52108100+59.16988
库存:3
