JDX Hybrid
Mixed Power & Signal
Mixed PowerBackshell
and SignalFire
Waterproof
Connector
Integrated
proof Connector
The JDX mixed power and signal connector offers the ability to integrate
2 or 3 power contacts with 6 to 8 signal contacts in one connector housing
Mixed power & signal layout
Secure for Outdoor applications
Quick Release Breakaway Coupler
Single Connector Solution for simplified cabling
Waterproof, IP68 (Mated and Unmated)
Disengages at specified pull force levels for
safe quick disconnects
Rugged
Robust to withstand Harshest Environments
Flexible
3 Layouts Available for multiple applications
Confirmed Mating
Space Savings
Shielding
Audible, Tactile, Visual
Small footprint, allows access
in tight applications
360° EMI Shielding
JDX Hybrid
Description
• Mixed power & signal rugged sealed
connector for high vibration and shock
environments for both indoor and outdoor
applications
• Waterproof, IP68 (Mated and Unmated)
• Shell available in Brass and Lightweight
Aluminum
• Available in Shell Size 2
• 3 layouts for multiple applications
- 2P + 6S (2 Power + 6 Signal)
- 2P + 8S (2 Power + 8 Signal)
- 3P + 6S (3 Power + 6 Signal)
Applications
• SOURIAU Sealed connectors can be used
in a variety of markets including Industrial,
Instrumentation, Medical, Mil-Aero,
Broadcast Entertainment and
Telecommunications.
Technical Information
Materials
Electrical
Environmental
• Shell: Brass or Aluminum
• Current Rating: see chart on Page 3 & 4
• Operating Temperature: -40°C to +125°C
• Shell Plating: Black Chrome over Nickel
• Contact Resistance: see chart on Page 4
• Salt Spray Resistance: 96 hours
• Insulator: PEEK with15% Glass filled
• Insulation Resistance: 500 MΩ
• Sealing: IP68 (Mated & Unmated)
• Contacts: Brass
• Dielectric Withstanding Voltage:
see chart on Page 4
• RoHS Compliant
• Operating Voltage: see chart on Page 4
Mechanical
• Contacts Plating: Gold over Nickel
• Potting Seal: Epoxy Potting Compound
• Endurance:
Shell: 2500 mating/unmating
Contacts: 1000 mating/unmating
• Vibration: 10 - 2000 HZ
(per EIA 364)
• Shock: 50g duration 6ms
(per MIL STD 1344A)
• Autoclavable
2
JDX Hybrid
2P + 6S
Power Derating curve - Signal Contact Fixed at 2A
Connector rating:
Connector layout:
(temperature °C)
• Power Contact: 26A at 30˚C T-Rise
• Signal Contact: 2A
140
Max temp use
120
Recommended use
100
80
60
40
10
15
30
35
40
45
Current for Power contact (A)
Signal Contact (cable awg 26) is powered at 2A
Power Contact (cable awg 16): 0 to 35 A
2P + 8S
140
Max temp use
120
Recommended use
Connector layout:
(temperature °C)
Connector rating:
100
80
60
40
10
15
30
35
40
45
Current for Power Contact (A)
Signal Contact (cable awg 26) is powered at 2A,
Power Contact (cable awg 18): 0 to 40 A
3P + 6S
140
Max temp use
• Power Contact: 17A at 30˚C T-Rise
120
Recommended use
Connector layout:
(temperature °C)
Connector rating:
100
80
60
40
10
15
30
Power Contact (cable awg 20): 0 to 25 A
3
35
40
45
JDX Hybrid
Contact Layouts & Technical Information
Shell size 2
2P+6S
2P+8S
3P+6S
Solder
S
S
S
PCB Straight Tails
P
P
P
Power contact diameter (mm)
2.0
1.6
1.3
Signal contact diameter (mm)
0.7
0.7
0.7
Power Solder wire Max. AWG
16
18
Signal Solder wire Max. AWG
26
26
26
Male Insulator Wire Side
Contact Diameter (mm)
Solder Wire Max. AWG
Current Rating
Power current rating
See Derating Curve on page 3
Signal current rating
Contact Resistance (mΩ)
Power contact resistance (mΩ)
2.5
2.5
3
Signal contact resistance (mΩ)
5
5
5
1500
1500
1500
700/500
700/500
700/500
Operating Voltage (Vdc/Vrms)
Contacts
Solder contacts
Contacts
ØC
ØF
0.7
Usable Cables
Core section (mm²)
Current Rating* (A)
AWG
Power
Contact
Signal
Contact
Power
Contact
Signal
Contact
Endurance
(Cycles)
Min.
Max.
0.7
0.3
26
2
5
1000
1.3
1.1
0.6
3.0
1000
1.6
1.5
0.93
18
26
2.5
1000
2.0
1.9
1.34
16
26
2.5
1000
*see chart on page 3
4
JDX Hybrid
Keying
Keying angles
Key
T
U
A
B
Plug &
Receptacle
Keying shells availability
Shell Styles for Plugs & Receptacles (see page 8)
Shell size
2
Key
ED
EP
EE
ER
EZ
IL
FA
FB
FD
T
U
A
B
● Available for JDX Series
Keying color codes
Keying
Contacts Standard Gender
Contacts Reverse Gender
T
Red
Purple
U
White
Yellow
A
Green
Orange
B
Blue
Light Brown
5
JDX Hybrid
Part Numbers
²
Existing Shell Style Part Numbers
ER: Rear Panel Mount
FD: Straight Cable Plug
Please note:
FD Straight Plug is supplied as overmolded cable
assembly or as stand alone connector (strain relief
boot not available for this product)
For other shell styles & part numbers see shell styles on page 8 and part number configurator on page 9.
Part Number
Description
Shell Style
Shell Size
Shell Type
JDXFD2T001MSN
2 Power / 6 Signal (2P + 6S)
FD
2
Plug
JDXFD2T002MSN
2 Power / 8 Signal (2P + 8S)
FD
2
Plug
JDXFD2T003MSN
3 Power / 6 Signal (3P + 6S)
FD
2
Plug
JDXER2T001FSN
ER
2
Receptacle
JDXER2T002FSN
ER
2
Receptacle
JDXER2T003FSN
ER
2
Receptacle
6
JDX Hybrid
Dimensions
²
2P + 6S
Plug
Receptacle
²
2P + 8S
Plug
Receptacle
3P + 6S
²
Receptacle
Plug
Panel cut-out
Note: All dimensions
are in millimeters (mm)
7
JDX Hybrid
JDX Hybrid Shell Styles – Size 2
²
²
Receptacles
EZ: Rear Panel Mount PCB Capable
Protruding Front (With Grounding Pins)
Plugs
Mounting Plane
Please Note:
overmolded cable assembly or as
ED: Rear Panel Mount PCB Capable
EP: Front Panel Mount
FA: Front Panel Mount Plug
IL: In-Line Cable Receptacle
FB: Rear Panel Mount Plug
Please note:
IL In-Line Cable Receptacle is supplied
as overmolded cable assembly or as
Note: All dimensions are in
millimeters (mm)
EE: Rear Panel Mount PCB Capable
Protruding Back (With Grounding Pins)
Mounting Plane
8
JDX Hybrid
Ordering Information
BASIC SERIES
JDX
FD
2
T
001
Shells Type - Receptacle
EP – Front Panel Mount
ER – Rear Panel Mount
EZ – Rear Panel Mount PCB Capable, Protruding Front (With Grounding Pins)
ED – Rear Panel Mount PCB Capable (With Grounding Pins)
EE – Rear Panel Mount PCB Capable, Protruding Back (With Grounding Pins)
*IL – In-Line Cable Receptacle
Shells Type - Plug
*FD – Straight Cable Plug
FA – Front Panel Mount Plug
FB – Rear Panel Mount Plug (With Grounding Pins)
Shell Size
2
Keying
T - U - A - B (see page 5 for more keying details)
Contact Layouts
001 - 2P + 6S (2 Power + 6 Signal)
002 - 2P + 8S (2 Power + 8 Signal)
003 - 3P + 6S (3 Power + 6 Signal)
Contact Type
M: Male
F: Female
Contact Termination
S - Solder
P - PCB Straight
Surface Plating
N: Non Reflective Black Chrome over Nickel
S: Chrome over Nickel
Shell Material (Brass is standard material)
A: Add A for Aluminum Shell
*Please note: FD and IL shell styles are supplied as overmolded cable assemblies or as stand alone connectors
(strain relief boot not available for this product)
Custom cable assemblies available upon request.
Custom grommets and overmolds can be designed for any application.
9
M
S
N
A
© Copyright SOURIAU 05/2013 - All information in this document presents only general particulars and shall not form part of any contract. All rights reserved to SOURIAU for changes without prior notification or public announcement. Any duplication is prohibited, unless approved in writing.
很抱歉,暂时无法提供与“JDXFD2T003MSN”相匹配的价格&库存,您可以联系我们找货
